Because i need a more recent kernel than 5.10 on my odroid m2, i tried armbian.
i searched for the nearest model and i manage to find Radxa Rock 5C (rocky 3588s2)
i flash emmc with Bleeding edge images with Armbian Linux v6.11/ Debian 12 (Bookworm)Minimal / IOT for the rock 5c
in /boot/armbianEnv.txt i changed just one line after installation :
fdtfile=rockchip/rk3588s-odroid-m2.dtb
and after a final apt upgrade i can run version 6.12.1-edge-rockchip-rk3588 of the kernel.
for now it seems fine to me.
I'm not sure if you're Jidea on the odroid forums, but I'll reply here as well.
Changing the ftdfile line does not work on my M2. If I change the default, I'm only getting a black screen.
I can still access the machine on ssh to revert it.
Testing the M2 16G with trunk 90 (Kernel 6.15) & trunk 38 (Kern 6.14.8) and the USB-C OTG port isn't working.
[  +0.245948] usb 7-1: new full-speed USB device number 2 using xhci-hcd
[  +0.124258] usb 7-1: device descriptor read/64, error -71
[  +0.227984] usb 7-1: device descriptor read/64, error -71
[  +0.223715] usb 7-1: new full-speed USB device number 3 using xhci-hcd
[  +0.124295] usb 7-1: device descriptor read/64, error -71
[  +0.223803] usb 7-1: device descriptor read/64, error -71
[  +0.104107] usb usb7-port1: attempt power cycle
[  +0.395844] usb 7-1: new full-speed USB device number 4 using xhci-hcd
[  +0.000112] usb 7-1: Device not responding to setup address.
[  +0.203891] usb 7-1: Device not responding to setup address.
[  +0.203946] usb 7-1: device not accepting address 4, error -71
[  +0.000609] usb 7-1: WARN: invalid context state for evaluate context command.
[  +0.119353] usb 7-1: new full-speed USB device number 5 using xhci-hcd
[  +0.000118] usb 7-1: Device not responding to setup address.
[  +0.204373] usb 7-1: Device not responding to setup address.
[  +0.207473] usb 7-1: device not accepting address 5, error -71
[  +0.000613] usb 7-1: WARN: invalid context state for evaluate context command.
[  +0.000109] usb usb7-port1: unable to enumerate USB device
[ +30.217458] usb 7-1: new full-speed USB device number 6 using xhci-hcd
[  +0.123993] usb 7-1: device descriptor read/64, error -71
[  +0.231951] usb 7-1: device descriptor read/64, error -71
[  +0.223935] usb 7-1: new full-speed USB device number 7 using xhci-hcd
[  +0.120028] usb 7-1: device descriptor read/64, error -71
[  +0.224108] usb 7-1: device descriptor read/64, error -71
[  +0.103939] usb usb7-port1: attempt power cycle
[  +0.396008] usb 7-1: new full-speed USB device number 8 using xhci-hcd
[  +0.000139] usb 7-1: Device not responding to setup address.
[  +0.203807] usb 7-1: Device not responding to setup address.
[  +0.207853] usb 7-1: device not accepting address 8, error -71
[  +0.000608] usb 7-1: WARN: invalid context state for evaluate context command.
[  +0.119394] usb 7-1: new full-speed USB device number 9 using xhci-hcd
[  +0.000140] usb 7-1: Device not responding to setup address.
[  +0.204031] usb 7-1: Device not responding to setup address.
[  +0.203926] usb 7-1: device not accepting address 9, error -71
[  +0.000796] usb 7-1: WARN: invalid context state for evaluate context command.
[  +0.000293] usb usb7-port1: unable to enumerate USB device
[Jun 2 19:50] usb 7-1: new full-speed USB device number 10 using xhci-hcd
[  +0.123926] usb 7-1: device descriptor read/64, error -71
[  +0.116517] xhci-hcd xhci-hcd.7.auto: remove, state 4
[  +0.000011] usb usb8: USB disconnect, device number 1
[  +0.000280] xhci-hcd xhci-hcd.7.auto: USB bus 8 deregistered
[  +0.000009] xhci-hcd xhci-hcd.7.auto: remove, state 1
[  +0.000004] usb usb7: USB disconnect, device number 1
[  +0.055430] usb usb7-port1: attempt power cycle
Same USB-C device (CCD camera) tested and working in the USB-3 port.
