David N Posted May 13 Posted May 13 (edited) I recently bought an orange pi plus and am using the armbian 6.12 server (https://dl.armbian.com/orangepi5-plus/Noble_current_server) I'm wanting to setup hardware acceleration for jellyfin but having trouble with the right steps. I'm using jellyfin inside docker on the orange pi inside armbian. I've found various tutorials but it seems like some of them reference things that no longer exist (like panfork seems to no longer be needed for latest mesa if I'm understanding correctly?), so wanting to see what I need to do to set this up. So it seems like I need to disable panthor and use mali instead, but I can't find in the armbian config menu the option to do that, and not sure if I know how to get the right mali. Any help would be greatly appreciated. armbianmonitor is at https://paste.armbian.com/nurazajipu I've seen these tutorials/posts for reference: * https://akashrajpurohit.com/blog/setup-jellyfin-with-hardware-acceleration-on-orange-pi-5-rockchip-rk3558/ * https://github.com/andyshrk/mesa/blob/panthor-v4/Panfrost-build-howto.md * https://forum.jellyfin.org/t-solved-hw-transcoding-rk3588-arch-not-working?pid=54084 * `https://forum.armbian.com/topic/49115-how-to-install-opencl-on-orangepi-5-plus/` * https://forum.jellyfin.org/t-rockchip-transcode-missing-dev-mali0 Edited May 13 by David N 0 Quote
David N Posted May 14 Author Posted May 14 I did not realize there was a forum for orange pi plus, might be better there? https://forum.armbian.com/forum/250-orange-pi-5-plus/ 0 Quote
Werner Posted May 14 Posted May 14 moved You are using the wrong kernel branch. You need vendor 6.1.y kernel. This is also mentioned in the official documentation of Jellyfin. 0 Quote
David N Posted May 14 Author Posted May 14 (edited) Thanks for the response! For the kernel switch, is it using armbian-config to pick under my current installation? linux-image-vendor-rk35xx=25.2.3 v6.1.99 Is there anything else I need to do as well? Thanks! Edited May 14 by David N 0 Quote
Solution Werner Posted May 14 Solution Posted May 14 I don't think so. You can check in /boot/armbianEnv.txt if there is panthor overlay enabled. If so, disable it so you can use the proprietary mali blobs. 0 Quote
David N Posted May 14 Author Posted May 14 Thanks for the help! Switching to that kernel was enough to allow me to turn on transcoding after I mounted the proper /dev stuff to the docker container. Before I did this, transcoding just immediately crashed. Now I can see it working and it also looks to be using alot mess CPU as well, showing it's using the hardware. 0 Quote
Gian Luca Posted Monday at 04:14 PM Posted Monday at 04:14 PM Hi. My question is the same: how to set up mali hardware acceleration. I just disabled the panthor-gpu devicetree overlay via armbian-config, but the dmesg kernel messages don't contain strings like mail. I also looked for panthor string (after the proper enable procedure via armbian-config) but with no success. Do I need a specific kernel ? The running version is 6.1.115-vendor-rk35xx 0 Quote
Werner Posted 9 hours ago Posted 9 hours ago On 10/27/2025 at 5:14 PM, Gian Luca said: how to set up mali hardware acceleration Have you installed the proprietary mali blobs? https://github.com/tsukumijima/libmali-rockchip/releases/download/v1.9-1-2131373/libmali-valhall-g610-g24p0-gbm_1.9-1_arm64.deb 0 Quote
