pbg Posted December 1, 2025 Posted December 1, 2025 As of 2025-12-01, current 'Armbian 25.11.1 Trixie Minimal / IOT' lists as 'Kernel: 6.12.58, Size: 505 KB, Release date: Nov 22, 2025' and seems to have had problems on image generation. Please check when possible. Thanks in advance, pbg 0 Quote
Igor Posted December 1, 2025 Posted December 1, 2025 2 hours ago, pbg said: and seems to have had problems on image generation. Does it fail to assemble image? Or you can make image but image is corrupted? For that part we have an explanation: https://docs.armbian.com/User-Guide_Getting-Started/#flash-to-sd-card 0 Quote
eselarm Posted December 1, 2025 Posted December 1, 2025 File (.xz) less than 1M, it extracts to 1444M, only 836k content, rest is sparse. Only U-Boot is written It looks like. So clearly image generation failed. 0 Quote
Solution Werner Posted December 2, 2025 Solution Posted December 2, 2025 just noticed current kernel is broken. I assume because of upstream changes. looks like similar what I've fixed for meson64 6.18-rc7. Got it, will send pr Of course this does not explain why the image wasn't correctly assembled at all... Looking good: https://paste.armbian.de/ohagifufem ls -l|grep Odr -rw-rw-r-- 1 root root 142 Dec 2 05:14 Armbian-unofficial_26.02.0-trunk_Odroidc2_trixie_current_6.12.60_minimal.img.sha -rw-rw-r-- 1 root root 19751 Dec 2 05:14 Armbian-unofficial_26.02.0-trunk_Odroidc2_trixie_current_6.12.60_minimal.img.txt -rw-rw-r-- 1 root root 322026836 Dec 2 05:14 Armbian-unofficial_26.02.0-trunk_Odroidc2_trixie_current_6.12.60_minimal.img.x 0 Quote
Igor Posted December 2, 2025 Posted December 2, 2025 11 hours ago, pbg said: Please check when possible. We checked and it works on supported build host. We need to see logs to understand why it is failing for you. 0 Quote
pbg Posted December 2, 2025 Author Posted December 2, 2025 I have not tried to build the image myself. I wanted to flag that the file linked for download was not correctly assembled. I should have been more precise. 0 Quote
Igor Posted December 2, 2025 Posted December 2, 2025 3 hours ago, pbg said: the file linked for download was not correctly assembled. Aha. We only test one randomly picked image per board - not all of them. And nobody noticed small size of the file ... I see now. Probably runner starved for memory or some other problem. Logs were already deleted so I can't check, but have started new build. 3 hours ago, pbg said: I should have been more precise. Indeed All clear now. 0 Quote
Igor Posted December 2, 2025 Posted December 2, 2025 7 hours ago, pbg said: download was not correctly assembled Can you check one from here: https://fi.mirror.armbian.de/incoming/igorpecovnik/odroidc2/archive/ Sizes seems alright. 0 Quote
pbg Posted December 2, 2025 Author Posted December 2, 2025 I downloaded 'Armbian_25.11.2_Odroidc2_trixie_current_6.12.58_minimal.img.xz', flashed it to sdcard, and it booted fine. As a sidenote unrelated to the issue at hand, my first try was with the sdcard on a device with emmc, and in this case the boot process stopped after block-local (?), and dropped to initramfs shell prompt. 1 Quote
