ZlobniyDaemon Posted February 19 Posted February 19 https://github.com/orangepi-xunlong/orangepi-build/tree/next The build script does not include OPI4a. The build for OPI4, as expected, does not run. Or i'm too lame, and don't understand, how i could duild it for OPT4a 0 Quote
Nick A Posted February 19 Posted February 19 (edited) Quote git clone https://github.com/orangepi-xunlong/orangepi-build.git --branch next --single-branch It's on the next branch. It was added back in Nov 18, 2024. https://github.com/orangepi-xunlong/orangepi-build/commit/0a00a8bc4d7874643203c38fe3c62943931397b3 If it doesn't work then ask the orange pi forums for help. Edited February 19 by Nick A 0 Quote
ZlobniyDaemon Posted February 19 Posted February 19 (edited) It's on the next branch. I don't understand, how to launch this build script Upd:I feel so dumb. Figured it out. Edited February 19 by ZlobniyDaemon 0 Quote
ZlobniyDaemon Posted February 19 Posted February 19 (edited) For some reason i'v got this error during build [ error ] ERROR in function compile_uboot [ ./build.sh:305 -> scripts/main.sh:638 -> scripts/main.sh:524 -> scripts/compilation.sh:247 -> scripts/general.sh:0 ] [ error ] U-boot compilation failed Upd: Found an open issue with a response stating that the script does not work in Docker: https://github.com/orangepi-xunlong/orangepi-build/issues/163 Try run in WSL, but also has an error, telling WSL is not supported by skript I'll try to install Ubuntu on my old laptop and run it there. Edited February 19 by ZlobniyDaemon 0 Quote
Ditrih Bolen Posted February 19 Posted February 19 (edited) @ZlobniyDaemon Seems like we're working on the same task ru_lang: похоже мы решаем одну и туже задачу, предлагаю объединить усилия) Edited February 19 by Ditrih Bolen 0 Quote
ZlobniyDaemon Posted February 19 Posted February 19 Цитата So to change the dtb you need to add this in your /boot/armbianEnv.txt fdtfile=sun55i-t527-orangepi-4a.dtb This didn't work for me. Boeard still not boot 0 Quote
ZlobniyDaemon Posted February 19 Posted February 19 @ditrih-bolen I am currently trying to build the image using the official script. Сейчас пытаюсь собрать образ официальным скриптом. 0 Quote
Ditrih Bolen Posted February 19 Posted February 19 @ZlobniyDaemon Can we go to telegram? может в тг передейм ? @r_mercader 0 Quote
ZlobniyDaemon Posted February 19 Posted February 19 Цитата Can we go to telegram? может в тг передейм ? @r_mercader Let's go. Same username Давай, тот же username 0 Quote
Nick A Posted February 19 Posted February 19 (edited) Can’t really tell if the image works without a boot log. You would need a USB to TTL serial adapter connected to your uart pins. Edited February 19 by Nick A 0 Quote
ZlobniyDaemon Posted February 19 Posted February 19 Цитата You would a USB to TTL serial adapter connected to your uart pins I don't have one, sadly 0 Quote
JuanEsf Posted February 20 Posted February 20 (edited) @Nick A Image based on the "apritzel" kernel for a527, I have compiled the image and it works on my board. The you just to chage "dev" to "edge" and add the clean patches for the board (I will take the time to learn and send). this is very edge and has no video, ethernet, wifi, etc... @Igor is it applicable to send to the armbian/build repository? Add Radxa Cubie A5E (sun55i-a527) Armbian Radxa Cubie A5E Debian BookWorm (Image) Edited February 20 by JuanEsf 0 Quote
Igor Posted February 20 Posted February 20 2 hours ago, JuanEsf said: is it applicable to send to the armbian/build repository? Sure, the rest can be adjusted on PR itself. I still wait / hope we will manage to switch CURRENT to 6.12.y with this release, otherwise this will stick at edge until. 0 Quote
