nihilista 3 Posted October 12, 2017 Share Posted October 12, 2017 Just a little question: I'm new with this device, but not with armbian. Tested the Image for HC1 and it works fine, but if i try to boot root filesystem from sata device (using armbian-config, sata install) it didn't boot. Anyone tested that with success? Thx Link to post Share on other sites
Igor 2164 Posted October 12, 2017 Share Posted October 12, 2017 6 minutes ago, nihilista said: but if i try to boot root filesystem from sata device You mean without SD card? Not possible. Link to post Share on other sites
nihilista 3 Posted October 12, 2017 Author Share Posted October 12, 2017 No, not without sdcard. Only with root filesystem on ssd. As i said, i did that with included armbian-config tool(nand-sata-install, boot from sd, rootfilefs on sata), but after reboot i have no access to the device. Don't know whats wrong, files are copied, boot.ini was changed to correct UUID, fstab (on ssd) includes new root, boot binding.... Maybe i have to manually change fstab on sdcard too? Or copy /boot to ssd too? I couldn't see whats wrong here... Link to post Share on other sites
Igor 2164 Posted October 12, 2017 Share Posted October 12, 2017 1 hour ago, nihilista said: Maybe i have to manually change fstab on sdcard too? Or copy /boot to ssd too? I couldn't see whats wrong here... No. It should go well. huh Please provide all possible logs, that we can inspect. I will also try to replicate this ASAP. Exactly which image you were using and which filesystem type did you choose? Link to post Share on other sites
nihilista 3 Posted October 12, 2017 Author Share Posted October 12, 2017 40 minutes ago, Igor said: No. It should go well. huh Please provide all possible logs, that we can inspect. I will also try to replicate this ASAP. Exactly which image you were using and which filesystem type did you choose? I used Armbian_5.33_Odroidxu4_Debian_jessie_next_4.9.51 image, tested with ext4 and btrfs, on GPT and dos partition. I dont have logs (flashed image again and again several times for next try), but after next try i could try to get some, need to mount sdcard on another linux device. Link to post Share on other sites
Igor 2164 Posted October 13, 2017 Share Posted October 13, 2017 I can confirm that we have a problem and I'll take a look into this. Link to post Share on other sites
tkaiser 1640 Posted October 13, 2017 Share Posted October 13, 2017 See also https://forum.armbian.com/index.php?/topic/5104-xu4-next-nand-sata-install-usb-disk-rootfs-not-found/ Link to post Share on other sites
Igor 2164 Posted October 13, 2017 Share Posted October 13, 2017 I recompile from latest sources but the problem remains. Spoiler Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x100 [ 0.000000] Linux version 4.9.54-odroidxu4 (root@armbian) (gcc version 6.4.1 20170707 (Linaro GCC 6.4-2017.08) ) #2 SMP PREEMPT Fri Oct 13 08:23:36 CEST 2017 [ 0.000000] CPU: ARMv7 Processor [410fc073] revision 3 (ARMv7), cr=70c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt:Machine model: Hardkernel Odroid XU4 [ 0.000000] cma: Reserved 128 MiB at 0x00000000b6800000 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] Samsung CPU ID: 0xe5422001 [ 0.000000] On node 0 totalpages: 518656 [ 0.000000] free_area_init_node: node 0, pgdat c1055400, node_mem_map eee25000 [ 0.000000] Normal zone: 1728 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 196608 pages, LIFO batch:31 [ 0.000000] HighMem zone: 322048 pages, LIFO batch:31 [ 0.000000] Running under secure firmware. [ 0.000000] percpu: Embedded 14 pages/cpu @eed7f000 s26700 r8192 d22452 u57344 [ 0.000000] pcpu-alloc: s26700 r8192 d22452 u57344 alloc=14*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 516928 [ 0.000000] Kernel command line: console=tty1 console=ttySAC2,115200n8 consoleblank=0 loglevel=10 panic=10 root=UUID=8db53544-eb20-4ca8-a5df-b96cd720b24c rootfstype=ext4 rootwait rw smsc95xx.macaddr=00:1e:06:61:7a:55 governor=performance hdmi_tx_amp_lvl=31 hdmi_tx_lvl_ch0=3 hdmi_tx_lvl_ch1=3 hdmi_tx_lvl_ch2=3 hdmi_tx_emp_lvl=6 hdmi_clk_amp_lvl=31 hdmi_tx_res=0 HPD=true vout=hdmi usb-storage.quirks= s5p_mfc.mem=16M [ 0.000000] hdmi: using HDMI mode [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 1904252K/2074624K available (8192K kernel code, 344K rwdata, 2332K rodata, 2048K init, 349K bss, 39300K reserved, 131072K cma-reserved, 1157120K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf800000 - 0xbfe00000 ( 6 MB) [ 0.000000] .text : 0xc0008000 - 0xc0a00000 (10208 kB) [ 0.000000] .init : 0xc0e00000 - 0xc1000000 (2048 kB) [ 0.000000] .data : 0xc1000000 - 0xc10563c0 ( 345 kB) [ 0.000000] .bss : 0xc1058000 - 0xc10af56c ( 350 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 0.000000] hperf_hmp: fast CPUs mask: 000000F0 [ 0.000000] hperf_hmp: slow CPUs mask: 0000000F [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 32. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] Switching to timer-based delay loop, resolution 41ns [ 0.000000] clocksource: mct-frc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000007] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns [ 0.001860] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.001880] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.001900] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001914] Ignoring duplicate/late registration of read_current_timer delay [ 0.002141] Console: colour dummy device 80x30 [ 0.003257] console [tty1] enabled [ 0.003299] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=120000) [ 0.003354] pid_max: default: 32768 minimum: 301 [ 0.003581] Security Framework initialized [ 0.003613] AppArmor: AppArmor disabled by boot time parameter [ 0.003695] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.003729] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.004671] CPU: Testing write buffer coherency: ok [ 0.005535] CPU0: update cpu_capacity 551 [ 0.005571] CPU0: thread -1, cpu 0, socket 1, mpidr 80000100 [ 0.005708] Setting up static identity map for 0x40200000 - 0x4020004c [ 0.006397] ARM CCI driver probed [ 0.006642] Exynos MCPM support installed [ 0.090301] CPU1: update cpu_capacity 551 [ 0.090308] CPU1: thread -1, cpu 1, socket 1, mpidr 80000101 [ 0.091211] CPU2: update cpu_capacity 551 [ 0.091218] CPU2: thread -1, cpu 2, socket 1, mpidr 80000102 [ 0.092039] CPU3: update cpu_capacity 551 [ 0.092046] CPU3: thread -1, cpu 3, socket 1, mpidr 80000103 [ 0.092843] CPU4: update cpu_capacity 1496 [ 0.092851] CPU4: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.093898] CPU5: update cpu_capacity 1496 [ 0.093905] CPU5: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.094806] CPU6: update cpu_capacity 1496 [ 0.094812] CPU6: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.095638] CPU7: update cpu_capacity 1496 [ 0.095645] CPU7: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.095749] Brought up 8 CPUs [ 0.095966] SMP: Total of 8 processors activated (384.00 BogoMIPS). [ 0.095988] CPU: All CPU(s) started in HYP mode. [ 0.096007] CPU: Virtualization extensions available. [ 0.096709] devtmpfs: initialized [ 0.122370] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0 [ 0.122572] hperf_hmp: registered cpufreq transition notifier [ 0.122737] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 9556302231375000 ns [ 0.122778] futex hash table entries: 2048 (order: 5, 131072 bytes) [ 0.125359] xor: measuring software checksum speed [ 0.174955] arm4regs : 1540.800 MB/sec [ 0.224955] 8regs : 1163.200 MB/sec [ 0.274957] 32regs : 1132.000 MB/sec [ 0.324955] neon : 2241.600 MB/sec [ 0.324976] xor: using function: neon (2241.600 MB/sec) [ 0.325079] pinctrl core: initialized pinctrl subsystem [ 0.326941] NET: Registered protocol family 16 [ 0.329362] DMA: preallocated 1024 KiB pool for atomic coherent allocations [ 0.344254] cpuidle: using governor menu [ 0.360371] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.360405] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.370233] exynos-audss-clk 3810000.audss-clock-controller:: epll 180633609 [ 0.372135] iommu: Adding device 10850000.g2d: to group 0 [ 0.378411] iommu: Adding device 11000000.codec: to group 1 [ 0.403457] iommu: Adding device 14450000.mixer: to group 2 [ 0.403949] iommu: Adding device 11c00000.rotator: to group 3 [ 0.408461] iommu: Adding device 13e00000.video-scaler: to group 4 [ 0.408936] iommu: Adding device 13e10000.video-scaler: to group 5 [ 0.409429] iommu: Adding device 11f50000.jpeg: to group 6 [ 0.409909] iommu: Adding device 11f60000.jpeg: to group 7 [ 0.410244] EXYNOS5420 PMU initialized [ 0.525046] raid6: int32x1 gen() 178 MB/s [ 0.609981] raid6: int32x1 xor() 184 MB/s [ 0.695054] raid6: int32x2 gen() 276 MB/s [ 0.779984] raid6: int32x2 xor() 235 MB/s [ 0.865114] raid6: int32x4 gen() 337 MB/s [ 0.950055] raid6: int32x4 xor() 261 MB/s [ 1.035011] raid6: int32x8 gen() 396 MB/s [ 1.120063] raid6: int32x8 xor() 246 MB/s [ 1.205009] raid6: neonx1 gen() 721 MB/s [ 1.279983] random: fast init done [ 1.289989] raid6: neonx1 xor() 626 MB/s [ 1.374976] raid6: neonx2 gen() 1031 MB/s [ 1.459976] raid6: neonx2 xor() 958 MB/s [ 1.544993] raid6: neonx4 gen() 1400 MB/s [ 1.629987] raid6: neonx4 xor() 1000 MB/s [ 1.715014] raid6: neonx8 gen() 1289 MB/s [ 1.799990] raid6: neonx8 xor() 937 MB/s [ 1.800011] raid6: using algorithm neonx4 gen() 1400 MB/s [ 1.800031] raid6: .... xor() 1000 MB/s, rmw enabled [ 1.800051] raid6: using intx1 recovery algorithm [ 1.801802] SCSI subsystem initialized [ 1.802082] usbcore: registered new interface driver usbfs [ 1.802166] usbcore: registered new interface driver hub [ 1.802331] usbcore: registered new device driver usb [ 1.803012] i2c-gpio soc:i2c-hdmi:: using pins 177 (SDA) and 178 (SCL) [ 1.803600] s3c-i2c 12c70000.i2c:: slave address 0x00 [ 1.803629] s3c-i2c 12c70000.i2c:: bus frequency set to 378 KHz [ 1.803912] s3c-i2c 12c70000.i2c:: i2c-1: S3C I2C adapter [ 1.804351] media: Linux media interface: v0.10 [ 1.804417] Linux video capture interface: v2.00 [ 1.804833] s3c2410-wdt 101d0000.watchdog:: watchdog inactive, reset disabled, irq disabled [ 1.805632] Advanced Linux Sound Architecture Driver Initialized. [ 1.806279] NetLabel: Initializing [ 1.806301] NetLabel: domain hash size = 128 [ 1.806320] NetLabel: protocols = UNLABELED CIPSOv4 [ 1.806388] NetLabel: unlabeled traffic allowed by default [ 1.807339] clocksource: Switched to clocksource mct-frc [ 1.807531] VFS: Disk quotas dquot_6.6.0 [ 1.807612] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 1.821878] NET: Registered protocol family 2 [ 1.822566] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 1.822659] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 1.822829] TCP: Hash tables configured (established 8192 bind 8192) [ 1.822893] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 1.822944] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 1.823176] NET: Registered protocol family 1 [ 1.823711] RPC: Registered named UNIX socket transport module. [ 1.823736] RPC: Registered udp transport module. [ 1.823756] RPC: Registered tcp transport module. [ 1.823777] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.823995] Trying to unpack rootfs image as initramfs... [ 2.090407] Freeing initrd memory: 4448K [ 2.090850] kvm [1]: 8-bit VMID [ 2.090871] kvm [1]: IDMAP page: 40201000 [ 2.090892] kvm [1]: HYP VA range: c0000000:ffffffff [ 2.091827] kvm [1]: Hyp mode initialized successfully [ 2.091899] kvm [1]: vgic-v2@10484000 [ 2.092229] kvm [1]: vgic interrupt IRQ16 [ 2.092262] kvm [1]: virtual timer IRQ60 [ 2.095387] audit: initializing netlink subsys (disabled) [ 2.095442] audit: type=2000 audit(2.090:1): initialized [ 2.095705] Initialise system trusted keyrings [ 2.096142] workingset: timestamp_bits=14 max_order=19 bucket_order=5 [ 2.106803] zbud: loaded [ 2.110719] NFS: Registering the id_resolver key type [ 2.110760] Key type id_resolver registered [ 2.110782] Key type id_legacy registered [ 2.110812] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 2.110839] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 2.112026] romfs: ROMFS MTD (C) 2007 Red Hat, Inc. [ 2.112833] JFS: nTxBlock = 8192, nTxLock = 65536 [ 2.117729] SGI XFS with ACLs, security attributes, realtime, no debug enabled [ 2.126405] Key type asymmetric registered [ 2.126477] bounce: pool size: 64 pages [ 2.126734] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248) [ 2.126921] io scheduler noop registered [ 2.126946] io scheduler deadline registered [ 2.127209] io scheduler cfq registered (default) [ 2.129994] 12130000.phy: supply vbus not found, using dummy regulator [ 2.131057] 12100000.phy: supply vbus not found, using dummy regulator [ 2.131139] 12100000.phy: supply vbus-boost not found, using dummy regulator [ 2.131530] 12500000.phy: supply vbus not found, using dummy regulator [ 2.131620] 12500000.phy: supply vbus-boost not found, using dummy regulator [ 2.136921] dma-pl330 3880000.adma: Loaded driver for PL330 DMAC-241330 [ 2.136952] dma-pl330 3880000.adma: DBUFF-4x8bytes Num_Chans-6 Num_Peri-16 Num_Events-6 [ 2.140369] dma-pl330 121a0000.pdma: Loaded driver for PL330 DMAC-241330 [ 2.140399] dma-pl330 121a0000.pdma: DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32 [ 2.143789] dma-pl330 121b0000.pdma: Loaded driver for PL330 DMAC-241330 [ 2.143817] dma-pl330 121b0000.pdma: DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32 [ 2.144829] dma-pl330 10800000.mdma: Loaded driver for PL330 DMAC-241330 [ 2.144858] dma-pl330 10800000.mdma: DBUFF-64x8bytes Num_Chans-8 Num_Peri-1 Num_Events-32 [ 2.214141] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 2.216766] 12c00000.serial:: ttySAC0 at MMIO 0x12c00000 (irq = 80, base_baud = 0) is a S3C6400/10 [ 2.217224] 12c10000.serial:: ttySAC1 at MMIO 0x12c10000 (irq = 81, base_baud = 0) is a S3C6400/10 [ 2.217700] 12c20000.serial:: ttySAC2 at MMIO 0x12c20000 (irq = 82, base_baud = 0) is a S3C6400/10 [ 3.377773] console [ttySAC2] enabled [ 3.381791] 12c30000.serial:: ttySAC3 at MMIO 0x12c30000 (irq = 83, base_baud = 0) is a S3C6400/10 [ 3.391736] [drm] Initialized [ 3.394838] exynos-hdmi 14530000.hdmi:: Failed to get supply 'vdd': -517 [ 3.401310] exynos-rot 11c00000.rotator:: The exynos rotator is probed successfully [ 3.408358] exynos-drm-ipp exynos-drm-ipp: drm ipp registered successfully. [ 3.419079] mali 11800000.mali:: GPU identified as 0x0620 r0p1 status 0 [ 3.424944] devfreq 11800000.mali:: Couldn't update frequency transition information. [ 3.432102] mali 11800000.mali:: could not find power_model node [ 3.438642] mali 11800000.mali:: Probed as mali0 [ 3.456951] brd: module loaded [ 3.467590] loop: module loaded [ 3.470105] libphy: Fixed MDIO Bus: probed [ 3.473753] usbcore: registered new interface driver r8152 [ 3.478872] usbcore: registered new interface driver cdc_ether [ 3.484679] usbcore: registered new interface driver cdc_subset [ 3.491075] exynos-dwc3 soc:usb3-0:: no suspend clk specified [ 3.496327] exynos-dwc3 soc:usb3-1:: no suspend clk specified [ 3.503290] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 3.508453] ehci-exynos: EHCI EXYNOS driver [ 