wildcat_paris Posted December 19, 2015 Posted December 19, 2015 Hello, I am using for the first time a cable Neuftech PL2303HX I was looking @ lamobo-r1.fex file and cannot figure out which pins are the default uart for boot-up (not skilled enough yet) both links mention P13 as default, but I cannot get any messages from USB-uart cable (double checked UART RX & TX + ground) http://linux-sunxi.org/Lamobo_R1 http://www.bananapi.com/index.php/component/content/article?layout=edit&id=59 Thanks!
Tido Posted December 20, 2015 Posted December 20, 2015 Hi, If I remember correctly wanted TK look at the boot up from R1 (couple months ago) - shortly after he returned, complaining there is no UART
wildcat_paris Posted December 20, 2015 Author Posted December 20, 2015 ok, thanks @tkaiser @Igor @Tido Reading http://linux-sunxi.org/LeMaker_Banana_Pi on the lamobo-r1 with "Armbian 5.00 mainline kernel 4.3.3" sudo /sbin/agetty --keep-baud 115200 38400 9600 ttyS0 vt220 using putty on my Trusty-based PC with Prolific cable serial /dev/ttyUSB0 115200 now creating my /etc/init/ttyS0.conf Et voilà merci à tous.
