Jorropo Posted November 30, 2024 Posted November 30, 2024 armbianmonitor -u https://paste.next.armbian.com/hoyonuruye I installed the newest fresh debian minimal image for the RockPi-S and no matter what I do overlays do not apply. I've followed and compiled spi1 and spi2 rk3308. I've also tested the external antenna device tree as I have installed an external antenna: However neither the external antenna is being used nor spidev are present. I have diffed dtc -I fs -O dts /proc/device-tree and they are identical before and after enabling the overlays in armbian-config and rebooting. I was able to confirm the "overlays" work by manually copypasting their changes in linux's source dts and generating a patch file, placing it in armbian's linux patch folder and recompiling from scratch, so if I do change the options spidev works, just I somehow can only do this by editing the source. Here is the `/boot/armbianEnv.txt` file generated: verbosity=1 bootlogo=false console=serial overlay_prefix=rk3308 fdtfile=rockchip/rk3308-rock-pi-s.dtb extraargs=cma=16M rootdev=UUID=036c1484-611d-470e-b2ef-775fe550149b rootfstype=ext4 fdt_overlays=rk3308-s0-ext-antenna rk3308-spi1-spidev rk3308-spi2-spidev usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Also after editing the overlays in armbian-config this error pops up: /boot/armbianEnv.txt: line 9: rk3308-spi1-spidev: command not found 0 Quote
Werner Posted December 1, 2024 Posted December 1, 2024 9 hours ago, Jorropo said: verbosity=1 bootlogo=false console=serial overlay_prefix=rk3308 fdtfile=rockchip/rk3308-rock-pi-s.dtb extraargs=cma=16M rootdev=UUID=036c1484-611d-470e-b2ef-775fe550149b rootfstype=ext4 fdt_overlays=rk3308-s0-ext-antenna rk3308-spi1-spidev rk3308-spi2-spidev usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Try this: verbosity=1 bootlogo=false console=serial overlay_prefix=rk3308 fdtfile=rockchip/rk3308-rock-pi-s.dtb extraargs=cma=16M rootdev=UUID=036c1484-611d-470e-b2ef-775fe550149b rootfstype=ext4 overlays=s0-ext-antenna spi1-spidev spi2-spidev usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u For once the prefix is already set and for the other IIRC it is just overlays instead of fdt_overlays. But not sure. Overall there might be a bug in config-ng with overlays. Just need to verify that manual applying works. 0 Quote
brentr Posted December 1, 2024 Posted December 1, 2024 Applying the overlays manually works. I use the s0-ext-antenna and b@1.3ghz overlays frequently. I've never done it any other way. 0 Quote
Jorropo Posted December 1, 2024 Author Posted December 1, 2024 44 minutes ago, Werner said: verbosity=1 bootlogo=false console=serial overlay_prefix=rk3308 fdtfile=rockchip/rk3308-rock-pi-s.dtb extraargs=cma=16M rootdev=UUID=036c1484-611d-470e-b2ef-775fe550149b rootfstype=ext4 overlays=s0-ext-antenna spi1-spidev spi2-spidev usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u This does not work either. 0 Quote
Jorropo Posted December 1, 2024 Author Posted December 1, 2024 25 minutes ago, brentr said: Applying the overlays manually works. I use the s0-ext-antenna and b@1.3ghz overlays frequently. I've never done it any other way. Have you tried it with debian minimal image or the noble CLI ? 0 Quote
Meestor_X Posted December 10, 2024 Posted December 10, 2024 (edited) I too am not seeing any overlays added via armbianEnv.txt whether I add them on the overlays= line or user_overlays= line. ls /proc/device-tree is the same whether items are added or not. Running 24.8.3 (bookworm). Can anyone confirm that overlays aren't working in case it's something I'm doing wrong? Edited December 11, 2024 by Meestor_X 0 Quote
