Igor Posted April 10, 2018 Posted April 10, 2018 34 minutes ago, MunkeyBalls said: Armbian_5.42_Rock64_Debian_stretch_default_4.4.124_desktop That image 100% works: http://ix.io/17uH If you have troubles, https://docs.armbian.com/User-Guide_Getting-Started/ 35 minutes ago, MunkeyBalls said: I think the log I posted was from the latest nightly, want me to retry with the one from the main download page? Nightly images are not subject of a support. Nobody but developers care if they work or not.
MunkeyBalls Posted April 10, 2018 Posted April 10, 2018 34 minutes ago, Igor said: That image 100% works: http://ix.io/17uH If you have troubles, https://docs.armbian.com/User-Guide_Getting-Started/ Nightly images are not subject of a support. Nobody but developers care if they work or not. The one reason I tried the nightly is because the first image wouldn't boot for me. I've tried the guide before coming here, but there's probably still something I'm missing. Could it be that this has something to do with it? rock64@rock64:/boot$ ls -l total 25536 -rw-r--r-- 1 root root 4492973 Oct 12 09:15 System.map-4.4.77-rockchip-ayufan-136 -rw-r--r-- 1 root root 143541 Oct 12 09:15 config-4.4.77-rockchip-ayufan-136 lrwxrwxrwx 1 root root 49 Apr 10 19:00 dtb -> dtbs/4.4.77-rockchip-ayufan-136/rk3328-rock64.dtb lrwxrwxrwx 1 root root 49 Apr 10 19:00 dtb-4.4.77-rockchip-ayufan-136 -> dtbs/4.4.77-rockchip-ayufan-136/rk3328-rock64.dtb drwxr-xr-x 4 root root 4096 Apr 10 18:56 dtbs drwxr-xr-x 4 root root 16384 Jan 1 1970 efi -rw-r--r-- 1 root root 7491 Sep 8 2017 filesystem.packages -rw-r--r-- 1 root root 1 Sep 8 2017 filesystem.packages-remove -rw-r--r-- 1 root root 2866287 Apr 10 19:00 initrd.img-4.4.77-rockchip-ayufan-136 -rwxr-xr-x 1 root root 18606088 Oct 12 09:15 vmlinuz-4.4.77-rockchip-ayufan-136 rock64@rock64:/boot$ uname -a Linux rock64 4.4.120-rockchip-ayufan-209 #1 SMP Mon Apr 2 16:05:07 UTC 2018 aarch64 GNU/Linux This was after already removing linux-image-4.4.120-rockchip-ayufan-209 and reinstalling linux-image-4.4.77-rockchip-ayufan-136 and rebooting rock64@rock64:/boot$ sudo apt-get remove 4.4.120-rockchip-ayufan-209 [sudo] password for rock64: Reading package lists... Done Building dependency tree Reading state information... Done Note, selecting 'linux-headers-4.4.120-rockchip-ayufan-209' for regex '4.4.120-rockchip-ayufan-209' Note, selecting 'linux-image-4.4.120-rockchip-ayufan-209-dbg' for regex '4.4.120-rockchip-ayufan-209' Note, selecting 'linux-image-4.4.120-rockchip-ayufan-209' for regex '4.4.120-rockchip-ayufan-209' Note, selecting 'linux-debug-4.4.120-rockchip-ayufan-209' for regex '4.4.120-rockchip-ayufan-209' Note, selecting 'linux-modules-4.4.120-rockchip-ayufan-209' for regex '4.4.120-rockchip-ayufan-209' Note, selecting 'linux-firmware-image-4.4.120-rockchip-ayufan-209' for regex '4.4.120-rockchip-ayufan-209' Note, selecting 'linux-image-4.4.120-rockchip-ayufan-209' instead of 'linux-modules-4.4.120-rockchip-ayufan-209' Note, selecting 'linux-image-4.4.120-rockchip-ayufan-209-dbg' instead of 'linux-debug-4.4.120-rockchip-ayufan-209' Package 'linux-firmware-image-4.4.120-rockchip-ayufan-209' is not installed, so not removed Package 'linux-headers-4.4.120-rockchip-ayufan-209' is not installed, so not removed Package 'linux-image-4.4.120-rockchip-ayufan-209' is not installed, so not removed Package 'linux-image-4.4.120-rockchip-ayufan-209-dbg' is not installed, so not removed The following packages were automatically installed and are no longer required: debsums libfile-fnmatch-perl u-boot-rock64 Use 'sudo apt autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded. rock64@rock64:/boot$ sudo apt-get autoremove Reading package lists... Done Building dependency tree Reading state information... Done The following packages will be REMOVED: debsums libfile-fnmatch-perl u-boot-rock64 0 upgraded, 0 newly installed, 3 to remove and 2 not upgraded. After this operation, 1237 kB disk space will be freed. Do you want to continue? [Y/n] y (Reading database ... 86722 files and directories currently installed.) Removing u-boot-rock64 (0.6.31) ... Removing debsums (2.2.2) ... Removing libfile-fnmatch-perl (0.02-2+b3) ... Processing triggers for man-db (2.7.6.1-2) ... rock64@rock64:/boot$ sudo reboot now Using username "rock64". rock64@192.168.2.101's password: Send automatic password _ __ _ _ _ __ ___ ___| | __/ /_ | || | | '__/ _ \ / __| |/ / '_ \| || |_ | | | (_) | (__| <| (_) |__ _| |_| \___/ \___|_|\_\\___/ |_| Linux rock64 4.4.120-rockchip-ayufan-209 #1 SMP Mon Apr 2 16:05:07 UTC 2018 aarch64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law.
