August 26Aug 26 Not sure why, but i had to add the pcie_aspm=off to my /boot/extlinux.conf to get the newest build to see my nvme drive, this has never happened on previous builds, and the only options i turn on from the default config being fetched is enabling graphics drivers. very strange.
August 26Aug 26 took me a long time to figure out why, my nvme drive would show under lspci, and it would see the controller but id never get anything under lsblk. still not sure what changed but if anyone else runs into similar problem thats how i fixed it.
August 28Aug 28 Author @cal5582 Seems like lots of NVME needs to disable ASPM. For my Samsung 9b1 NVME, I solved this with a kernel patch, see https://github.com/armbian/build/blob/main/patch/kernel/archive/spacemit-6.18/013-Disable-ASPM-L0-for-Samsung-PM9B1-NVME.patch HTH // Sven-Ola
September 2Sep 2 so im not exactly sure why, but now i am getting an error building the most recent images in debian 13 under virtualbox. [🔨] INSTALL /home/vm/armbian/build/.tmp/work-7197f8ae-9b85-4959-9885-0c198551c928/kernel_dest_install_dir-wUSTJ/libc_headers/include [🔨] /bin/sh: 1: rsync: not found [🔨] make[2]: *** [Makefile:1416: headers_install] Error 127 [🔨] make[1]: *** [/home/vm/armbian/build/cache/sources/linux-kernel-worktree/6.18__spacemit__riscv64/Makefile:380: __build_one_by_one] Error 2 [🔨] make: *** [Makefile:248: __sub-make] Error 2 [🌱] Ccache result [ hit=0 miss=0 (0%) ] [💥] Error 2 occurred in main shell [ at /home/vm/armbian/build/lib/functions/compilation/kernel.sh:264 kernel_build() --> lib/functions/compilation/kernel.sh:264 do_with_hooks() --> lib/functions/general/extensions.sh:618 do_with_logging() --> lib/functions/logging/section-logging.sh:81 kernel_prepare_build_and_package() --> lib/functions/compilation/kernel.sh:166 compile_kernel() --> lib/functions/compilation/kernel.sh:99 artifact_kernel_build_from_sources() --> lib/functions/artifacts/artifact-kernel.sh:310 artifact_build_from_sources() --> lib/functions/artifacts/artifacts-obtain.sh:34 obtain_complete_artifact() --> lib/functions/artifacts/artifacts-obtain.sh:280 build_artifact_for_image() --> lib/functions/artifacts/artifacts-obtain.sh:394 main_default_build_packages() --> lib/functions/main/build-packages.sh:97 full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:31 do_with_default_build() --> lib/functions/main/default-build.sh:42 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:216 main() --> compile.sh:50 ] [💥] Cleaning up [ please wait for cleanups to finish ] [✨] Repeat Build Options [ ./compile.sh build BOARD=orangepirv2 BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=no INSTALL_HEADERS=yes KERNEL_CONFIGURE=yes KERNEL_GIT=Full RELEASE=trixie ]
September 5Sep 5 Hello. Finally, I have built an image on my Orange Pi 5B for the Orange Pi RV2 and launched it from a TF card. Currently, I have two RV2 boards with 8 GB of RAM and plan to maximize these devices by contributing to Armbian specifically for this device. Well, so far I have only successfully launched the system, and it will take a few days to figure out its capabilities and errors. So far I can only work with TF cards, but after a while I will add m.2 drives. It is not very clear what about working with USB. I am interested not only in the successful work of the server build but also in the effective work of the graphical desktop environment. In a few days I will write about the test results.
September 20Sep 20 Hi. Following up on the previous post: I used the built image to compile HestiaCP and set up a web hosting server, successfully launching a PHP site. I also ran several Go applications, which proved stable without requiring any "quick-and-dirty" workarounds. My next step is to perform load testing on the web server—specifically, testing how it handles a significant number of connections and streams multimedia and data via WebSockets. I plan to deploy this same image on another board and attempt to install a graphical environment. I’m not moving very fast, but I’m glad the server is up and running stably; this allows me to start planning for its deployment in a production environment.
