Posted (edited)
For those with a Radxa Cubie A7A/A7Z, I made a custom Armbian Build using the BSP kernel.
https://github.com/NickAlilovic/build/tree/Radxa-A7A
https://github.com/NickAlilovic/build/releases
To build your own image:
git clone https://github.com/NickAlilovic/build.git --branch Radxa-A7A
./compile.sh
"do not change the kernel configuration"
"show csc/wip/eos/tvb"
"I understand and agree"
"radxa-cubie-a7a" or "radxa-cubie-a7z"
rest is up to you...
Should you choose to run Armbian, ensure the CPU has adequate cooling by installing the Radxa Heatsink.
https://radxa.com/products/accessories/heatsink-6530b
https://radxa.com/products/accessories/heatsink-6540b
Edited by Nick A
  • Nick A changed the title to Radxa Cubie A7A - Allwinner a733
Posted (edited)
Fixed the automatic first boot configuration on Bookwarm. Now you can boot the desktop image without a usb serial device.
Edited by Nick A
Hey @Nick A, first of all, thanks for providing us with the build, I flashed and tried the image, But I could not see kvm enabled in the system. Is this expected?
some example outputs:
~$ ls -l /dev/kvm
ls: cannot access '/dev/kvm': No such file or directory
~$ sudo dmesg | grep -i kvm
[    0.184039] kvm [1]: HYP mode not available
also no output on
lscpu | grep Virtualization
  • Nick A changed the title to Radxa Cubie A7A/A7Z - Allwinner a733
Posted (edited)
@Gavin Munday Did you compile a desktop or server image? Did you write the image onto a reliable sdcard? Remember there’s no framebuffer support. Server images need a usb to serial device attached to the UART. Having a usb serial device attached to the UART helps with these types of problems.
https://docs.radxa.com/en/cubie/a7a/system-config/uart_debug
Also, first boot might take awhile to boot. For desktop images wait at least 5 minutes for a display manager login screen.
Edited by Nick A
First step is to cleanup and bump the sunxi patchset to 6.18. This is a major blocker. Once that is done. Patches for more recent Allwinner SoCs can be added.
I started doing that but it is extremely exhausting. I have no clue how the-going managed to maintain that for that long... must be sort of masochistic or something lol.
https://github.com/EvilOlaf/build/tree/sunxi-6.18
Posted (edited)
Just tested a build i made locally from your branch, on the A7Z build, build with the latest Debian + XFCE Nice job @Nick A.
Seems to work fine, but it's lacking GPU acceleration, in both Chrome and VLC, same as the official builds.
Do you have any info on that? Is there any work going on the Armbian team for supporting the Imagination GPU? I know Imagination has pretty shitty software support.
Edited by Pop Alex
Posted (edited)
@Pop AlexI haven't spent a lot of time on GPU acceleration but I know there's a member here who has worked on it. He's using Radxa's GPU drivers.
https://github.com/radxa-pkg/aw-drivers-dkms/
https://github.com/chainsx/build/commit/a0527bd977bbe55b13c1f46ec46d0aab4369c798
fengRadxa Engineer
"Allwinner has feedback that the browser hardware decoding support is still under development. You can first use GStreamer to play video files encoded in H264, H265, VP9, or AVS formats as a test."
https://forum.radxa.com/t/hardware-decoding-for-video-not-enabled-on-a7a/29836/9
There's a new Tina V1.4.8 SDK. In the directory "debian/packages/arm64/chromium" you will find "chromium-browser-gst_120.0.6099.224-5_arm64.deb". Not sure if this is an updated verison of chromium?
https://mega.nz/file/sqRG1RaC#TpVwOuZSOoRaSfLDLF60Y0qHAVaViFTMPuZKFQw6m8c.
Edited by Nick A
