guidol Posted October 23, 2017 Posted October 23, 2017 4 hours ago, tkaiser said: After this commit I built an Ubuntu Xenial image: http://kaiser-edv.de/tmp/NumpU8/Armbian_5.34_Sunvellr69_Ubuntu_xenial_default_3.4.113.img.xz (MD5 sum: 06e5a14865f0be6861f7e11babdd8bb3) Still feedback wanted but only based on this image (none for other devices, really): Wi-Fi working / which 'performance' led functionality (there should be two leds and both accessible through sysfs as @guidol demontrated already with one of them) Firstly the image is missing the symbolic link for script.bin -> /boot# ln -s bin/sunvell-r69.bin script.bin Config and WiFi connect via nmtui without problems: wlan0 Link encap:Ethernet HWaddr dc:44:6d:b0:b9:7a inet addr:192.168.6.152 Bcast:192.168.6.255 Mask:255.255.255.0 inet6 addr: fe80::de44:6dff:feb0:b97a/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:7466 errors:0 dropped:0 overruns:0 frame:0 TX packets:13966 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:509194 (509.1 KB) TX bytes:21076827 (21.0 MB) iperf3 test result (iperf3 server was my NanoPi Neo2): root@sunvellr69:~# iperf3 -c 192.168.6.22 Connecting to host 192.168.6.22, port 5201 [ 4] local 192.168.6.152 port 41002 connected to 192.168.6.22 port 5201 [ ID] Interval Transfer Bandwidth Retr Cwnd [ 4] 0.00-1.00 sec 1.92 MBytes 16.1 Mbits/sec 8 84.8 KBytes [ 4] 1.00-2.00 sec 1.85 MBytes 15.6 Mbits/sec 1 70.7 KBytes [ 4] 2.00-3.00 sec 2.13 MBytes 17.8 Mbits/sec 0 80.6 KBytes [ 4] 3.00-4.00 sec 1.64 MBytes 13.8 Mbits/sec 4 70.7 KBytes [ 4] 4.00-5.00 sec 1.82 MBytes 15.3 Mbits/sec 0 79.2 KBytes [ 4] 5.00-6.00 sec 2.02 MBytes 16.9 Mbits/sec 0 83.4 KBytes [ 4] 6.00-7.00 sec 1.89 MBytes 15.9 Mbits/sec 0 91.9 KBytes [ 4] 7.00-8.00 sec 2.01 MBytes 16.8 Mbits/sec 0 100 KBytes [ 4] 8.00-9.00 sec 1.81 MBytes 15.2 Mbits/sec 0 107 KBytes [ 4] 9.00-10.00 sec 1.83 MBytes 15.3 Mbits/sec 0 113 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.00 sec 18.9 MBytes 15.9 Mbits/sec 13 sender [ 4] 0.00-10.00 sec 18.9 MBytes 15.9 Mbits/sec receiver from outside the case I can only see the led connected to the trigger of the "red" led: echo "heartbeat" > /sys/class/leds/red_led/trigger when I had the case open the led looks like a red/blue dual-led....but the case is transculent for infrared...so I dont know if it is the red or blue light that shine.... SSH-console via WiFi sometimes hangs for a few parts of a second (bad latency) ....doesnt seem to be very stable a very stable signal: (but it show 52 of 70 for the quality) root@sunvellr69:/sys/class/leds# iwconfig wlan0 wlan0 IEEE 802.11bgn ESSID:"XXXXXX" Mode:Managed Frequency:2.462 GHz Access Point: C0:25:XX:XX:XX:XX Bit Rate=65 Mb/s Tx-Power=20 dBm Retry long limit:7 RTS thr:off Fragment thr:off Encryption key:off Power Management:off Link Quality=52/70 Signal level=-58 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:18 Invalid misc:0 Missed beacon:0 After a "reboot" we got the same kernel-panic and 10 second timer - BUT the restart seems to work After the restart you see in the first line a <5 and then the normal Ubuntu-Login Screen. 0 Quote
