TonyMac32 Posted December 24, 2017 Posted December 24, 2017 Well, not knowing the exact pedigree of the board I have (donated) I haven't completely trusted all the things it does, so please report any and all "strange things", that will verify anything I may have seen, and I can make a list to work on in the spare time. The memory issue would obviously be of primary interest.
eugene Posted December 24, 2017 Posted December 24, 2017 Maybe you know link for the latest version NanoPi K2's kernel source code? I want try to make own OS Image. I recently bought this device and are now trying to use all its functions, but without success. If one function works, then not works another. )
eugene Posted December 24, 2017 Posted December 24, 2017 ок. If i'll find bugs, then will write to you
TonyMac32 Posted December 24, 2017 Posted December 24, 2017 GitHub.com/armbian/build will let you build kernel images that work with the Armbian distro (outputs Deb packages), and that way you can also generate patches. Look at docs.armbian.com for details on the options of the build system. For friendlyArm, they have their own GitHub I don't have the link to off the top of my head.
wikrie Posted January 23, 2018 Posted January 23, 2018 (edited) I have the exact same issue as Eugen had. my RAM is only shown 844M instead of 2GB. I try to find a reason for this but I cannot find any. Maybe somebody has a tip for me? I only try to get a working Linux with Kodi and remote control, but it seams to be unsolvable with NanoPi k2 free -m total used free shared buff/cache available Memory: 844 552 75 43 215 154 Swap: 422 204 217 br wikrie On 12/24/2017 at 7:35 PM, eugene said: Аnyone knows, where is 2GB of RAM on K2 with Armbian_5.37_Nanopik2_Ubuntu_xenial_next_4.14.5_desktop images ?? Device is very slow ! MB values aev@nanopik2:~$ free -m total used free shared buff/cache available Memory: 844 552 75 43 215 154 Swap: 422 204 217 Expand I have exact the same issue, any hints? Edited January 23, 2018 by wikrie add free -m
eugene Posted January 23, 2018 Posted January 23, 2018 Wikrie. Try to use Armbian_5.27_NanoPiK2_Ubuntu_xenial_3.14.29_mate_KODI_20170702.img
TonyMac32 Posted January 24, 2018 Posted January 24, 2018 This is a u-boot issue I believe that I haven't gotten to fixing. Remember K2 is WIP, so it's not always on the top of the list. hopefully I can move these to a mainline u-boot sooner rather than later... [edit] Found it, the p201 board def I copied defines the RAM as 1 GB, fixing/testing quickly. _ _ _ _ ______ | \ | | __ _ _ __ ___ _ __ (_) | |/ /___ \ | \| |/ _` | '_ \ / _ \| '_ \| | | ' / __) | | |\ | (_| | | | | (_) | |_) | | | . \ / __/ |_| \_|\__,_|_| |_|\___/| .__/|_| |_|\_\_____| |_| Welcome to ARMBIAN 5.35 user-built Ubuntu 16.04.3 LTS 4.14.2-meson64 System load: 0.11 0.30 0.16 Up time: 3 min Memory usage: 13 % of 1850MB IP: 169.254.12.141 10.0.0.40 Usage of /: 20% of 30G [ 0 security updates available, 78 updates total: apt upgrade ] Last check: 2017-12-13 23:13 Last login: Thu Dec 21 02:15:11 2017 I'll get that updated in the build system.
TonyMac32 Posted January 24, 2018 Posted January 24, 2018 Until the build system makes new packages, you can take the https://github.com/armbian/build/blob/master/packages/blobs/meson/u-boot-nanopik2.bin and stuff it into your current SD card. Make sure your SD card is your SD card or you could wreck your host machine. <--- don't say I didn't warn you, some assembly required (seriously, don't overwrite your computer's boot sector) # sudo dd if=fip/u-boot-nanopik2.bin of=/dev/<your SD Card> conv=fsync,notrunc bs=1 count=444 # sudo dd if=fip/u-boot-nanopik2.bin of=/dev/<your SD Card> conv=fsync,notrunc bs=512 skip=1 seek=1 # sync 1
wikrie Posted January 24, 2018 Posted January 24, 2018 On 1/23/2018 at 11:28 PM, eugene said: Wikrie. Try to use Armbian_5.27_NanoPiK2_Ubuntu_xenial_3.14.29_mate_KODI_20170702.img Expand THanks eugene but I cannot find the image under https://dl.armbian.com/nanopik2/ So where can I get this?
wikrie Posted January 24, 2018 Posted January 24, 2018 On 1/24/2018 at 5:38 AM, TonyMac32 said: Until the build system makes new packages, you can take the https://github.com/armbian/build/blob/master/packages/blobs/meson/u-boot-nanopik2.bin and stuff it into your current SD card. Make sure your SD card is your SD card or you could wreck your host machine. <--- don't say I didn't warn you, some assembly required (seriously, don't overwrite your computer's boot sector) # sudo dd if=fip/u-boot-nanopik2.bin of=/dev/<your SD Card> conv=fsync,notrunc bs=1 count=444 # sudo dd if=fip/u-boot-nanopik2.bin of=/dev/<your SD Card> conv=fsync,notrunc bs=512 skip=1 seek=1 # sync Expand many thanks your hotfix works, I now see my full ram 1,8GB, so now I can start testing ...
