Hello guys
is there a way to customize boot.cmd without changing any git-controlled files ? For example, I would like to setenv console to null.
I found the file lib/config/bootenv/sunxi-default.txt but I have no idea how to override it in my userpaches folder.
Thanks
In customize-image.sh you can use echo or sed -i to add/change the environment file (/boot/armbianEnv.txt) or the boot script itself (/boot/boot.cmd). I would not recommend to try to change the whole boot script, but it's possible - if you put your version in userpatches/overlay/ it will be accessible from /tmp/overlay from customize-image.sh
Thanks for the answer..
But it seems like I can't go that way.
I need to disable console and I thought I would be able to do that by setting console=null but after analyzing boot.cmd I see that it is not possible.
So now the question  is: how can I disable console so that boot messages are not displayed and login prompt is not visible ?
I should be able to only login by ssh. I need to run a linuxfb application and so I don't need the console.
If I replace boot.cmd  in customize-image.sh will  *.scr file be built too ?
I have finally ended up with the following patch:
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h
index 9b514ff..a09a3da 100644
--- a/include/configs/sunxi-common.h
+++ b/include/configs/sunxi-common.h
@@ -518,6 +518,7 @@ extern int soft_i2c_gpio_scl;
 #endif
 #define CONFIG_EXTRA_ENV_SETTINGS \
+       "silent=1\0" \
        CONSOLE_ENV_SETTINGS \
        MEM_LAYOUT_ENV_SETTINGS \
        DFU_ALT_INFO_RAM \
@@ -532,4 +533,8 @@ extern int soft_i2c_gpio_scl;
 #endif
+#define CONFIG_SILENT_CONSOLE
+#define CONFIG_SYS_DEVICE_NULLDEV
+#define CONFIG_SILENT_CONSOLE_UPDATE_ON_RELOC
 #endif /* _SUNXI_COMMON_CONFIG_H */
