north1 Posted January 14, 2025 Posted January 14, 2025 Hello, I ran sudo apt update / suodo apt upgrade on my Rock 3C this morning. I did notice that the kernel was upgraded but rebooted. It transpires that the kernel was upgraded to a completely new version (6.12.9) from 6.6.63 (or 62 I believe). 0 Quote
eselarm Posted January 14, 2025 Posted January 14, 2025 Look in Radxa Rock3C documentation howto connect a serial console cable. And post U-Boot + as far as it gets here on the forum. Otherwise even you yourself cannot fix it let alone that others can. Or you can download a latest image if that is there with also 6.12.x kernel. 0 Quote
north1 Posted January 14, 2025 Author Posted January 14, 2025 Hello, I ran sudo apt update / sudo apt upgrade on my Rock 3C this morning. I did notice that the kernel was upgraded and rebooted. Unfortunately my board will no longer boot, it transpires that the kernel was upgraded to a completely new version (6.12.9) from 6.6.63 (or perhaps 62). I did look at the recovery suggestions here, but I can not interrupt u-boot in terminal following these instructions - are these instructions still current? How can I recover or roll back to the previous kernel? Detailed console output below: DDR V1.18 f366f69a7d typ 23/07/17-15:48:58 ln LP4/4x derate en, other dram:1x trefi ddrconfig:0 LP4 MR14:0x4d LPDDR4, 324MHz BW=32 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=2048MB tdqss: cs0 dqs0: 72ps, dqs1: -48ps, dqs2: 24ps, dqs3: -120ps, change to: 324MHz clk skew:0x60 change to: 528MHz clk skew:0x58 change to: 780MHz clk skew:0x58 change to: 1056MHz(final freq) PHY drv:clk:38,ca:38,DQ:30,odt:60 vrefinner:16%, vrefout:29% dram drv:40,odt:80 vref_ca:00000068 clk skew:0x29 cs 0: the read training result: DQS0:0x3c, DQS1:0x39, DQS2:0x3e, DQS3:0x39, min : 0xf 0xf 0x11 0xe 0x2 0x5 0x8 0x4 , 0x4 0x5 0x2 0x1 0x9 0x8 0xb 0x7 , 0x10 0x10 0xd 0x9 0x3 0x1 0x3 0x4 , 0xc 0x9 0x7 0x1 0xf 0xf 0xc 0xe , mid :0x2b 0x2b 0x2d 0x29 0x1e 0x21 0x25 0x20 ,0x22 0x22 0x1f 0x1d 0x25 0x24 0x28 0x24 , 0x2d 0x2c 0x29 0x26 0x21 0x1d 0x20 0x21 ,0x29 0x26 0x24 0x1f 0x2c 0x2c 0x29 0x2b , max :0x47 0x47 0x49 0x45 0x3b 0x3d 0x42 0x3d ,0x41 0x3f 0x3c 0x39 0x42 0x41 0x45 0x41 , 0x4a 0x49 0x46 0x44 0x3f 0x3a 0x3d 0x3f ,0x46 0x43 0x42 0x3d 0x49 0x49 0x47 0x48 , range:0x38 0x38 0x38 0x37 0x39 0x38 0x3a 0x39 ,0x3d 0x3a 0x3a 0x38 0x39 0x39 0x3a 0x3a , 0x3a 0x39 0x39 0x3b 0x3c 0x39 0x3a 0x3b ,0x3a 0x3a 0x3b 0x3c 0x3a 0x3a 0x3b 0x3a , the write training result: DQS0:0x32, DQS1:0x23, DQS2:0x2c, DQS3:0x19, min :0x63 0x63 0x65 0x62 0x56 0x59 0x5c 0x5d 0x5c ,0x4c 0x4e 0x49 0x47 0x4f 0x50 0x51 0x4f 0x4b , 0x58 0x58 0x55 0x53 0x4d 0x4b 0x4c 0x52 0x51 ,0x46 0x44 0x43 0x3d 0x48 0x48 0x47 0x4a 0x44 , mid :0x7f 0x7f 0x81 0x7d 0x72 0x75 0x78 0x78 0x77 ,0x69 0x6a 0x66 0x63 0x6c 0x6c 0x6c 0x6b 0x68 , 0x75 0x75 0x71 0x70 0x6a 0x66 0x68 0x6d 0x6d ,0x64 0x60 0x5f 0x5a 0x65 0x66 0x63 0x67 0x60 , max :0x9b 0x9c 0x9d 0x99 0x8f 0x92 0x95 0x93 0x93 ,0x87 0x87 0x83 0x80 0x89 0x88 0x87 0x88 0x85 , 0x93 0x92 0x8e 0x8e 0x87 0x82 0x84 0x88 0x8a ,0x83 0x7d 0x7c 0x78 0x83 0x85 0x80 0x84 0x7c , range:0x38 0x39 0x38 0x37 0x39 0x39 0x39 0x36 0x37 ,0x3b 0x39 0x3a 0x39 0x3a 0x38 0x36 0x39 0x3a , 0x3b 0x3a 0x39 0x3b 0x3a 0x37 0x38 0x36 0x39 ,0x3d 0x39 0x39 0x3b 0x3b 0x3d 0x39 0x3a 0x38 , CA Training result: cs:0 min :0x48 0x44 0x3e 0x34 0x3e 0x36 0x47 ,0x47 0x41 0x3e 0x36 0x3d 0x32 0x45 , cs:0 mid :0x84 0x85 0x79 0x78 0x79 0x78 0x72 ,0x83 0x82 0x79 0x78 0x78 0x75 0x70 , cs:0 max :0xc1 0xc7 0xb4 0xbd 0xb4 0xbb 0x9e ,0xbf 0xc3 0xb4 0xbb 0xb4 0xb8 0x9c , cs:0 range:0x79 0x83 0x76 0x89 0x76 0x85 0x57 ,0x78 0x82 0x76 0x85 0x77 0x86 0x57 , out U-Boot SPL latest-2023.10-9-eed05a18-geed05a18 (Jan 30 2024 - 07:49:23 +0000) Trying to boot from SPI ## Checking hash(es) for config config-1 ... OK ## Checking hash(es) for Image atf-1 ... sha256+ OK ## Checking hash(es) for Image u-boot ... sha256+ OK ## Checking hash(es) for Image fdt-1 ... sha256+ OK ## Checking hash(es) for Image atf-2 ... sha256+ OK ## Checking hash(es) for Image atf-3 ... sha256+ OK ## Checking hash(es) for Image atf-4 ... sha256+ OK ## Checking hash(es) for Image atf-5 ... sha256+ OK INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-181-gc9a647cae-dirty:xsf NOTICE: BL31: Built : 11:30:09, Oct 18 2022 INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: pmu v1 is valid INFO: dfs DDR fsp_param[0].freq_mhz= 1056MHz INFO: dfs DDR fsp_param[1].freq_mhz= 324MHz INFO: dfs DDR fsp_param[2].freq_mhz= 528MHz INFO: dfs DDR fsp_param[3].freq_mhz= 780MHz INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0xa00000 INFO: SPSR = 0x3c9 U-Boot latest-2023.10-9-eed05a18-geed05a18 (Jan 30 2024 - 07:49:23 +0000) Model: Radxa ROCK 3 Model C DRAM: 2 GiB PMIC: RK8090 (on=0x40, off=0x00) Core: 334 devices, 31 uclasses, devicetree: separate MMC: mmc@fe2b0000: 1, mmc@fe2c0000: 2, mmc@fe310000: 0 Loading Environment from nowhere... OK Override default fdtfile to rockchip/rk3566-rock-3c-aic8800ds2.dtb In: serial@fe660000 Out: serial@fe660000 Err: serial@fe660000 Model: Radxa ROCK 3 Model C Net: eth0: ethernet@fe010000 starting USB... Bus usb@fcc00000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fd000000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fd800000: USB EHCI 1.00 Bus usb@fd840000: USB OHCI 1.0 Bus usb@fd880000: USB EHCI 1.00 Bus usb@fd8c0000: USB OHCI 1.0 scanning bus usb@fcc00000 for devices... 1 USB Device(s) found scanning bus usb@fd000000 for devices... 1 USB Device(s) found scanning bus usb@fd800000 for devices... 1 USB Device(s) found scanning bus usb@fd840000 for devices... ERROR: USB-error: DEVICENOTRESPONDING: Device did not respond to token (IN) or did not provide a handshake (OUT) (5) ERROR: USB-error: DEVICENOTRESPONDING: Device did not respond to token (IN) or did not provide a handshake (OUT) (5) unable to get device descriptor (error=-1) 1 USB Device(s) found scanning bus usb@fd880000 for devices... 1 USB Device(s) found scanning bus usb@fd8c0000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit Ctrl+C key in 0 seconds to stop autoboot... Card did not respond to voltage select! : -110 Card did not respond to voltage select! : -110 ** Booting bootflow 'nvme#0.blk#1.bootdev.part_1' with script Boot script loaded from nvme 0:1 259 bytes read in 2 ms (126 KiB/s) 26128157 bytes read in 78 ms (319.5 MiB/s) 36473344 bytes read in 107 ms (325.1 MiB/s) 115554 bytes read in 2 ms (55.1 MiB/s) Working FDT set to a100000 Failed to load '/dtb/rockchip/overlay/rk35xx-.dtbo' Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Moving Image from 0x2080000 to 0x2200000, end=45a0000 ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Ty AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 26128093 Bytes = 24.9 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0a100000 Booting using the fdt blob at 0xa100000 Working FDT set to a100000 Host not halted after 16000 microseconds. Loading Ramdisk to 7b5c4000, end 7ceaeedd ... OK Loading Device Tree to 000000007b53f000, end 000000007b5c3fff ... OK Working FDT set to 7b53f000 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 0.000000] Linux version 6.12.9-current-rockchip64 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PREEMPT Thu Jan 9 12:33:55 UTC 2025 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Radxa ROCK 3C [ 0.000000] efi: UEFI not found. [ 0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x000000007fffffff] [ 0.000000] NODE_DATA(0) allocated [mem 0x7fb6c100-0x7fb6e87f] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000000200000-0x000000007fffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000200000-0x000000007fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x000000007fffffff] [ 0.000000] On node 0, zone DMA: 512 pages in unavailable ranges [ 0.000000] cma: Reserved 128 MiB at 0x0000000073400000 on node -1 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 34 pages/cpu s98968 r8192 d32104 u139264 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: Virtualization Host Extensions [ 0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009 [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: root=UUID=ef4da573-1412-4701-988c-c1a952709f76 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=7 ubootpart= usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ 0.000000] Unknown kernel command line parameters "splash ubootpart= cgroup_enable=memory cgroup_memory=1", will be passed to user space. [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] Fallback order for Node 0: 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 523776 [ 0.000000] Policy zone: DMA [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off [ 0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 1MB [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x000000007d500000-0x000000007d700000] (2MB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 320 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: MBI range [296:319] [ 0.000000] GICv3: Using MBI frame 0x00000000fd410000 [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1 [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000 [ 0.000000] ITS: No ITS available, not enabling LPIs [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001369] Console: colour dummy device 80x25 [ 0.001391] printk: legacy console [tty1] enabled [ 0.002342] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.002391] pid_max: default: 32768 minimum: 301 [ 0.002525] LSM: initializing lsm=capability,yama,apparmor [ 0.002641] Yama: becoming mindful. [ 0.003001] AppArmor: AppArmor initialized [ 0.003166] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.003214] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.024126] rcu: Hierarchical SRCU implementation. [ 0.024183] rcu: Max phase no-delay instances is 1000. [ 0.024699] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level [ 0.028518] EFI services will not be available. [ 0.031598] smp: Bringing up secondary CPUs ... [ 0.043989] Detected VIPT I-cache on CPU1 [ 0.044111] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000 [ 0.044174] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 0.055880] Detected VIPT I-cache on CPU2 [ 0.055995] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000 [ 0.056051] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 0.068120] Detected VIPT I-cache on CPU3 [ 0.068231] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000 [ 0.068286] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 0.068483] smp: Brought