eselarm Posted December 11, 2024 Posted December 11, 2024 (edited) For my ROCK3A (rockchip RK3568) using Armbian 24.11.x I enable SATA (beta 6.1.84 kernel). I need the file: /boot/dtb/rockchip/overlay/rock-3a-sata.dtbo, that exists. I see in armbianEnv overlay_prefix=rk35xx, but from boot.cmd there is now an extra option without applying overlay_prefix, which is needed in my case I see. I compared with and older NanoPi-NEO (allwinner sun8i/H3), how i did it there. So my statement added in armbianEnv.txt is: overlays=rock-3a-sata and that works. Note that I added it with a text editor to armbianEnv.txt myself, as I needed to change paths related to booting unusual things that armbian-config doesn't know. Edited December 11, 2024 by eselarm 0 Quote
Igor Posted December 11, 2024 Posted December 11, 2024 3 hours ago, eselarm said: I see in armbianEnv overlay_prefix=rk35xx, This was a bug in armbian-config ... fixed with https://github.com/armbian/configng/pull/299 0 Quote
Meestor_X Posted December 11, 2024 Posted December 11, 2024 (edited) @eselarm are you saying that overlays are working now in 24.11.1 ? (I'm unable to update due to an issue with Armbian-config and apt update not being able to find servers) Edited December 11, 2024 by Meestor_X 0 Quote
eselarm Posted December 12, 2024 Posted December 12, 2024 @Meestor_XMy 32-bit boards still use 24.8.3 according to /etc/armbian-release I see. There there the older armbian-config is installed and I see overlays are under System->Hardware. My new RK35xx boards all run beta/rolling/testing/trunk, so armbian-configng and I see no list there you can tick at the moment (configng is work-in-progress). There is an option to edit armbianEnv.txt. So that is what you need to do, same as I did and others in this topic. Make sure you understand this linux kernel DTB and overlays well enough I would say, else take older image. 0 Quote
Meestor_X Posted December 12, 2024 Posted December 12, 2024 (edited) @eselarmI've been working on this for several days, and as far as I can tell, on Armbian 24.8.3, if the "simple test" for whether an overlay has installed is to see if it shows up in `/proc/device-tree` then they are not loading, whether they are added via the overlays= or user_overlays= lines in /boot/armbianEnv.txt. This is for exisitng .dbto files (like s0-ext-antenna, bs, bs@1.3ghz, sdio@10mhz, etc), ones I've copied from websites or forums, or self-created ones. The ONLY way I've been able to successfully install an overlay is by decompiling rk3308-rock-pi-s.dtb, editing it, and recompiling it. Annoyingly, `apt upgrade` will revert that file, so being able to add overlays or user_overlays would be very helpful. References: https://docs.armbian.com/User-Guide_Armbian_overlays/ https://forum.radxa.com/t/usb-sound-card-on-type-c-connector/17627 https://source.android.com/docs/core/architecture/dto/syntax#reference Edited December 12, 2024 by Meestor_X 0 Quote
Meestor_X Posted December 14, 2024 Posted December 14, 2024 Is anyone be able to say whether or not overlays are working in the latest Armbian (with or without armbian-config, I can edit /boot/armbianEnv.txt directly)? 0 Quote
Meestor_X Posted December 29, 2024 Posted December 29, 2024 It's been a few weeks, I've been unable to figure out why overlays don't load in armbian. I've tried everything I can think of, scoured the internet with no answers... Anyone figured anything out yet? I can't be the only one having this problem?? 0 Quote
mm2189 Posted December 29, 2024 Posted December 29, 2024 Hello, I can confirm, that I have the same problem as you, I am using the latest Armbian 24.11.1 and the overlay files are not applied (checked with proc/device-tree) Unfortunately I don't have any solution for that - if I've found one, I will write this into your Thread. 1 Quote
Meestor_X Posted December 30, 2024 Posted December 30, 2024 My understanding is that it might take an RS232 logger to see what happens when the device is booting. I bought an RS232 to USB adapter and if I can figure out how to use it to watch the boot process maybe that will lead to an answer. I was hoping that one of the experts here had done this already, but I know how busy everyone is! 0 Quote
