greenais Posted 13 hours ago Posted 13 hours ago Please give me a tip - what is purpose of /dev/mmcblk2boot block devices created? Quite small size - 4MB - ones, do they serve to something u-boot needs at boot time? There are no records for them in fstab so I assume they are created by zram, but what happens to them after boot when they aren't needed anymore? Board Orangepi 3LTS with bookworm minimal Also as a matter of wondering - why there are two zram devices: one of 1/2 of RAM (as usual) and another of quite small 50MB only, what is it for? root@heaven:~# fdisk -l <redacted> Disk /dev/mmcblk2boot0: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/mmcblk2boot1: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes <redacted> Disk /dev/zram0: 987,53 MiB, 1035497472 bytes, 252807 sectors Units: sectors of 1 * 4096 = 4096 bytes Sector size (logical/physical): 4096 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/zram1: 50 MiB, 52428800 bytes, 12800 sectors Units: sectors of 1 * 4096 = 4096 bytes Sector size (logical/physical): 4096 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes 0 Quote
Werner Posted 13 hours ago Posted 13 hours ago 18 minutes ago, greenais said: /dev/mmcblk2boot Good question. Have you tried to use binwalk oder strings on it? 18 minutes ago, greenais said: e two zram devices: One is for ramlog and should be mounted to /var/log. The other is zram which by default is half of your actual memory. In the early days SBCs hat very limited memory, so using zram was a simple way to increase that by sacrificing some cpu resources. Nowadays SBCs come with a lot more memory and some may not even need zram anymore. Depending on your setup you can disable it as well. Check /etc/default/armbian-* files. 0 Quote
greenais Posted 11 hours ago Author Posted 11 hours ago 1 hour ago, Werner said: One is for ramlog and should be mounted to /var/log. The other is zram which by default is half of your actual memory. In fact in image's default fstab they aren't mounted so those probably could be assumed as a kind of waste of RAM this way? Or there is chance that they actually mounted somewhere else but fstab? root@heaven:~# cat /etc/fstab # <file system> <mount point> <type> <options> <dump> <pass> tmpfs /tmp tmpfs defaults,nosuid 00 UUID=fb077685-a428-49f2-b013-287dc5fc9672 / ext4 defaults,noatime,commit=120,errors=remount-ro,x-gvfs-hide 0 1 Thank you for tip regarding /var/log, I was suspecting that it should be there as soon as device created. 1 hour ago, Werner said: Have you tried to use binwalk oder strings on it? Do you mean to inspect with binwalk/strngs those devices in hope to find out what is there? I'd gave a try - there is nothing: root@heaven:~# binwalk /dev/mmcblk2boot0 DECIMAL HEXADECIMAL DESCRIPTION -------------------------------------------------------------------------------- root@heaven:~# binwalk /dev/mmcblk2boot1 DECIMAL HEXADECIMAL DESCRIPTION -------------------------------------------------------------------------------- root@heaven:~# strings /dev/mmcblk2boot0 root@heaven:~# They also can't be mounted - dmesg excerpt: [390869.014377] F2FS-fs (mmcblk2boot0): Magic Mismatch, valid(0xf2f52010) - read(0x0) [390869.014508] F2FS-fs (mmcblk2boot0): Can't find valid F2FS filesystem in 1th superblock Magic mismatch - mystic things unsolved) 0 Quote
Werner Posted 11 hours ago Posted 11 hours ago 2 minutes ago, greenais said: In fact in image's default fstab they aren't mounted so those probably could be assumed as a kind of waste of RAM this way? Have you checked "mount" command to list actualy mounts? I am quite confident mount is happening by the ramlog service and is not integrated into fstab. some more background: sdcards have a limited amount of writes until its cells die. Since everytime some service or whatever writes some logs this issues a write event. To drastically increase the lifespan of the microsd log entries are buffered to (compressed) memory and then recurringly written all at once. 0 Quote
greenais Posted 11 hours ago Author Posted 11 hours ago 9 minutes ago, Werner said: I am quite confident mount is happening by the ramlog service and is not integrated into fstab. You are completely right - at least 50MB one is there /dev/zram1 on /var/log type ext4 (rw,nosuid,nodev,noexec,relatime,discard) But big 987MB /dev/zram0 isn't at all - so it looks like it's useless and could be removed from zram config, right? Both mystic /dev/mmcblk2bootX are still in question 0 Quote
Werner Posted 9 hours ago Posted 9 hours ago 2 hours ago, greenais said: 987MB I explained above what zram is created for. OPi3LTS should have 2G of memory, so having 1G of zram makes perfect sense here. 0 Quote
greenais Posted 8 hours ago Author Posted 8 hours ago 28 minutes ago, Werner said: what zram is created for Yes, but since this created device isn't mounted anywhere it makes no sense - no service or whatever could use it anyway, what definitely turns this creature into just waste of RAM for nothing, am I wrong? 0 Quote
laibsch Posted 4 hours ago Posted 4 hours ago not everything is mounted, at least not in the way you expect it. check "swapon -s" 0 Quote
greenais Posted 4 hours ago Author Posted 4 hours ago 19 minutes ago, laibsch said: check "swapon -s" Wow, I didn't know those command and mechanism even exist... Thank you for your tip! Any ideas regarding main (mmcblk2boot) topic question, perhaps? 1 Quote
SteeMan Posted 4 hours ago Posted 4 hours ago I have only ever seen mmcblk?boot? Partitions on media that was setup for Android as the A/B is part of how Android installs updates and can fall back to the previous version. I've never seen them on an Armbian created media. 0 Quote
greenais Posted 2 hours ago Author Posted 2 hours ago I didn't mention, sorry, probably it matters somehow - my bookworm is already transferred to emmc, so system boots and runs from there, not from SD-card 0 Quote
SteeMan Posted 1 hour ago Posted 1 hour ago 59 minutes ago, greenais said: already transferred to emmc How was this transfered? What was on the eMMC before the transfer? Was the eMMC wiped before the transfer? My guess is that your eMMC has Android loaded on it, you didn't wipe it and now you have partitions left over from the Android install. 0 Quote
greenais Posted 40 minutes ago Author Posted 40 minutes ago 16 minutes ago, SteeMan said: How was this transfered? What was on the eMMC before the transfer? Was the eMMC wiped before the transfer? Using included in image armbian-config script as many times for other boards before. I have no idea what was there and I didn't care because Script formats emmc before transfer (with "Warning! All data will be destroyed - proceed?") So there is no chance to leave any trails of anything rested on emmc before 0 Quote