3.513009] exynos-ehci 12110000.usb:: EHCI Host Controller [ 3.518180] exynos-ehci 12110000.usb:: new USB bus registered, assigned bus number 1 [ 3.526115] exynos-ehci 12110000.usb:: irq 94, io mem 0x12110000 [ 3.542368] exynos-ehci 12110000.usb:: USB 2.0 started, EHCI 1.00 [ 3.547189] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.553774] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.560965] usb usb1: Product: EHCI Host Controller [ 3.565807] usb usb1: Manufacturer: Linux 4.9.54-odroidxu4 ehci_hcd [ 3.572047] usb usb1: SerialNumber: 12110000.usb: [ 3.577430] hub 1-0:1.0: USB hub found [ 3.580463] hub 1-0:1.0: 3 ports detected [ 3.585383] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 3.590610] ohci-exynos: OHCI EXYNOS driver [ 3.594996] exynos-ohci 12120000.usb:: USB Host Controller [ 3.600234] exynos-ohci 12120000.usb:: new USB bus registered, assigned bus number 2 [ 3.608041] exynos-ohci 12120000.usb:: irq 94, io mem 0x12120000 [ 3.676578] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 3.681915] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.689884] usb usb2: Product: USB Host Controller [ 3.693868] usb usb2: Manufacturer: Linux 4.9.54-odroidxu4 ohci_hcd [ 3.700105] usb usb2: SerialNumber: 12120000.usb: [ 3.705427] hub 2-0:1.0: USB hub found [ 3.708543] hub 2-0:1.0: 3 ports detected [ 3.714027] usbcore: registered new interface driver cdc_wdm [ 3.718327] usbcore: registered new interface driver usb-storage [ 3.724957] mousedev: PS/2 mouse device common for all mice [ 3.731330] i2c /dev entries driver [ 3.736186] LDO4: mapping for mode 1 not defined [ 3.739838] LDO27: mapping for mode 1 not defined [ 3.744064] LDO28: mapping for mode 1 not defined [ 3.748744] LDO30: mapping for mode 1 not defined [ 3.765709] vdd_ldo9: Bringing 3300000uV into 3000000-3000000uV [ 3.781662] vdd_ldo15: Bringing 3300000uV into 3100000-3100000uV [ 3.794619] vdd_sd: Bringing 3300000uV into 2800000-2800000uV [ 4.857139] s5m-rtc s2mps14-rtc: rtc core: registered s5m-rtc as rtc0 [ 4.864956] IR NEC protocol handler initialized [ 4.868047] IR RC5(x/sz) protocol handler initialized [ 4.873061] IR RC6 protocol handler initialized [ 4.877566] IR JVC protocol handler initialized [ 4.882054] IR Sony protocol handler initialized [ 4.886664] IR SANYO protocol handler initialized [ 4.891344] IR Sharp protocol handler initialized [ 4.896024] IR MCE Keyboard/mouse protocol handler initialized [ 4.901830] IR XMP protocol handler initialized [ 4.907391] s5p-jpeg 11f50000.jpeg:: encoder device registered as /dev/video20 [ 4.913716] s5p-jpeg 11f50000.jpeg:: decoder device registered as /dev/video21 [ 4.920735] s5p-jpeg 11f50000.jpeg:: Samsung S5P JPEG codec [ 4.926599] s5p-jpeg 11f60000.jpeg:: encoder device registered as /dev/video22 [ 4.933650] s5p-jpeg 11f60000.jpeg:: decoder device registered as /dev/video23 [ 4.940664] s5p-jpeg 11f60000.jpeg:: Samsung S5P JPEG codec [ 4.964449] s5p-mfc 11000000.codec:: preallocated 16 MiB buffer for the firmware and context buffers [ 4.972388] s5p-mfc 11000000.codec:: decoder registered as /dev/video10 [ 4.978889] s5p-mfc 11000000.codec:: encoder registered as /dev/video11 [ 4.994530] device-mapper: uevent: version 1.0.3 [ 4.998119] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com [ 5.019454] sdhci: Secure Digital Host Controller Interface driver [ 5.024166] sdhci: Copyright(c) Pierre Ossman [ 5.028714] Synopsys Designware Multimedia Card Interface Driver [ 5.035045] dwmmc_exynos 12200000.mmc:: IDMAC supports 32-bit address mode. [ 5.041466] dwmmc_exynos 12200000.mmc:: Using internal DMA controller. [ 5.047912] dwmmc_exynos 12200000.mmc:: Version ID is 250a [ 5.053391] dwmmc_exynos 12200000.mmc:: DW MMC controller at irq 97,64 bit host data width,64 deep fifo [ 5.062856] dwmmc_exynos 12200000.mmc:: Got