eselarm Posted December 31, 2024 Posted December 31, 2024 (edited) Indeed you need to hook up a 'serial console cable' for cases like this. Some call it 'serial debug cable' or you say 'RS232 logger'. It actually should not be RS232, that is serial but other higher voltage signal levels used for long wires, PCs in the past. It must be TTL level 0V en 3V3. Which pin you need is undocumented for your RockPiS ('Comming soon', cheap board so no good documentation...) https://radxa.com/products/rockpi/pis#techspec I guess you need to take the same pin numbers from the colored header as for RaspberryPi boards and almost all others like for my Rock3A. See what is Rx, Tx, GND. If you look in boot.cmd for your board you could derive what setting you need on the USB side of the cable(in your laptop or so). For Linux laptop controlling my Rock3A I use for example: sudo screen /dev/ttyUSB0 1500000 Edited December 31, 2024 by eselarm 0 Quote
MaxT Posted December 31, 2024 Posted December 31, 2024 It seems that new armbian config adds full overlay file name into armbianEnv.txt, in the same time there exists overlay_prefix variable, eg:overlay_prefix=rockchipoverlays=rockchip-rk3399-spi-jedec-norAFAIU, to get a full file name of an overlay, boot script joins overlay_prefix and, in this case, a full overlay name (from overlays variable as added by armbian config), adding "-" in between and obviously cannot find the resulting file name since overlay_prefix + "-" are effectively doubled: rockchip-rockchip-rk3399-spi-jedec-norFor me practical solution was to remove "rockchip-" from overlay name. Removal of overlay_prefix variable is not working, I guess this is because boot script anyway adds leading "-" making file name wrong.Boot scripts are black boxes for me, but may be @Igor will be able to have a look whether scripts or armbian config need any changes in logic. 0 Quote
Meestor_X Posted January 1, 2025 Posted January 1, 2025 (edited) @MaxT that sounds like it's working as intended. The `overlays=` line in /boot/armbianEnv.txt should NOT have the prefix on each overlay name, and the actual overlay files do have that prefix name. e.g. here's my /boot/armbianEnv.txt cat /boot/armbianEnv.txt verbosity=1 bootlogo=false console=serial overlay_prefix=rk3308 fdtfile=rockchip/rk3308-rock-pi-s.dtb extraargs=cma=16M rootdev=UUID=036c1484-611d-470e-b2ef-775fe550149b rootfstype=ext4 overlays=s0-ext-antenna bs bs@1.3ghz sdio@10mhz extraargs=net.ifnames=0 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u The files in /boot/dtb/rockchip/overlay are called: ls -l /boot/dtb/rockchip/overlay/rk3308-* -rw-r--r-- 1 root root 459 Nov 18 03:47 /boot/dtb/rockchip/overlay/rk3308-b@1.3ghz.dtbo -rw-r--r-- 1 root root 459 Nov 18 03:47 /boot/dtb/rockchip/overlay/rk3308-bs@1.3ghz.dtbo -rw-r--r-- 1 root root 688 Nov 18 03:47 /boot/dtb/rockchip/overlay/rk3308-bs.dtbo -rw-r--r-- 1 root root 223 Nov 18 03:47 /boot/dtb/rockchip/overlay/rk3308-emmc.dtbo -rw-r--r-- 1 root root 1204 Nov 18 03:47 /boot/dtb/rockchip/overlay/rk3308-s0-ext-antenna.dtbo -rw-r--r-- 1 root root 226 Nov 18 03:47 /boot/dtb/rockchip/overlay/rk3308-sdio@10mhz.dtbo -rw-r--r-- 1 root root 226 Nov 18 03:47 /boot/dtb/rockchip/overlay/rk3308-sdio@4mhz.dtbo The overlay files have the prefix as part of their names (rk3308 in this case), so it should "just work", but sadly it does not. Edited January 1, 2025 by Meestor_X 0 Quote
Meestor_X Posted January 1, 2025 Posted January 1, 2025 Again, my only way of checking to see if the overlays loaded is to look at /proc/device-tree. I ASSUME any loaded overlay will show up there? 0 Quote