up 1 node, 4 CPUs [ 0.068634] SMP: Total of 4 processors activated. [ 0.068654] CPU: All CPU(s) started at EL2 [ 0.068673] CPU features: detected: 32-bit EL0 Support [ 0.068692] CPU features: detected: 32-bit EL1 Support [ 0.068713] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 0.068739] CPU features: detected: Common not Private translations [ 0.068760] CPU features: detected: CRC32 instructions [ 0.068786] CPU features: detected: RCpc load-acquire (LDAPR) [ 0.068806] CPU features: detected: LSE atomic instructions [ 0.068826] CPU features: detected: Privileged Access Never [ 0.068844] CPU features: detected: RAS Extension Support [ 0.068867] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 0.068974] alternatives: applying system-wide alternatives [ 0.074275] Memory: 1853756K/2095104K available (16384K kernel code, 2914K rwdata, 11072K rodata, 5120K init, 786K bss, 105280K reserved, 131072K cma-reserved) [ 0.075782] devtmpfs: initialized [ 0.098594] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.098695] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.103351] 23648 pages in range for non-PLT usage [ 0.103384] 515168 pages in range for PLT usage [ 0.103879] pinctrl core: initialized pinctrl subsystem [ 0.104717] DMI not present or invalid. [ 0.110138] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.113054] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations [ 0.115216] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.117393] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.117541] audit: initializing netlink subsys (disabled) [ 0.118046] audit: type=2000 audit(0.112:1): state=initialized audit_enabled=0 res=1 [ 0.119217] thermal_sys: Registered thermal governor 'fair_share' [ 0.119230] thermal_sys: Registered thermal governor 'bang_bang' [ 0.119258] thermal_sys: Registered thermal governor 'step_wise' [ 0.119281] thermal_sys: Registered thermal governor 'user_space' [ 0.119397] cpuidle: using governor menu [ 0.119881] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.120139] ASID allocator initialised with 65536 entries [ 0.120616] Serial: AMBA PL011 UART driver [ 0.137336] /vop@fe040000: Fixed dependency cycle(s) with /hdmi@fe0a0000 [ 0.137491] /hdmi@fe0a0000: Fixed dependency cycle(s) with /vop@fe040000 [ 0.143052] /pcie@fe260000: Fixed dependency cycle(s) with /pcie@fe260000/legacy-interrupt-controller [ 0.164367] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.165022] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000 [ 0.165630] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.166058] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000 [ 0.166537] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.167736] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000 [ 0.168311] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.168726] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000 [ 0.169175] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.169579] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000 [ 0.171952] /hdmi@fe0a0000: Fixed dependency cycle(s) with /hdmi-con [ 0.172089] /hdmi-con: Fixed dependency cycle(s) with /hdmi@fe0a0000 [ 0.179058] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.179110] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.179135] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.179156] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.179179] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.179199] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.179221] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.179241] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.181681] cryptd: max_cpu_qlen set to 1000 [ 0.251046] raid6: neonx8 gen() 1405 MB/s [ 0.319279] raid6: neonx4 gen() 1431 MB/s [ 0.387508] raid6: neonx2 gen() 1319 MB/s [ 0.455719] raid6: neonx1 gen() 1071 MB/s [ 0.523945] raid6: int64x8 gen() 910 MB/s [ 0.592151] raid6: int64x4 gen() 1047 MB/s [ 0.660405] raid6: int64x2 gen() 937 MB/s [ 0.728638] raid6: int64x1 gen() 684 MB/s [ 0.728666] raid6: using algorithm neonx4 gen() 1431 MB/s [ 0.796775] raid6: .... xor() 1102 MB/s, rmw enabled [ 0.796805] raid6: using neon recovery algorithm [ 0.798347] iommu: Default domain type: Translated [ 0.798389] iommu: DMA domain TLB invalidation policy: strict mode [ 0.799539] SCSI subsystem initialized [ 0.800227] usbcore: registered new interface driver usbfs [ 0.800301] usbcore: registered new interface driver hub [ 0.800372] usbcore: registered new device driver usb [ 0.801203] pps_core: LinuxPPS API ver. 1 registered [ 0.801234] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.801282] PTP clock support registered [ 0.801359] EDAC MC: Ver: 3.0.0 [ 0.801910] scmi_core: SCMI protocol bus registered [ 0.803639] NetLabel: Initializing [ 0.803671] NetLabel: domain hash size = 128 [ 0.803691] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 0.803808] NetLabel: unlabeled traffic allowed by default [ 0.804110] vgaarb: loaded [ 0.804984] clocksource: Switched to clocksource arch_sys_counter [ 0.805827] VFS: Disk quotas dquot_6.6.0 [ 0.805929] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.806835] AppArmor: AppArmor Filesystem Enabled [ 0.822540] NET: Registered PF_INET protocol family [ 0.822946] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.894422] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear) [ 0.894686] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.894782] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.895108] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear) [ 0.895626] TCP: Hash tables configured (established 16384 bind 16384) [ 0.895861] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.895955] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.896305] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.896392] NET: Registered PF_XDP protocol family [ 0.896433] PCI: CLS 0 bytes, default 64 [ 0.896933] Trying to unpack rootfs image as initramfs... [ 0.906389] kvm [1]: nv: 554 coarse grained trap handlers [ 0.907081] kvm [1]: IPA Size Limit: 40 bits [ 0.907147] kvm [1]: GICv3: no GICV resource entry [ 0.907171] kvm [1]: disabling GICv2 emulation [ 0.907231] kvm [1]: GIC system register CPU interface enabled [ 0.907296] kvm [1]: vgic interrupt IRQ9 [ 0.907371] kvm [1]: VHE mode initialized successfully [ 0.910598] Initialise system trusted keyrings [ 0.910729] Key type blacklist registered [ 0.911144] workingset: timestamp_bits=44 max_order=19 bucket_order=0 [ 0.911243] zbud: loaded [ 0.912104] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.912843] fuse: init (API version 7.41) [ 0.916032] integrity: Platform Keyring initialized [ 0.989057] xor: measuring software checksum speed [ 0.991029] 8regs : 1716 MB/sec [ 0.993172] 32regs : 1550 MB/sec [ 0.995104] arm64_neon : 1725 MB/sec [ 0.995126] xor: using function: arm64_neon (1725 MB/sec) [ 0.995160] Key type asymmetric registered [ 0.995183] Asymmetric key parser 'x509' registered [ 0.995393] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 0.995843] io scheduler mq-deadline registered [ 0.995874] io scheduler kyber registered [ 0.995971] io scheduler bfq registered [ 1.002670] rockchip-naneng-combphy fe830000.phy: error -ENOENT: failed to get phy reset [ 1.002735] rockchip-naneng-combphy fe830000.phy: probe with driver rockchip-naneng-combphy failed with error -2 [ 1.003179] rockchip-naneng-combphy fe840000.phy: error -ENOENT: failed to get phy reset [ 1.003225] rockchip-naneng-combphy fe840000.phy: probe with driver rockchip-naneng-combphy failed with error -2 [ 2.464542] Freeing initrd memory: 25512K [ 2.467849] ledtrig-cpu: registered to indicate activity on CPUs [ 2.475591] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 2.475675] dma-pl330 fe530000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 2.479315] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 2.479399] dma-pl330 fe550000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 2.482900] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 2.489423] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 25, base_baud = 1500000) is a 16550A [ 2.491276] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 26, base_baud = 1500000) is a 16550A [ 2.491626] printk: legacy console [ttyS2] enabled [ 2.615150] Serial: AMBA driver [ 2.628653] loop: module loaded [ 2.631052] Key type psk registered [ 2.637171] thunder_xcv, ver 1.0 [ 2.637557] thunder_bgx, ver 1.0 [ 2.637906] nicpf, ver 1.0 [ 2.642002] usbcore: registered new interface driver usb-storage [ 2.645085] mousedev: PS/2 mouse device common for all mice [ 2.646347] i2c_dev: i2c /dev entries driver [ 2.657274] sdhci: Secure Digital Host Controller Interface driver [ 2.657871] sdhci: Copyright(c) Pierre Ossman [ 2.658326] Synopsys Designware Multimedia Card Interface Driver [ 2.659928] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.662964] arm-scmi arm-scmi.0.auto: Using scmi_smc_transport [ 2.663518] arm-scmi arm-scmi.0.auto: SCMI max-rx-timeout: 30ms [ 2.664272] scmi_protocol scmi_dev.1: Enabled polling mode TX channel - prot_id:16 [ 2.665461] arm-scmi arm-scmi.0.auto: SCMI Notifications - Core Enabled. [ 2.666148] arm-scmi arm-scmi.0.auto: Malformed reply - real_sz:8 calc_sz:4 (loop_num_ret:3) [ 2.666938] arm-scmi arm-scmi.0.auto: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 2.670510] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 2.671490] hid: raw HID events driver (C) Jiri Kosina [ 2.672095] usbcore: registered new interface driver usbhid [ 2.672611] usbhid: USB HID core driver [ 2.674728] rockchip-dfi fe230000.dfi: dfi initialized, dram type: 0x7, channels: 1 [ 2.677506] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 (0,8000003f) counters available [ 2.680099] NET: Registered PF_INET6 protocol family [ 2.742650] Segment Routing with IPv6 [ 2.743124] In-situ OAM (IOAM) with IPv6 [ 2.743618] NET: Registered PF_PACKET protocol family [ 2.744385] 8021q: 802.1Q VLAN Support v1.8 [ 2.744867] Key type dns_resolver registered [ 2.758711] registered taskstats version 1 [ 2.759642] Loading compiled-in X.509 certificates [ 2.779287] zswap: loaded using pool zstd/z3fold [ 2.780315] Demotion targets for Node 0: null [ 2.781332] Key type .fscrypt registered [ 2.781710] Key type fscrypt-provisioning registered [ 2.786879] Btrfs loaded, zoned=yes, fsverity=yes [ 2.787723] Key type encrypted registered [ 2.788120] AppArmor: AppArmor sha256 policy hashing enabled [ 2.833053] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected! [ 