eugene Posted January 24, 2018 Posted January 24, 2018 On 1/24/2018 at 8:48 AM, wikrie said: THanks eugene but I cannot find the image under https://dl.armbian.com/nanopik2/ So where can I get this? Expand https://cloud.mail.ru/public/Eq1q/YQdunFMhv To start WiFi do this in terminal: 1. su - (enter the root password) 2. modprobe wifi_dummy P.S. This image is so old You can follow the recommendations by TonyMac32, Balbes150. 1
eugene Posted January 24, 2018 Posted January 24, 2018 On 1/24/2018 at 10:19 AM, wikrie said: did you get the remote controle working? Expand I haven't remote control
wikrie Posted January 24, 2018 Posted January 24, 2018 but you have a NanoPiK2? without remote control? thats strange. Could anybody else gave me a hint how to activate the Friendlyarm RC-100, as I know the use this RC for several NanoPi's.
eugene Posted January 25, 2018 Posted January 25, 2018 A quick test Armbian_5.37_Nanopik2_Ubuntu_xenial_next_4.14.5_desktop.7z revealed the WiFi instability. Connection involved, but the data transfer is unstable. The signal level to 40%, with a connection IPEX antenna signal level above 70%, but the transfer data is present, then no.
Igor Posted January 25, 2018 Posted January 25, 2018 On 1/25/2018 at 10:15 AM, eugene said: but the transfer data is present, then no. Expand This chip is actually quite reliable. Is perhaps power management turned on? This has huge impact. Type: iwconfig
eugene Posted January 25, 2018 Posted January 25, 2018 Thanks Igor for advice. I didn't change power management. I will try
eugene Posted January 25, 2018 Posted January 25, 2018 aev@nanopik2:~$ iwconfig eth0 no wireless extensions. wlan0 no wireless extensions. dummy0 no wireless extensions. lo no wireless extensions. in Interfaces file, i added line 'wireless-power off', but no result. Wifi working 1-3 sec, then no load data, then load data again.
Igor Posted January 25, 2018 Posted January 25, 2018 It should look like this: Reveal hidden contents iwconfig lo no wireless extensions. eth0 no wireless extensions. wlan0 IEEE 802.11 ESSID:off/any Mode:Managed Access Point: Not-Associated Tx-Power=31 dBm Retry short limit:7 RTS thr:off Fragment thr:off Encryption key:off Power Management:on Than: iwconfig wlan0 power off results in: Reveal hidden contents iwconfig lo no wireless extensions. eth0 no wireless extensions. wlan0 IEEE 802.11 ESSID:off/any Mode:Managed Access Point: Not-Associated Tx-Power=31 dBm Retry short limit:7 RTS thr:off Fragment thr:off Encryption key:off Power Management:off Most likely kernel configuration also need some work.
eugene Posted January 25, 2018 Posted January 25, 2018 aev@nanopik2:~$ iwconfig wlan0 power off Error for wireless request "Set Power Management" (8B2C) : SET failed on device wlan0 ; Invalid argument.
TonyMac32 Posted January 25, 2018 Posted January 25, 2018 Hmmmm, I will test this tonight, I have been running exclusively on wifi (need a larger switch), and have not ha any issues dropping the network. I'll try to exercise it more fully.
eugene Posted January 25, 2018 Posted January 25, 2018 Maybe it's a hardware issue? Although the truncated version RAM image, wifi worked well.
eugene Posted January 25, 2018 Posted January 25, 2018 I installed a vendor's OS android to test the performance of Wi-Fi. It works fine, but within a radius of 2 meters from the router. ) Within a range of 4 meters or more starts unstable work Wi-Fi. Who tested the wifi working range ? However, with the image OS (Armbian_5.37_Nanopik2_Ubuntu_xenial_next_4.14.5_desktop ) i-Fi works with breaks even within a radius of 1 meter.
eugene Posted January 25, 2018 Posted January 25, 2018 I re-mounted the image. And wifi started to work fine even in a radius of 6 meters. Very strange!
TonyMac32 Posted January 26, 2018 Posted January 26, 2018 Well, I didn't copy the image to the root directory of the card, I just did it from the host PC. As long as you wrote it to the device and not to a partition (so /dev/sd(x) and not /dev/sd(x)1 ) that should be it, I followed it moments before posting it the other night.
eugene Posted January 26, 2018 Posted January 26, 2018 Ок. I misunderstood your post "and stuff it into your current SD card." I Deleted my previos post that would not be problems from other users. Board K2 still works with WiFi. Other test will try tomorrow. Thanks for you job.