MaxT Posted January 1, 2025 Posted January 1, 2025 Again, my only way of checking to see if the overlays loaded is to look at /proc/device-tree. I ASSUME any loaded overlay will show up there?You mentioned that overlay name shouldn't contain prefix and that's right, but I see that armbian-config adds overlay name with prefix included and to make it work, one has to remove prefix, so not sure that it works as intended.AFIAK since overlays modify DT nodes, you can only see modified data in relevant nodes, rather than an overlay itself.Another consideration is that overlay itself might not work. Don't remember which exactly, but some overlay for eg rk3399 is not working. 0 Quote
Meestor_X Posted January 2, 2025 Posted January 2, 2025 Well, it's all a bit of a mystery. Learning as much I can, but I sure wish there were more experts here that could offer some help! 0 Quote
eselarm Posted January 2, 2025 Posted January 2, 2025 2 hours ago, Meestor_X said: Well, it's all a bit of a mystery. You might have the situation that your Pi sees/has 2x U-Boot, 2x boot.scr Or even more. boot.scr is generated from boot.cmd, look in there how scripting composes the name of your overlay files. Multiple copies and/or versions will create mystery. Take your time and see what is what and where. And connect serial console. It allows you to load dtbo manually, needs a lot of U-boot commands study, I also had to learn myself. 1 Quote
Meestor_X Posted January 6, 2025 Posted January 6, 2025 (edited) Ok, I've gotten the serial monitor working for a Rock S0 (same CPU and armbian build as the Rockpi-S AFAIK). I created an overlay to enable PWM, and added it to armbianEnv.txt: cat /boot/armbianEnv.txt verbosity=1 bootlogo=false console=serial overlay_prefix=rk3308 fdtfile=rockchip/rk3308-rock-s0.dtb extraargs=cma=16M rootdev=UUID=edc1b473-11f6-4b32-bf33-0986876f47d1 rootfstype=ext4 user_overlays=pwm usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Here's what I see on the serial log: ---- Opened the serial port /dev/tty.usbserial-12240 ---- DDR Version V2.06 20211109 CHIP ID = 0x00003308 REG2C: 0x00000034, 0x00000034 In 589MHz DDR3 Col=10 Bank=3 Row=15 Size=512MB OUT: sdram_init finish. Boot1 Release Time: Mar 24 2022 08:28:57, version: 1.36 ROM VER:0x56323030, 19 chip_id:330800,0 ChipType = 0x13, 510 DPLL = 1300 MHz ...nandc_flash_init enter... No.1 FLASH ID:ff ff ff ff ff ff DPLL = 1300 MHz sfc nor id: ff ff ff DPLL = 1300 MHz sfc_nand id: ff ff ff NeedKHz=200KHz,clock=12000KHz NeedKHz=200KHz,clock=12000KHz NeedKHz=200KHz,clock=12000KHz mmc2:cmd8,20 mmc2:cmd5,20 mmc2:cmd55,20 DPLL = 1300 MHz NeedKHz=18000KHz,clock=650000KHz DPLL = 1300 MHz NeedKHz=48000KHz,clock=650000KHz mmc2:cmd19,100 SdmmcInit=2 0 BootCapSize=2000 UserCapSize=7456MB FwPartOffset=2000 , 2000 NeedKHz=200KHz,clock=12000KHz NeedKHz=200KHz,clock=12000KHz NeedKHz=200KHz,clock=12000KHz mmc0:cmd5,20 DPLL = 1300 MHz NeedKHz=24000KHz,clock=650000KHz DPLL = 1300 MHz NeedKHz=40000KHz,clock=650000KHz SdmmcInit=0 0 BootCapSize=0 UserCapSize=60906MB FwPartOffset=2000 , 0 StorageInit ok = 258238 SecureMode = 0 Secure read PBA: 0x4 Secure read PBA: 0x404 Secure read PBA: 0x804 Secure read PBA: 0xc04 Secure read PBA: 0x1004 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x3306530 signature is wrong recovery gpt... GPT 0x3306530 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x600000, size=0x994a8 RunBL31 0x40000 @ 335685 us INFO: Preloader serial: 0 NOTICE: BL31: v1.3(release):30f1405 NOTICE: BL31: Built : 17:08:28, Sep 23 2019 INFO: Lastlog: last=0x100000, realtime=0x102000, size=0x2000 INFO: ARM GICv2 driver initialized INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 1 INFO: plat_rockchip_pmu_init: pd status 0xe b INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x600000 INFO: SPSR = 0x3c9 U-Boot 2022.04-armbian-2022.04-Se4b6-P2db4-He13b-Vc245-Bda0a-R448a (Nov 16 2024 - 02:36:02 +0000) Model: Radxa ROCK S0 DRAM: 510 MiB Core: 275 devices, 20 uclasses, devicetree: separate MMC: dwmmc@ff480000: 1, dwmmc@ff490000: 0 Loading Environment from nowhere... OK In: serial Out: serial Err: serial Model: Radxa ROCK S0 rockchip_dnl_key_pressed read board id failed Net: eth0: ethernet@ff4e0000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3633 bytes read in 4 ms (886.7 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1:1 251 bytes read in 3 ms (81.1 KiB/s) 14324658 bytes read in 610 ms (22.4 MiB/s) 30097920 bytes read in 1274 ms (22.5 MiB/s) 54895 bytes read in 9 ms (5.8 MiB/s) 538 bytes read in 5 ms (104.5 KiB/s) Applying user provided DT overlay pwm.dtbo Moving Image from 0x680000 to 0x800000, end=2560000 ## Loading init Ramdisk from Legacy Image at 04000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 14324594 Bytes = 13.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 02800000 Booting using the fdt blob at 0x2800000 Loading Ramdisk to 1d17d000, end 1df26372 ... OK ERROR: reserving fdt memory region failed (addr=0 size=0 flags=0) Loading Device Tree to 000000001d107000, end 000000001d17cfff ... OK Starting kernel ... Not really seeing where the overlays are loading or not in this text - but I may have missed it? Edited January 6, 2025 by Meestor_X 0 Quote
MaxT Posted January 6, 2025 Posted January 6, 2025 Not really seeing where the overlays are loading Search for the word overlay - it's in the u-boot part of the log, before starting kernel... 0 Quote
Meestor_X Posted January 6, 2025 Posted January 6, 2025 (edited) NM, I see that it did load. Applying user provided DT overlay pwm.dtbo It didn't actually enable the PWM, but it does look like it loaded at least! I'll have to try some system ones and see what happens. Edited January 6, 2025 by Meestor_X 0 Quote
Meestor_X Posted January 6, 2025 Posted January 6, 2025 (edited) Ok, tried some adding some other overlays via armbian-config and I see that they DIDN'T load.. . root@rock-s0:~# cat /boot/armbianEnv.txt verbosity=1 bootlogo=false console=serial overlay_prefix=rk3308 fdtfile=rockchip/rk3308-rock-s0.dtb extraargs=cma=16M rootdev=UUID=edc1b473-11f6-4b32-bf33-0986876f47d1 rootfstype=ext4 user_overlays=pwm fdt_overlays=rk3308-bs@1.3ghz rk3308-bs rk3308-s0-ext-antenna rk3308-sdio@10mhz usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Found U-Boot script /boot/boot.scr 3633 bytes read in 4 ms (886.7 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1:1 331 bytes read in 4 ms (80.1 KiB/s) 14324658 bytes read in 610 ms (22.4 MiB/s) 30097920 bytes read in 1275 ms (22.5 MiB/s) 54895 bytes read in 8 ms (6.5 MiB/s) 538 bytes read in 6 ms (86.9 KiB/s) Applying user provided DT overlay pwm.dtbo Moving Image from 0x680000 to 0x800000, end=2560000 ## Loading init Ramdisk from Legacy Image at 04000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 14324594 Bytes = 13.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 02800000 Booting using the fdt blob at 0x2800000 Loading Ramdisk to 1d17d000, end 1df26372 ... OK ERROR: reserving fdt memory region failed (addr=0 size=0 flags=0) Loading Device Tree to 000000001d107000, end 000000001d17cfff ... OK Edited January 6, 2025 by Meestor_X 0 Quote
Meestor_X Posted January 6, 2025 Posted January 6, 2025 (edited) Ok, so one issue is that armbian-config doesn't create the correct line for the overlays. The overlay_prefix is automatically added to the name, and the command is "overlays=", not "ftd_overlays=" root@rock-s0:~# cat /boot/armbianEnv.txt verbosity=1 bootlogo=false console=serial overlay_prefix=rk3308 fdtfile=rockchip/rk3308-rock-s0.dtb extraargs=cma=16M rootdev=UUID=edc1b473-11f6-4b32-bf33-0986876f47d1 rootfstype=ext4 user_overlays=pwm overlays=b@1.3ghz s0-ext-antenna sdio@10mhz usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Found U-Boot