CD GPIO [ 5.067626] dwmmc_exynos 12200000.mmc:: allocated mmc-pwrseq [ 5.093722] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63) [ 5.117521] dwmmc_exynos 12200000.mmc:: 1 slots initialized [ 5.121847] dwmmc_exynos 12220000.mmc:: IDMAC supports 32-bit address mode. [ 5.128606] dwmmc_exynos 12220000.mmc:: Using internal DMA controller. [ 5.135074] dwmmc_exynos 12220000.mmc:: Version ID is 250a [ 5.140557] dwmmc_exynos 12220000.mmc:: DW MMC controller at irq 98,64 bit host data width,64 deep fifo [ 5.172781] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63) [ 5.197390] dwmmc_exynos 12220000.mmc:: 1 slots initialized [ 5.202197] hidraw: raw HID events driver (C) Jiri Kosina [ 5.210066] usbcore: registered new interface driver usbhid [ 5.214175] usbhid: USB HID core driver [ 5.231590] exynos-nocp: new NoC Probe device registered: 10ca1000.nocp: [ 5.236934] exynos-nocp: new NoC Probe device registered: 10ca1400.nocp: [ 5.244249] exynos-nocp: new NoC Probe device registered: 10ca1800.nocp: [ 5.250272] exynos-nocp: new NoC Probe device registered: 10ca1c00.nocp: [ 5.261482] odroid-audio sound:: dit-hifi <-> 3830000.i2s: mapping ok [ 5.267212] NET: Registered protocol family 17 [ 5.270888] NET: Registered protocol family 15 [ 5.275336] Key type dns_resolver registered [ 5.279960] Registering SWP/SWPB emulation handler [ 5.284658] registered taskstats version 1 [ 5.288373] Loading compiled-in X.509 certificates [ 5.293179] zswap: loaded using pool lzo/zbud [ 5.298367] Btrfs loaded, crc32c=crc32c-generic [ 5.309829] Key type encrypted registered [ 5.331947] [drm] Exynos DRM: using 14450000.mixer: device for DMA mapping operations [ 5.335313] mmc_host mmc1: Bus speed (slot 0) = 200000000Hz (slot req 200000000Hz, actual 200000000HZ div = 0) [ 5.348426] exynos-drm exynos-drm: bound 14450000.mixer: (ops 0xc0a6aec0) [ 5.355138] exynos-drm exynos-drm: bound 14530000.hdmi: (ops 0xc0a6b068) [ 5.361695] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 5.368279] [drm] No driver support for vblank timestamp query. [ 5.374215] [drm] Initialized exynos 1.0.0 20110530 on minor 0 [ 5.380126] exynos-dwc3 soc:usb3-0:: no suspend clk specified [ 5.389560] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 5.393581] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 3 [ 5.401432] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00010010 [ 5.409890] xhci-hcd xhci-hcd.2.auto: irq 146, io mem 0x12000000 [ 5.415948] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 5.422599] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.429793] usb usb3: Product: xHCI Host Controller [ 5.433365] mmc1: new ultra high speed SDR104 SDHC card at address aaaa [ 5.440120] mmcblk1: mmc1:aaaa SU08G 7.40 GiB [ 5.441919] mmcblk1: p1 [ 5.448162] usb usb3: Manufacturer: Linux 4.9.54-odroidxu4 xhci-hcd [ 5.454397] usb usb3: SerialNumber: xhci-hcd.2.auto [ 5.459609] hub 3-0:1.0: USB hub found [ 5.462994] hub 3-0:1.0: 1 port detected [ 5.467086] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 5.472342] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 4 [ 5.480007] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 5.488108] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003 [ 5.494783] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.501976] usb usb4: Product: xHCI Host Controller [ 5.506825] usb usb4: Manufacturer: Linux 4.9.54-odroidxu4 xhci-hcd [ 5.513067] usb usb4: SerialNumber: xhci-hcd.2.auto [ 5.518259] hub 4-0:1.0: USB hub found [ 5.521648] hub 4-0:1.0: 1 port detected [ 5.525991] exynos-dwc3 soc:usb3-1:: no suspend clk specified [ 5.533028] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller [ 5.537038] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 5 [ 5.544892] xhci-hcd xhci-hcd.5.