Nick A Posted February 20 Posted February 20 (edited) Quote this is very edge and has no video, ethernet, wifi, etc... Yes, the warpme patches adds a lot more features. Apritzel sources will mostly likely be mainlined. You can use Apritzel's kernel source and add warpme patches on top. I took the quickest route and just added all of warpme's patches. warpme: aliases { serial0 = &uart0; mmc0 = &mmc0; mmc1 = &mmc1; mmc2 = &mmc2; ethernet0 = &gmac0; ethernet1 = &gmac1; ethernet2 = &wlan; }; apritzel: aliases { serial0 = &uart0; }; &mmc0 { vmmc-supply = <®_cldo3>; cd-gpios = <&pio 5 6 (GPIO_ACTIVE_LOW | GPIO_PULL_DOWN)>; /* PF6 */ bus-width = <4>; status = "okay"; }; Edited February 20 by Nick A 1 Quote
Michael Slobodskih Posted February 22 Posted February 22 @Nick A Please tell me if you have plans to add HDMI output support? 0 Quote
JuanEsf Posted February 22 Posted February 22 This board is very new and not mature in any way. If you use the radxa bsp kernel (debian) you have video, audio, wifi, etc... but with a modified version of the kernel with drivers and binaries closed in some cases. Mainline support is being worked on but it will take some time for the developers to add the necessary drivers and some may not arrive and even free and proprietary drivers may be mixed to make some specific features of each board work. warpme is merging Andre's work (mainline kernel) with drivers that are in the radxa cubie a5e bsp to enable network ports for example. in the sunxi kernel repo revisions of the "Display Engine 3.3" are being sent which adds video support for the new generation of allwinner (h616) soc among them. The GPU drivers for the Cubie A5e board are present in the mainline kernel, so once the graphics engine is enabled, it should be easy to enable GPU video acceleration. 1 Quote
Michael Slobodskih Posted February 24 Posted February 24 On 2/22/2025 at 8:28 PM, JuanEsf said: If you use the radxa bsp kernel (debian) you have video, audio, wifi, etc... but with a modified version of the kernel with drivers and binaries closed in some cases. Tell me where to get a radxa image to test on orange pi 4a? 0 Quote
JuanEsf Posted February 25 Posted February 25 (edited) @Michael Slobodskih Hi. This is mainline. Test image, I do not have the board to test. I can add a draft of the configuration, at this moment the changes were made on the cubie a5e tree that I currently have Log (link) Image (link) Edited February 25 by JuanEsf 0 Quote
JamesCL Posted February 25 Author Posted February 25 @JuanEsf Thanks for the image, I'm going to try it on my opi 4a and I'll let you know. Regards 0 Quote
MisterSBC Posted February 25 Posted February 25 (edited) @JuanEsf Thank you for your work! I was able to give that image a go during my lunch break on my Opi 4a. So far, it does not boot. Just the standard standby power light. Edited February 25 by MisterSBC 0 Quote
Michael Slobodskih Posted February 26 Posted February 26 12 hours ago, MisterSBC said: it does not boot. Just the standard standby power light i have the same result , i will try run with uart console today. 0 Quote
JamesCL Posted February 26 Author Posted February 26 (edited) @JuanEsf Have this : it gets stuck there : U-Boot 2025.01-armbian-2025.01-S2ebd-Pe2be-H8869-V77e1-Bb703-R448a+ (Feb 24 2025 - 23:31:20 -0300) Allwinner Technology CPU: Allwinner A523 (SUN55I) Model: OrangePi 4A DRAM: 4 GiB sunxi_set_gate: (CLK#32) unhandled Core: 52 devices, 20 uclasses, devicetree: separate WDT: Not starting watchdog@2050000 MMC: mmc@4020000: 0 Loading Environment from FAT... Unable to use mmc 0:1... In: serial@2500000 Out: serial@2500000 Err: serial@2500000 Net: No ethernet found. Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 4641 bytes read in 5 ms (906.3 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 156 bytes read in 3 ms (50.8 KiB/s) Load fdt: /boot/dtb/allwinner/sun55i-t527-orangepi-4a.dtb 17256 bytes read in 13 ms (1.3 MiB/s) Working FDT set to 4fa00000 Failed to load '/boot/dtb/allwinner/overlay/sun55i-t527-fixup.scr' 8116855 bytes read in 2781 ms (2.8 MiB/s) 42523136 bytes read in 14555 ms (2.8 MiB/s) Moving Image from 0x40080000 to 0x40200000, end=0x42b40000 ## Loading init Ramdisk from Legacy Image at 4ff00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 8116791 Bytes = 7.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Working FDT set to 4fa00000 Loading Ramdisk to 49842000, end 49fffa37 ... OK Loading Device Tree to 00000000497d5000, end 0000000049841fff ... OK Working FDT set to 497d5000 Starting kernel ... Edited February 26 by JamesCL Update Code 0 Quote