Igor Posted April 10, 2018 Posted April 10, 2018 1 minute ago, MunkeyBalls said: Could it be that this has something to do with it? You are not using our images.
MunkeyBalls Posted April 10, 2018 Posted April 10, 2018 34 minutes ago, Igor said: You are not using our images. I was trying to but they weren't working. Now I'm trying to figure out why it's not working but I'm a bit of a noob and could use some help. From windows I've formatted the SDCard Sandisk 10 with SDFormatter, then downloaded, checked the hash of and flashed the image you say 100% WORKS with etcher, then tried booting it but it did not work (numerous times I've repeated this). I noticed with my above problem that no matter which image I try the kernel seems to be stuck at 4.4.120-rockchip-ayufan-209, even with the old images. (after numerous reboots) Then I removed the eMMC and the kernel changed. Now gonna retry flash with armbian and try the whole process again to see if it also fixes my problem booting armbian. EDIT: Removing the emmc did the trick, it's working for me now. Knew it was something stupid I was missing.
MunkeyBalls Posted April 10, 2018 Posted April 10, 2018 So after doing apt-get update and apt-get upgrade it installed a new kernel and went back to the same behaviour as previously root@rock64:~# sudo apt-get upgrade Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: libicu57 libnss-myhostname libpam-systemd libssl-dev libssl1.0.2 libssl1.1 libsystemd0 libudev1 openssl systemd systemd-sysv thunderbird tzdata udev 14 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 54.0 MB of archives. After this operation, 142 kB of additional disk space will be used. Do you want to continue? [Y/n] y Get:1 http://security.debian.org stretch/updates/main arm64 libssl1.0.2 arm64 1.0.2l-2+deb9u3 [907 kB] Get:10 http://security.debian.org stretch/updates/main arm64 libssl-dev arm64 1.1.0f-3+deb9u2 [1,375 kB] Get:2 http://cdn-fastly.deb.debian.org/debian stretch-updates/main arm64 libsystemd0 arm64 232-25+deb9u3 [240 kB] Get:3 http://cdn-fastly.deb.debian.org/debian stretch-updates/main arm64 libnss-myhostname arm64 232-25+deb9u3 [101 kB] Get:4 http://cdn-fastly.deb.debian.org/debian stretch-updates/main arm64 libpam-systemd arm64 232-25+deb9u3 [168 kB] Get:11 http://security.debian.org stretch/updates/main arm64 libssl1.1 arm64 1.1.0f-3+deb9u2 [1,112 kB] Get:5 http://cdn-fastly.deb.debian.org/debian stretch-updates/main arm64 systemd arm64 232-25+deb9u3 [2,139 kB] Get:12 http://security.debian.org stretch/updates/main arm64 libicu57 arm64 57.1-6+deb9u2 [7,550 kB] Get:6 http://cdn-fastly.deb.debian.org/debian stretch-updates/main arm64 udev arm64 232-25+deb9u3 [1,056 kB] Get:7 http://cdn-fastly.deb.debian.org/debian stretch-updates/main arm64 libudev1 arm64 232-25+deb9u3 [115 kB] Get:8 http://cdn-fastly.deb.debian.org/debian stretch-updates/main arm64 systemd-sysv arm64 232-25+deb9u3 [81.1 kB] Get:9 http://cdn-fastly.deb.debian.org/debian stretch-updates/main arm64 tzdata all 2018d-0+deb9u1 [266 kB] Get:13 http://security.debian.org stretch/updates/main arm64 openssl arm64 1.1.0f-3+deb9u2 [697 kB] Get:14 http://security.debian.org stretch/updates/main arm64 thunderbird arm64 1:52.7.0-1~deb9u1 [38.2 MB] Fetched 54.0 MB in 2s (21.4 MB/s) Preconfiguring packages ... (Reading database ... 96979 files and directories currently installed.) Preparing to unpack .../libsystemd0_232-25+deb9u3_arm64.deb ... Unpacking libsystemd0:arm64 (232-25+deb9u3) over (232-25+deb9u2) ... Setting up libsystemd0:arm64 (232-25+deb9u3) ... (Reading database ... 