tkaiser Posted October 23, 2017 Posted October 23, 2017 32 minutes ago, guidol said: Firstly the image is missing the symbolic link for script.bin -> /boot# ln -s bin/sunvell-r69.bin script.bin Thank you for testing and yeah, stupid mistake by me naming board config sunvellr69.csc and fex file differently sunvell-r69.fex. Fixed. Still interested in the output from iperf3 -R -c 192.168.6.22 echo "heartbeat" > /sys/class/leds/green_led/trigger (iperf3 testing in reverse direction and trying out the led connected to PL10 pin (according to vendor fex, IIRC we have another device with dual color led and there it's also PL10/PA15). Currently we know there's a blue led connected to PA15 (and labeled wrongly) so would be interesting to see whether's reaction to toggling PL10 too. 0 Quote
t.munzer Posted October 23, 2017 Posted October 23, 2017 11 minutes ago, tkaiser said: Fixed. Is it fixed the link given in your previous post ? Because using version downloaded five minutes ago, i'm stuck with Starting kernel... 0 Quote
tkaiser Posted October 23, 2017 Posted October 23, 2017 6 minutes ago, t.munzer said: Is it fixed the link given in your previous post ? Because using version downloaded five minutes ago, i'm stuck with Starting kernel... I didn't recreate the image since I want to fix all open issues in one batch so only fixed in local Github repo copy. I fear the link has to be created somehow otherwise behaviour expected... 0 Quote
t.munzer Posted October 23, 2017 Posted October 23, 2017 @tkaiser, Thanks, I apply @guidol correction and successfully boot. 0 Quote
guidol Posted October 23, 2017 Posted October 23, 2017 21 minutes ago, t.munzer said: @tkaiser, Thanks, I apply @guidol correction and successfully boot. I created the symbolic link after mounting the uSD on my NanoPi Neo2 as /mnt/sda1 Its good to have more than one from these small computers Nice to hear that it also worked for you 0 Quote
guidol Posted October 23, 2017 Posted October 23, 2017 53 minutes ago, tkaiser said: Still interested in the output from iperf3 -R -c 192.168.6.22 echo "heartbeat" > /sys/class/leds/green_led/trigger here the reverse mode: root@sunvellr69:~# iperf3 -R -c 192.168.6.22 Connecting to host 192.168.6.22, port 5201 Reverse mode, remote host 192.168.6.22 is sending [ 4] local 192.168.6.118 port 49106 connected to 192.168.6.22 port 5201 [ ID] Interval Transfer Bandwidth [ 4] 0.00-1.00 sec 11.1 MBytes 93.0 Mbits/sec [ 4] 1.00-2.00 sec 11.1 MBytes 92.8 Mbits/sec [ 4] 2.00-3.00 sec 11.2 MBytes 94.2 Mbits/sec [ 4] 3.00-4.00 sec 11.2 MBytes 94.2 Mbits/sec [ 4] 4.00-5.00 sec 11.1 MBytes 92.8 Mbits/sec [ 4] 5.00-6.00 sec 11.2 MBytes 94.1 Mbits/sec [ 4] 6.00-7.00 sec 11.2 MBytes 94.0 Mbits/sec [ 4] 7.00-8.00 sec 11.1 MBytes 93.4 Mbits/sec [ 4] 8.00-9.00 sec 11.2 MBytes 94.2 Mbits/sec [ 4] 9.00-10.00 sec 11.2 MBytes 94.0 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.00 sec 113 MBytes 94.4 Mbits/sec 0 sender [ 4] 0.00-10.00 sec 112 MBytes 93.8 Mbits/sec receiver as written - I cant see any reaction while the mainboard in the closed case when trying root@sunvellr69:~# echo "heartbeat" > /sys/class/leds/green_led/trigger root@sunvellr69:~# if I set echo "mmc0" > /sys/class/leds/red_led/trigger and echo "heartbeat" > /sys/class/leds/green_led/trigger I didnt see any heartbeat. 0 Quote
