Hi everybody. I have one of these cards (along with many other OPis and RPis) and I was trying to use it for my Home Assistant installation, but OPi's Debian was not correctly complied so it did not work with ZIgbee USB adapters (and with many other things). I tested the Armbian imga someone put here, but I couldn't make it work.
I tried to recompile OPis Debian and to my surprise it complied without any glitch and everything is working. As soon as I can (which may take some time) I'll try to build my own Armbian image. If I succeed I'll bring it here.
This message was just to say that OPi's Debian is working fine when rebuilt from scratch, in case someone needs a working system right now.
Best regards.
Angel
Posted (edited)
@Angel Luis Pérez
Thank you very much for your valuable contribution and for sharing your experience with the community. I came across your post about successfully rebuilding Debian for the Orange Pi 4A, and it sounds like a great solution for those of us struggling with the official images. If it’s not too much trouble, would you mind sharing the image you built? I’d be incredibly grateful for any help you could provide.
Edited by BigGratz
Posted (edited)
Sorry everybody, been really busy these days.
Where can I upload the image so that all of you can get it?
Regards.
Angel Luis Perez
Edit: I shared it in GDrive. https://drive.google.com/file/d/1VClauaXtNZEkqzH8XBSHnJkweS142Ztv/view?usp=drive_link
I didn't change absolutely nothing in the build configuration. I mean, if you want you can just download the source code (it's explained quite clearly in th OPi 4a manual) from OrangePi an just "build". Nothing changed.
I hope it works for you.
Please take into account I'm not a developerand I didn't change anything in the code. I mean, don't ask me about the build, because I can't help you :(. I just tested to build Debian and it just works...
Edited by Angel Luis Pérez
Link shared
@ioncube I'm not sure I understand you. With the OPi source rebuild everything seems to work. With the build sharde by OrangePi in their web there were drivers missing. I.E. the USB Zigbee adapter from SonOff was not being recognised, and I'm afraid that any other device which should use /dev/ttyXXX would not work, because the needed drivers were not in the build.
Maybe there are some other drivers missing, I don't know, I just tested with the Zigbee adapter, and it didn't work in Debian nor Ubuntu OPi releases.
Regards.
Does anyone have the i2c working in the orange pi 4a? I tried the debian official image and build my image with the orange pi source code but I can't get it to work, everything works including spi gpio, any help will be appreciated,  also I want to build Armbian for the orange pi 4a
Posted (edited)
I never said this was Armbian, sorry. What I said was:
  "This message was just to say that OPi's Debian is working fine when rebuilt from scratch, in case someone needs a working system right now."
Sorry if I didn't explain clearly.
Regards.
On 4/12/2025 at 5:31 PM, BigGratz said:
where is Armbian here?
The software used by the Orange Pi "team" is, to a very large extent (estimates go as high as 99.9%), based on the work of developers from the Armbian project (and beyond). Their contribution mainly includes adding basic support for new boards, but unfortunately, without further maintenance or long-term support – which practically means that the entire burden of maintenance and support falls on the community.
It should be noted that systems such as Orange OS Ubuntu and Debian on ARM architecture are the result of years of work by more than 500 people gathered around the Armbian project. Orange Pi only makes minor adjustments. In the past ten years, we have not seen a single contribution from any member of the Orange Pi team to the development of these key components. Absolutely nothing, while they keep signing under our work (even changed to some degree) ... on top of stealing software support. Which they don't provide in any way.
The work of the Orange Pi team (which appears to be just one individual), on top of some old Armbian, can be tracked here:
https://github.com/orangepi-xunlong/orangepi-build/commits/next (they removed other board configs)
@Angel Luis Pérezthank you for you help, you can test i2c attaching a sensor like MPU6050 in the i2c pins (TWI4, TWI1, TW5), enable the i2c like in the orange pi user manual (add the overlay in /boot/extlinux/extlinux.com), and use the same command to test the i2c (sudo i2cdetect -y 4), it will show a table with all the i2c devices attached with their addresses, for instance if you are using a MPU6050 it will report the address 0x68, mine it is not reporting the address, it pauses the scanning for five seconds at the column 60 and the row 8, meaning that it is like detecting the address but finally it doesn't reports nothing, so it results with an empty table, also i tried to write and read registers but without success.
also i tried to connect an arduino acting as i2c slave device and printing every device information, including when it acknowledges the address, for debugging purposes, the arduino acknowledges the programmed address (0x20), but the orange pi 4a can't see any attached device, also the arduino can't receive any data.
just to share my experienced, i had 2 orangepi : opi4a and opi5pro.
for opi5pro, flashed with armbian orangepi5pro community. install zerotier, proxmox and install lxc and VM HAOS with no issue.
i tried on opi4a, default debian and ubuntu with no luck.
after compile the image https://github.com/orangepi-xunlong/orangepi-build/commits/next , and enable additional kernel config for everything missing in default opi4a (tun. tap, lvm, lvm-thin, ebt, kvm) now zerotier install working, proxmox partial complete. LXC working, but VM no luck: "KVM configured but not available", there is no /dev/kvm. create manual via "mknod /dev/kvm c 10 232" still not working.
already compared all "KVM" related in opi4a config and opi5pro, and enable the possible KVM config one in opi4a.
please,
if you any idea, what is missing ?
i tried to enable SMT support kernel also but still NOK.
thanks
Hello! If somebody search a resolution how to enable can interface (it`s necessery for 3d printers with can bus circuits) on orange pi distr - you can use attachment kernel conf for build image.
You should palce it in `orange-build/external/config/kenrel` (with replace) or `orange-build/kernel` and load on kernel configuration. Other steps is default for building opi image:
git clone https://github.com/orangepi-xunlong/orangepi-build
mv -f ./linux-5.15-sun55iw3-current.config ./orangepi-build/external/config/kernel
cd ./orangepi-build
sudo ./build.sh BOARD=orangepi4a BRANCH=current BUILD_OPT=image RELEASE=jammy BUILD_MINIMAL=no BUILD_DESKTOP=no KERNEL_CONFIGURE=n
If the OS does not detect the can0 interface - check if any CAN device is connected
voron@voron:~$ lsusb
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 004: ID 1b3f:2247 Generalplus Technology Inc. GENERAL WEBCAM
-------> Bus 001 Device 003: ID 1d50:606f OpenMoko, Inc. Geschwister Schneider CAN adapter <---------
Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Hi, I also tried to run this sensor, tried different ports but to no avail.
maybe you found a way to solve this problem?
