Hi
Providing logs with
PASTE_SERVER_HOST=paste.armbian.de armbianmonitor -u
 helps with troubleshooting and significantly raises chances that issue gets addressed.
Hi Pet,
The axp209 modules should already be loaded by default, if not then they should at least be included in the kernel. This is the pmic onboard the cubietruck. Are you using a lipo or coin cell for rtc? You can check the current state by look at '/sys/bus/i2c/devices/i2c-x/x-0034/battery. Replace x with the i2c bus that the axp209 is assigned to. Normally this should be 0 but not always the case. For example this it what it looks like on my device:
[    2.973703] axp20x-i2c 1-0034: AXP20x variant AXP209 found
[    2.981221] input: axp20x-pek as /devices/platform/soc/1c2ac00.i2c/i2c-1/1-0034/axp20x-pek/input/input0
[    3.000378] axp20x-i2c 1-0034: Backup (RTC) battery charging is disabled
[    3.000562] axp20x-i2c 1-0034: AXP20X driver loaded
[    5.367992] axp20x-gpio axp20x-gpio: DMA mask not set
[    5.382424] axp20x-gpio axp20x-gpio: AXP209 pinctrl and GPIO driver loaded
[   21.124944] axp20x-adc axp20x-adc: DMA mask not set
best of luck
Ryzer
Your answers are pretty much appreciated, and i would like to thank you for all the good work for the last 15 years @armbian.com. But, i would like to have a system that is more stable than (the last more or less two years) armbian on cubie* or friendlyarm SBCs just right now. I do need a stable OS which is able to serve pihole or other base network stuff constantly.
Something like
dpkg-deb (subprocess): decompressing archive '/tmp/apt-dpkg-install-mzEu51/7-linux-image-current-sunxi64_25.11.0-trunk.41_arm64.deb' (size=38908852) member 'data.tar': lzma error: compressed data is corrupt
dpkg-deb: error: <decompress> subprocess returned error exit status 2
dpkg: error processing archive /tmp/apt-dpkg-install-mzEu51/7-linux-image-current-sunxi64_25.11.0-trunk.41_arm64.deb (--unpack):
 cannot copy extracted data for './lib/modules/6.12.35-current-sunxi64/kernel/drivers/hwmon/w83781d.ko' to '/lib/modules/6.12.35-current-sunxi64/kernel/drivers/hwmon/w83781d.ko.dpkg-new': unexpected end of file or stream
...leading to a system that is not able to boot anymore (this is today's log of 'armbian-upgrade' on a NanoPI Neo+2) makes me think about asking you if i could provide some time to test your community builds and upgrades before they will be released to the public (-:
 Cheers