script /boot/boot.scr 3633 bytes read in 4 ms (886.7 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1:1 295 bytes read in 3 ms (95.7 KiB/s) 14324658 bytes read in 609 ms (22.4 MiB/s) 30097920 bytes read in 1274 ms (22.5 MiB/s) 54895 bytes read in 9 ms (5.8 MiB/s) 459 bytes read in 6 ms (74.2 KiB/s) Applying kernel provided DT overlay rk3308-b@1.3ghz.dtbo 1204 bytes read in 7 ms (168 KiB/s) Applying kernel provided DT overlay rk3308-s0-ext-antenna.dtbo 226 bytes read in 6 ms (36.1 KiB/s) Applying kernel provided DT overlay rk3308-sdio@10mhz.dtbo 538 bytes read in 6 ms (86.9 KiB/s) Applying user provided DT overlay pwm.dtbo Moving Image from 0x680000 to 0x800000, end=2560000 ## Loading init Ramdisk from Legacy Image at 04000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 14324594 Bytes = 13.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 02800000 Booting using the fdt blob at 0x2800000 Loading Ramdisk to 1d17d000, end 1df26372 ... OK ERROR: reserving fdt memory region failed (addr=0 size=0 flags=0) Loading Device Tree to 000000001d107000, end 000000001d17cfff ... OK Starting kernel ... Edited January 6, 2025 by Meestor_X 0 Quote
Meestor_X Posted January 6, 2025 Posted January 6, 2025 Looks like the latest armbian-config is better, but it's still not respecting the overlay_prefix. Used armbian-config to add the sdio@10mhz overlay, and it did this to armbianEnv.txt. root@rock-s0:/boot# cat armbianEnv.txt verbosity=1 bootlogo=false console=serial overlay_prefix=rk3308 fdtfile=rockchip/rk3308-rock-s0.dtb extraargs=cma=16M rootdev=UUID=edc1b473-11f6-4b32-bf33-0986876f47d1 rootfstype=ext4 overlays=rk3308-sdio@10mhz usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Of course, it didn't load the overlay, due to the prefix being added. Found U-Boot script /boot/boot.scr 3633 bytes read in 4 ms (886.7 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1:1 260 bytes read in 3 ms (84 KiB/s) 14325592 bytes read in 611 ms (22.4 MiB/s) 30097920 bytes read in 1275 ms (22.5 MiB/s) 54150 bytes read in 10 ms (5.2 MiB/s) Failed to load '/boot/dtb/rockchip/overlay/rk3308-rk3308-sdio@10mhz.dtbo' Moving Image from 0x680000 to 0x800000, end=2560000 My suggestion would be to have armbian change the armbianEnv.txt file to not include the overlay_prefix= line by default. Not sure if it serves any useful purpose? 0 Quote
Meestor_X Posted January 6, 2025 Posted January 6, 2025 Ok, that doesn't work either! 😉 I understand what you mean, now, @MaxT The added "-" messes everything up. root@rock-s0:~# cat /boot/armbianEnv.txt verbosity=1 bootlogo=false console=serial fdtfile=rockchip/rk3308-rock-s0.dtb extraargs=cma=16M rootdev=UUID=edc1b473-11f6-4b32-bf33-0986876f47d1 rootfstype=ext4 overlays=rk3308-b@1.3ghz rk3308-s0-ext-antenna rk3308-sdio@10mhz user_overlays=pwm usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Found U-Boot script /boot/boot.scr 3633 bytes read in 4 ms (886.7 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1:1 294 bytes read in 4 ms (71.3 KiB/s) 14325592 bytes read in 610 ms (22.4 MiB/s) 30097920 bytes read in 1275 ms (22.5 MiB/s) 54150 bytes read in 11 ms (4.7 MiB/s) Failed to load '/boot/dtb/rockchip/overlay/-rk3308-b@1.3ghz.dtbo' Failed to load '/boot/dtb/rockchip/overlay/-rk3308-s0-ext-antenna.dtbo' Failed to load '/boot/dtb/rockchip/overlay/-rk3308-sdio@10mhz.dtbo' 538 bytes read in 5 ms (104.5 KiB/s) Applying user provided DT overlay pwm.dtbo Moving Image from 0x680000 to 0x800000, end=2560000 0 Quote
Jorropo Posted January 6, 2025 Author Posted January 6, 2025 (edited) @Meestor_X thx for all of this, could you please show find /boot/overlay-user/ -type f Or wherever you stores pwm.dtbo I am not sure if this has the same prefix issues (I've tried both with and without rk3308- in armbianEnv.txt and neither works) Edited January 6, 2025 by Jorropo 0 Quote
