DiegoBM Posted yesterday at 09:53 AM Posted yesterday at 09:53 AM We have been stuck on version 6.1 for almost half a year ever since the initial attempt to migrate to 6.12 caused some issues with HDMI if I remember correctly. Anyone knows if 6.12 or 6.14 are still in the works for this SBC? Thank you! 0 Quote
Solution Werner Posted yesterday at 11:12 AM Solution Posted yesterday at 11:12 AM This device is community-maintained. Armbian core team does not monitor its status nor gets involved into development here. However anyone from the community can step up and send fixes. I saw some stuff upstreamed from time to time for 5 ultra and max, hit somewhere between 6.16 and 6.18 I guess. When rockchip64 gets bumped further they will be available for these boards. Since mainline is still under development though sticking with 6.1.y vendor kernel isn't a bad option since most things work here. 0 Quote
DiegoBM Posted 14 hours ago Author Posted 14 hours ago (edited) Thank you @Werner, that makes, sense and I'll follow your advice. Can you please tell me where do you check those updates? And should I assume that when those changes are completed in mainline, they'll make it to the Armbian distribution with the regular updates? Or will I need to change to a different one if noone updates this one? Thank you again. Kind regards Edited 14 hours ago by DiegoBM 0 Quote
Werner Posted 13 hours ago Posted 13 hours ago 38 minutes ago, DiegoBM said: Can you please tell me where do you check those updates? I usually check here every couple of days: https://patchwork.kernel.org/project/linux-rockchip/list/ 38 minutes ago, DiegoBM said: they'll make it to the Armbian distribution with the regular updates? Yes, they will be included in edge kernel and in a year or two when the next LTS kernel hits they'll be included in current as well. 2 Quote
The Tall Man Posted 2 hours ago Posted 2 hours ago 11 hours ago, Werner said: I usually check here every couple of days: https://patchwork.kernel.org/project/linux-rockchip/list/ Awesome! Thanks so much for this! I see they're addressing some key issues, such as NPU functionality and fixing the ES8388 audio issue with the Orange PI 5 Plus (the board I have). This is terrific!! 0 Quote
