greg396 Posted July 11, 2025 Posted July 11, 2025 Actual booting from eMMC and system including OMV from Sata SSD. Running boot & system from eMMC should be possible now and I would like to transfer system from SSD to eMMC without losing my config and starting from scratch again. That way I'll have a sdd beside the hdd for OMV. How can I manually transfer the system including OMV from SSD to eMMC and what configuration files need to be altered? 0 Quote
greg396 Posted July 11, 2025 Author Posted July 11, 2025 Dear Werner, I am booting without a sd-card and can use armbian-install with just an option transfering system from ssd to emmc and emmc won't be formatted? Which option should I chose? boot frm emmc / system on emmc? https://docs.armbian.com/User-Guide_Getting-Started/#how-to-install-to-emmc-nand-sata-usb Armbian Installer support those storage scenarios: boot from SD, system on SATA / USB boot from eMMC / NAND, system on eMMC/NAND boot from eMMC / NAND, system on SATA / USB / NVME Boot from SPI - system on SATA, USB or NVMe Install/Update the bootloader on SD/eMMC Install/Update the bootloader on special eMMC partition Install/Update the bootloader on SPI Flash Install system to UEFI disk thank you for clarification! 0 Quote
Werner Posted July 11, 2025 Posted July 11, 2025 1 hour ago, greg396 said: ssd to emmc and emmc won't be formatted? Not possible. emmc will be formatted before rootfs is copied over. If you have files there backup beforehand. Since the rootfs is moved as it is you should not loose any configs. 0 Quote
greg396 Posted July 11, 2025 Author Posted July 11, 2025 I backuped the boot dir. So I don't need booting from Sd-card, armbian-install will format emmc and copy from where the boot dir? Afterward it moves the system to emmc. If I am running armbian-config there's a message "Warning: The current OS (bookworm) is not supported or not listed" it's the latest version "Armbian 21.02.1 stable 6.12.32-current-rockchip64 (Debian bookworm)" apt-get install armbian-config armbian-config is already the newest version (25.8.0-trunk.330.0708.120916) I can't see any option to install/update system 0 Quote