Edited by Walter Zambotti
After the last update/upgrade USB BUS 7 has completely disappeared!  So no life at all on the USB-C port.  The following packages were upgraded :
linux-dtb-edge-rockchip64, armbian-bsp-cli-odroidm2-edge, linux-image-edge-rockchip64, linux-u-boot-odroidm2-edge, armbian-firmware
I suspect linux-dtb-edge-rockchip64 is not the M2 specific package and it has over written the dtb.
Also I can't seem to install the kernel headers from armbian-config.  It appears to go through the motions but nothing is installed.
Also where can I find a documentation on what each device overlay (in armbian-config) is for?
Just plugged a M.2 M key to E key adapter with an Intel AX200 iwlwifi (installed the firmware) booted up and Wifi 6 is going without using a USB port.
My project is one step closer!!!
Just have to get that last USB-C port working.
The latest 6.16.RC3 kernel breaks the Intel PCI Wifi drivers.
Was working in 6.15 without issue:
[    5.321789] iwlwifi 0004:41:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz
[    5.329839] iwlwifi 0004:41:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[    5.330430] iwlwifi 0004:41:00.0: loaded firmware version 77.864baa2e.0 cc-a0-77.ucode op_mode iwlmvm
[    5.587350] iwlwifi 0004:41:00.0: Detected RF HR B3, rfid=0x10a100
[    5.653139] iwlwifi 0004:41:00.0: base HW address: 04:ed:33:54:7e:d2
[    5.716280] iwlwifi 0004:41:00.0 wlP4p65s0: renamed from wlan0
[    8.890717] iwlwifi 0004:41:00.0: Registered PHC clock: iwlwifi-PTP, with index: 1
[    8.890759] WARNING: CPU: 6 PID: 1203 at drivers/net/wireless/intel/iwlwifi/mvm/mld-mac.c:37 iwl_mvm_mld_mac_ctxt_cmd_common+0x158/0x1e4 [iwlmvm]
[    8.890778] Modules linked in: sunrpc iwlmvm pwm_fan display_connector mac80211 rk805_pwrkey libarc4 snd_soc_hdmi_codec snd_soc_core hantro_vpu snd_compress rockchip_vdec2(C) snd_pcm_dmaengine v4l2_vp9 rk_crypto2 iwlwifi v4l2_jpeg rockchip_rga snd_pcm sm3_generic v4l2_h264 libsm3 videobuf2_dma_contig v4l2_mem2mem videobuf2_dma_sg snd_timer videobuf2_memops videobuf2_v4l2 snd videodev joydev panthor soundcore cfg80211 videobuf2_common drm_gpuvm drm_exec mc rfkill gpu_sched drm_shmem_helper cpufreq_dt zram binfmt_misc sch_fq_codel dm_mod autofs4 realtek phy_rockchip_samsung_hdptx phy_rockchip_usbdp fusb302 tcpm typec rtc_pcf8563 dwmac_rk nvmem_rockchip_otp stmmac_platform stmmac rockchip_rng rng_core pcs_xpcs rockchipdrm dw_hdmi_qp dw_hdmi cec dw_mipi_dsi analogix_dp drm_display_helper drm_dp_aux_bus
[    8.891251] iwlwifi 0004:41:00.0: Microcode SW error detected. Restarting 0x0.
[    8.891978] iwlwifi 0004:41:00.0: Start IWL Error Log Dump:
[    8.892489] iwlwifi 0004:41:00.0: Transport status: 0x0000004B, valid: 6
[    8.892494] iwlwifi 0004:41:00.0: Loaded firmware version: 77.864baa2e.0 cc-a0-77.ucode
[    8.892499] iwlwifi 0004:41:00.0: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
Any news on this subject ?
Official Ubuntu is too limited .... I'm thinking to change to armbian my server .....
To install it, does it need a full recompilation ? or is there an img ? where can I find the DTB file for M2 ?
3 hours ago, xNiux said:
Do you know if the access to Rockchip NPU is OK ?
If wired correctly, dmesg reveals the following:
[    5.967316] [drm] Initialized rocket 0.0.0 for rknn on minor 0
[    5.975499] rocket fdab0000.npu: Rockchip NPU core 0 version: 1179210309
[    5.978652] rocket fdac0000.npu: Rockchip NPU core 1 version: 1179210309
[    5.985602] rocket fdad0000.npu: Rockchip NPU core 2 version: 1179210309
And when mesa is built with the rocket driver enabled, it can be used via teflon.
