my installed version is about a year old at least...so I'd like to upgrade without loosing settings and data.
Is this possible?
If yes, how? In doc. there is only decribte how to update the kernel, nothing else...
Thanks,
Astro
System says:
root@cubie:~# cat /etc/issue
Debian GNU/Linux CT Debian 2.7 wheezy
root@cubie:~# cat /proc/version
Linux version 3.4.104-sunxi (root@cubie) (gcc version 4.8.2 (Ubuntu/Linaro 4.8.2-16ubuntu4) ) #1 SMP PREEMPT Fri Sep 26 18:30:39 CEST 2014
thanks, I found this in Documentation, atm it doesn't work cause I have a "litle" problem with dpkg :-/...I'll try later again.
How to update scripts etc.?
Scripts are part of the board support package. For example: If you have cubietruck and wheezy:
linux-wheezy-root-cubietruck
http://www.armbian.com/kernel/
What's missing are possible new packages:
https://github.com/igorpecovnik/lib/blob/master/debootstrap.sh#L135-L141
and this
https://github.com/igorpecovnik/lib/blob/master/debootstrap.sh#L143-L154
Some of them are mandatory, so do this install too.
Great! Thanks!...
Maybe someone can give me a short hint what to do with this problem:
root@cubie:~# apt-get install mc
W: Not using locking for read only lock file /var/lib/dpkg/lock
E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem.
root@cubie:~# dpkg --configure -a
dpkg: error: unable to access dpkg status area: Read-only file system
EDIT: Looks like SD Card is nearly dead or something :-/ :
Jan  4 23:40:15 localhost kernel: [ 1300.326224] [mmc-err] smc 0 err, cmd 18,  DTO
Jan  4 23:40:15 localhost kernel: [ 1300.333891] [mmc-err] In data read operation
Jan  4 23:40:15 localhost kernel: [ 1300.343307] [mmc-msg] found data error, need to send stop command
Jan  4 23:40:15 localhost kernel: [ 1300.355359] mmcblk0: timed out sending r/w cmd command, card status 0x900
Jan  4 23:40:15 localhost kernel: [ 1300.366282] mmcblk0: not retrying timeout
Jan  4 23:40:15 localhost kernel: [ 1300.376002] end_request: I/O error, dev mmcblk0, sector 4267944
Edited by Astrofreak85
Check using dmesg why your rootfs is mounted read-only and compare the output of /etc/fstab and /etc/mtab. And if you're not suffering from a corrupted filesystem then maybe just a simple
mount -v -o remount /
might do the trick.
dmesg:
[53237.773765] [mmc-msg] found data error, need to send stop command
[53237.785822] mmcblk0: timed out sending r/w cmd command, card status 0x900
[53237.795748] mmcblk0: not retrying timeout
[53237.804772] end_request: I/O error, dev mmcblk0, sector 803008
[53297.788709] [mmc-err] smc 0 err, cmd 18,  DTO
[53297.796397] [mmc-err] In data read operation
[53297.805799] [mmc-msg] found data error, need to send stop command
[53297.822319] mmcblk0: timed out sending r/w cmd command, card status 0x900
[53297.833150] mmcblk0: not retrying timeout
[53297.842215] end_request: I/O error, dev mmcblk0, sector 803008
[53357.784933] [mmc-err] smc 0 err, cmd 18,  DTO
[53357.792632] [mmc-err] In data read operation
[53357.802046] [mmc-msg] found data error, need to send stop command
[53357.814113] mmcblk0: timed out sending r/w cmd command, card status 0x900
[53357.829171] mmcblk0: not retrying timeout
[53357.838258] end_request: I/O error, dev mmcblk0, sector 803008
fstab:
root@cubie:~# cat /etc/fstab
# UNCONFIGURED FSTAB FOR BASE SYSTEM
/dev/mmcblk0p1  /           ext4    defaults,noatime,nodiratime,data=writeback,commit=600,errors=remount-ro        0       0
/dev/sda1 /opt  ext4 defaults   0       2
mtab:
root@cubie:~# cat /etc/mtab
rootfs / rootfs rw 0 0
/dev/root / ext4 ro,noatime,nodiratime,errors=remount-ro,commit=600 0 0
devtmpfs /dev devtmpfs rw,relatime,size=1023780k,nr_inodes=182162,mode=755 0 0
sysfs /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0
tmpfs /run tmpfs rw,nosuid,noexec,relatime,size=131072k,mode=755 0 0
tmpfs /run/lock tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k 0 0
proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0
configfs /sys/kernel/config configfs rw,relatime 0 0
tmpfs /run/shm tmpfs rw,nosuid,nodev,noexec,relatime,size=131072k 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0
/dev/sda1 /opt ext4 rw,relatime,data=ordered 0 0
tmpfs /tmp tmpfs rw,nosuid,nodev,relatime,size=1048576k 0 0
OWFS /mnt/1wire fuse.OWFS rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other 0 0
Look like SD is dying (?!) Hopefully I can still make an image... :-/
Yes. Or maybe you use a fake card (only half the capacity as advertised with) and exceeded this limit. It's alway a good idea to check every flash based media prior to using it. Check the FAQ: http://www.armbian.com/documentation/
At this point I would rely on ddrescue to try to create an image, get a new card and then proceed.
Card is a Sanddisk Card...but it's now 2 years old (or even older...), since one year systems runs from SD (since the internal NAND died..)...strange
Maybe a good start for a clean system...only some little things to do, everything importand are scripts on HDD or in Backup :D
I's no problem to get a full fake card showing a major brand logo ;)
BTW: I usually let this job run weekly on Armbian servers to store the rootfs on SD card to a connected SATA/USB disk or another system:
/usr/bin/rsync -aAX --delete --delete-excluded --exclude={"/dev/*","/proc/*","/sys/*","/tmp/*","/run/*","/mnt/*","/media/*","/lost+found","/var/log.hdd","/var/swap"} /* /mnt/sda/sd-card-backup/rootfs-$i/ && touch /mnt/sda/sd-card-backup/rootfs-$i/.last_successful_run
$i is either 1 or 2 in rotation and the job stops automatically triggering an email notification when either rsync exits != 0 or the first mmc error occurs parsing dmesg after the run.
Why you run a weekly backup of your sd card instead of using rootfs directly on the sata hard drive?
Since it's a HDD I neither like the LCC problem (that many drives show: parking the heads after a few seconds of inactivity just to unramp them a few seconds later until parked to death) nor constantly spinning disks. When nothing's to do the drive has to go into standby/sleeping state (spiining down completely and only consuming 0.1W in most cases). Would it be an SSD instead the rootfs would be there (and a sync to SD card would happen).
Armbian's default settings (tmpfs, ramlog, 600 seconds commit interval) are perfect to stay with the rootfs on SD card even when a HDD is connected. That does not apply to most other distros available for SBCs.
Hum... My first board was an IGEPv2 with it's original rootfs on a new SD card. The card died after only a year, and the board was slow. I move the rootfs on a notebook hard drive and I speed up my board.
I haven't tried armian image directly on the SD card: i'm using rootfs on a Western Digital Red hard drive.
