I am using Armbian 5.30 stable Ubuntu 16.04.2 LTS 3.4.113-sun8i and when I plugged usb grabber with chipset utv007 lsusb shows Bus 002 Device 005: ID 1b71:3002 Fushicai USBTV007 Video Grabber [EasyCAP].
But /dev/video0 is not created.
Please, Is there any hack or module I should load to have it in /dev/video0?
I tried this with Mainline kernel on OPI-PC ( 4.11.7 ), and it works for about 1 minute and locks up the system.
All 4 CPU go to 100%, and Eth0 stops working quickly.
I gave up on it.
Let me clarify.
The device /dev/video0 is created ok.  When I try to use FFMPEG to SW encode the stream,  all 4 CPUs go to 100% and the system locks up, after 1 minute.
R
Because there is no support for it in this kernel and it looks drivers are not very stable in modern kernel either according to @Rosimildo
I don't know if this info is necessary, but that is what I get when I use this grabber to encode some input stream,  OPI-PC :
Linux orangepipc 4.11.7-sun8i #12 SMP Wed Jun 28 13:18:43 CEST 2017 armv7l armv7l armv7l GNU/Linux
Driver loads ok:
[    9.158844] usbtv 4-1:1.0: Fushicai USBTV007 Audio-Video Grabber
[    9.158931] usbcore: registered new interface driver usbtv
root@orangepipc:/opt# ls -l /dev/video0
crw-rw---- 1 root video 81, 0 Oct 13 13:35 /dev/video0
When it crashes:
[  295.258775] INFO: rcu_sched self-detected stall on CPU
[  295.265071]  0-...: (1 GPs behind) idle=6c9/140000000000002/0 softirq=6053/6053 fqs=1031
[  295.273752]   (t=2101 jiffies g=1886 c=1885 q=2148)
[  295.278446] INFO: rcu_sched detected stalls on CPUs/tasks:
[  295.278894]  0-...: (1 GPs behind) idle=6c9/140000000000002/0 softirq=6053/6053 fqs=1031
[  295.278945]  (detected by 1, t=2102 jiffies, g=1886, c=1885, q=2155)
[  295.279400] Sending NMI from CPU 1 to CPUs 0:
[  305.309817] rcu_sched kthread starved for 1003 jiffies! g1886 c1885 f0x0 RCU_GP_DOING_FQS(4) ->state=0x0
[  305.309894] NMI backtrace for cpu 0
[  305.310253] CPU: 0 PID: 138 Comm: kworker/0:3 Not tainted 4.11.7-sun8i #12
[  305.310342] Hardware name: Allwinner sun8i Family
[  305.310717] Workqueue: events dbs_work_handler
[  305.311315] [<c010bad5>] (unwind_backtrace) from [<c01090df>] (show_stack+0xb/0xc)
[  305.311724] [<c01090df>] (show_stack) from [<c0463c39>] (dump_stack+0x69/0x78)
[  305.312121] [<c0463c39>] (dump_stack) from [<c0466117>] (nmi_cpu_backtrace+0x8f/0x90)
[  305.312476] [<c0466117>] (nmi_cpu_backtrace) from [<c04661bb>] (nmi_trigger_cpumask_backtrace+0xa3/0xd8)
[  305.312920] [<c04661bb>] (nmi_trigger_cpumask_backtrace) from [<c019c99b>] (rcu_dump_cpu_stacks+0x75/0x96)
[  305.313418] [<c019c99b>] (rcu_dump_cpu_stacks) from [<c01606c5>] (rcu_check_callbacks+0x415/0x5d0)
[  305.313844] [<c01606c5>] (rcu_check_callbacks) from [<c01628ed>] (update_process_times+0x25/0x44)
[  305.314223] [<c01628ed>] (update_process_times) from [<c016f0f3>] (tick_sched_timer+0x2b/0x54)
[  305.314604] [<c016f0f3>] (tick_sched_timer) from [<c016335b>] (__hrtimer_run_queues+0xd7/0x140)
[  305.314964] [<c016335b>] (__hrtimer_run_queues) from [<c016356f>] (hrtimer_interrupt+0x7b/0x16c)
[  305.315383] [<c016356f>] (hrtimer_interrupt) from [<c05d9527>] (arch_timer_handler_phys+0x1f/0x24)