2.845742] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 2.846307] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1 [ 2.847189] xhci-hcd xhci-hcd.1.auto: USB3 root hub has no ports [ 2.847752] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002000010 [ 2.848672] xhci-hcd xhci-hcd.1.auto: irq 37, io mem 0xfcc00000 [ 2.849764] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 2.850529] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.851190] usb usb1: Product: xHCI Host Controller [ 2.851640] usb usb1: Manufacturer: Linux 6.12.9-current-rockchip64 xhci-hcd [ 2.852280] usb usb1: SerialNumber: xhci-hcd.1.auto [ 2.853644] hub 1-0:1.0: USB hub found [ 2.854067] hub 1-0:1.0: 1 port detected [ 2.858958] ehci-platform fd800000.usb: EHCI Host Controller [ 2.858988] ohci-platform fd840000.usb: Generic Platform OHCI controller [ 2.859049] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 2 [ 2.859383] ehci-platform fd880000.usb: EHCI Host Controller [ 2.859417] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 3 [ 2.859556] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 4 [ 2.859608] ehci-platform fd880000.usb: irq 39, io mem 0xfd880000 [ 2.859711] ohci-platform fd840000.usb: irq 40, io mem 0xfd840000 [ 2.860310] ehci-platform fd800000.usb: irq 38, io mem 0xfd800000 [ 2.869040] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00 [ 2.870008] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 2.870770] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.871430] usb usb3: Product: EHCI Host Controller [ 2.871881] usb usb3: Manufacturer: Linux 6.12.9-current-rockchip64 ehci_hcd [ 2.872521] usb usb3: SerialNumber: fd880000.usb [ 2.873900] hub 3-0:1.0: USB hub found [ 2.874321] hub 3-0:1.0: 1 port detected [ 2.881008] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00 [ 2.881938] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 2.882701] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.883360] usb usb2: Product: EHCI Host Controller [ 2.883810] usb usb2: Manufacturer: Linux 6.12.9-current-rockchip64 ehci_hcd [ 2.884450] usb usb2: SerialNumber: fd800000.usb [ 2.885670] hub 2-0:1.0: USB hub found [ 2.886088] hub 2-0:1.0: 1 port detected [ 2.917498] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.12 [ 2.918323] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.919036] usb usb4: Product: Generic Platform OHCI controller [ 2.919661] usb usb4: Manufacturer: Linux 6.12.9-current-rockchip64 ohci_hcd [ 2.920306] usb usb4: SerialNumber: fd840000.usb [ 2.921593] hub 4-0:1.0: USB hub found [ 2.922012] hub 4-0:1.0: 1 port detected [ 2.961763] vdda0v9_image: Bringing 600000uV into 900000-900000uV [ 2.992871] vcca1v8_image: Bringing 600000uV into 1800000-1800000uV [ 3.003682] ohci-platform fd8c0000.usb: Generic Platform OHCI controller [ 3.004354] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 5 [ 3.005365] ohci-platform fd8c0000.usb: irq 66, io mem 0xfd8c0000 [ 3.006898] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode. [ 3.007381] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 3.007610] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller. [ 3.008246] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 3.008822] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a [ 3.008840] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 3.008918] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 68,32 bit host data width,256 deep fifo [ 3.009555] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 67,32 bit host data width,256 deep fifo [ 3.012806] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq [ 3.013461] mmc_host mmc2: card is non-removable. [ 3.025829] WCN: marlin_init entry! [ 3.026849] of_cfs_init [ 3.027152] of_cfs_init: OK [ 3.028699] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 3.045108] mmc0: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA [ 3.065457] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.12 [ 3.066257] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.066933] usb usb5: Product: Generic Platform OHCI controller [ 3.067481] usb usb5: Manufacturer: Linux 6.12.9-current-rockchip64 ohci_hcd [ 3.068129] usb usb5: SerialNumber: fd8c0000.usb [ 3.069764] hub 5-0:1.0: USB hub found [ 3.070281] hub 5-0:1.0: 1 port detected [ 3.127602] clk: Disabling unused clocks [ 3.128878] PM: genpd: Disabling unused power domains [ 3.137078] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 3.154870] Freeing unused kernel memory: 5120K [ 3.155655] Run /init as init process [ 3.172311] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0) [ 3.221389] mmc0: Failed to initialize a non-removable card [ 3.445140] dwmmc_rockchip femmc: Successfully tuned phase to 169 [ 3.451831] mmc2: new ultra high speed SDR104 SDIO card at address 390b [ 4.059555] rk808-rtc rk808-rtc.5.auto: registered as rtc0 [ 4.063024] rk808-rtc rk808-rtc.5.auto: setting system clock to 2017-08-05T09:00:11 UTC (1501923611) [ 4.076704] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found [ 4.077943] rk_gmac-dwmac fe010000.ethernet: IRQ sfty not found [ 4.085473] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input). [ 4.086167] rk_gmac-dwmac fe010000.ethernet: Can not read property: tx_delay. [ 4.086820] rk_gmac-dwmac fe010000.ethernet: set tx_delay to 0x30 [ 4.091247] rk_gmac-dwmac fe010000.ethernet: Can not read property: rx_delay. [ 4.091945] rk_gmac-dwmac fe010000.ethernet: set rx_delay to 0x10 [ 4.092531] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [ 4.093229] rk_gmac-dwmac fe010000.ethernet: clock input from PHY [ 4.098180] rockchip-vop2 fe040000.vop: Adding to iommu group 0 [ 4.101144] rk_gmac-dwmac fe010000.ethernet: init for RGMII_ID [ 4.106457] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 4.107184] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5 [ 4.107683] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [ 4.108373] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [ 4.109667] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [ 4.110352] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [ 4.111101] rk_gmac-dwmac fe010000.ethernet: TSO supported [ 4.111633] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 4.112374] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10) [ 4.117632] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [ 4.118239] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width [ 4.121675] mdio_bus stmmac-0: MDIO device at address 1 is missing. [ 4.125175] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm]) [ 4.140310] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 4.143076] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver [ 4.144676] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm]) [ 4.147966] [drm] Initialized rockchip 1.0.0 for display-subsystem on minor 0 [ 4.149835] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 4.151997] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 4.311565] rk_gmac-dwmac fe010000.ethernet end0: renamed from eth0 0 Quote
eselarm Posted January 14, 2025 Posted January 14, 2025 (edited) OK contents lost, so again but shorter; 35 minutes ago, north1 said: U-Boot latest-2023.10-9-eed05a18-geed05a18 (Jan 30 2024 - 07:49:23 +0000) 35 minutes ago, north1 said: Override default fdtfile to rockchip/rk3566-rock-3c-aic8800ds2.dtb 35 minutes ago, north1 said: Failed to load '/dtb/rockchip/overlay/rk35xx-.dtbo' 35 minutes ago, north1 said: [ 1.002670] rockchip-naneng-combphy fe830000.phy: error -ENOENT: failed to get phy reset 35 minutes ago, north1 said: [ 4.311565] rk_gmac-dwmac fe010000.ethernet end0: renamed from eth0 Above are all points you should look at; Old U-Boot, likely some failing strange ethernet driver and/or power issue; I would see if the board boot OK with a SPI disabled, NVMe removed from a latest 6.12 Arbian image from SD-card. For my Rock3A from 6.6 to 6.12 I have bypassed boot.src/boot.cmd and armbianEnv.txt, but likely some errors are coming from there. Compare yours with those from fresh latest image I would say. Edited January 14, 2025 by eselarm 0 Quote
north1 Posted January 17, 2025 Author Posted January 17, 2025 Thank you for your feedback. I looked into this a bit further and it looks like the core of the problem relates to boot from nvme vs boot from SD card. Version 6.12.8 and 6.12.9 will boot from an SD card, although I don't think ethernet worked in 6.12.8 (but works in 6.12.9) I can not boot 6.12.9 to from nvme - I tried using 6.12.9 from a self-build and the 16 Jan 2025 Bookworm image published here. I have attached two u-boot output files for comparison: One output from a startup of 6.6.63 and a second output from 6.12.9. The boot log implies that failure sets in when mounting the nvme drive. So in summary, I don't believe the problems are due to specific issues with my legacy upgrade, as I see a comparable problem with a fresh installation of 6.12.9. Kernel 6.6.63 [ 3.767401] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [ 3.768022] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width [ 4.036061] rk_gmac-dwmac fe010000.ethernet end0: renamed from eth0 [ 4.466054] EXT4-fs (nvme0n1p2): mounted filesystem ef4da573-1412-4701-988c-c1a952709f76 ro with writeback data mode. Quota mode: none. [ 4.852164] systemd[1]: System time before build time, advancing clock. [ 4.860256] systemd[1]: Inserted module 'autofs4' Kernel 6.12.9 [ 4.156229] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [ 4.156781] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width [ 4.390817] rk_gmac-dwmac fe010000.ethernet end0: renamed from eth0 6.6.63.txt 6.12.9.txt 0 Quote
eselarm Posted January 17, 2025 Posted January 17, 2025 You could try: - mainline U-Boot - run rootfs from SD-card and then see if NVMe / PCIe is there and try to mount a filesystem on it. I run OS (edge) from SD-card, so can't tell if NVMe works with >= 6.12.9 I would need to order extra NVMe first. 0 Quote
north1 Posted January 18, 2025 Author Posted January 18, 2025 The nmve drive is not visible if I boot from an sd card. No nvme drive listed by lsblk and lspci returns a blank. dmesg | grep pci [ 0.154664] /pcie@fe260000: Fixed dependency cycle(s) with /pcie@fe260000/legacy-interrupt-cotroller [ 18.659471] platform 3c0000000.pcie: deferred probe pending: platform: supplier fe840000.phy not ready 0 Quote
