New 'Armbian 25.11.1 Trixie Minimal / IOT' image is possibly corrupted
Go to solution Solved by Werner,
As of 2025-12-01, current 'Armbian 25.11.1 Trixie Minimal / IOT' lists as 'Kernel: 6.12.58, Size: 505 KB, Release date: Nov 22, 2025' and seems to have had problems on image generation.
Please check when possible.
Thanks in advance,
pbg
  • Solution
just noticed current kernel is broken. I assume because of upstream changes. looks like similar what I've fixed for meson64 6.18-rc7.
Got it, will send pr
Of course this does not explain why the image wasn't correctly assembled at all...
Looking good: https://paste.armbian.de/ohagifufem
ls -l|grep Odr
-rw-rw-r-- 1 root root        142 Dec  2 05:14 Armbian-unofficial_26.02.0-trunk_Odroidc2_trixie_current_6.12.60_minimal.img.sha
-rw-rw-r-- 1 root root      19751 Dec  2 05:14 Armbian-unofficial_26.02.0-trunk_Odroidc2_trixie_current_6.12.60_minimal.img.txt
-rw-rw-r-- 1 root root  322026836 Dec  2 05:14 Armbian-unofficial_26.02.0-trunk_Odroidc2_trixie_current_6.12.60_minimal.img.x
We checked and it works on supported build host. We need to see logs to understand why it is failing for you.
I have not tried to build the image myself. I wanted to flag that the file linked for download was not correctly assembled. I should have been more precise.
Aha. We only test one randomly picked image per board - not all of them. And nobody noticed small size of the file ... I see now. Probably runner starved for memory or some other problem. Logs were already deleted so I can't check, but have started new build.
Indeed :) All clear now.