JuanEsf Posted February 26 Posted February 26 @JamesCL When u-boot finishes and starts booting the kernel it takes a minute and shows no messages on the console until it runs the kernel and launches the Armbian setup wizard. can you re-run it and wait a couple of minutes on the console please. 0 Quote
JamesCL Posted February 26 Author Posted February 26 @JuanEsf Ok, I'll try again, connect everything and let you know... Thanks for your work 🙂 0 Quote
Nick A Posted February 26 Posted February 26 Change the armbianEnv.txt log level to 8 in your sdcard. That should give you a more verbose kernel startup. 0 Quote
JamesCL Posted February 26 Author Posted February 26 @Nick AI made the change, but there were no changes in the log 0 Quote
Werner Posted February 27 Posted February 27 5 hours ago, Nick A said: og level to 8 i There is no log level 8. 7 is max https://linuxconfig.org/introduction-to-the-linux-kernel-log-levels 0 Quote
Nick A Posted February 27 Posted February 27 (edited) Sorry @JamesCL, Werner is correct. I thought 8 would display all kernel messages. Not sure if we can pass ignore_loglevel. Try loglevel 7. The source I got the information from was wrong. https://stackoverflow.com/questions/16390004/change-default-console-loglevel-during-boot-up/16390389#16390389 Edited March 10 by Nick A 0 Quote
JuanEsf Posted February 28 Posted February 28 (edited) @JamesCL Changes: git status On branch main Your branch is up to date with 'origin/main'. Changes not staged for commit: (use "git add <file>..." to update what will be committed) (use "git restore <file>..." to discard changes in working directory) modified: config/boards/radxa-cubie-a5e.conf modified: config/sources/families/sun55iw3.conf Untracked files: (use "git add <file>..." to include in what will be committed) config/boards/orangepi4a.conf patch/kernel/archive/sunxi-dev-6.12/Add-sun55iw3-OrangePi-4A.patch patch/u-boot/sunxi-dev-u-boot-a523/ you should skip the cubie board changes: config/boards/radxa-cubie-a5e.conf config/sources/families/sun55iw3.conf # # SPDX-License-Identifier: GPL-2.0 # # Copyright (c) 2013-2023 Igor Pecovnik, igor@armbian.com # # This file is a part of the Armbian Build Framework # https://github.com/armbian/build/ # enable_extension "sunxi-tools" declare -g ARCH=arm64 declare -g ATFSOURCE='https://github.com/jernejsk/arm-trusted-firmware' declare -g ATF_TARGET_MAP="PLAT=sun55i_a523 DEBUG=1 bl31;;build/sun55i_a523/debug/bl31.bin" declare -g ATFBRANCH="branch:a523" declare -g BOOTSCRIPT='boot-sun50i-next.cmd:boot.cmd' declare -g BOOTDELAY=1 declare -g BOOTSOURCE='https://github.com/jernejsk/u-boot/' declare -g BOOTPATCHDIR="sunxi-dev-${BOOTPATCHDIR:-"u-boot-a523"}" declare -g BOOTBRANCH="${BOOTBRANCH:-"branch:a523"}" declare -g BOOTENV_FILE='sunxi.txt' declare -g UBOOT_TARGET_MAP="${UBOOT_TARGET_MAP:-BINMAN_ALLOW_MISSING=1;;u-boot-sunxi-with-spl.bin}" declare -g OVERLAY_DIR="/boot/dtb/allwinner/overlay" declare -g LINUXFAMILY="sun55iw3" case "${BRANCH}" in dev) declare -g KERNELSOURCE='https://github.com/apritzel/linux' declare -g KERNELBRANCH='branch:a523-v2-WIP' declare -g KERNEL_MAJOR_MINOR="6.12" # Major and minor versions of this kernel. KERNELPATCHDIR="archive/sunxi-dev-${KERNEL_MAJOR_MINOR}" ;; esac family_tweaks() { # execute specific tweaks function if present [[ $(type -t family_tweaks_s) == function ]] && family_tweaks_s cp $SRC/packages/blobs/splash/armbian-u-boot-24.bmp $SDCARD/boot/boot.bmp } write_uboot_platform() { dd if=/dev/zero of=$2 