t.munzer Posted October 23, 2017 Posted October 23, 2017 (edited) Install to emmc went fine. Setup Wifi, reboot disconnecting Ethernet, and test accessing iperf server on a orange pi pc (with ethernet connection) root@sunvellr69:~# iperf3 -R -c 192.168.0.240 Connecting to host 192.168.0.240, port 5201 Reverse mode, remote host 192.168.0.240 is sending [ 4] local 192.168.0.36 port 44822 connected to 192.168.0.240 port 5201 [ ID] Interval Transfer Bandwidth [ 4] 0.00-1.00 sec 1.53 MBytes 12.8 Mbits/sec [ 4] 1.00-2.00 sec 1.68 MBytes 14.1 Mbits/sec [ 4] 2.00-3.00 sec 1.73 MBytes 14.5 Mbits/sec [ 4] 3.00-4.00 sec 2.12 MBytes 17.8 Mbits/sec [ 4] 4.00-5.00 sec 1.51 MBytes 12.6 Mbits/sec [ 4] 5.00-6.00 sec 2.40 MBytes 20.1 Mbits/sec [ 4] 6.00-7.00 sec 1.78 MBytes 14.9 Mbits/sec [ 4] 7.00-8.00 sec 1.81 MBytes 15.2 Mbits/sec [ 4] 8.00-9.00 sec 2.54 MBytes 21.3 Mbits/sec [ 4] 9.00-10.00 sec 675 KBytes 5.52 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.00 sec 20.1 MBytes 16.9 Mbits/sec 1 sender [ 4] 0.00-10.00 sec 18.3 MBytes 15.3 Mbits/sec receiver iperf Done. root@sunvellr69:~# iperf3 -c 192.168.0.240 Connecting to host 192.168.0.240, port 5201 [ 4] local 192.168.0.36 port 44824 connected to 192.168.0.240 port 5201 [ ID] Interval Transfer Bandwidth Retr Cwnd [ 4] 0.00-1.00 sec 1.22 MBytes 10.3 Mbits/sec 1 96.2 KBytes [ 4] 1.00-2.00 sec 535 KBytes 4.38 Mbits/sec 2 73.5 KBytes [ 4] 2.00-3.00 sec 255 KBytes 2.09 Mbits/sec 4 46.7 KBytes [ 4] 3.00-4.00 sec 153 KBytes 1.25 Mbits/sec 4 18.4 KBytes [ 4] 4.00-5.00 sec 423 KBytes 3.47 Mbits/sec 3 32.5 KBytes [ 4] 5.00-6.00 sec 1.79 MBytes 15.0 Mbits/sec 0 157 KBytes [ 4] 6.00-7.00 sec 2.15 MBytes 18.0 Mbits/sec 0 274 KBytes [ 4] 7.00-8.00 sec 1.95 MBytes 16.3 Mbits/sec 0 369 KBytes [ 4] 8.00-9.00 sec 2.31 MBytes 19.3 Mbits/sec 0 467 KBytes [ 4] 9.00-10.00 sec 2.61 MBytes 21.9 Mbits/sec 0 584 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.00 sec 13.4 MBytes 11.2 Mbits/sec 14 sender [ 4] 0.00-10.00 sec 13.0 MBytes 10.9 Mbits/sec receiver iperf Done. root@sunvellr69:~# iwconfig wlan0 wlan0 IEEE 802.11bgn ESSID:"9bxchodk_guest" Mode:Managed Frequency:2.427 GHz Access Point: C6:6E:1F:2C:F5:CF Bit Rate=39 Mb/s Tx-Power=20 dBm Retry long limit:7 RTS thr:off Fragment thr:off Encryption key:off Power Management:off Link Quality=50/70 Signal level=-60 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:187 Invalid misc:0 Missed beacon:0 Edited October 23, 2017 by t.munzer Add iwconfig output 0 Quote
t.munzer Posted October 23, 2017 Posted October 23, 2017 17 minutes ago, guidol said: I created the symbolic link after mounting the uSD on my NanoPi Neo2 as /mnt/sda1 Its good to have more than one from these small computers Nice to hear that it also worked for you Well I used the emmc install to create the link ! in fact echo "heartbeat" > /sys/class/leds/green_led/trigger blinks a little red led. Case closed it's only lightly visible through the case's vent... if the case is upside down ! Well, as notice by Sven K in his Facebook report, the box engineers seems to have a strange physics. where heat went down and it's logical to put led where nobody can see it ! 0 Quote
tkaiser Posted October 23, 2017 Posted October 23, 2017 20 minutes ago, guidol said: 94.2 Mbits/sec That's Ethernet (so packets in this direction travel over the other interface -- which might have slightly improved your wifi numbers before, it's not that easy to correctly measure wifi performance when more than one interface is active and two or more interfaces are connected to the same subnet). Anyway we already know we can't expect wonders from XR819, it works somewhat ok-ish (see @t.munzer results) and anyone wanting to have decent Wi-Fi performance can always