Renoria Posted Tuesday at 06:08 AM Posted Tuesday at 06:08 AM Hi guys, First post here, I successfully managed to flash and boot Armbian 25.8.2 (Bookworm Minimal) from an SD card. Everything was working great, HDMI output and network included. I then ran “sudo armbian-install” and selected Option 4 to move the system to my NVMe SSD and make it boot from there. The process itself completed without errors. However, after shutting down and removing the SD card and powering on again the system doesn’t boot. I have the red LED turned on however the green LED that was previously flickering doesn’t turn on. There’s also no HDMI output and the board doesn’t connect to the network. I tried inserting the SD card and the system does boot from that just fine. Where did I screw up? Appreciate the help! 0 Quote
laibsch Posted Tuesday at 06:14 AM Posted Tuesday at 06:14 AM sounds like a genuine bug and not an error on your end. @Efe Çetin Can you confirm the issue? 0 Quote
Igor Posted Tuesday at 07:40 AM Posted Tuesday at 07:40 AM I tested self build opi5 few days ago and there was no problem installing and booting from nvme, legacy kernel, Noble Gnome desktop. Make sure you select second option when updating SPI bootloader (not sata). 0 Quote
Renoria Posted Tuesday at 07:44 AM Author Posted Tuesday at 07:44 AM Hi @Igor, that’s what I selected (not the sata loader) and then ext4 but no luck. 0 Quote
Igor Posted Tuesday at 07:48 AM Posted Tuesday at 07:48 AM 2 minutes ago, Renoria said: and then ext4 but no luck. Is SSD in good shape and is SPI flash o.k. ... logs would tell more. 0 Quote
Renoria Posted Tuesday at 09:02 AM Author Posted Tuesday at 09:02 AM @Igor could you help how to figure out if both SSD, SPI flash are ok? happy to provide logs as well, which to share? 0 Quote
Werner Posted Tuesday at 01:18 PM Posted Tuesday at 01:18 PM 4 hours ago, Renoria said: which to share? The logs you can aquire this way: https://debug.armbian.de 0 Quote
Efe Çetin Posted 22 hours ago Posted 22 hours ago On 11/11/2025 at 7:08 AM, Renoria said: I tried inserting the SD card and the system does boot from that just fine. Could you try to write SPI image to spi flash manually? (not the sata one) Also, can you send the content of /boot/armbianEnv.txt which is located in the ssd. 0 Quote
Renoria Posted 1 hour ago Author Posted 1 hour ago (edited) 20 hours ago, Efe Çetin said: Could you try to write SPI image to spi flash manually? (not the sata one) Also, can you send the content of /boot/armbianEnv.txt which is located in the ssd. Hi @Efe Çetin, how do I write SPI image manually? as for the content inside SSD, this is what it shows: cat /mnt/boot/armbianEnv.txt verbosity=1 bootlogo=false console=both extraargs=cma=256M overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=98220746-d581-4d83-9e96-0f31702ef529 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Thanks in advance! Edited 1 hour ago by Renoria 0 Quote
