Posted (edited)
Try an apt full-upgrade. The libraspberrypi packages have been deprecated recently (e.g. June/July) and recent RPI packages shouldn't depend on them, including raspi-firmware.
Edited by mitu
Thank you very much for the tip. I have heard that one should avoid updating the firmware if possible. Of course, I don't want my entire system to stop working afterwards. Can that happen? Should I make a complete backup before?
Where did you hear that ? Note that the 'firmware' package is not updating the EEPROM that's present on a Pi4/Pi5 and I had no booting issues updating the raspi-firmware package on RaspiOS.\
Of course you could make a backup if you want to feel safer, but I have no reason to believe there's anything that's going to cause issues if you're going to upgrade the raspi-firmware package.
The following is documented:
Zitat
Troubleshooting
On Debian bookworm variant you might bump into broken packages dependency, conflicts between firmware and bsp package. Here is how you can solve it:
apt update
dpkg --remove --force-all libraspberrypi0 armbian-bsp-cli-rpi4b-current
apt --fix-broken install
apt install armbian-bsp-cli-rpi4b-current
But nobody seems to read the docs.😪
Raspberry Pi