add an RTL8211AU 2x2 MIMO dongle anyway (well, that needs most probably mainline kernel support so someone has to hack together a .dts and submit upstream) 12 minutes ago, t.munzer said: a little red led Ok, then blue and visible led is connected to PA15 (and labeled wrongly red) and there's another rather invisible led connected to PL10 and wrongly labeled green. To make things worse I decided to now label the blue one green just to get almost consistent boot behaviour on all H2+/H3 boards (blue led labeled green will light up when kernel starts to load, at the time login is possible it will blink 3 times and then turn into solid mode again): https://github.com/armbian/build/commit/6981e324192dd6aad06e9ebd1a21a4c2f5c47d32 Will now create the Xenial image again (just check the timestamps at the download location). So now two contributions are IMO needed to consider switching from 'community supported' OS image to fully supported: Someone has to create a device page in linux-sunxi wiki Someone has to submit pull requests with u-boot config (576 MHz DRAM clock, 1008MHz CPU clock and MMC2 setting for eMMC) and a patch adding DT for the board (please keep in mind that 3.4 LTS kernel support ended already half a year ago) 1 Quote
guidol Posted October 23, 2017 Posted October 23, 2017 4 minutes ago, tkaiser said: That's Ethernet Ooops - for better SSHing I swicthed to ethernet....here WiFi: root@sunvellr69:~# iperf3 -R -c 192.168.6.22 Connecting to host 192.168.6.22, port 5201 Reverse mode, remote host 192.168.6.22 is sending [ 4] local 192.168.6.152 port 49601 connected to 192.168.6.22 port 5201 [ ID] Interval Transfer Bandwidth [ 4] 0.00-1.00 sec 2.77 MBytes 23.3 Mbits/sec [ 4] 1.00-2.00 sec 2.96 MBytes 24.8 Mbits/sec [ 4] 2.00-3.00 sec 2.88 MBytes 24.1 Mbits/sec [ 4] 3.00-4.00 sec 3.08 MBytes 25.8 Mbits/sec [ 4] 4.00-5.00 sec 3.00 MBytes 25.1 Mbits/sec [ 4] 5.00-6.00 sec 2.96 MBytes 24.8 Mbits/sec [ 4] 6.00-7.00 sec 3.05 MBytes 25.6 Mbits/sec [ 4] 7.00-8.00 sec 3.04 MBytes 25.5 Mbits/sec [ 4] 8.00-9.00 sec 2.46 MBytes 20.7 Mbits/sec [ 4] 9.00-10.00 sec 3.15 MBytes 26.4 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.00 sec 30.5 MBytes 25.6 Mbits/sec 0 sender [ 4] 0.00-10.00 sec 29.5 MBytes 24.7 Mbits/sec receiver iperf Done. root@sunvellr69:~# iperf3 -c 192.168.6.22 Connecting to host 192.168.6.22, port 5201 [ 4] local 192.168.6.152 port 49603 connected to 192.168.6.22 port 5201 [ ID] Interval Transfer Bandwidth Retr Cwnd [ 4] 0.00-1.00 sec 1.65 MBytes 13.8 Mbits/sec 2 76.4 KBytes [ 4] 1.00-2.00 sec 1.75 MBytes 14.6 Mbits/sec 1 66.5 KBytes [ 4] 2.00-3.00 sec 1.61 MBytes 13.5 Mbits/sec 0 74.9 KBytes [ 4] 3.00-4.00 sec 1.62 MBytes 13.6 Mbits/sec 4 59.4 KBytes [ 4] 4.00-5.00 sec 1.70 MBytes 14.2 Mbits/sec 0 73.5 KBytes [ 4] 5.00-6.00 sec 1.77 MBytes 14.8 Mbits/sec 1 62.2 KBytes [ 4] 6.00-7.00 sec 1.64 MBytes 13.7 Mbits/sec 0 72.1 KBytes [ 4] 7.00-8.00 sec 1.65 MBytes 13.8 Mbits/sec 0 80.6 KBytes [ 4] 8.00-9.00 sec 1.57 MBytes 13.2 Mbits/sec 0 87.7 KBytes [ 4] 9.00-10.00 sec 1.67 MBytes 14.0 Mbits/sec 0 94.7 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.00 sec 16.6 MBytes 13.9 Mbits/sec 8 sender [ 4] 0.00-10.00 sec 16.5 MBytes 13.9 Mbits/sec receiver iperf Done. 0 Quote