eselarm Posted January 18, 2025 Posted January 18, 2025 (edited) 1 hour ago, north1 said: if I boot from an sd card What U-Boot version does it run then? I have used also a Radxa version 2023.10 or so pulled as blob from the latest Radxa Rock3A image. Rock3C might be different as especially PCIe is different for RK3568 and RK3566. Edited January 18, 2025 by eselarm 0 Quote
north1 Posted January 18, 2025 Author Posted January 18, 2025 Now I used the u-boot version that comes with the weekly build Bookworm image (armbian 2017-09). Is that not the correct one to use? I also tested this u-boot with 6.6.63 and that works fine DDR 2d653b3476 typ 24/01/20-15:04:19,fwver: v1.21 ln LP4/4x derate en, other dram:1x trefi ddrconfig:7 LPDDR4, 324MHz BW=32 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB tdqss: cs0 dqs0: 48ps, dqs1: -120ps, dqs2: -72ps, dqs3: -144ps, tdqss: cs1 dqs0: 48ps, dqs1: -96ps, dqs2: -48ps, dqs3: -144ps, change to: 324MHz PHY drv:clk:38,ca:38,DQ:30,odt:0 vrefinner:41%, vrefout:41% dram drv:40,odt:0 clk skew:0x61 rx vref: 41.9% tx vref: 38.0% change to: 528MHz PHY drv:clk:38,ca:38,DQ:30,odt:0 vrefinner:41%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 rx vref: 41.9% tx vref: 38.0% change to: 780MHz PHY drv:clk:38,ca:38,DQ:30,odt:60 vrefinner:16%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 rx vref: 15.4% tx vref: 38.0% change to: 1056MHz(final freq) PHY drv:clk:38,ca:38,DQ:30,odt:60 vrefinner:16%, vrefout:29% dram drv:40,odt:80 vref_ca:00000068 clk skew:0x39 rx vref: 15.4% tx vref: 35.0% cs 0: the read training result: DQS0:0x3c, DQS1:0x3c, DQS2:0x3d, DQS3:0x39, min : 0xb 0xb 0xd 0xb 0x2 0x2 0x6 0x6 , 0x6 0x8 0x4 0x1 0xb 0xb 0xd 0xb , 0xf 0xd 0xb 0x9 0x2 0x1 0x1 0x9 , 0xb 0x9 0x7 0x0 0xc 0xd 0x8 0xd , mid :0x28 0x29 0x2a 0x28 0x1e 0x1f 0x23 0x23 ,0x24 0x25 0x20 0x1e 0x28 0x28 0x29 0x27 , 0x2c 0x2a 0x27 0x26 0x1f 0x1d 0x1d 0x23 ,0x28 0x24 0x22 0x1e 0x29 0x2a 0x26 0x2a , max :0x46 0x47 0x48 0x46 0x3b 0x3d 0x40 0x40 ,0x42 0x43 0x3d 0x3c 0x46 0x46 0x45 0x44 , 0x49 0x47 0x43 0x43 0x3c 0x39 0x39 0x3e ,0x46 0x40 0x3e 0x3c 0x47 0x48 0x44 0x48 , range:0x3b 0x3c 0x3b 0x3b 0x39 0x3b 0x3a 0x3a ,0x3c 0x3b 0x39 0x3b 0x3b 0x3b 0x38 0x39 , 0x3a 0x3a 0x38 0x3a 0x3a 0x38 0x38 0x35 ,0x3b 0x37 0x37 0x3c 0x3b 0x3b 0x3c 0x3b , the write training result: DQS0:0x3f, DQS1:0x2d, DQS2:0x33, DQS3:0x26, min :0x65 0x67 0x68 0x67 0x58 0x5b 0x5e 0x5e 0x62 ,0x4d 0x4d 0x4a 0x49 0x51 0x52 0x54 0x52 0x50 , 0x54 0x53 0x51 0x50 0x48 0x48 0x47 0x4e 0x50 ,0x47 0x45 0x42 0x3d 0x4b 0x4d 0x47 0x4d 0x47 , mid :0x7e 0x80 0x81 0x80 0x74 0x75 0x78 0x78 0x7b ,0x68 0x68 0x64 0x63 0x6c 0x6c 0x6d 0x6c 0x6a , 0x6f 0x6e 0x6a 0x6a 0x62 0x5e 0x5f 0x65 0x68 ,0x61 0x5e 0x5b 0x58 0x64 0x65 0x60 0x66 0x60 , max :0x98 0x9a 0x9b 0x9a 0x90 0x90 0x93 0x93 0x94 ,0x84 0x84 0x7f 0x7e 0x87 0x86 0x86 0x86 0x85 , 0x8a 0x89 0x83 0x84 0x7c 0x74 0x78 0x7c 0x81 ,0x7b 0x77 0x75 0x73 0x7e 0x7e 0x7a 0x80 0x79 , range:0x33 0x33 0x33 0x33 0x38 0x35 0x35 0x35 0x32 ,0x37 0x37 0x35 0x35 0x36 0x34 0x32 0x34 0x35 , 0x36 0x36 0x32 0x34 0x34 0x2c 0x31 0x2e 0x31 ,0x34 0x32 0x33 0x36 0x33 0x31 0x33 0x33 0x32 , cs 1: the read training result: DQS0:0x3c, DQS1:0x3c, DQS2:0x3d, DQS3:0x39, min : 0xb 0xb 0xd 0xb 0x2 0x2 0x6 0x6 , 0x6 0x8 0x4 0x1 0xb 0xb 0xd 0xb , 0xf 0xd 0xb 0x9 0x2 0x1 0x1 0x9 , 0xb 0x9 0x7 0x0 0xc 0xd 0x8 0xd , mid :0x28 0x29 0x2a 0x28 0x1e 0x1f 0x23 0x23 ,0x24 0x25 0x20 0x1e 0x28 0x28 0x29 0x27 , 0x2c 0x2a 0x27 0x26 0x1f 0x1d 0x1d 0x23 ,0x28 0x24 0x22 0x1e 0x29 0x2a 0x26 0x2a , max :0x46 0x47 0x48 0x46 0x3b 0x3d 0x40 0x40 ,0x42 0x43 0x3d 0x3c 0x46 0x46 0x45 0x44 , 0x49 0x47 0x43 0x43 0x3c 0x39 0x39 0x3e ,0x46 0x40 0x3e 0x3c 0x47 0x48 0x44 0x48 , range:0x3b 0x3c 0x3b 0x3b 0x39 0x3b 0x3a 0x3a ,0x3c 0x3b 0x39 0x3b 0x3b 0x3b 0x38 0x39 , 0x3a 0x3a 0x38 0x3a 0x3a 0x38 0x38 0x35 ,0x3b 0x37 0x37 0x3c 0x3b 0x3b 0x3c 0x3b , the write training result: DQS0:0x3f, DQS1:0x2d, DQS2:0x33, DQS3:0x26, min :0x65 0x67 0x68 0x67 0x58 0x5b 0x5e 0x5e 0x62 ,0x4d 0x4d 0x4a 0x49 0x51 0x52 0x54 0x52 0x50 , 0x54 0x53 0x51 0x50 0x48 0x48 0x47 0x4e 0x50 ,0x47 0x45 0x42 0x3d 0x4b 0x4d 0x47 0x4d 0x47 , mid :0x7e 0x80 0x81 0x80 0x74 0x75 0x78 0x78 0x7b ,0x68 0x68 0x64 0x63 0x6c 0x6c 0x6d 0x6c 0x6a , 0x6f 0x6e 0x6a 0x6a 0x62 0x5e 0x5f 0x65 0x68 ,0x61 0x5e 0x5b 0x58 0x64 0x65 0x60 0x66 0x60 , max :0x98 0x9a 0x9b 0x9a 0x90 0x90 0x93 0x93 0x94 ,0x84 0x84 0x7f 0x7e 0x87 0x86 0x86 0x86 0x85 , 0x8a 0x89 0x83 0x84 0x7c 0x74 0x78 0x7c 0x81 ,0x7b 0x77 0x75 0x73 0x7e 0x7e 0x7a 0x80 0x79 , range:0x33 0x33 0x33 0x33 0x38 0x35 0x35 0x35 0x32 ,0x37 0x37 0x35 0x35 0x36 0x34 0x32 0x34 0x35 , 0x36 0x36 0x32 0x34 0x34 0x2c 0x31 0x2e 0x31 ,0x34 0x32 0x33 0x36 0x33 0x31 0x33 0x33 0x32 , CA Training result: cs:0 min :0x42 0x41 0x38 0x35 0x39 0x36 0x3e ,0x3d 0x3b 0x37 0x34 0x35 0x30 0x3d , cs:0 mid :0x80 0x81 0x76 0x75 0x78 0x76 0x6d ,0x7c 0x7b 0x75 0x73 0x74 0x71 0x6d , cs:0 max :0xbe 0xc1 0xb5 0xb6 0xb7 0xb7 0x9d ,0xbc 0xbb 0xb3 0xb3 0xb3 0xb2 0x9d , cs:0 range:0x7c 0x80 0x7d 0x81 0x7e 0x81 0x5f ,0x7f 0x80 0x7c 0x7f 0x7e 0x82 0x60 , cs:1 min :0x43 0x43 0x39 0x36 0x3c 0x37 0x3b ,0x40 0x3c 0x37 0x34 0x37 0x31 0x3a , cs:1 mid :0x81 0x82 0x78 0x77 0x7a 0x77 0x6e ,0x7f 0x7c 0x76 0x74 0x75 0x72 0x6d , cs:1 max :0xbf 0xc1 0xb8 0xb8 0xb8 0xb7 0xa2 ,0xbe 0xbd 0xb5 0xb5 0xb3 0xb4 0xa0 , cs:1 range:0x7c 0x7e 0x7f 0x82 0x7c 0x80 0x67 ,0x7e 0x81 0x7e 0x81 0x7c 0x83 0x66 , out U-Boot SPL board init U-Boot SPL 2017.09-armbian-2017.09-S2284-Pe069-Hd0b5-V023a-Bb703-R448a (Jan 15 2025 - 02:39:10unknown raw ID 0 0 0 unrecognized JEDEC id bytes: 00, 00, 00 Trying to boot from MMC2 No misc partition spl: partition error Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(b5946ac63d...) + OK ## Checking uboot 0x00a00000 ... sha256(344e10b64d...) + OK ## Checking fdt 0x00b55938 ... sha256(fa69173509...) + OK ## Checking atf-2 0xfdcc1000 ... sha256(b8dca786b4...) + OK ## Checking atf-3 0x0006b000 ... sha256(2f91089eb7...) + OK ## Checking atf-4 0xfdcce000 ... sha256(86ef885748...) + OK ## Checking atf-5 0xfdcd0000 ... sha256(0b2b146c60...) + OK ## Checking atf-6 0x00069000 ... sha256(a9a1e63bef...) + OK Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000) Total: 252.741/450.943 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-645-g8cea6ab0b:cl, fwver: v1.44 NOTICE: BL31: Built : 16:36:43, Sep 19 2023 INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: pmu v1 is valid 220114 INFO: l3 cache partition cfg-0 INFO: dfs DDR fsp_param[0].freq_mhz= 1056MHz INFO: dfs DDR fsp_param[1].freq_mhz= 324MHz INFO: dfs DDR fsp_param[2].freq_mhz= 528MHz INFO: dfs DDR fsp_param[3].freq_mhz= 780MHz INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0xa00000 INFO: SPSR = 0x3c9 U-Boot 2017.09-armbian-2017.09-S2284-Pe069-Hd0b5-V023a-Bb703-R448a (Jan 15 2025 - 02:39:10 + Model: Radxa ROCK3 Model C MPIDR: 0x81000000 PreSerial: 2, raw, 0xfe660000 DRAM: 4 GiB Sysmem: init Relocation Offset: ed20a000 Relocation fdt: eb9f55f8 - eb9fecc0 CR: M/C/I Using default environment DM: v1 dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0 switch to partitions #0, OK mmc1 is current device Boot from SDcard Bootdev(scan): mmc 1 MMC1: Legacy, 52Mhz PartType: EFI No misc partition boot mode: None FIT: No boot partition Failed to load DTB, ret=-19 No valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 I2c0 speed: 100000Hz vsel-gpios- not found! Error: -2 FAN53555 Option[12] Rev[15] Detected! vdd_cpu init 900000 uV PMIC: RK8090 (on=0x80, off=0x08) vdd_logic init 900000 uV vdd_gpu init 900000 uV vdd_npu init 900000 uV io-domain: OK Failed to get scmi clk dev dmc_fsp failed, ret=-19 Model: Radxa ROCK3 Model C : 0x81000000 ## Error: Can't overwrite "ethaddr" ## Error inserting "ethaddr" variable, errno=1 ## Error: Can't overwrite "eth1addr" ## Error inserting "eth1addr" variable, errno=1 CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A) apll 816000 KHz dpll 528000 KHz gpll 1188000 KHz cpll 1000000 KHz npll 1200000 KHz vpll 24000 KHz hpll 24000 KHz ppll 200000 KHz armclk 816000 KHz aclk_bus 150000 KHz pclk_bus 100000 KHz aclk_top_high 300000 KHz aclk_top_low 200000 KHz hclk_top 150000 KHz pclk_top 100000 KHz aclk_perimid 300000 KHz hclk_perimid 150000 KHz pclk_pmu 100000 KHz No misc partition Net: eth1: ethernet@fe010000 Hit key to stop autoboot('CTRL+C'): 0 starting USB... Bus dwc3@fcc00000: usb maximum-speed not found Failed to get USB PHY0 for dwc3@fcc00000 Port not available. Bus dwc3@fd000000: usb maximum-speed not found Failed to get USB PHY0 for dwc3@fd000000 Port not available. Bus usb@fd800000: USB EHCI 1.00 Bus usb@fd840000: USB OHCI 1.0 Bus usb@fd880000: USB EHCI 1.00 Bus usb@fd8c0000: USB OHCI 1.0 scanning bus usb@fd800000 for devices... 1 USB Device(s) found scanning bus usb@fd840000 for devices... 1 USB Device(s) found scanning bus usb@fd880000 for devices... 1 USB Device(s) found scanning bus usb@fd8c0000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Dvice 0: unknown device switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot.scr reading /boot.scr 4149 bytes read in 2 ms (2 MiB/s) ## Executing script at 00c00000 Boot script loaded from mmc 1:1 reading /armbianEnv.txt 232 bytes read in 1 ms (226.6 KiB/s) reading /uInitrd 17260603 bytes read in 1424 ms (11.6 MiB/s) reading /Image 36473344 bytes read in 3011 ms (11.6 MiB/s) reading /dtb/rockchip/rk3566-rock-3c.dtb 115554 bytes read in 15 ms (7.3 MiB/s) Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Fdt Ramdisk skip relocation No misc partition ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 17260539 Bytes = 16.5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0x08300000 Booting using the fdt blob at 0x08300000 reserving fdt memory region: addr=8300000 size=82000 Using Device Tree in place at 0000000008300000, end 0000000008384fff can't found rockchip,drm-logo, use rockchip,fb-logo WARNING: could not set reg FDT_ERR_BADOFFSET. failed to reserve fb-loader-logo memory WARNING: could not set reg FDT_ERR_BADOFFSET. Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000) Adding bank: 0x1f0000000 - 0x200000000 (size: 0x10000000) Total: 9737.297/9744.47 ms 0 Quote
eselarm Posted January 18, 2025 Posted January 18, 2025 I think 6.12.9 is not compatible with the U-Boot versions you used so far. I would try with a 2024.10 mainline U-Boot. I did disable teh SPI flash, see Radxa docs/wiki ( you can also erase it) and then wrote a 2024.10 mainline U-Boot in the boot area of the SD-card. It was from the edge/beta repo a month ago. Currently: root@rock3a:~# apt list| grep rock-3c armbian-bsp-cli-rock-3c-current/noble 25.2.0-trunk.340 arm64 armbian-bsp-cli-rock-3c-edge/noble 25.2.0-trunk.340 arm64 armbian-bsp-cli-rock-3c/noble 25.2.0-trunk.340 arm64 linux-u-boot-rock-3c-current/noble 25.2.0-trunk.340 arm64 linux-u-boot-rock-3c-edge/noble 25.2.0-trunk.340 arm64 0 Quote