[  305.315893] [<c05d9527>] (arch_timer_handler_phys) from [<c0159e07>] (handle_percpu_devid_irq+0x4b/0xd8)
[  305.316315] [<c0159e07>] (handle_percpu_devid_irq) from [<c0156c9b>] (generic_handle_irq+0x17/0x20)
[  305.316701] [<c0156c9b>] (generic_handle_irq) from [<c0157057>] (__handle_domain_irq+0x3f/0x80)
[  305.317056] [<c0157057>] (__handle_domain_irq) from [<c0101335>] (gic_handle_irq+0x39/0x6c)
[  305.317382] [<c0101335>] (gic_handle_irq) from [<c0109925>] (__irq_svc+0x65/0x94)
[  305.317515] Exception stack(0xc9c37bd8 to 0xc9c37c20)
[  305.317696] 7bc0:                                                       00000000 40000193
[  305.318015] 7be0: 00000002 00009ad2 edc4b100 60000113 eeb7e400 00000000 eeb7e4d8 ffffe000
[  305.318337] 7c00: 40000000 c0b02080 60000193 c9c37c28 c056c0f7 c0559728 60000133 ffffffff
[  305.318744] [<c0109925>] (__irq_svc) from [<c0559728>] (__usb_hcd_giveback_urb+0x5c/0xd4)
[  305.319164] [<c0559728>] (__usb_hcd_giveback_urb) from [<c0559803>] (usb_giveback_urb_bh+0x63/0x94)
[  305.319580] [<c0559803>] (usb_giveback_urb_bh) from [<c011bb49>] (tasklet_hi_action+0x51/0xbc)
[  305.319984] [<c011bb49>] (tasklet_hi_action) from [<c011bd57>] (__do_softirq+0xa7/0x1a0)
[  305.320370] [<c011bd57>] (__do_softirq) from [<c011c059>] (irq_exit+0x8d/0xdc)
[  305.320757] [<c011c059>] (irq_exit) from [<c015705b>] (__handle_domain_irq+0x43/0x80)
[  305.320896] rcu_sched       R
[  305.321217] [<c015705b>] (__handle_domain_irq) from [<c0101335>] (gic_handle_irq+0x39/0x6c)
[  305.321293]   running task
[  305.321569] [<c0101335>] (gic_handle_irq) from [<c0109925>] (__irq_svc+0x65/0x94)
[  305.321700] Exception stack(0xc9c37d18 to 0xc9c37d60)
[  305.321853]     0     8      2 0x00000000
[  305.322034] 7d00:                                                       00000083 00000001
[  305.322461] [<c06f80c3>] (__schedule) from [<c06f876f>] (preempt_schedule_common+0x13/0x20)
[  305.322856] [<c06f876f>] (preempt_schedule_common) from [<c06f87a3>] (_cond_resched+0x27/0x2c)
[  305.322955] 7d20: fff95200 00004024 f0809000 c09142d4 042c1d80 00000000 10000000 0010624c
[  305.323403] [<c06f87a3>] (_cond_resched) from [<c015fd0f>] (rcu_gp_kthread+0x357/0x6b0)
[  305.323499] 7d40: 610333fe 0000003f 29aa5045 c9c37d6c c04ab0db c0163f8c 60000133 ffffffff
[  305.323850] [<c0109925>] (__irq_svc) from [<c0163f8c>] (ktime_get+0x8/0xbc)
[  305.324230] [<c015fd0f>] (rcu_gp_kthread) from [<c012c639>] (kthread+0xf5/0xfc)
[  305.324646] [<c012c639>] (kthread) from [<c01060f1>] (ret_from_fork+0x11/0x20)
[  305.324902] [<c0163f8c>] (ktime_get) from [<90001810>] (0x90001810)
@Rosimildo, @Igor  (I am posting my reply to this and second thread too) I just wanted to let you know my findings - I tried it with RPi 3 with Raspbian and utv007 works great with the latest release. Maybe drivers could be ported to Armbian - I don't know, this is just idea because I don't have any experience with these driver things.
By the way, If somebody is able to make utv007 work in Armbian, I would like to pay amount I can afford to help this great project and other people, too.
