armbuilder Posted Tuesday at 03:08 AM Posted Tuesday at 03:08 AM FYI latest image for rock 5B+ in downloads section is broken (Armbian_25.5.1_Rock-5b-plus_noble_vendor_6.1.115_gnome_desktop) Wont boot at all, previous 25.2.2 images works fine. 0 Quote
Werner Posted Tuesday at 03:47 AM Posted Tuesday at 03:47 AM 39 minutes ago, armbuilder said: Wont boot at all https://debug.armbian.de 0 Quote
Igor Posted Tuesday at 03:34 PM Posted Tuesday at 03:34 PM Yeah, it was reported at GH too: https://github.com/armbian/build/issues/8227 Probably related: https://github.com/armbian/build/issues/8269 No solution yet. 0 Quote
armbuilder Posted Tuesday at 05:48 PM Author Posted Tuesday at 05:48 PM Are platinum supported boards not tested on actual hardware before posting images? FYI we are on of radxas big partners that paid for the platinum membership so there is better support for this board, not sure if all the USB/wifi related driver issues were fixed? 0 Quote
Igor Posted Tuesday at 07:18 PM Posted Tuesday at 07:18 PM 1 hour ago, armbuilder said: Are platinum supported boards not tested on actual hardware before posting images? Yes, that is the main idea, but sometimes things slipped trough. Images were tested (we aim to have two people on one platinum target to be able to provide better service, but perfection is still not possible), but here we ran into weird problem that CI compilation silently broke on u-boot recompilation, while local build works. We have a problem with build framework / compiler internals, unrelated to this specific hardware and problem only manifest on some u-boot variants. Right now, I don't have a clear picture, but we are working on it. This was introduced while moving framework to Noble, which is mandatory for some targets and there are some Python libraries troubles ... which are sometimes used for u-boot / ATF compile. Its a mess. 1 hour ago, armbuilder said: not sure if all the USB/wifi related driver issues were fixed? Software maintenance within such extreme complexity is job that is never done. Generally speaking. 0 Quote
meco Posted Tuesday at 08:06 PM Posted Tuesday at 08:06 PM 2 hours ago, armbuilder said: not sure if all the USB/wifi related driver issues were fixed 5B+ on vendor (6.1.115) has all I/O related stuff fixed (since 6.1.84) as far as my testing (the one reported in the https://www.armbian.com/rock-5b-plus/ description). Looking into the broken gnome image though and will update here! 0 Quote
meco Posted Wednesday at 03:33 PM Posted Wednesday at 03:33 PM @Igor Just tried with the latest image on https://dl.armbian.com/rock-5b-plus/Noble_vendor_gnome. This 100% works as I had tested, so either @armbuilder has a broken flash storage or had an error while writing to the storage medium. Gnome Desktop is working too 0 Quote