imnlfn Posted January 18, 2025 Posted January 18, 2025 I am having issues with my Rock 4A that are similar to those that @north1 is having. The 6.6.63 kernel was working great and now I can no longer boot after upgrading to the 6.12.9 kernel, since it no longer sees the drives I have connected via NMVe. I tried reverting to the old kernel via armbian-config, but it continues to load the newer kernel. The documentation for armbian-config is frankly appalling, BTW. 0 Quote
eselarm Posted January 19, 2025 Posted January 19, 2025 9 hours ago, imnlfn said: The 6.6.63 kernel was working great It looks like some more generic issue with PCIe/NVMe as Rock4A is Rk3399, not RK35xx. On my RK3588S NVMe works OK with 6.12.9 and 6.13.0-rc5 (2024.10 U-Boot loader in eMMC). I hope you have backups, so then there is always tricks to copy 6.6.x kernel+DTB+modules from there and get it to boot again. You will need spare/temporary SD-card I think. I do rather crazy things with SBC Linux installs, so I have my methods to flip to an older/other kernel (Btrfs snapshots). SBC/embedded Linux does not have GRUB bootmanager by default, otherwise that would be the way to select older kernel. You can always download and older image (from archives) and use that (for manually extracting older kernel). Same as my earlier comment for Rock3C, I think newer U-Boot is needed. It also might be a power stability issue. I know with my Rock3A I needed even to look in schematics before I got some trust in the board. The 6.12.9 kernel might initialize things in a different way/sequence, but all pure guessing. I do not know the power architecture of the Rock3C nor Rock4A. For my Rock3A, I soldered a 12V wire pair to a USB-C DIY connector, so the board uses its own 5V 8A DC/DC convertor. That works fine. 0 Quote
usual user Posted January 19, 2025 Posted January 19, 2025 2 hours ago, eselarm said: SBC/embedded Linux does not have GRUB bootmanager by default, otherwise that would be the way to select older kernel. But I'm grateful that it also works for me with pure U-boot: Spoiler U-Boot SPL 2025.01 (Jan 16 2025 - 00:00:00 +0000) Trying to boot from SPI ## Checking hash(es) for config config-1 ... OK ## Checking hash(es) for Image atf-1 ... sha256+ OK ## Checking hash(es) for Image u-boot ... sha256+ OK ## Checking hash(es) for Image fdt-1 ... sha256+ OK ## Checking hash(es) for Image atf-2 ... sha256+ OK NOTICE: BL31: v2.12.0(release): NOTICE: BL31: Built : 00:00:00, Nov 27 2024 NOTICE: BL31: Rockchip release version: v1.0 U-Boot 2025.01 (Jan 16 2025 - 00:00:00 +0000) Model: Hardkernel ODROID-M1 SoC: RK3568B2 DRAM: 8 GiB (effective 7.7 GiB) PMIC: RK809 (on=0x80, off=0x08) Core: 324 devices, 37 uclasses, devicetree: separate MMC: mmc@fe2b0000: 1, mmc@fe310000: 0 Loading Environment from nowhere... OK In: serial,usbkbd Out: serial,vidconsole Err: serial,vidconsole Model: Hardkernel ODROID-M1 SoC: RK3568B2 Net: eth0: ethernet@fe2a0000 starting USB... Bus usb@fd000000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fd800000: USB EHCI 1.00 Bus usb@fd840000: USB OHCI 1.0 Bus usb@fd880000: USB EHCI 1.00 Bus usb@fd8c0000: USB OHCI 1.0 scanning bus usb@fd000000 for devices... 1 USB Device(s) found scanning bus usb@fd800000 for devices... 2 USB Device(s) found scanning bus usb@fd840000 for devices... 1 USB Device(s) found scanning bus usb@fd880000 for devices... 5 USB Device(s) found scanning bus usb@fd8c0000 for devices... 1 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found scanning bus for devices... SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp fbss pio slum part ccc apst Card did not respond to voltage select! : -110 Card did not respond to voltage select! : -110 Cannot persist EFI variables without system partition *** U-Boot Boot Menu *** Press UP/DOWN to move, ENTER to select, ESC to quit Standard Boot NVME USB Mass Storage SCSI USB Mass Storage eMMC USB Mass Storage microSD USB Mass Storage Power Off usb 0 mmc 1 nvme 0 Exit Hit any key to stop autoboot: 2 Hit any key to stop autoboot: 1 Scanning for bootflows in all bootdevs Seq Method State Uclass Part Name Filename --- ----------- ------ -------- ---- ------------------------ ---------------- Scanning global bootmeth 'efi_mgr': 0 efi_mgr ready (none) 0 <NULL> ** Booting bootflow '<NULL>' with efi_mgr Loading Boot0000 'usb 0' failed Loading Boot0001 'mmc 1' failed Loading Boot0002 'nvme 0' failed EFI boot manager: Cannot load any image Boot failed (err=-14) Scanning bootdev 'mmc@fe2b0000.bootdev': 1 extlinux ready mmc 1 mmc@fe2b0000.bootdev.part /extlinux/extlinux.conf ** Booting bootflow 'mmc@fe2b0000.bootdev.part_1' with extlinux Boot Options 1: ODROID-M1 40000015-01 2: ODROID-M1 50000006-01 3: NanoPC-T4 40000015-01 4: NanoPC-T4 40000015-01 verbose 5: NanoPC-T4 40000015-01 previous 6: Odroid-N2+ 40000015-01 7: Odroid-N2+ 40000015-01 verbose 8: Odroid-N2+ 40000015-01 previous 9: Odroid-N2+ SPI NOR 40000015-01 10: ODROID-M1 40000015-01 verbose 11: ODROID-M1 40000015-01 previous 12: ODROID-M1 40000015-01 previous verbose Enter choice: 1: ODROID-M1 40000015-01 Retrieving file: /usr/lib/modules/linux/vmlinuz append: loglevel=4 root=PARTUUID=40000015-01 coherent_pool=2M console=ttyS02,1500000 console=tty0 rootwait Retrieving file: /usr/lib/modules/linux/dtb/rockchip/rk3568-odroid-m1.dtb Uncompressing Kernel Image to 0 ## Flattened Device Tree blob at 12000000 Booting using the fdt blob at 0x12000000 Working FDT set to 12000000 Loading Device Tree to 00000000eae82000, end 00000000eae94200 ... OK Working FDT set to eae82000 Starting kernel ... 0 Quote
eselarm Posted January 19, 2025 Posted January 19, 2025 With U-Boot in SPI: U-Boot SPL 2024.10-armbian-2024.10-Sf919-Pe8a7-H29de-Vf307-Bb703-R448a (Jan 06 2025 - 02:00:45 +0000): - I can confirm that there is no NVMe when kernel 6.12.9-current-rockchip64 (I did take out a Samsung 970 EVO 500G from another computer temporarily) - it works with 6.12.6-edge-rockchip64, 6.6.67-current-rockchip64, 6.13.0-rc5-edge-rockchip64 Another issue is that when overlay rock-3a-sata.dtbo is used, the SATA HDD is available, but the NVMe is not there then. It looks like mixing up of PCIe entities (in general), that is my guess. 0 Quote
imnlfn Posted January 19, 2025 Posted January 19, 2025 9 hours ago, eselarm said: I hope you have backups, so then there is always tricks to copy 6.6.x kernel+DTB+modules from there and get it to boot again. You will need spare/temporary SD-card I think. I do rather crazy things with SBC Linux installs, so I have my methods to flip to an older/other kernel (Btrfs snapshots). I don't have backups, but anything of any importance should be on the SSDs connected via NVMe (a copy of which is also on an external drive in case of an emergency), so if I have to rebuild what's on the eMMC, that won't be the end of the world. I will start taking backups though, to make this whole recovery process easier in the future. 9 hours ago, eselarm said: SBC/embedded Linux does not have GRUB bootmanager by default, otherwise that would be the way to select older kernel. I think that I should have been able to do this with armbian-config, but it wasn't working properly. I have a theory that this was because I "pinned" the current kernel before attempting to rollback to an older one, but I can't test my theory anymore because something that I did has rendered my system unbootable, even with the SSD drives disconnected. 10 hours ago, eselarm said: You can always download and older image (from archives) and use that (for manually extracting older kernel). This is what I am going to attempt to do. I have successfully booted a much older image from an SD card, and I have been able to mount the eMMC, so if I can figure out what I need to replace in order to get the system to boot again on its own, I'll do that. If that's unsuccessful, I will just reinstall to the eMMC and add back the applications that I was using. 10 hours ago, eselarm said: Same as my earlier comment for Rock3C, I think newer U-Boot is needed. I get that this is what bootstraps the board, but that is the entire extent of my knowledge of it. I'd like to better understand the boot process, but I haven't been able to find any basic explanation of it. To complicate matters, my 4A has an onboard SPI, which I believe can also contain the bootstrap code, but I have no idea if that would be a better way to go or not. Thanks for your comments! 0 Quote
imnlfn Posted January 19, 2025 Posted January 19, 2025 12 hours ago, eselarm said: It also might be a power stability issue. I know with my Rock3A I needed even to look in schematics before I got some trust in the board. The 6.12.9 kernel might initialize things in a different way/sequence, but all pure guessing. I do not know the power architecture of the Rock3C nor Rock4A. For my Rock3A, I soldered a 12V wire pair to a USB-C DIY connector, so the board uses its own 5V 8A DC/DC convertor. That works fine. It's definitely not a power issue in my case. I'm using a Penta Hat with my 4A and it has its own barrel jack and 12V/5A power supply that powers both the board and the drives. In any case, I let my system boot from the original configuration and took a picture of the messages before all of the BOOTP messages ran them off of the screen. I saw that it was failing to load a bunch of files, so I booted off of the SD again, this time using a version of Armbian with the 6.6.63 kernel. I saw then that several of the symbolic links the boot process needs were broken, so I fixed them, copying over files as needed (the kernel itself, specifically). Now I'm back in action, exactly as I was before the kernel update. I've left the current version pinned in armbian-configure and will wait for a version using a 6.13 series kernel before updating again. 0 Quote
north1 Posted January 20, 2025 Author Posted January 20, 2025 I recovered my unit by moving the 6.12.9 nvme image over to an sd card, as the sd card will boot. I subsequently rolled back the kernel to 6.6.63 using armbian-config and finally moved the 6.6.63 image back to my nvme. Clonezilla worked great for this exercise. Please also note that I could not get wifi to work using 6.12.9. I would normally install the aic8800 modules from Radxa's Github page here, but the modules generate an error message under 6.12.9. In summary I think the recommendation would be to stay on 6.6.x for now. 0 Quote