October 10Oct 10 Hello! I would like to get Trixie with a desktop working on my board. I currently use "armbian-unofficial_26.02.0-*-6.18.18_gnome_desktop" and it actually works well. It worked better and had less stuttering before i upgraded and got "6.18.44-current-spacemit", but it's still usable for light browsing, "RDP"ing into my main machine with Remmina (currently doing that to write this comment!) and even gaming: "The Question" demo renpy game from repos works well and I'm curious how something bigger like "Everlasting Summer" is going to work on that board, but for that I need renpy 8.3.4 and noble is at 8.1.3, so that's why I want to get Trixie working: it has the exact version I need. Should I try to compile the image with BUILD_DESKTOP set? Does the unofficial image contain some additional fixes for graphics drivers? Edited October 10Oct 10 by VBB
October 11Oct 11 I have build Trixie with gnome desktop. Then ran the `spacemit-gpu-addon.sh` script and hw acceleration appears to be working. vkcube fails with this error: ``` Selected WSI platform: xcb vulkan: No DRI3 support detected - required for presentation Note: you can probably enable DRI3 in your Xorg config vkcube: ./cube/cube.c:4228: demo_select_physical_device: Assertion `demo->gpu_number >= 0' failed. ``` Then I tried to launch gnome system monitor with vulkan renderer (GSK_RENDERER=vulkan gnome-system-monitor) and, besides some bugs with icons, it does work, inspector show that vulkan gsk renderer is used. I was able to successfully launch Everlasting Summer (copied it from stream from renpy8 branch) with the 7dl mod (must be ported to python3 and renpy8, luckily sources are available). Very much playable. I have used renpy from distro repos and removed splash screen pictures, because the game crashes after being unable to create a window for that splash screen. `RENPY_LESS_UPDATES=1` can be used too, but it also reduces animations in the game itself. Wi-Fi doesn't work, but it's not a big deal for me, since I use Ethernet. Bluetooth works. Boot time is veeery long. 3 mins for kernel. ``` systemd-analyze Startup finished in 3min 15.784s (kernel) + 31.495s (userspace) = 3min 47.280s graphical.target reached after 31.491s in userspace. ```
October 18Oct 18 Hey! It looks like Íker Pedrosa got upstream GPU support (GPU firmware is not upstream) https://lore.kernel.org/linux-riscv/20261015-orangepi-gpu-v1-0-03566a615660@gmail.com/ I just hope that thermal and cpufreq stuff get a bit better because my K1 does not get under 65-75ºC
November 5Nov 5 Hey. I've installed the image to my Orangepi RV2. I experience some weird delay on boot: i see a black screen (hdmi) for 3 minutes and then the mini pc shows the terminal and I can log in. I used another image (kernel 6.6), and such an issue didn't exist there. Can you help me solve this issue, pls?
November 6Nov 6 This PR should resolve the issue; https://github.com/armbian/build/pull/11035Try updating the kernel.
November 8Nov 8 On 11/6/2026 at 1:47 PM, c0rnelius said:This PR should resolve the issue; https://github.com/armbian/build/pull/11035Try updating the kernel.The issue still exists. I tested using the last version (the image from Nov 3 + all the updates). Each time I power on Orangepi RV2, i have to wait ~3 mins. I also tested Armbian Debian image several months ago. I had the same issue. I decided to continue using Orangepirv2_1.0.0_debian_trixie_minimal_linux6.6.63-v3.img because of that issue. Recently, a critical velnerability was discovered in Linux kernel (in TCP). I can't use 6.6.63 anymore because of it.I am not sure if I would experience the delay if I used an NVME SSD. I think booting from a fast MicroSD card should not be a problem. I don't know how I can troubleshoot this issue because it happens on an early stage, i.e. before Systemd starts services. I tried disconnecting all the USB devices and HDMI monitor. I does not help to fix the delay.
