pininux Posted October 11, 2017 Posted October 11, 2017 Hello to all, I installed Armbian ( legacy kernel ) on my OPI plus 2 H3 but all usb ports not work, only micro usb Otg. I can t use mouse or keyboard someone help me please?
sebby3000 Posted October 12, 2017 Posted October 12, 2017 Hi, I wonder if this is related to the same issue I see on the NanoPi Neo. I seem to be missing the USB connections that NanoPi Neo have on the extension pins with the Armbian 5.32.170704 nightly. root@nanopiair:~# uname -a Linux nanopiair 4.11.5-sun8i #3 SMP Mon Jul 3 02:24:22 CEST 2017 armv7l armv7l armv7l GNU/Linux root@nanopiair:~# lsusb Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub root@nanopiair:~# When I use the FriendlyArm Ubuntu build, then I get the USB port available; root@NanoPi-NEO:~# uname -a Linux NanoPi-NEO 4.11.2 #1 SMP Mon Jul 10 11:06:36 CST 2017 armv7l armv7l armv7l GNU/Linux root@NanoPi-NEO:~# lsusb Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 002: ID 1199:9071 Sierra Wireless, Inc. Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub root@NanoPi-NEO:~# I also tried to install the armbianmonitor, but it seems to fail, but might be something related to this nightly build. root@nanopineo:~# armbianmonitor -r Installing RPi-Monitor. This can take up to 5 minutes. Be patient pleaseE: Unable to locate package rpimonitor /usr/bin/armbianmonitor: line 562: /usr/share/rpimonitor/scripts/updatePackagesStatus.pl: No such file or directory Now patching RPi-Monitor to deal correctly with H3 Now you're able to enjoy RPi-Monitor at http://147.214.54.14:8888 root@nanopineo:~# I have tried to compare the device tree files between FriendlyArm build and Armbian, but can't find anything obvious that would indicate that the USB ports are missing, which makes me believe that it might be something in the kernel config instead. Regards, Sebastian
Igor Posted October 12, 2017 Posted October 12, 2017 Nanopi Neo modern kernel was never released by Armbian. There was only some development builds ... Try recent 4.13.x kernel. https://dl.armbian.com/nanopineo/nightly/ we moved here few days ago and images need testing and minor fixing. If USB is not working it's probably just not enabled in DT.
sebby3000 Posted October 12, 2017 Posted October 12, 2017 1 hour ago, Igor said: Nanopi Neo modern kernel was never released by Armbian. There was only some development builds ... Try recent 4.13.x kernel. https://dl.armbian.com/nanopineo/nightly/ we moved here few days ago and images need testing and minor fixing. If USB is not working it's probably just not enabled in DT. Tested the 4.13.5, and see the same issue there. I checked the DT between FriendlyArm and Mainline, and could only find the one below. (maybe other DT files need to be compared as well) # diff friendlyarm/linux/arch/arm/boot/dts/sun8i-h3-nanopi-neo.dts linux/arch/arm/boot/dts/sun8i-h3-nanopi-neo.dts # diff friendlyarm/linux/arch/arm/boot/dts/sun8i-h3-nanopi.dtsi linux/arch/arm/boot/dts/sun8i-h3-nanopi.dtsi 50d49 < #include <dt-bindings/pinctrl/sun4i-a10.h> # Which include these, #ifndef __DT_BINDINGS_PINCTRL_SUN4I_A10_H_ #define __DT_BINDINGS_PINCTRL_SUN4I_A10_H_ #define SUN4I_PINCTRL_10_MA 0 #define SUN4I_PINCTRL_20_MA 1 #define SUN4I_PINCTRL_30_MA 2 #define SUN4I_PINCTRL_40_MA 3 #define SUN4I_PINCTRL_NO_PULL 0 #define SUN4I_PINCTRL_PULL_UP 1 #define SUN4I_PINCTRL_PULL_DOWN 2 #endif /* __DT_BINDINGS_PINCTRL_SUN4I_A10_H_ */ But I don't know if this is related. -Sebastian
sebby3000 Posted October 12, 2017 Posted October 12, 2017 Found same issue here: So I will test this and get back with results. -Sebastian
pininux Posted October 13, 2017 Author Posted October 13, 2017 Thank You To All, for help, i Temporarily solved changing distro but hope we find soon a solution if is a kernel related bug...
Igor Posted October 13, 2017 Posted October 13, 2017 21 minutes ago, pininux said: i Temporarily solved changing distro but hope we find soon a solution if is a kernel related bug... Opi Zero 2+ does not have USB connectors. If a connector is not there is (usually) disabled by default. It's a matter of user configuration. It's not a bug and it's not related to USB on Nanopi NEO with modern kernel ...
martinayotte Posted October 13, 2017 Posted October 13, 2017 Since there is the possibility of having NAS expansion board on top of OPiZeroPlus2, I think it is a good idea to have USB enabled by default. Last time I've done an OPiZeroPlus2, if I recall, they were already enabled. If not, then, simple overlays could enable them.
zador.blood.stained Posted October 13, 2017 Posted October 13, 2017 We should already have the necessary overlays. IMO it's easier to maintain overlays than to patch every board DTS that doesn't enable external peripherals by default.
tkaiser Posted October 13, 2017 Posted October 13, 2017 On 11.10.2017 at 1:58 PM, pininux said: Armbian ( legacy kernel ) on my OPI plus 2 Legacy kernel (all USB ports enabled on every board) OPi Plus 2 and not Opi Zero 2+ The next time you try it with Armbian please provide output from 'armbianmonitor -u' so we get an idea which OS image you tried.
martinayotte Posted October 13, 2017 Posted October 13, 2017 3 hours ago, tkaiser said: OPi Plus 2 and not Opi Zero 2+ Ok ! I didn't pay attention to the OP, and the thread drifted by talking Opi Zero 2+ ... BTW, I've rebuilt an Opi Zero 2+ image today, and I've figured out that USB were not detect due to the USBPHY not enabled by the overlays... (I will fix that when I get some spare time)
mzb Posted October 14, 2017 Posted October 14, 2017 6 hours ago, martinayotte said: Ok ! I didn't pay attention to the OP, and the thread drifted by talking Opi Zero 2+ ... BTW, I've rebuilt an Opi Zero 2+ image today, and I've figured out that USB were not detect due to the USBPHY not enabled by the overlays... (I will fix that when I get some spare time) Sorry to be OT, but I'd love to see the USB fixed for zero 2+. I tried modifying a .dts file and making .dtb, but I'll need more practice before I have half a clue.
mzb Posted October 14, 2017 Posted October 14, 2017 (edited) 20 hours ago, mzb said: Sorry to be OT, but I'd love to see the USB fixed for zero 2+. I tried modifying a .dts file and making .dtb, but I'll need more practice before I have half a clue. OK, put more effort in and built an image (+1 vote for Debian instead of Ubuntu, btw!) after realising that martinayotte had already made a commit! So, after applying usbhost2+usbhost3 overlays I'm now met with: root@orangepizeroplus2:~# lsusb Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 002: ID 0a5c:2121 Broadcom Corp. BCM2210 Bluetooth Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Thank you! Note: untested functionality [EDIT] ... a few hours later Bluetooth dongle and a uBlox GPS both proven to work on the USB ports (simultaneously). root@zp2:~# lsusb Bus 004 Device 002: ID 0a5c:2121 Broadcom Corp. BCM2210 Bluetooth Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 002: ID 1546:01a8 U-Blox AG Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub and able to cat/gpspipe data from gps to rfcomm serial on bluetooth, so all working. Edited October 14, 2017 by mzb Updated result
