Getting error installing Octoprint via armbian-config on Orange Pi Zero
Hi,
I installed on my Orange Pi Zero (not plus) armbian and using armbian-config I am trying to install Octoprint to control my 3d printer.
I got an error:
docker: Error response from daemon: error gathering device information while adding custom device "/dev/video0": no such file or directory
I have no webcam attached and I am not planning to use it for now, Can I disable this check?
Make sure that the octoprint project still supports 32 bit CPUs
For low ram sbc's, I suggest doing a classic installation, instead of Docker
You can skip the webcam portion installation, and give you no problems.
I had my opiz LTS (512MB) running octoprint last year, and the webcam function works well... but I only used octoprint-Docker when I had 2GB of RAM server.
Hi there,
I ran octoprint and klipper on a orangepi zero (not at the same time). Octoprint from docker and klipper I cannot remember.
Octoprint ran fine but it did have some issues when the CPU got overloaded with loading a new gcode file while printing for example. If you do things one by one it should be OKish.
Btw i ran octoprint in a 512MB version, not on the 256MB one.
Groetjes,