November 8Nov 8 4 hours ago, Nazar said:The issue still exists. I tested using the last version (the image from Nov 3 + all the updates). Each time I power on Orangepi RV2, i have to wait ~3 mins. I also tested Armbian Debian image several months ago. I had the same issue. I decided to continue using Orangepirv2_1.0.0_debian_trixie_minimal_linux6.6.63-v3.img because of that issue. Recently, a critical velnerability was discovered in Linux kernel (in TCP). I can't use 6.6.63 anymore because of it.I am not sure if I would experience the delay if I used an NVME SSD. I think booting from a fast MicroSD card should not be a problem. I don't know how I can troubleshoot this issue because it happens on an early stage, i.e. before Systemd starts services. I tried disconnecting all the USB devices and HDMI monitor. I does not help to fix the delay.Hmm. I thought this was resolved; https://github.com/armbian/build/pull/11035But apparently not.This was merged the other day; https://github.com/armbian/build/pull/11248Try disabling jpu@c02f8000 and see if it resolves the issue.https://github.com/armbian/build/pull/10518/changes#diff-87d719db1ad61c4ceacfbbd298072a93c09595c45ff7d3e9914d8f845fe8a415R860Thanx.
November 10Nov 10 On 11/8/2026 at 3:10 PM, c0rnelius said:Hmm. I thought this was resolved; https://github.com/armbian/build/pull/11035But apparently not.This was merged the other day; https://github.com/armbian/build/pull/11248Try disabling jpu@c02f8000 and see if it resolves the issue.https://github.com/armbian/build/pull/10518/changes#diff-87d719db1ad61c4ceacfbbd298072a93c09595c45ff7d3e9914d8f845fe8a415R860Thanx.I installed latest updates (kernel 6.18.62) today. Orangepi RV2 boots very fast now. Without any delay. I tested multiple times. Thanks a lot.
November 11Nov 11 Hi everyone!This is my first time attempting to boot Armbian on my Orange Pi RV2, but I can't get it to work. It gets stuck during the boot process. I've tried both the latest Armbian release and building the image myself, but every attempt gets stuck at boot.The official Ubuntu image works fine, so I don't think it's a hardware issue.What am I missing here?U-Boot SPL 2022.10_armbian-2022.10-Sd61c-Pbf4f-H0027-Vc38c-B3ba1-R448a (Nov 09 2026 - 13:47:57 +0000)[ 0.366] DDR type LPDDR4X[ 0.367] set ddr tx odt to 80ohm![ 0.376] Enable & config CLK/CA ODT[ 0.387] lpddr silicon init consume 20ms[ 0.388] Change DDR data rate to 2400MT/s[ 0.644] Boot from fit configuration x1_orangepi-rv2[ 0.646] ## Checking hash(es) for config conf_18 ... OK[ 0.651] ## Checking hash(es) for Image uboot ... crc32+ OK[ 0.662] ## Checking hash(es) for Image fdt_18 ... crc32+ OK[ 0.689] ## Checking hash(es) for config config_1 ... OK[ 0.692] ## Checking hash(es) for Image opensbi ... crc32+ OK[ 0.736]U-Boot 2022.10_armbian-2022.10-Sd61c-Pbf4f-H0027-Vc38c-B3ba1-R448a (Nov 09 2026 - 13:47:57 +0000)[ 0.743] CPU: rv64imafdcv[ 0.746] Model: ky x1 orangepi-rv2 board[ 0.750] DRAM: 8 GiB[ 0.815] Core: 414 devices, 29 uclasses, devicetree: board[ 0.828] WDT: Started PMIC_WDT with servicing (60s timeout)[ 0.832] WDT: Started watchdog@D4080000 with servicing (60s timeout)[ 0.841] MMC:[ 0.948] initialize_console_log_buffer[ 0.949] Have allocated memory for console log buffer[ 0.954] In: serial[ 0.956] Out: serial[ 0.959] Err: serial[ 1.096] SF: Detected XM25QU128C with page size 256 Bytes, erase size 64 KiB, total 16 MiBList of MTD devices:[ 1.103] * nor0[ 1.104] - device: flash@0[ 1.107] - parent: spi@d420c000[ 1.110] - driver: jedec_spi_nor[ 1.114] - path: /soc/spi@d420c000/flash@0[ 1.118] - type: NOR flash[ 1.121] - block size: 0x10000 bytes[ 1.124] - min I/O: 0x1 bytes[ 1.127] - 0x000000000000-0x000001000000 : "nor0"[ 1.132] - 0x000000000000-0x000000010000 : "bootinfo"[ 1.137] - 0x000000010000-0x000000020000 : "private"[ 1.142] - 0x000000020000-0x000000060000 : "fsbl"[ 1.147] - 0x000000060000-0x000000070000 : "env"[ 1.152] - 0x000000070000-0x0000000a0000 : "opensbi"[ 1.157] - 0x0000000a0000-0x000001000000 : "uboot"[ 1.164] RGMII interface[ 1.165] eth0: ethernet@cac80000[ 1.168] K1X: :_load_env_from_blk[ 1.193] Failed to load 'env_k1-x.txt'[ 1.194] Net: eth0: ethernet@cac80000[ 1.199] Hit any key to stop autoboot: 0[ 2.206] Loading K1 environment[ 2.255] Booting from mmc 0:1 ...