guidol Posted October 23, 2017 Posted October 23, 2017 Funny thing about the SSH latency via WiFi: If I do play Internet Radio via mpg123 -v -@ /home/guido/absolut_128.m3u on the HDMI console using WiFi I can use SSH at puTTY with like no lantency - also via WiFi Seems like that when only my typeing is transmitted via WiFi - the XRadio would go in a like sleep mode between the chars 0 Quote
tkaiser Posted October 23, 2017 Posted October 23, 2017 10 minutes ago, guidol said: Seems like that when only my typeing is transmitted via WiFi - the XRadio would go in a like sleep mode between the chars Well, that was what we observed one year ago on Orange Pi Zero prior to disabling wi-fi powermanagement (it reads off in your and @t.munzer's iwconfig output). Anyway new image finished uploading: http://kaiser-edv.de/tmp/NumpU8/Armbian_5.34_Sunvell-r69_Ubuntu_xenial_default_3.4.113.img.xz In my opinion the fex file is fine now (looking at it not that much from an Armbian perspective but more having users of other projects in mind like H3Droid, RetrOrangePi, Lakka or @jernej's OpenELEC who hopefully can use the fex 1:1). For Armbian we would need mainline kernel/u-boot support contributed by volunteers. 2 Quote
guidol Posted October 23, 2017 Posted October 23, 2017 26 minutes ago, tkaiser said: Anyway new image finished uploading: http://kaiser-edv.de/tmp/NumpU8/Armbian_5.34_Sunvell-r69_Ubuntu_xenial_default_3.4.113.img.xz In my opinion the fex file is fine now For Armbian we would need mainline kernel/u-boot support contributed by volunteers. Downloaded it already (23-Oct-2017 18:53 193264056) But will test it tomorrow (other timezone her ) kernel/u-boot volunteer isnt my level so I have to wait 0 Quote
t.munzer Posted October 23, 2017 Posted October 23, 2017 1 minute ago, guidol said: kernel/u-boot volunteer isnt my level so I have to wait For me it isn't my level but my league. Do I need to worry about that ? root@sunvellr69:~# armbianmonitor -v Starting package integrity check. This might take some time. Be patient please... It appears you may have corrupt packages. This is usually a symptom of filesystem corruption caused by SD cards or eMMC dying or burning the OS image to the installation media went wrong. The following changes from packaged state files were detected: /lib/modules/3.4.113-sun8i/modules.dep /lib/modules/3.4.113-sun8i/modules.dep.bin /lib/modules/3.4.113-sun8i/modules.alias /lib/modules/3.4.113-sun8i/modules.alias.bin /lib/modules/3.4.113-sun8i/modules.symbols /lib/modules/3.4.113-sun8i/modules.symbols.bin 0 Quote
guidol Posted October 23, 2017 Posted October 23, 2017 45 minutes ago, tkaiser said: Anyway new image finished uploading: http://kaiser-edv.de/tmp/NumpU8/Armbian_5.34_Sunvell-r69_Ubuntu_xenial_default_3.4.113.img.xz Reboot doesnt seems to work like before.... while booting up the <5 appears then the Ubuntu-login-Screen. After u-boot the screen seems to be initialized in another way (short dissorted image) 1 Quote
tkaiser Posted October 23, 2017 Posted October 23, 2017 18 minutes ago, t.munzer said: It appears you may have corrupt packages. Interesting, maybe a packaging fix is needed. 