Jose Luis Posted January 25, 2025 Posted January 25, 2025 I have a similar problem but I have a mixed SD and NVMe setup, my boot in is SD but my rootfs is in NVMe. My rock-3a does boot u-boot, the kernel and initramfs, but it gets stuck at trying to mount the rootfs. I tried to load some modules from the kernel to make NVMe driver load with no luck. I got back to 6.6.x with a SD card reader and NVMe reader with another computer. 0 Quote
Jose Luis Posted January 25, 2025 Posted January 25, 2025 Checking the kernel output and comparing 6.6 to 6.12, these lines are not in there: [ 2.643952] rockchip-dw-pcie 3c0000000.pcie: PCIe Gen.2 x1 link up [ 2.645608] rockchip-dw-pcie 3c0000000.pcie: PCI host bridge to bus 0000:00 [ 2.646256] pci_bus 0000:00: root bus resource [bus 00-0f] [ 2.646769] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff]) [ 2.647632] pci_bus 0000:00: root bus resource [mem 0xf4200000-0xf5ffffff] [ 2.648300] pci_bus 0000:00: root bus resource [mem 0x300000000-0x33fffffff] (bus address [0x40000000-0x7fffffff]) [ 2.649276] pci 0000:00:00.0: [1d87:3566] type 01 class 0x060400 [ 2.649852] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 2.650539] pci 0000:00:00.0: supports D1 D2 [ 2.650936] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 2.659656] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f]) [ 2.660853] pci 0000:01:00.0: [1c5c:174a] type 00 class 0x010802 [ 2.661510] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] [ 2.662162] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff] [ 2.662765] pci 0000:01:00.0: reg 0x1c: [mem 0x00000000-0x00000fff] [ 2.664228] pci 0000:01:00.0: 4.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x1 link at 0000:00:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link) [ 2.676066] pci 0000:00:00.0: BAR 14: assigned [mem 0xf4200000-0xf42fffff] [ 2.676708] pci 0000:00:00.0: BAR 6: assigned [mem 0xf4300000-0xf430ffff pref] [ 2.677378] pci 0000:01:00.0: BAR 0: assigned [mem 0xf4200000-0xf4203fff 64bit] [ 2.678094] pci 0000:01:00.0: BAR 2: assigned [mem 0xf4204000-0xf4204fff] [ 2.678729] pci 0000:01:00.0: BAR 3: assigned [mem 0xf4205000-0xf4205fff] [ 2.679362] pci 0000:00:00.0: PCI bridge to [bus 01-ff] [ 2.679876] pci 0000:00:00.0: bridge window [mem 0xf4200000-0xf42fffff] [ 2.683300] pcieport 0000:00:00.0: PME: Signaling with IRQ 75 [ 2.684444] pcieport 0000:00:00.0: AER: enabled with IRQ 75 [ 2.685767] nvme nvme0: pci function 0000:01:00.0 [ 2.686232] nvme 0000:01:00.0: enabling device (0000 -> 0002) [ 2.714314] hwmon hwmon2: temp1_input not attached to any thermal zone [ 2.715024] hwmon hwmon2: temp2_input not attached to any thermal zone [ 2.715702] hwmon hwmon2: temp3_input not attached to any thermal zone [ 2.721387] nvme nvme0: 4/0/0 default/read/poll queues [ 2.727449] nvme nvme0: Ignoring bogus Namespace Identifiers [ 2.733920] nvme0n1: p1 p2 So looks all the PCIe bus is not being detected ( maybe due to changes in dts and u-boot not compatible as it happened before ) Anyone got the chance to boot the rolling trixie with 6.12 ? 0 Quote
eselarm Posted January 25, 2025 Posted January 25, 2025 (edited) 19 minutes ago, Jose Luis said: Anyone got the chance to boot the rolling trixie with 6.12 ? NVMe is back with kernels 6.12.10-current-rockchip64 and 6.13.0-edge-rockchip64. I just keep the same rootfs (ubuntu/noble based, on SD-card currently until issues are sorted out) There was a problem with repositories yesterday. 'Normally', I change the single line in the armbian.list, now I have 2 lines as the u-boot edge package was orphan. So: root@rock3a:/tmp# cat /etc/apt/sources.list.d/armbian.list deb [signed-by=/usr/share/keyrings/armbian.gpg] http://apt.armbian.com noble main noble-utils noble-desktop deb [signed-by=/usr/share/keyrings/armbian.gpg] http://beta.armbian.com noble main noble-utils noble-desktop This allows to install legacy, current, edge (of kernel/DTB, U-Boot). I am not sure about U-Boot versions. My goal is to have/use mainline/Armbian, but It might be that I need to hack an older 2017 or Radxa 2023 version into SD-card boot area (and disable SPI for the time being) as I can't get both NVMe and SATA working at the moment, but that is another (but maybe related) issue. This is specific Rock3A, I haven't looked at details of Rock3C yet. Edited January 25, 2025 by eselarm 0 Quote
Igor Posted January 25, 2025 Posted January 25, 2025 Yesterday bugfix release of rockchip64-current should address this problem. In stable channel, beta is anyway having latest. 0 Quote
north1 Posted January 29, 2025 Author Posted January 29, 2025 Thank you for the update. Could you please confirm which problem(s) have been addressed? I tested with 25.2.0/6.12.11 and see that the nvme drive shows up as one of the available block devices on the Rock 3C. It did not show up a s a block device with eg 6.12.9. I do exactly the same as @Jose Luis, ie I have u-boot on an sd card and rootfs on nvme, but it will not boot from the nvme. I am using the u-boot image that comes with the build. Are we now down to the problem suggested by @eselarm, ie that the Armbian supplied u-boot is not fully compatible with the image? 0 Quote
eselarm Posted January 29, 2025 Posted January 29, 2025 (edited) W.r.t. U-boot, I see the following: I have this in SPI (that is used to boot the Rock3A): U-Boot SPL 2024.10-armbian-2024.10-Sf919-Pe8a7-H29de-Vf307-Bb703-R448a (Jan 06 2025 - 02:00:45 +0000) When I stop autoboot and scan: => bootflow scan Card did not respond to voltage select! : -110 Card did not respond to voltage select! : -110 No EFI system partition No EFI system partition Failed to persist EFI variables No EFI system partition Failed to persist EFI variables No EFI system partition Failed to persist EFI variables Card did not respond to voltage select! : -110 pcie_dw_rockchip pcie@fe260000: PCIe-0 Link Fail pcie_dw_rockchip pcie@fe260000: PCIe-0 Link Fail scanning bus for devices... Bus usb@fd000000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fd800000: USB EHCI 1.00 Bus usb@fd880000: USB EHCI 1.00 Bus usb@fd8c0000: USB OHCI 1.0 scanning bus usb@fd000000 for devices... 1 USB Device(s) found scanning bus usb@fd800000 for devices... 3 USB Device(s) found scanning bus usb@fd880000 for devices... 1 USB Device(s) found scanning bus usb@fd8c0000 for devices... 1 USB Device(s) found pcie_dw_rockchip pcie@fe260000: PCIe-0 Link Fail ethernet@fe010000 Waiting for PHY auto negotiation to complete........ done BOOTP broadcast 1 The line with PCIe-0 Link Fail made me think something is wrong, but this is actually correct as there is no PCiE device on the pcie2x1, only a Radxa SATA breakout board. A bootscan list shows: => bootflow list Showing all bootflows Seq Method State Uclass Part Name Filename --- ----------- ------ -------- ---- ------------------------ ---------------- 0 efi_mgr ready (none) 0 <NULL> 1 extlinux ready mmc 1 mmc@fe2b0000.bootdev.part /extlinux/extlinux.conf 2 script ready mmc 1 mmc@fe2b0000.bootdev.part /boot.scr 3 efi ready nvme 1 nvme#0.blk#1.bootdev.part /EFI/BOOT/BOOTAA64.EFI 4 pxe ready ethernet 0 ethernet@fe010000.bootdev extlinux/extlinux.conf --- ----------- ------ -------- ---- ------------------------ ---------------- (5 bootflows, 5 valid) So check via serial console what is happening I would say. Edited January 29, 2025 by eselarm 0 Quote
north1 Posted January 31, 2025 Author Posted January 31, 2025 I did a small test: Bot into U-Boot on SD card (U-Boot 2024.10 (Jan 30 2025 - 09:24:11 +0000)) Run the following bootflow scan load nvme 0:1 $kernel_addr_r /Image load nvme 0:1 $ramdisk_addr_r /uInitrd load nvme 0:1 $fdt_addr_r /dtb/rockchip/rk3566-rock-3c.dtb setenv bootargs root=/dev/nvme0n1p2 rootwait console=ttyS2,1500000 earlycon pci=nomsi booti $kernel_addr_r $ramdisk_addr_r $fdt_addr_r This will take you into initramfs with a few error messages: Gave up waiting for root file system device. Common problems Boot args (cat /proc/cmdline) - Check rootdelay= (did the system wait long enough?) - Missing modules (cat /proc/modules; ls /dev) ALERT! /dev/nvme0n1p2 does not exist. Dropping to a shell! This will take you to initramfs. subsequently typing 'ls/dev' at the prompt confirms that the nvme drive is not available Finally generated dmesg as below that confirms that pcie fails to initialise properly. Quote [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 0.000000] Linux version 6.12.11-current-rockchip64 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PREEMPT Thu Jan 23 16:23:05 UTC 2025 [ 0.000000] KASLR enabled [ 0.000000] Machine model: Radxa ROCK 3C [ 0.000000] earlycon: uart0 at MMIO32 0x00000000fe660000 (options '1500000n8') [ 0.000000] printk: legacy bootconsole [uart0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000001ffffffff] [ 0.000000] NODE_DATA(0) allocated [mem 0x1ff769080-0x1ff76b7ff] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000001ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 0.000000] node 0: [mem 0x00000001f0000000-0x00000001ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff] [ 0.000000] On node 0, zone DMA: 512 pages in unavailable ranges [ 0.000000] cma: Reserved 128 MiB at 0x00000000e3400000 on node -1 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 34 pages/cpu s98968 r8192 d32104 u139264 [ 0.000000] pcpu-alloc: s98968 r8192 d32104 u139264 alloc=34*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: Virtualization Host Extensions [ 0.000000] CPU features: kernel page table isolation forced ON by KASLR [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009 [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: root=/dev/nvme0n1p2 rootwait console=ttyS2,1500000 earlycon pci=nomsi [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] Fallback order for Node 0: 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1048064 [ 0.000000] Policy zone: Normal [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x00000000df400000-0x00000000e3400000] (64MB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 320 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: MBI range [296:319] [ 0.000000] GICv3: Using MBI frame 0x00000000fd410000 [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1 [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000 [ 0.000000] ITS: No ITS available, not enabling LPIs [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.002184] Console: colour dummy device 80x25 [ 0.002768] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.003786] pid_max: default: 32768 minimum: 301 [ 