Jean-Marc Posted December 31, 2024 Posted December 31, 2024 Hi, on orangepi5B, not possible to insert module g_ether root@orangepi5:~# modprobe g_ether modprobe: ERROR: could not insert 'g_ether': Exec format error root@orangepi5:~# uname -a Linux orangepi5 6.1.75-vendor-rk35xx #1 SMP Wed Aug 21 11:45:59 UTC 2024 aarch64 GNU/Linux root@orangepi5:~# 0 Quote
Werner Posted January 1 Posted January 1 Hi Providing logs with PASTE_SERVER_HOST=paste.armbian.de armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. Please check your /boot/config-... for "CONFIG_USB_ETH" 0 Quote
Solution Jean-Marc Posted January 30 Author Solution Posted January 30 Hi, Good news on recent kernel root@hn-orangepi5b-450:~# uname -a Linux hn-orangepi5b-450 6.12.0-current-rockchip-rk3588 #3 SMP PREEMPT Sun Nov 17 22:15:08 UTC 2024 aarch64 GNU/Linux all is now ok root@hn-orangepi5b-450:~# lsmod |grep g_ether g_ether 12288 0 usb_f_rndis 32768 1 g_ether u_ether 24576 5 usb_f_rndis,usb_f_ecm_subset,g_ether,usb_f_eem,usb_f_ecm libcomposite 61440 6 usb_f_rndis,u_ether,usb_f_ecm_subset,g_ether,usb_f_eem,usb_f_ecm Thanks to the Team 0 Quote