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00010010 [ 5.553366] xhci-hcd xhci-hcd.5.auto: irq 147, io mem 0x12400000 [ 5.559413] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002 [ 5.566072] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.573267] usb usb5: Product: xHCI Host Controller [ 5.578115] usb usb5: Manufacturer: Linux 4.9.54-odroidxu4 xhci-hcd [ 5.584350] usb usb5: SerialNumber: xhci-hcd.5.auto [ 5.589556] hub 5-0:1.0: USB hub found [ 5.592951] hub 5-0:1.0: 1 port detected [ 5.597036] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller [ 5.602299] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 6 [ 5.609963] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 5.618061] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003 [ 5.624738] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.631932] usb usb6: Product: xHCI Host Controller [ 5.636780] usb usb6: Manufacturer: Linux 4.9.54-odroidxu4 xhci-hcd [ 5.643019] usb usb6: SerialNumber: xhci-hcd.5.auto [ 5.648248] hub 6-0:1.0: USB hub found [ 5.651602] hub 6-0:1.0: 1 port detected [ 5.656481] rtc rtc1: invalid alarm value: 1900-1-2 0:0:0 [ 5.660978] s3c-rtc 101e0000.rtc:: rtc core: registered s3c as rtc1 [ 5.668351] exynos-bus: new bus device registered: soc:bus_wcore: ( 84000 KHz ~ 400000 KHz) [ 5.675934] exynos-bus: new bus device registered: soc:bus_noc: ( 67000 KHz ~ 100000 KHz) [ 5.683956] exynos-bus: new bus device registered: soc:bus_fsys_apb: (100000 KHz ~ 200000 KHz) [ 5.692418] exynos-bus: new bus device registered: soc:bus_fsys: (100000 KHz ~ 200000 KHz) [ 5.700827] exynos-bus: new bus device registered: soc:bus_fsys2: ( 75000 KHz ~ 150000 KHz) [ 5.709249] exynos-bus: new bus device registered: soc:bus_mfc: ( 96000 KHz ~ 333000 KHz) [ 5.717359] exynos-bus: new bus device registered: soc:bus_gen: ( 89000 KHz ~ 267000 KHz) [ 5.725352] exynos-bus: new bus device registered: soc:bus_peri: ( 67000 KHz ~ 67000 KHz) [ 5.733775] exynos-bus: new bus device registered: soc:bus_g2d: ( 84000 KHz ~ 333000 KHz) [ 5.741865] exynos-bus: new bus device registered: soc:bus_g2d_acp: ( 67000 KHz ~ 267000 KHz) [ 5.750354] exynos-bus: new bus device registered: soc:bus_jpeg: ( 75000 KHz ~ 300000 KHz) [ 5.758608] exynos-bus: new bus device registered: soc:bus_jpeg_apb: ( 84000 KHz ~ 167000 KHz) [ 5.767054] exynos-bus: new bus device registered: soc:bus_disp1_fimd: (120000 KHz ~ 200000 KHz) [ 5.775870] exynos-bus: new bus device registered: soc:bus_disp1: (120000 KHz ~ 300000 KHz) [ 5.784196] exynos-bus: new bus device registered: soc:bus_gscl_scaler: (150000 KHz ~ 300000 KHz) [ 5.793136] exynos-bus: new bus device registered: soc:bus_mscl: ( 84000 KHz ~ 400000 KHz) [ 5.801364] input: gpio_keys: as /devices/platform/gpio_keys:/input/input0 [ 5.808922] Power domain power-domain@10044120 disable failed [ 5.814205] s5m-rtc s2mps14-rtc: setting system clock to 2000-01-01 00:01:08 UTC (946684868) [ 5.824221] ALSA device list: [ 5.825709] #0: odroid-snd [ 5.830162] Freeing unused kernel memory: 2048K Loading, please wait... starting version 232 [ 6.772453] usb 6-1: new SuperSpeed USB device number 2 using xhci-hcd [ 6.798407] usb 6-1: New USB device found, idVendor=0bda, idProduct=8153 [ 6.803654] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6 [ 6.810760] usb 6-1: Product: USB 10/100/1000 LAN [ 6.815432] usb 6-1: Manufacturer: Realtek [ 6.819507] usb 6-1: SerialNumber: 000001000000 [ 6.986067] usb 6-1: reset SuperSpeed USB device number 2 using xhci-hcd [ 7.078568] r8152 6-1:1.0 eth0: v1.08.8 [ 7.085234] r8152 6-1:1.0 enx001e0630c785: renamed from eth0 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. [ 10.652465] usb 4-1: new SuperSpeed USB device number 2 using xhci-hcd [ 10.678849] usb 4-1: New USB device found, idVendor=152d, idProduct=0578 [ 10.684099] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 10.691201] usb 4-1: Product: USB to SATA bridge [ 10.695789] usb 4-1: Manufacturer: JMicron [ 10.699862] usb 4-1: SerialNumber: DB00000000013B [ 10.708481] uas: section 3 reloc 4 sym '_raw_spin_lock_irqsave': relocation 10 out of range (0xbf800158 -> 0xc08553e9) Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. ^CBegin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Link to post Share on other sites
