ThermonuclearBowlOfPetunia Posted February 18, 2025 Posted February 18, 2025 I I'm getting a 502 Bad gateway when I'm trying to run apt update on the http://apt.armbian.com/dists/noble/InRelease repository. I checked the forum and didn't see a server maintenance notice. And the arbianmonitor seems to fail to post the report too. Is there an infrastructure problem? 0 Quote
Werner Posted February 18, 2025 Posted February 18, 2025 Something isn't right, agree. Needs investigation. Until then feel free to use any mirror from here: https://docs.armbian.com/Mirrors/ For armbianmonitor you can use this workaround until we can get that one properly back up too: PASTE_SERVER_HOST=paste.armbian.de armbianmonitor -u paste.armbian.eu works too. 0 Quote
Solution Werner Posted February 18, 2025 Solution Posted February 18, 2025 please test again. 0 Quote
ThermonuclearBowlOfPetunia Posted February 18, 2025 Author Posted February 18, 2025 The problem is fixed thanks ! 0 Quote
VerAS Posted February 19, 2025 Posted February 19, 2025 (edited) Hi @Werner, I have the same problem (beta.armbian.com 502 Bad Gateway [IP: 130.185.239.78 80]) Скрытый текст <RockPi4c_root WLAN>/$ apt upgrade -y Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: linux-headers-current-rockchip64 1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 14.6 MB of archives. After this operation, 16.4 kB of additional disk space will be used. Ign:1 http://beta.armbian.com bookworm/main arm64 linux-headers-current-rockchip64 arm64 25.5.0-trunk.80 Ign:1 http://beta.armbian.com bookworm/main arm64 linux-headers-current-rockchip64 arm64 25.5.0-trunk.80 Ign:1 http://beta.armbian.com bookworm/main arm64 linux-headers-current-rockchip64 arm64 25.5.0-trunk.80 Err:1 http://beta.armbian.com bookworm/main arm64 linux-headers-current-rockchip64 arm64 25.5.0-trunk.80 502 Bad Gateway [IP: 130.185.239.78 80] E: Failed to fetch http://beta.armbian.com/pool/main/l/linux-headers-current-rockchip64/linux-headers-current-rockchip64_25.5.0-trunk.80_arm64__6.12.15-S9843-D7b0b-P5113-C67e9H02eb-HK01ba-Vc222-B8de6-R448a.deb 50 2 Bad Gateway [IP: 130.185.239.78 80] E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? Скрытый текст <RockPi4c_root WLAN>/$ apt-get update -y --fix-missing Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian bookworm-updates InRelease Hit:3 http://security.debian.org bookworm-security InRelease Hit:4 http://deb.debian.org/debian bookworm-backports InRelease Hit:5 https://github.armbian.com/configng stable InRelease Ign:6 http://beta.armbian.com bookworm InRelease Ign:6 http://beta.armbian.com bookworm InRelease Ign:6 http://beta.armbian.com bookworm InRelease Err:6 http://beta.armbian.com bookworm InRelease 502 Bad Gateway [IP: 130.185.239.78 80] Reading package lists... Done W: Failed to fetch http://beta.armbian.com/dists/bookworm/InRelease 502 Bad Gateway [IP: 130.185.239.78 80] W: Some index files failed to download. They have been ignored, or old ones used instead. Edited February 19, 2025 by Alexandr Vereschak added apt-get update 0 Quote