[ 2.255] Retrieving file: /boot/extlinux/extlinux.conf[ 2.288] 1: Armbian-unofficial[ 2.288] Retrieving file: /boot/uInitrd[ 3.140] Retrieving file: /boot/Image[ 4.104] append: root=UUID=e26b749c-00f0-4581-9681-1245d3b715b7 earlycon=sbi console=tty1 console=ttyS0,115200 loglevel=7 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 ignore_loglevel[ 4.120] Retrieving file: /boot/dtb/spacemit/k1-orangepi-rv2.dtb[ 4.174] Uncompressing Kernel Image[ 4.539] Moving Image from 0x10000000 to 0x200000, end=29ee000[ 4.561] ## Loading init Ramdisk from Legacy Image at 21000000 ...[ 4.564] Image Name: uInitrd[ 4.568] Image Type: RISC-V Linux RAMDisk Image (gzip compressed)[ 4.574] Data Size: 13555067 Bytes = 12.9 MiB[ 4.579] Load Address: 00000000[ 4.582] Entry Point: 00000000Verifying Checksum ... OK[ 4.647] ## Flattened Device Tree blob at 31000000[ 4.648] Booting using the fdt blob at 0x31000000[ 4.653] Loading Ramdisk to 7d0aa000, end 7dd9757b ... OK[ 4.668] Loading Device Tree to 000000007d08a000, end 000000007d0a922b ... OKStarting kernel ...sys: 0x200try sd...bm:3j...U-Boot SPL 2022.10_armbian-2022.10-Sd61c-Pbf4f-H0027-Vc38c-B3ba1-R448a (Nov 09 2026 - 13:47:57 +0000)[ 0.366] DDR type LPDDR4X[ 0.368] set ddr tx odt to 80ohm![ 0.377] Enable & config CLK/CA ODT[ 0.388] lpddr silicon init consume 20ms[ 0.389] Change DDR data rate to 2400MT/s[ 0.644] Boot fr[10:44:18.395] Disconnected console.log build.log
November 11Nov 11 13 hours ago, asoilole said:Hi everyone!This is my first time attempting to boot Armbian on my Orange Pi RV2, but I can't get it to work. It gets stuck during the boot process. I've tried both the latest Armbian release and building the image myself, but every attempt gets stuck at boot.The official Ubuntu image works fine, so I don't think it's a hardware issue.What am I missing here?Remove the ignore_loglevel from the /boot/extlinux/extilinux.conf and repost please.
November 12Nov 12 On 11/12/2026 at 12:41 AM, c0rnelius said:Remove the ignore_loglevel from the /boot/extlinux/extilinux.conf and repost please.So it was the power supply issue. It's working fine now on a 30 W USB-C supply.Thanks for your help.
November 13Nov 13 10.11.2026 в 13:10, Nazar сказал:I installed latest updates (kernel 6.18.62) todayapt list --upgradable doesn't show available kernel update on Trixie. Why? And my current one is `6.18.55-current-spacemit`. Am I doing something wrong?Would love to get that boot time speed-up
November 14Nov 14 10 hours ago, VBB said:apt list --upgradable doesn't show available kernel update on Trixie. Why?For daily updates you need to switch to rolling https://docs.armbian.com/config/updates/#rolling
November 17Nov 17 Switching to rolling will get you 6.18.62, but it changes more than the kernel, so take a backup first. If you only want to see why the update isn't offered, run apt policy linux-image-current-spacemit and confirm your Armbian sources point at the stable Trixie repoapt list --upgradable only shows versions present in the repos you have enabled. The boot-time fix may also be backported later, so rolling isn't the only option.
November 20Nov 20 If NMVe is not working the first try shall be to add pcie_aspm=offto kernel boot parameters (file /boot/extlinux/extlinux.conf).
