pkfox Posted February 7, 2025 Posted February 7, 2025 (edited) I've recently used armbian-install to enable booting from my nvme/ssd drive and all appears to be working fine. However, I'm curious to know, why, the device is mounted twice as shown below. The / mount point is in /etc/fstab but where/how does the device get mounted again on /var/log.hdd. mount|grep nvme /dev/nvme0n1p1 on / type ext4 (rw,noatime,errors=remount-ro,commit=120) /dev/nvme0n1p1 on /var/log.hdd type ext4 (rw,noatime,errors=remount-ro,commit=120) Edited February 7, 2025 by pkfox added text 0 Quote
Werner Posted February 8, 2025 Posted February 8, 2025 I think this is part of the ramlog service. To reduce wear on microsd cards stuff is logged into memory and periodically written to sd. Since you are using a nvme this can be disabled. Check /etc/default/armbian-... files. 0 Quote
