kisso Posted February 15, 2025 Posted February 15, 2025 I need to turn off the pwr_led light under the armbian system, thank! 0 Quote
specs Posted February 15, 2025 Posted February 15, 2025 It largely depends on the system. A simple "echo 0 > /sys/devices/platform/leds/leds/system-led/brightness" will kill the heartbeat on a T6. (The heartbeat itself is activated in the DTB.) The other leds should available along the same path (user_led, etc.). NB I have found no other way of restoring the heartbeat than rebooting. 0 Quote
Werner Posted February 16, 2025 Posted February 16, 2025 As mentioned it might be possible or not. Depends on board. Check /sys for keywords led and trigger. cat the trigger file/s to get an idea what values it accepts. 0 Quote
Solution Torte Posted February 17, 2025 Solution Posted February 17, 2025 I wrote a small guide for customizing the status LED's behaviour on the MKS-Klipad50 board. The available LEDs and their names in "/sys/class/leds/" will be different on other boards, but the general behaviour should be the same. Just make sure to change the filenames like "firefly:blue:user" in the examples to those available on your system. 0 Quote
kisso Posted February 18, 2025 Author Posted February 18, 2025 Below is the brightness file I found in the /sys folder. Unfortunately, I can't turn off the pwr_led light no matter what I try. I have been able to turn off the light on devices such as raspberry 3b and king3399 before, so I don't know if it is a system problem? # root @ nanopct4 in /sys [12:13:15] $ find . -name "*brightness*" ./devices/platform/gpio-leds/leds/status_led/brightness ./devices/platform/gpio-leds/leds/status_led/max_brightness ./devices/platform/fe330000.mmc/leds/mmc2::/brightness ./devices/platform/fe330000.mmc/leds/mmc2::/max_brightness 0 Quote
Werner Posted February 18, 2025 Posted February 18, 2025 Depends on board. Some vendor hard-wire leds, other allow software control. 0 Quote
Torte Posted February 18, 2025 Posted February 18, 2025 (edited) (Please ignore, this doesn't apply to the NanoPC T4) You can try if the LEDs show up after "sudo modprobe pinctrl-rk805". The switch from rockchip64 kernel 6.6.x to 6.12.x included a change that made the "pinctrl-rk805" being built as a module instead of compiled-in. That module does not get autoloaded, so it has to be added to /etc/modules. On the Klipad50, the gpio-leds are attached to the rk805 gpio bank, which is not known to the system without that kernel module. Only after loading that module, the LEDs appeared under /sys/class/leds and started working. Edit: - Board is NanoPC T4 - sorry, I haven't seen the label - The NanoPC T4 does not have the rk805 controller, so this posting does not apply. Edit#2: Do "sudo gpioset 0 13=1" or "sudo gpioset 0 13=0" change the LED state? Edited February 18, 2025 by Torte 0 Quote
linuxenjoerno Posted March 7 Posted March 7 (edited) I managed to disable heartbeat. I am running HA based on debian trixie and my it was only led i could change to off echo 0 | sudo tee /sys/class/leds/state-led/brightness Edited March 7 by linuxenjoerno 0 Quote
