November 16, 20242 yr It looks like there is a linux-headers mismatch in those two images: Armbian_24.11.1_Odroidhc4_bookworm_current_6.6.60_minimal.img Armbian_24.11.1_Odroidhc4_noble_current_6.6.60-kisak.img Installed those linux-headers: apt install linux-headers-current-meson64 I tried then to install ZFS module, and it failed: Setting up zfs-dkms (2.2.5-1~bpo12+1) ... Loading new zfs-2.2.5 DKMS files... Building for 6.6.60-current-meson64 Module build for kernel 6.6.60-current-meson64 was skipped since the kernel headers for this kernel do not seem to be installed. root@odroidhc4:~# dpkg -l | grep linux-headers ii linux-headers-current-meson64 24.8.2 arm64 Armbian Linux current headers 6.6.47-current-meson64 The Armbian_24.8.1_Odroidhc4_bookworm_current_6.6.47_minimal.img is OK. Finally I see both SSDs and ZFS works! 🙂 Regards, Chris
November 17, 20242 yr 15 hours ago, ChrisO said: It looks like there is a linux-headers mismatch in those two images: Headers are released via repository and that is done when images are tested. In about a week.