0.004353] LSM: initializing lsm=capability,yama,apparmor [ 0.004984] Yama: becoming mindful. [ 0.005658] AppArmor: AppArmor initialized [ 0.006251] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.007004] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.030366] rcu: Hierarchical SRCU implementation. [ 0.030864] rcu: Max phase no-delay instances is 1000. [ 0.031928] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level [ 0.033857] EFI services will not be available. [ 0.038474] smp: Bringing up secondary CPUs ... [ 0.046988] Detected VIPT I-cache on CPU1 [ 0.047113] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000 [ 0.047178] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 0.055022] Detected VIPT I-cache on CPU2 [ 0.055150] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000 [ 0.055214] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 0.067052] Detected VIPT I-cache on CPU3 [ 0.067181] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000 [ 0.067244] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 0.067505] smp: Brought up 1 node, 4 CPUs [ 0.073080] SMP: Total of 4 processors activated. [ 0.073545] CPU: All CPU(s) started at EL2 [ 0.073950] CPU features: detected: 32-bit EL0 Support [ 0.074455] CPU features: detected: 32-bit EL1 Support [ 0.074962] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 0.075875] CPU features: detected: Common not Private translations [ 0.076494] CPU features: detected: CRC32 instructions [ 0.077007] CPU features: detected: RCpc load-acquire (LDAPR) [ 0.077572] CPU features: detected: LSE atomic instructions [ 0.078117] CPU features: detected: Privileged Access Never [ 0.078664] CPU features: detected: RAS Extension Support [ 0.079225] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 0.079989] alternatives: applying system-wide alternatives [ 0.085568] Memory: 3847292K/4192256K available (16384K kernel code, 2914K rwdata, 11072K rodata, 5184K init, 786K bss, 209544K reserved, 131072K cma-reserved) [ 0.088863] devtmpfs: initialized [ 0.111794] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.112801] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.117811] 23632 pages in range for non-PLT usage [ 0.117839] 515152 pages in range for PLT usage [ 0.118710] pinctrl core: initialized pinctrl subsystem [ 0.120442] DMI not present or invalid. [ 0.125535] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.128154] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations [ 0.130109] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.132056] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.132929] audit: initializing netlink subsys (disabled) [ 0.133819] audit: type=2000 audit(0.128:1): state=initialized audit_enabled=0 res=1 [ 0.135062] thermal_sys: Registered thermal governor 'fair_share' [ 0.135076] thermal_sys: Registered thermal governor 'bang_bang' [ 0.135677] thermal_sys: Registered thermal governor 'step_wise' [ 0.136266] thermal_sys: Registered thermal governor 'user_space' [ 0.136952] cpuidle: using governor menu [ 0.138177] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.139099] ASID allocator initialised with 32768 entries [ 0.139957] Serial: AMBA PL011 UART driver [ 0.156776] /vop@fe040000: Fixed dependency cycle(s) with /hdmi@fe0a0000 [ 0.157557] /hdmi@fe0a0000: Fixed dependency cycle(s) with /vop@fe040000 [ 0.163806] /pcie@fe260000: Fixed dependency cycle(s) with /pcie@fe260000/legacy-interrupt-controller [ 0.185951] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.187476] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000 [ 0.188695] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.189974] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000 [ 0.191040] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.192326] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000 [ 0.193473] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.194720] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000 [ 0.195777] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.197068] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000 [ 0.199952] /hdmi@fe0a0000: Fixed dependency cycle(s) with /hdmi-con [ 0.200744] /hdmi-con: Fixed dependency cycle(s) with /hdmi@fe0a0000 [ 0.208207] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.208965] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.209589] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.210254] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.210871] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.211535] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.212150] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.212813] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.215501] cryptd: max_cpu_qlen set to 1000 [ 0.281729] raid6: neonx8 gen() 1405 MB/s [ 0.349961] raid6: neonx4 gen() 1438 MB/s [ 0.418201] raid6: neonx2 gen() 1319 MB/s [ 0.486429] raid6: neonx1 gen() 1074 MB/s [ 0.554636] raid6: int64x8 gen() 911 MB/s [ 0.622874] raid6: int64x4 gen() 1047 MB/s [ 0.691092] raid6: int64x2 gen() 935 MB/s [ 0.759373] raid6: int64x1 gen() 690 MB/s [ 0.759800] raid6: using algorithm neonx4 gen() 1438 MB/s [ 0.827497] raid6: .... xor() 1102 MB/s, rmw enabled [ 0.827993] raid6: using neon recovery algorithm [ 0.829920] iommu: Default domain type: Translated [ 0.830410] iommu: DMA domain TLB invalidation policy: strict mode [ 0.831924] SCSI subsystem initialized [ 0.832610] libata version 3.00 loaded. [ 0.832987] usbcore: registered new interface driver usbfs [ 0.833573] usbcore: registered new interface driver hub [ 0.834155] usbcore: registered new device driver usb [ 0.835377] pps_core: LinuxPPS API ver. 1 registered [ 0.835915] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.836831] PTP clock support registered [ 0.837286] EDAC MC: Ver: 3.0.0 [ 0.838125] scmi_core: SCMI protocol bus registered [ 0.840315] NetLabel: Initializing [ 0.840664] NetLabel: domain hash size = 128 [ 0.841094] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 0.841745] NetLabel: unlabeled traffic allowed by default [ 0.842638] vgaarb: loaded [ 0.843501] clocksource: Switched to clocksource arch_sys_counter [ 0.844968] VFS: Disk quotas dquot_6.6.0 [ 0.845420] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.846966] AppArmor: AppArmor Filesystem Enabled [ 0.862846] NET: Registered PF_INET protocol family [ 0.863765] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.936616] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.937681] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.938546] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.939951] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear) [ 0.941643] TCP: Hash tables configured (established 32768 bind 32768) [ 0.942506] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.943284] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.944433] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.945048] NET: Registered PF_XDP protocol family [ 0.945539] PCI: CLS 0 bytes, default 64 [ 0.946333] Trying to unpack rootfs image as initramfs... [ 0.960732] kvm [1]: nv: 554 coarse grained trap handlers [ 0.961923] kvm [1]: IPA Size Limit: 40 bits [ 0.962391] kvm [1]: GICv3: no GICV resource entry [ 0.962868] kvm [1]: disabling GICv2 emulation [ 0.963398] kvm [1]: GIC system register CPU interface enabled [ 0.964049] kvm [1]: vgic interrupt IRQ9 [ 0.964499] kvm [1]: VHE mode initialized successfully [ 0.968078] Initialise system trusted keyrings [ 0.968609] Key type blacklist registered [ 0.969423] workingset: timestamp_bits=44 max_order=20 bucket_order=0 [ 0.970162] zbud: loaded [ 0.971267] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.972649] fuse: init (API version 7.41) [ 0.975957] integrity: Platform Keyring initialized [ 1.050048] xor: measuring software checksum speed [ 1.052491] 8regs : 1690 MB/sec [ 1.055012] 32regs : 1577 MB/sec [ 1.057403] arm64_neon : 1676 MB/sec [ 1.057849] xor: using function: 8regs (1690 MB/sec) [ 1.058355] Key type asymmetric registered [ 1.058763] Asymmetric key parser 'x509' registered [ 1.059426] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 1.060584] io scheduler mq-deadline registered [ 1.061043] io scheduler kyber registered [ 1.061516] io scheduler bfq registered [ 1.069141] rockchip-naneng-combphy fe830000.phy: error -ENOENT: failed to get phy reset [ 1.069963] rockchip-naneng-combphy fe830000.phy: probe with driver rockchip-naneng-combphy failed with error -2 [ 1.071401] rockchip-naneng-combphy fe840000.phy: error -ENOENT: failed to get phy reset [ 1.072298] rockchip-naneng-combphy fe840000.phy: probe with driver rockchip-naneng-combphy failed with error -2 [ 2.510822] Freeing initrd memory: 25536K [ 2.514782] ledtrig-cpu: registered to indicate activity on CPUs [ 2.523139] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 2.524060] dma-pl330 fe530000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 2.528488] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 2.529258] dma-pl330 fe550000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 2.533554] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 2.540601] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 25, base_baud = 1500000) is a 16550A [ 2.543229] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 26, base_baud = 1500000) is a 16550A [ 2.544487] printk: legacy console [ttyS2] enabled [ 2.545395] printk: legacy bootconsole [uart0] disabled [ 2.549162] Serial: AMBA driver [ 2.562361] loop: module loaded [ 2.564607] Key type psk registered [ 2.570663] thunder_xcv, ver 1.0 [ 2.571027] thunder_bgx, ver 1.0 [ 2.571360] nicpf, ver 1.0 [ 2.575668] usbcore: registered new interface driver usb-storage [ 2.578787] mousedev: PS/2 mouse device common for all mice [ 2.580033] i2c_dev: i2c /dev entries driver [ 2.583226] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected! [ 2.591304] sdhci: Secure Digital Host Controller Interface driver [ 2.591917] sdhci: Copyright(c) Pierre Ossman [ 2.592354] Synopsys Designware Multimedia Card Interface Driver [ 2.593991] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.597053] arm-scmi arm-scmi.0.auto: Using scmi_smc_transport [ 2.597587] arm-scmi arm-scmi.0.auto: SCMI max-rx-timeout: 30ms [ 2.598318] scmi_protocol scmi_dev.1: Enabled polling mode TX channel - prot_id:16 [ 2.599374] arm-scmi arm-scmi.0.auto: SCMI Notifications - Core Enabled. [ 2.600086] arm-scmi arm-scmi.0.auto: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 