nihilista 3 Posted October 14, 2017 Author Share Posted October 14, 2017 Good to see thats a real bug, but it stops me from setting up the device If i could i would help fixing this fast, but i have no idea how...but i hope you will find a solution Link to post Share on other sites
Igor 2164 Posted October 14, 2017 Share Posted October 14, 2017 You can run it safely from SD card and when we solve this, move to SSD. Only reserve one big enough partition for system on your SSD. Wrote on mobile Link to post Share on other sites
nihilista 3 Posted October 14, 2017 Author Share Posted October 14, 2017 Yes, i know, but my thought was if solution is known and just some days away i wait and did a setup from scratch with benefits of fast ssd.... Link to post Share on other sites
Igor 2164 Posted October 18, 2017 Share Posted October 18, 2017 On 14. 10. 2017 at 1:14 PM, nihilista said: Yes, i know, but my thought was if solution is known and just some days away i wait and did a setup from scratch with benefits of fast ssd.... Fixed. http://sprunge.us/DMbR Link to post Share on other sites
nihilista 3 Posted October 19, 2017 Author Share Posted October 19, 2017 10 hours ago, Igor said: Fixed. http://sprunge.us/DMbR Ah, great, thx Waiting for getting fixed packages from the repo ;-) Link to post Share on other sites
Igor 2164 Posted October 19, 2017 Share Posted October 19, 2017 1 minute ago, nihilista said: Waiting for getting fixed packages from the repo ;-) OK ... last time when I was adding some packages to the stable repo, I crashed indexes and have to recheck the whole process again. If you haven't started doing anything, images from download are fixed for this problem. Link to post Share on other sites
nihilista 3 Posted October 19, 2017 Author Share Posted October 19, 2017 35 minutes ago, Igor said: OK ... last time when I was adding some packages to the stable repo, I crashed indexes and have to recheck the whole process again. If you haven't started doing anything, images from download are fixed for this problem. Thats bad, cause now i've setup my device and just waiting for update, complete new install is not an option as i took some hours in configuring..... Are the packages in beta repo fixed too? So that maybe i can set beta source temporarily and install new packages from there? Link to post Share on other sites
Igor 2164 Posted October 19, 2017 Share Posted October 19, 2017 2 minutes ago, nihilista said: Are the packages in beta repo fixed too? Yes, they are and it should be safe to use them. Link to post Share on other sites
nihilista 3 Posted October 19, 2017 Author Share Posted October 19, 2017 2 minutes ago, Igor said: Yes, they are and it should be safe to use them. Ah, good, which packages should be installed? linux-image-next-odroidxu4_5.34.171020, 5.34 u-boot, jessie-root, dtb ....? Link to post Share on other sites
Igor 2164 Posted October 19, 2017 Share Posted October 19, 2017 Go to armbian-config, switch to beta, update, reboot and switch back to stable. Link to post Share on other sites
nihilista 3 Posted October 19, 2017 Author Share Posted October 19, 2017 OK, thx, will try that.. Link to post Share on other sites
nihilista 3 Posted October 19, 2017 Author Share Posted October 19, 2017 Confirmed, works without problems till now... Link to post Share on other sites