11 minutes ago, guidol said: Reboot doesnt seems to work like before.... while booting up the <5 appears then the Ubuntu-login-Screen. After u-boot the screen seems to be initialized in another way (short dissorted image) No idea and won't look into further. Current situation is that most needed bits are part of Armbian repo, everyone can build/improve legacy images and wrt 'full support' we need a wiki page and some copy&paste work (using Beelink X2 mainline stuff it's mostly just that + testing which I can't since not owning the device). Desktop and CLI image as well as 'support package' with individual packages: http://kaiser-edv.de/tmp/NumpU8/ 45a44de60feb7b388ad77c456ff58917 Armbian_5.34_Sunvell-r69_Support_Package.tar.gz f3eb7ae54762e37df11a069d4193fddb Armbian_5.34_Sunvell-r69_Ubuntu_xenial_default_3.4.113_desktop.img.xz 44fdbd858437df4c1cfce81f0d92a8a6 Armbian_5.34_Sunvell-r69_Ubuntu_xenial_default_3.4.113.img.xz (No Debian yet of course since Stretch needs a newer kernel than the smelly Allwinner 3.4) 2 Quote
manuti Posted October 30, 2017 Posted October 30, 2017 Any chance of having Official support for this board? thanks 0 Quote
guidol Posted October 30, 2017 Posted October 30, 2017 Is there any tool for a checking stable and correct ethernet-transfer? While I hear internetradio (via mpg123 or mplayer) I had some quirks and hicks on some stations, which I doesnt have with an OPi Zero (with AddOn-Board) or a NanoPi Neo2 with USB-Audio-Adapter while using also mpg123 or mplayer. Maybe the R69 has only some problems with the compiles version of mpg123 or mplayer and it isnt the hardware, because with other services like SMB, FTP and SSH I didnt got any problems. 0 Quote
tkaiser Posted November 8, 2017 Posted November 8, 2017 On 30.10.2017 at 9:30 AM, manuti said: Any chance of having Official support for this board? Did you read what has been written just one post above? On 23.10.2017 at 10:03 PM, tkaiser said: wrt 'full support' we need a wiki page and some copy&paste work (using Beelink X2 mainline stuff it's mostly just that + testing which I can't since not owning the device). It's up to users of the device taking care of it since obviously TV box manufactuers don't care about such stuff. Is there a wiki page? Has a user started to provide DT modifications? I don't think so. On 30.10.2017 at 9:45 AM, guidol said: Is there any tool for a checking stable and correct ethernet-transfer? You could use iperf3 but should be aware that there can't be hardware related networking differences between OPi Zero and this box since the whole network functionality lives inside H2+ and only the external MagJack can make a difference. With Fast Ethernet also trace lengths on the PCB don't matter so if you get network issues with same software you're most probably already talking about defective hardware -- which wouldn't be a surprise especially given that the box is now on sale. I never understood why people expect quality hardware from dirt cheap TV boxes. 0 Quote
guidol Posted November 8, 2017 Posted November 8, 2017 43 minutes ago, tkaiser said: I never understood why people expect quality hardware from dirt cheap TV boxes. I dont expect real quality, but I want to check if it is the ethernet-port or the streaming-app or the driver for ethernet of the os. The "dirty cheap" Orange Pi Zero (with Expansion PCB) is streaming Internet-Radio without problems and has also a Allwinner-SoC. 0 Quote
tkaiser Posted November 8, 2017 Posted November 8, 2017 2 hours ago, guidol said: The "dirty cheap" Orange Pi Zero (with Expansion PCB) is streaming Internet-Radio without problems and has also a Allwinner-SoC. This is what I was telling you already. H2+ on this TV box and H2+ on OPi Zero are obviously the same, Ethernet MAC and PHY live inside the SoC so there are NO differences to expect other than a mechanical issue (MagJack or cable broken, this is easy to spot with iperf3 as already suggested) 0 Quote