2.602907] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 2.603896] hid: raw HID events driver (C) Jiri Kosina [ 2.604482] usbcore: registered new interface driver usbhid [ 2.604982] usbhid: USB HID core driver [ 2.606945] rockchip-dfi fe230000.dfi: dfi initialized, dram type: 0x7, channels: 1 [ 2.609726] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 (0,8000003f) counters available [ 2.612350] NET: Registered PF_INET6 protocol family [ 2.674077] Segment Routing with IPv6 [ 2.674530] In-situ OAM (IOAM) with IPv6 [ 2.675004] NET: Registered PF_PACKET protocol family [ 2.675765] 8021q: 802.1Q VLAN Support v1.8 [ 2.676233] Key type dns_resolver registered [ 2.689467] registered taskstats version 1 [ 2.690325] Loading compiled-in X.509 certificates [ 2.709804] zswap: loaded using pool zstd/z3fold [ 2.710742] Demotion targets for Node 0: null [ 2.711733] Key type .fscrypt registered [ 2.712093] Key type fscrypt-provisioning registered [ 2.716092] Btrfs loaded, zoned=yes, fsverity=yes [ 2.716811] Key type encrypted registered [ 2.717190] AppArmor: AppArmor sha256 policy hashing enabled [ 2.765288] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 2.765825] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1 [ 2.766688] xhci-hcd xhci-hcd.1.auto: USB3 root hub has no ports [ 2.767232] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002000010 [ 2.768168] xhci-hcd xhci-hcd.1.auto: irq 37, io mem 0xfcc00000 [ 2.769204] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 2.769946] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.770590] usb usb1: Product: xHCI Host Controller [ 2.771027] usb usb1: Manufacturer: Linux 6.12.11-current-rockchip64 xhci-hcd [ 2.771706] usb usb1: SerialNumber: xhci-hcd.1.auto [ 2.773011] hub 1-0:1.0: USB hub found [ 2.773411] hub 1-0:1.0: 1 port detected [ 2.778259] ehci-platform fd800000.usb: EHCI Host Controller [ 2.778263] ehci-platform fd880000.usb: EHCI Host Controller [ 2.778290] ohci-platform fd840000.usb: Generic Platform OHCI controller [ 2.778299] ohci-platform fd8c0000.usb: Generic Platform OHCI controller [ 2.778309] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 2 [ 2.778334] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 3 [ 2.778520] ohci-platform fd8c0000.usb: irq 42, io mem 0xfd8c0000 [ 2.778811] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 4 [ 2.778860] ehci-platform fd800000.usb: irq 38, io mem 0xfd800000 [ 2.779344] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 5 [ 2.780527] ehci-platform fd880000.usb: irq 39, io mem 0xfd880000 [ 2.780666] ohci-platform fd840000.usb: irq 40, io mem 0xfd840000 [ 2.787542] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00 [ 2.788455] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 2.789198] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.789840] usb usb2: Product: EHCI Host Controller [ 2.790277] usb usb2: Manufacturer: Linux 6.12.11-current-rockchip64 ehci_hcd [ 2.790909] usb usb2: SerialNumber: fd800000.usb [ 2.792155] hub 2-0:1.0: USB hub found [ 2.792553] hub 2-0:1.0: 1 port detected [ 2.799530] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00 [ 2.800452] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 2.801194] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.801837] usb usb4: Product: EHCI Host Controller [ 2.802274] usb usb4: Manufacturer: Linux 6.12.11-current-rockchip64 ehci_hcd [ 2.802905] usb usb4: SerialNumber: fd880000.usb [ 2.804091] hub 4-0:1.0: USB hub found [ 2.804491] hub 4-0:1.0: 1 port detected [ 2.835945] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.12 [ 2.836702] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.837345] usb usb3: Product: Generic Platform OHCI controller [ 2.837872] usb usb3: Manufacturer: Linux 6.12.11-current-rockchip64 ohci_hcd [ 2.838504] usb usb3: SerialNumber: fd8c0000.usb [ 2.839742] hub 3-0:1.0: USB hub found [ 2.840150] hub 3-0:1.0: 1 port detected [ 2.843901] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.12 [ 2.844674] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.845328] usb usb5: Product: Generic Platform OHCI controller [ 2.845863] usb usb5: Manufacturer: Linux 6.12.11-current-rockchip64 ohci_hcd [ 2.846514] usb usb5: SerialNumber: fd840000.usb [ 2.847795] hub 5-0:1.0: USB hub found [ 2.848212] hub 5-0:1.0: 1 port detected [ 2.851200] vdda0v9_image: Bringing 600000uV into 900000-900000uV [ 2.882420] vcca1v8_image: Bringing 600000uV into 1800000-1800000uV [ 2.895819] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode. [ 2.896194] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 2.896503] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller. [ 2.897115] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 2.897673] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a [ 2.898254] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 2.898807] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 67,32 bit host data width,256 deep fifo [ 2.899277] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 68,32 bit host data width,256 deep fifo [ 2.903736] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq [ 2.904313] mmc_host mmc2: card is non-removable. [ 2.914904] WCN: marlin_init entry! [ 2.915355] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 2.916047] of_cfs_init [ 2.916443] of_cfs_init: OK [ 2.927623] mmc0: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA [ 2.990894] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 100000000Hz, actual 50000000HZ div = 0) [ 3.015437] dwmmc_rockchip fe2b0000.mmc: Successfully tuned phase to 344 [ 3.017852] mmc1: new ultra high speed SDR50 SDXC card at address 59b4 [ 3.020090] mmcblk1: mmc1:59b4 USD00 58.9 GiB [ 3.023664] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 3.026062] clk: Disabling unused clocks [ 3.027772] PM: genpd: Disabling unused power domains [ 3.028753] dw-apb-uart fe660000.serial: forbid DMA for kernel console [ 3.029890] mmcblk1: [ 3.040160] Freeing unused kernel memory: 5184K [ 3.040806] Run /init as init process [ 3.041142] with arguments: [ 3.041152] /init [ 3.041160] with environment: [ 3.041167] HOME=/ [ 3.041174] TERM=linux [ 3.063424] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0) [ 3.105163] mmc0: Failed to initialize a non-removable card [ 3.207608] dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 173 [ 3.212736] mmc2: new ultra high speed SDR104 SDIO card at address 390b [ 3.915878] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found [ 3.916463] rk_gmac-dwmac fe010000.ethernet: IRQ sfty not found [ 3.918709] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input). [ 3.919369] rk_gmac-dwmac fe010000.ethernet: Can not read property: tx_delay. [ 3.920065] rk_gmac-dwmac fe010000.ethernet: set tx_delay to 0x30 [ 3.920627] rk_gmac-dwmac fe010000.ethernet: Can not read property: rx_delay. [ 3.923575] rk_gmac-dwmac fe010000.ethernet: set rx_delay to 0x10 [ 3.924173] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [ 3.924790] rk_gmac-dwmac fe010000.ethernet: clock input from PHY [ 3.931567] rk_gmac-dwmac fe010000.ethernet: init for RGMII_ID [ 3.936798] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 3.937475] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5 [ 3.937941] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [ 3.938609] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [ 3.939290] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [ 3.940666] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [ 3.941483] rk_gmac-dwmac fe010000.ethernet: TSO supported [ 3.942075] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 3.942824] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10) [ 3.943594] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [ 3.944161] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width [ 3.950297] rockchip-vop2 fe040000.vop: Adding to iommu group 0 [ 3.968559] rk808-rtc rk808-rtc.5.auto: registered as rtc0 [ 3.969182] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm]) [ 3.979444] rk808-rtc rk808-rtc.5.auto: setting system clock to 2025-01-31T11:53:20 UTC (1738324400) [ 4.036628] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 4.043347] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver [ 4.045003] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm]) [ 4.050551] [drm] Initialized rockchip 1.0.0 for display-subsystem on minor 0 [ 4.051701] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 4.052573] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 4.287886] rk_gmac-dwmac fe010000.ethernet end0: renamed from eth0 [ 14.316146] platform fd000000.usb: deferred probe pending: platform: supplier fe830000.phy not ready [ 14.316979] platform 3c0000000.pcie: deferred probe pending: platform: supplier fe840000.phy not ready [ 33.772607] vcc3v3_sd: disabling 0 Quote
eselarm Posted January 31, 2025 Posted January 31, 2025 (edited) 2 hours ago, north1 said: rockchip-naneng-combphy fe830000.phy: error -ENOENT: failed to get phy reset On the RK3568 (Rock3A) there are: pcie3x2 and pcie2x1. On the RK3566 (Rock3C) only pcie2x1. pcie3x2 seems to be fixed function PCI-E 3.0 2 lanes and I see that related to 'rockchip-dw-pcie 3c0800000.pcie: host bridge /pcie@fe280000' on my Rock3A and that is also where the NMVe is. I am not sure what 'rockchip-naneng-combphy' does or should do; For running the Rock3C rootfs from NVMe on the pcie2x1 multiPHY, it should be PCI-E function at least, not SATA or USB Quick search leads me to: https://lwn.net/Articles/880042/ It will need more study as I at least do not understand the details. At least the U-Boot version gets it right, the kernel does not is my simple conclusion from the post of @north1 Edited January 31, 2025 by eselarm 0 Quote
north1 Posted January 31, 2025 Author Posted January 31, 2025 Just as an FYI - Trixie (25.2/6.13.0) will also boot from NVME and the equivalent 'combphy' message is below Quote [ 2.949337] rockchip-naneng-combphy fe830000.phy: wait phy status ready timeout 0 Quote
north1 Posted February 4, 2025 Author Posted February 4, 2025 Booting from nvme is now working on my Rock 3C, following the latest updates (6.12.12+). Please note that wifi does not work on the 3C under 6.12.x / 6.13.y, I believe the Radxa aic8800 drivers/modules are not compatible with the newer kernels. 0 Quote
Jose Luis Posted February 7, 2025 Posted February 7, 2025 With 6.12.11-current-rockchip64 ( 6.12.11-S62b2-D7b0b-P3f7a-C67e9Heb51-HK01ba-Vc222-B8de6-R448a ) my Rock 3A boots from SDcard with rootfs in NVMe. Thanks for fixing it! 0 Quote