bs=512 count=1023 seek=1 status=noxfer > /dev/null 2>&1 dd if=$1/u-boot-sunxi-with-spl.bin of=$2 bs=512 seek=256 status=noxfer > /dev/null 2>&1 } setup_write_uboot_platform() { local tmp part dev if grep -q "ubootpart" /proc/cmdline; then # mainline with new boot script tmp=$(cat /proc/cmdline) tmp="${tmp##*ubootpart=}" tmp="${tmp%% *}" [[ -n $tmp ]] && part=$(findfs PARTUUID=$tmp 2> /dev/null) [[ -n $part ]] && dev=$(lsblk -n -o PKNAME $part 2> /dev/null) [[ -n $dev ]] && DEVICE="/dev/$dev" else # legacy or old boot script tmp=$(cat /proc/cmdline) tmp="${tmp##*root=}" tmp="${tmp%% *}" [[ -n $tmp ]] && part=$(findfs $tmp 2> /dev/null) [[ -n $part ]] && dev=$(lsblk -n -o PKNAME $part 2> /dev/null) # do not try to write u-boot to USB devices [[ -n $dev && $dev == mmcblk* ]] && DEVICE="/dev/$dev" fi } config/boards/orangepi4a.conf # Allwinner Cortex-A55 octa core SoC BOARD_NAME="Orange Pi 4A" BOARDFAMILY="sun55iw3" BOARD_MAINTAINER="" BOOTCONFIG="orangepi-4a_defconfig" OVERLAY_PREFIX="sun55i-t527" #BOOT_LOGO="desktop" KERNEL_TARGET="dev" patch/kernel/archive/sunxi-dev-6.12/Add-sun55iw3-OrangePi-4A.patch From 0000000000000000000000000000000000000000 Mon Sep 17 00:00:00 2001 From: John Doe <john.doe@somewhere.on.planet> Date: Mon, 24 Feb 2025 21:37:29 -0300 Subject: Add sun55i-t527-orangepi-4a dts file Signed-off-by: John Doe <john.doe@somewhere.on.planet> --- arch/arm64/boot/dts/allwinner/Makefile | 2 + arch/arm64/boot/dts/allwinner/sun55i-t527-orangepi-4a.dts | 375 ++++++++++ 2 files changed, 377 insertions(+) diff --git a/arch/arm64/boot/dts/allwinner/Makefile b/arch/arm64/boot/dts/allwinner/Makefile index 9d5e14695af0..b409e491bf73 100644 --- a/arch/arm64/boot/dts/allwinner/Makefile +++ b/arch/arm64/boot/dts/allwinner/Makefile @@ -53,5 +53,7 @@ dtb-$(CONFIG_ARCH_SUNXI) += sun50i-h700-anbernic-rg35xx-h.dtb dtb-$(CONFIG_ARCH_SUNXI) += sun50i-h700-anbernic-rg35xx-plus.dtb dtb-$(CONFIG_ARCH_SUNXI) += sun50i-h700-anbernic-rg35xx-sp.dtb dtb-$(CONFIG_ARCH_SUNXI) += sun55i-a527-radxa-a5e.dtb dtb-$(CONFIG_ARCH_SUNXI) += sun55i-h728-x96qpro+.dtb dtb-$(CONFIG_ARCH_SUNXI) += sun55i-t527-avaota-a1.dtb +dtb-$(CONFIG_ARCH_SUNXI) += sun55i-t527-orangepi-4a.dtb + diff --git a/arch/arm64/boot/dts/allwinner/sun55i-t527-orangepi-4a.dts b/arch/arm64/boot/dts/allwinner/sun55i-t527-orangepi-4a.dts new file mode 100644 index 000000000000..06046e2555af --- /dev/null +++ b/arch/arm64/boot/dts/allwinner/sun55i-t527-orangepi-4a.dts @@ -0,0 +1,375 @@ +// SPDX-License-Identifier: (GPL-2.0-only OR MIT) +// Copyright (C) 2024 Arm Ltd. + +/dts-v1/; + +#include "sun55i-a523.dtsi" + +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "OrangePi 4A"; + compatible = "xunlong,orangepi-4a", "allwinner,sun55i-t527"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + /* For now, until we have mainline components living in SRAM */ + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + /* 128 KiB reserved for Trusted Firmware-A (BL31). */ + secmon@48000000 { + reg = <0x0 0x48000000 0x0 0x20000>; + no-map; + }; + + /* 256 KiB reserved for the SCP. */ + secmon@48100000 { + reg = <0x0 0x48100000 0x0 0x40000>; + no-map; + }; + }; + + leds: gpio-leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + status = "okay"; + + status_led@0 { + gpios = <&pio 3 20 GPIO_ACTIVE_HIGH>; /* PD20 */ + label = "status_led"; + linux,default-trigger = "heartbeat"; + linux,default-trigger-delay-ms = <0>; + }; + }; + + reg_vcc5v: vcc5v { + /* board wide 5V supply from the 12V->5V regulator */ + compatible = "regulator-fixed"; + regulator-name = "vcc-5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + reg_exxt_vbus: exxt-vbus { + compatible = "regulator-fixed"; + regulator-name = "exxxxt-vbus"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-enable-ramp-delay = <1000>; + gpio = <&r_pio 0 8 GPIO_ACTIVE_HIGH>; + regulator-always-on; + regulator-boot-on; + enable-active-high; + }; + + reg_usb0_vbus: usb0-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb0-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-enable-ramp-delay = <1000>; + gpio = <&r_pio 0 4 GPIO_ACTIVE_HIGH>; + regulator-always-on; + regulator-boot-on; + enable-active-high; + }; + + reg_usb1_vbus: usb1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb1-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-enable-ramp-delay = <1000>; + gpio = <&r_pio 0 12 GPIO_ACTIVE_HIGH>; + regulator-always-on; + regulator-boot-on; + enable-active-high; + }; +}; + +&mmc0 { + vmmc-supply = <®_cldo3>; + vqmmc-supply = <®_cldo1>; + cd-gpios = <&pio 5 6 (GPIO_ACTIVE_LOW | GPIO_PULL_DOWN)>; /* PF6 */ + bus-width = <4>; + max-frequency = <20000000>; + status = "okay"; +}; + +&pio { + vcc-pb-supply = <®_cldo3>; + vcc-pc-supply = <®_cldo1>; + vcc-pd-supply = <®_dcdc4>; + vcc-pe-supply = <®_dcdc4>; + vcc-pf-supply = <®_cldo3>; + vcc-pg-supply = <®_bldo1>; + vcc-ph-supply = <®_cldo3>; + vcc-pi-supply = <®_dcdc4>; + vcc-pj-supply = <®_dcdc4>; + vcc-pk-supply = <®_bldo3>; +}; + +&r_i2c0 { + status = "okay"; + + axp717: pmic@35 { + compatible = "x-powers,axp717"; + reg = <0x35>; + interrupt-controller; + #interrupt-cells = <1>; + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + + vin1-supply = <®_vcc5v>; + vin2-supply = <®_vcc5v>; + vin3-supply = <®_vcc5v>; + vin4-supply = <®_vcc5v>; + aldoin-supply = <®_vcc5v>; + bldoin-supply = <®_vcc5v>; + cldoin-supply = <®_vcc5v>; + + regulators { + /* Supplies the "little" cluster (1.4 GHz cores) */ + reg_dcdc1: dcdc1 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1160000>; + regulator-name = "vdd-cpu0-3"; + }; + + reg_dcdc2: dcdc2 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1160000>; + regulator-name = "vdd-gpu-sys"; + }; + + reg_dcdc3: dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1160000>; + regulator-max-microvolt = <1160000>; + regulator-name = "vdd-dram"; + }; + + reg_dcdc4: dcdc4 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vdd-io"; + }; + + reg_aldo1: aldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "axp2202-aldo1"; + }; + + reg_aldo2: aldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "axp2202-aldo2"; + }; + + reg_aldo3: aldo3 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pl-pm"; + }; + + reg_aldo4: aldo4 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-pll-dxco-avcc"; + }; + + reg_bldo1: bldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-pg-wifi-lvds"; + }; + + reg_bldo2: bldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-dram-1v8"; + }; + + reg_bldo3: bldo3 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-cvp-pk-vid1v8"; + }; + + reg_bldo4: bldo4 { + regulator-always-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "axp2202-bldo4"; + }; + + reg_cldo1: cldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-pc"; + }; + + reg_cldo2: cldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-efuse"; + }; + + reg_cldo3: cldo3 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-mmc-eth-codec"; + }; + + reg_cldo4: cldo4 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "axp2202-cldo4"; + }; + + reg_cpusldo: cpusldo { + /* supplies the management core */ + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-name = "vdd-cpus"; + }; + }; + }; + + axp323: pmic@36 { + compatible = "x-powers,axp323"; + reg = <0x36>; + #interrupt-cells = <1>; + interrupt-controller; + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + status = "okay"; + + vin1-supply = <®_vcc5v>; + vin2-supply = <®_vcc5v>; + vin3-supply = <®_vcc5v>; + + regulators { + /* Supplies the "big" cluster (1.8 GHz cores) */ + reg_dcdc1_323: dcdc1 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1160000>; + regulator-name = "vdd-cpu4-7"; + }; + + reg_dcdc2_323: dcdc2 { + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "axp323-dcdc2"; + }; + + reg_dcdc3_323: dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-name = "vdd-npu"; + }; + + reg_aldo1_323: aldo1 { + regulator-name = "axp323-aldo1"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + reg_dldo1_323: dldo1 { + regulator-name = "axp323-dldo1"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; +}; + +&r_pio { +/* + * Specifying the supply would create a circular dependency. + * + * vcc-pl-supply = <®_aldo3>; + */ + vcc-pm-supply = <®_aldo3>; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pb_pins>; + status = "okay"; +}; + +&ehci0 { + drvvbus-supply = <®_usb0_vbus>; + status = "okay"; +}; + +&ohci0 { + drvvbus-supply = <®_usb0_vbus>; + status = "okay"; +}; + +&ehci1 { + drvvbus-supply = <®_usb1_vbus>; + status = "okay"; +}; + +&ohci1 { + drvvbus-supply = <®_usb1_vbus>; + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; + +&gmac1 { + phy-mode = "rgmii"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&gmac1_pins_default>; + pinctrl-1 = <&gmac1_pins_sleep>; + aw,soc-phy25m; + tx-delay = <1>; + rx-delay = <3>; + dwmac3v3-supply = <®_cldo3>; + phy3v3-supply = <®_cldo3>; + status = "okay"; +}; + +&gmac1_phy0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + reset-gpios = <&pio 8 15 GPIO_ACTIVE_LOW>; + reset-assert-us = <15000>; + reset-deassert-us = <100000>; +}; -- Created with Armbian build tools https://github.com/armbian/build patch/u-boot/sunxi-dev-u-boot-a523/Add-u-boot-OrangePi4A-defconfig.patch From 0000000000000000000000000000000000000000 Mon Sep 17 00:00:00 2001 From: John Doe <john.doe@somewhere.on.planet> Date: Mon, 24 Feb 2025 22:04:53 -0300 Subject: Add u-boot orangepi-4a_defconfig Signed-off-by: John Doe <john.doe@somewhere.on.planet> --- arch/arm/dts/sun55i-t527-orangepi-4a.dts | 375 ++++++++++ configs/orangepi-4a_defconfig | 26 + 2 files changed, 401 insertions(+) diff --git a/arch/arm/dts/sun55i-t527-orangepi-4a.dts b/arch/arm/dts/sun55i-t527-orangepi-4a.dts new file mode 100644 index 0000000000..06046e2555 --- /dev/null +++ b/arch/arm/dts/sun55i-t527-orangepi-4a.dts @@ -0,0 +1,375 @@ +// SPDX-License-Identifier: (GPL-2.0-only OR MIT) +// Copyright (C) 2024 Arm Ltd. + +/dts-v1/; + +#include "sun55i-a523.dtsi" + +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "OrangePi 4A"; + compatible = "xunlong,orangepi-4a", "allwinner,sun55i-t527"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + /* For now, until we have mainline components living in SRAM */ + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + /* 128 KiB reserved for Trusted Firmware-A (BL31). */ + secmon@48000000 { + reg = <0x0 0x48000000 0x0 0x20000>; + no-map; + }; + + /* 256 KiB reserved for the SCP. */ + secmon@48100000 { + reg = <0x0 0x48100000 0x0 0x40000>; + no-map; + }; + }; + + leds: gpio-leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + status = "okay"; + + status_led@0 { + gpios = <&pio 3 20 GPIO_ACTIVE_HIGH>; /* PD20 */ + label = "status_led"; + linux,default-trigger = "heartbeat"; + linux,default-trigger-delay-ms = <0>; + }; + }; + + reg_vcc5v: vcc5v { + /* board wide 5V supply from the 12V->5V regulator */ + compatible = "regulator-fixed"; + regulator-name = "vcc-5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + reg_exxt_vbus: exxt-vbus { + compatible = "regulator-fixed"; + regulator-name = "exxxxt-vbus"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-enable-ramp-delay = <1000>; + gpio = <&r_pio 0 8 GPIO_ACTIVE_HIGH>; + regulator-always-on; + regulator-boot-on; + enable-active-high; + }; + + reg_usb0_vbus: usb0-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb0-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-enable-ramp-delay = <1000>; + gpio = <&r_pio 0 4 GPIO_ACTIVE_HIGH>; + regulator-always-on; + regulator-boot-on; + enable-active-high; + }; + + reg_usb1_vbus: usb1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb1-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-enable-ramp-delay = <1000>; + gpio = <&r_pio 0 12 GPIO_ACTIVE_HIGH>; + regulator-always-on; + regulator-boot-on; + enable-active-high; + }; +}; + +&mmc0 { + vmmc-supply = <®_cldo3>; + vqmmc-supply = <®_cldo1>; + cd-gpios = <&pio 5 6 (GPIO_ACTIVE_LOW | GPIO_PULL_DOWN)>; /* PF6 */ + bus-width = <4>; + max-frequency = <20000000>; + status = "okay"; +}; + +&pio { + vcc-pb-supply = <®_cldo3>; + vcc-pc-supply = <®_cldo1>; + vcc-pd-supply = <®_dcdc4>; + vcc-pe-supply = <®_dcdc4>; + vcc-pf-supply = <®_cldo3>; + vcc-pg-supply = <®_bldo1>; + vcc-ph-supply = <®_cldo3>; + vcc-pi-supply = <®_dcdc4>; + vcc-pj-supply = <®_dcdc4>; + vcc-pk-supply = <®_bldo3>; +}; + +&r_i2c0 { + status = "okay"; + + axp717: pmic@35 { + compatible = "x-powers,axp717"; + reg = <0x35>; + interrupt-controller; + #interrupt-cells = <1>; + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + + vin1-supply = <®_vcc5v>; + vin2-supply = <®_vcc5v>; + vin3-supply = <®_vcc5v>; + vin4-supply = <®_vcc5v>; + aldoin-supply = <®_vcc5v>; + bldoin-supply = <®_vcc5v>; + cldoin-supply = <®_vcc5v>; + + regulators { + /* Supplies the "little" cluster (1.4 GHz cores) */ + reg_dcdc1: dcdc1 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1160000>; + regulator-name = "vdd-cpu0-3"; + }; + + reg_dcdc2: dcdc2 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1160000>; + regulator-name = "vdd-gpu-sys"; + }; + + reg_dcdc3: dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1160000>; + regulator-max-microvolt = <1160000>; + regulator-name = "vdd-dram"; + }; + + reg_dcdc4: dcdc4 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vdd-io"; + }; + + reg_aldo1: aldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "axp2202-aldo1"; + }; + + reg_aldo2: aldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "axp2202-aldo2"; + }; + + reg_aldo3: aldo3 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pl-pm"; + }; + + reg_aldo4: aldo4 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-pll-dxco-avcc"; + }; + + reg_bldo1: bldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-pg-wifi-lvds"; + }; + + reg_bldo2: bldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-dram-1v8"; + }; + + reg_bldo3: bldo3 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-cvp-pk-vid1v8"; + }; + + reg_bldo4: bldo4 { + regulator-always-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "axp2202-bldo4"; + }; + + reg_cldo1: cldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-pc"; + }; + + reg_cldo2: cldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-efuse"; + }; + + reg_cldo3: cldo3 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-mmc-eth-codec"; + }; + + reg_cldo4: cldo4 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "axp2202-cldo4"; + }; + + reg_cpusldo: cpusldo { + /* supplies the management core */ + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-name = "vdd-cpus"; + }; + }; + }; + + axp323: pmic@36 { + compatible = "x-powers,axp323"; + reg = <0x36>; + #interrupt-cells = <1>; + interrupt-controller; + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + status = "okay"; + + vin1-supply = <®_vcc5v>; + vin2-supply = <®_vcc5v>; + vin3-supply = <®_vcc5v>; + + regulators { + /* Supplies the "big" cluster (1.8 GHz cores) */ + reg_dcdc1_323: dcdc1 { + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1160000>; + regulator-name = "vdd-cpu4-7"; + }; + + reg_dcdc2_323: dcdc2 { + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "axp323-dcdc2"; + }; + + reg_dcdc3_323: dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-name = "vdd-npu"; + }; + + reg_aldo1_323: aldo1 { + regulator-name = "axp323-aldo1"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + reg_dldo1_323: dldo1 { + regulator-name = "axp323-dldo1"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; +}; + +&r_pio { +/* + * Specifying the supply would create a circular dependency. + * + * vcc-pl-supply = <®_aldo3>; + */ + vcc-pm-supply = <®_aldo3>; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pb_pins>; + status = "okay"; +}; + +&ehci0 { + drvvbus-supply = <®_usb0_vbus>; + status = "okay"; +}; + +&ohci0 { + drvvbus-supply = <®_usb0_vbus>; + status = "okay"; +}; + +&ehci1 { + drvvbus-supply = <®_usb1_vbus>; + status = "okay"; +}; + +&ohci1 { + drvvbus-supply = <®_usb1_vbus>; + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; + +&gmac1 { + phy-mode = "rgmii"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&gmac1_pins_default>; + pinctrl-1 = <&gmac1_pins_sleep>; + aw,soc-phy25m; + tx-delay = <1>; + rx-delay = <3>; + dwmac3v3-supply = <®_cldo3>; + phy3v3-supply = <®_cldo3>; + status = "okay"; +}; + +&gmac1_phy0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + reset-gpios = <&pio 8 15 GPIO_ACTIVE_LOW>; + reset-assert-us = <15000>; + reset-deassert-us = <100000>; +}; diff --git a/configs/orangepi-4a_defconfig b/configs/orangepi-4a_defconfig new file mode 100644 index 0000000000..5a9422535c --- /dev/null +++ b/configs/orangepi-4a_defconfig @@ -0,0 +1,26 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_SUNXI_ARMV8_32BIT_BUILD=y +CONFIG_DEFAULT_DEVICE_TREE="sun55i-a527-orangepi-4a" +CONFIG_SPL=y +CONFIG_DRAM_SUNXI_DX_ODT=0x07070707 +CONFIG_DRAM_SUNXI_DX_DRI=0x0d0d0d0d +CONFIG_DRAM_SUNXI_CA_DRI=0x0e0e +CONFIG_DRAM_SUNXI_ODT_EN=0x84848484 +CONFIG_DRAM_SUNXI_TPR0=0x80808080 +CONFIG_DRAM_SUNXI_TPR1=0x06060606 +CONFIG_DRAM_SUNXI_TPR6=0x38000000 +CONFIG_DRAM_SUNXI_TPR10=0x802f3333 +CONFIG_DRAM_SUNXI_TPR11=0xc6c4c2c0 +CONFIG_DRAM_SUNXI_TPR12=0x3a373233 +CONFIG_MACH_SUN55I_A523=y +CONFIG_R_I2C_ENABLE=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_I2C=y +CONFIG_SPL_SYS_I2C_LEGACY=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_SYS_I2C_SLAVE=0x7f +CONFIG_SYS_I2C_SPEED=400000 +CONFIG_AXP717_POWER=y +CONFIG_AXP_DCDC2_VOLT=920 +CONFIG_AXP_DCDC3_VOLT=1100 -- Created with Armbian build tools https://github.com/armbian/build patch/u-boot/sunxi-dev-u-boot-a523/Fix-uboot-sun55iw3-orangepi4a.patch From 0000000000000000000000000000000000000000 Mon Sep 17 00:00:00 2001 From: John Doe <john.doe@somewhere.on.planet> Date: Mon, 24 Feb 2025 23:29:02 -0300 Subject: Fix u-boot sun55iw3-orangepi-4a Signed-off-by: John Doe <john.doe@somewhere.on.planet> --- arch/arm/dts/sun55i-t527-orangepi-4a.dts | 21 ---------- configs/orangepi-4a_defconfig | 2 +- 2 files changed, 1 insertion(+), 22 deletions(-) diff --git a/arch/arm/dts/sun55i-t527-orangepi-4a.dts b/arch/arm/dts/sun55i-t527-orangepi-4a.dts index 06046e2555..d6e291c3b1 100644 --- a/arch/arm/dts/sun55i-t527-orangepi-4a.dts +++ b/arch/arm/dts/sun55i-t527-orangepi-4a.dts @@ -350,26 +350,5 @@ }; &usbphy { status = "okay"; }; - -&gmac1 { - phy-mode = "rgmii"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&gmac1_pins_default>; - pinctrl-1 = <&gmac1_pins_sleep>; - aw,soc-phy25m; - tx-delay = <1>; - rx-delay = <3>; - dwmac3v3-supply = <®_cldo3>; - phy3v3-supply = <®_cldo3>; - status = "okay"; -}; - -&gmac1_phy0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <1>; - reset-gpios = <&pio 8 15 GPIO_ACTIVE_LOW>; - reset-assert-us = <15000>; - reset-deassert-us = <100000>; -}; diff --git a/configs/orangepi-4a_defconfig b/configs/orangepi-4a_defconfig index 5a9422535c..10901edfc7 100644 --- a/configs/orangepi-4a_defconfig +++ b/configs/orangepi-4a_defconfig @@ -1,9 +1,9 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_SUNXI_ARMV8_32BIT_BUILD=y -CONFIG_DEFAULT_DEVICE_TREE="sun55i-a527-orangepi-4a" +CONFIG_DEFAULT_DEVICE_TREE="sun55i-t527-orangepi-4a" CONFIG_SPL=y CONFIG_DRAM_SUNXI_DX_ODT=0x07070707 CONFIG_DRAM_SUNXI_DX_DRI=0x0d0d0d0d CONFIG_DRAM_SUNXI_CA_DRI=0x0e0e CONFIG_DRAM_SUNXI_ODT_EN=0x84848484 -- Created with Armbian build tools https://github.com/armbian/build Those were the changes I made, I don't have the board to be able to test and try to repair the compilation, if someone has the board and can make the missing changes maybe this will help. You need to clone the following repository to apply the above changes: https://github.com/juanesf/build.git Edited February 28 by JuanEsf 0 Quote