I tried the lastest version "Armbian_community_25.11.0-trunk.472_Odroidm2_trixie_edge_6.18.0-rc5_minimal.img". But NPU is not mentioned in dmesg.
Also, I have this red line. what could be the effect on the system ?
I have that line also:
[    0.496136] rockchip-pm-domain fd8d8000.power-management:power-controller: Failed to enable supply: -517
[    0.938478] rockchip-pm-domain fd8d8000.power-management:power-controller: Failed to create device link (0x180) with supplier 2-0042 for /power-management@fd8d8000/power-controller/power-domain@8
[    1.224290] rockchip-pm-domain fd8d8000.power-management:power-controller: Failed to enable supply: -517
[    1.237338] rockchip-pm-domain fd8d8000.power-management:power-controller: Failed to create device link (0x180) with supplier 2-0042 for /power-management@fd8d8000/power-controller/power-domain@8
[    1.294276] rockchip-pm-domain fd8d8000.power-management:power-controller: Failed to create device link (0x180) with supplier spi2.0 for /power-management@fd8d8000/power-controller/power-domain@12
[   17.384495] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fdba4000.video-codec
[   17.385477] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fdba8000.video-codec
[   17.386457] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fdbac000.video-codec
[   17.387427] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fdc40100.video-codec
But VPU seems to be working anyway:
If I remember correctly to actually use the NPU you'd need a 6.18-kernel and a recent Mesa version.
Compared to the standard 24.0.x Mesa version in Debian Trixie I though you needed 24.3 or 25.0.
But if you actually tried working with it, you should be able tell what you are using.
The mesa 25.3 is imported into Debian, but that version is currently blocked for migration from experimental to unstable by a policy issue.
So it will not be available anytime soon in regular versions of Debian (Trixie/stable 25.0.x, Forky/testing 25.2.x, Sid/unstable 25.2.x).
To run mesa 25.3 with Debian you'll have to install mesa using source-packages.
I was just about to rebuild the source package, but today's upgrade delivered everything turnkey since my development team was faster and had done everything for me.
The previously referenced description does provide a working result, but it does not use the most current available releases. This script runs the NPU with the latest working releases:
#!/bin/bash
WORKBENCH="."
python3.11 -m venv ${WORKBENCH}/python/3.11
source ${WORKBENCH}/python/3.11/bin/activate
pip install numpy==1.26.4
pip install pillow==12.0.0
pip install tflite-runtime==2.14.0
TEFLON_DEBUG=verbose ETNA_MESA_DEBUG=ml_dbgs python ${WORKBENCH}/classification.py \
          -i ${WORKBENCH}/grace_hopper.bmp \
          -m ${WORKBENCH}/mobilenet_v1_1_224_quant.tflite \
          -l ${WORKBENCH}/labels_mobilenet_quant_v1_224.txt \
          -e /usr/lib64/libteflon.so
deactivate
classification-3.11.log
There has been a regression with USB-C in the latest rolling release for Armbian M2 with kernel 6.19.0 RC6. & RC7 (26.2.0-trunk.332)
I tested multiple USB devices in the USB-C port.  None of them worked.  All worked previously in kernel 6.18.0 RC6.
I'm going to downgrade and confirm back here.   I have reverted back to kernel 6.18.0 RC7 but still no USB-C.
If anyone knows how to get in contact with the Armbian M2 maintainer please let me know.
5 hours ago, Walter Zambotti said:
M2 maintainer
There is none. Its csc device. Community supported. You are community :)
OK so how can I help to fix this issue?
I would like to compare (dtdiff) the device trees from the working version to the current.  I have the the dtb for the (non working) current but I can't find the dtb from the trunk for the working version using the 6.18.0 RC6 kernel.
The only link I have found was Armbian_community_26.2.0-trunk.7_Odroidm2_noble_edge_6.18.0-rc6_gnome_desktop.img.xz.torrent in the archive but there are not enough seeds to download it as the current download estimate is running at over 300 days.
And I'm not even sure that is the correct version!
If anyone can point me to another resource where I can download multiple images (or better yet just the device trees) for multiple versions (quickly) that would be helpful.