manuti Posted November 8, 2017 Posted November 8, 2017 OK, I started the Sunxi wiki page ... http://linux-sunxi.org/Sunvell_R69 Is a pice of crap, yes I know. Hi @guidol may I use your board images in the wiki? Anyone interested in sent me info to fill the info. Thanks!! 1 Quote
guidol Posted November 8, 2017 Posted November 8, 2017 4 hours ago, manuti said: Hi @guidol may I use your board images in the wiki? Thanks!! Yes - for sure - if it do help with the Fake-6.0.1 Android...its inly a Kitkat 4.4 - so no KODI 17.5 - only KODI 16.1 Her are pictures from @tkaiser - maybe you can use them also? what did you say Thomas? 1 Quote
manuti Posted November 9, 2017 Posted November 9, 2017 OK, I try to update Sunxi page this evenig. So many tanks! 0 Quote
tkaiser Posted November 9, 2017 Posted November 9, 2017 15 hours ago, guidol said: Her are pictures from @tkaiser - maybe you can use them also? what did you say Thomas? These pictures are not from me (Maybe Sven Kayser?) Anyway: creating an account over at the wiki is as easy as clicking on this here. Let's help @manuti! 0 Quote
guidol Posted November 9, 2017 Posted November 9, 2017 1 hour ago, tkaiser said: These pictures are not from me (Maybe Sven Kayser?) Thats right...they are from Sven Kayser...I asked him now on Facebook about the pictures. [EDIT] He did say: Please do. 1 Quote
manuti Posted November 10, 2017 Posted November 10, 2017 Today, I received my Sunvell R69 and complete basic info on Sunxi page, including pictures. From Desktop image provided by @tkaiser the eMMC can be browsed, ¿any petition? 0 Quote
manuti Posted November 10, 2017 Posted November 10, 2017 Some minor issues related to @tkaiser armbian image, both of then: lock the /var/dpkg after first apt update , so I need to manually fix before run apt upgrade I can't make the system boot directly to armbian, I need to start Android -> insert the uSD card with armbian > go to a Terminal previously installed on Android > switch to root user (my device is factory rooted) > reboot I configure the screen using h3disp with 1080p60 as I use with other boards. With the Desktop image, the tty are 1080p and Ok but the Desktop is recognized by the TV as an 1080p but only room 3/4 of the screen. 0 Quote
邓平平 Posted November 12, 2017 Posted November 12, 2017 does any body can boot Linux from eMMC? Here is my log: Quote U-Boot 2017.09-armbian (Nov 10 2017 - 02:54:22 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Zero Plus 2 DRAM: 1 GiB MMC: SUNXI SD/MMC: 1, SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: vidconsole Err: vidconsole Net: No ethernet found. Failed to mount ext2 filesystem... ** Unrecognized filesystem type ** Failed to mount ext2 filesystem... ** Unrecognized filesystem type ** starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 USB4: USB EHCI 1.00 USB5: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found scanning bus 4 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0(part 0) is current device Failed to mount ext2 filesystem... ** Unrecognized filesystem type ** MMC: no card present mmc_init: -123, time 3 Device 0: device type unknown ... is now current device ** Bad device usb 0 ** Spoiler 0 Quote