96979 files and directories currently installed.) Preparing to unpack .../libnss-myhostname_232-25+deb9u3_arm64.deb ... Unpacking libnss-myhostname:arm64 (232-25+deb9u3) over (232-25+deb9u2) ... Preparing to unpack .../libpam-systemd_232-25+deb9u3_arm64.deb ... Unpacking libpam-systemd:arm64 (232-25+deb9u3) over (232-25+deb9u2) ... Preparing to unpack .../systemd_232-25+deb9u3_arm64.deb ... Unpacking systemd (232-25+deb9u3) over (232-25+deb9u2) ... Preparing to unpack .../udev_232-25+deb9u3_arm64.deb ... Unpacking udev (232-25+deb9u3) over (232-25+deb9u2) ... Preparing to unpack .../libudev1_232-25+deb9u3_arm64.deb ... Unpacking libudev1:arm64 (232-25+deb9u3) over (232-25+deb9u2) ... Setting up libudev1:arm64 (232-25+deb9u3) ... Setting up systemd (232-25+deb9u3) ... addgroup: The group `systemd-journal' already exists as a system group. Exiting. (Reading database ... 96979 files and directories currently installed.) Preparing to unpack .../0-systemd-sysv_232-25+deb9u3_arm64.deb ... Unpacking systemd-sysv (232-25+deb9u3) over (232-25+deb9u2) ... Preparing to unpack .../1-tzdata_2018d-0+deb9u1_all.deb ... Unpacking tzdata (2018d-0+deb9u1) over (2018c-0+deb9u1) ... Preparing to unpack .../2-libssl1.0.2_1.0.2l-2+deb9u3_arm64.deb ... Unpacking libssl1.0.2:arm64 (1.0.2l-2+deb9u3) over (1.0.2l-2+deb9u2) ... Preparing to unpack .../3-libssl-dev_1.1.0f-3+deb9u2_arm64.deb ... Unpacking libssl-dev:arm64 (1.1.0f-3+deb9u2) over (1.1.0f-3+deb9u1) ... Preparing to unpack .../4-libssl1.1_1.1.0f-3+deb9u2_arm64.deb ... Unpacking libssl1.1:arm64 (1.1.0f-3+deb9u2) over (1.1.0f-3+deb9u1) ... Preparing to unpack .../5-libicu57_57.1-6+deb9u2_arm64.deb ... Unpacking libicu57:arm64 (57.1-6+deb9u2) over (57.1-6+deb9u1) ... Preparing to unpack .../6-openssl_1.1.0f-3+deb9u2_arm64.deb ... Unpacking openssl (1.1.0f-3+deb9u2) over (1.1.0f-3+deb9u1) ... Preparing to unpack .../7-thunderbird_1%3a52.7.0-1~deb9u1_arm64.deb ... Unpacking thunderbird (1:52.7.0-1~deb9u1) over (1:52.6.0-1~deb9u1) ... Processing triggers for mime-support (3.60) ... Setting up libnss-myhostname:arm64 (232-25+deb9u3) ... Processing triggers for desktop-file-utils (0.23-1) ... Setting up tzdata (2018d-0+deb9u1) ... Current default time zone: 'Etc/UTC' Local time is now: Tue Apr 10 21:09:22 UTC 2018. Universal Time is now: Tue Apr 10 21:09:22 UTC 2018. Run 'dpkg-reconfigure tzdata' if you wish to change it. Setting up systemd-sysv (232-25+deb9u3) ... Setting up libicu57:arm64 (57.1-6+deb9u2) ... Setting up thunderbird (1:52.7.0-1~deb9u1) ... Setting up libssl1.0.2:arm64 (1.0.2l-2+deb9u3) ... Processing triggers for libc-bin (2.24-11+deb9u3) ... Setting up udev (232-25+deb9u3) ... addgroup: The group `input' already exists as a system group. Exiting. update-initramfs: deferring update (trigger activated) insserv: Service mountkernfs has to be enabled to start service udev Setting up libssl1.1:arm64 (1.1.0f-3+deb9u2) ... Setting up openssl (1.1.0f-3+deb9u2) ... Processing triggers for man-db (2.7.6.1-2) ... Processing triggers for dbus (1.10.26-0+deb9u1) ... Processing triggers for hicolor-icon-theme (0.15-1) ... Setting up libpam-systemd:arm64 (232-25+deb9u3) ... Setting up libssl-dev:arm64 (1.1.0f-3+deb9u2) ... Processing triggers for initramfs-tools (0.130) ... update-initramfs: Generating /boot/initrd.img-4.4.124-rk3328 update-initramfs: Converting to u-boot format Processing triggers for libc-bin (2.24-11+deb9u3) ... root@rock64:~# sudo reboot now Ill restart minicom (still haven't figured out how to do this without rebooting the whole machine) and run it with an output to file so I can show you the log. EDIT: Working again after taking power off, time to do some testing
nachoparker Posted April 11, 2018 Posted April 11, 2018 Hello gentlement, I am interested in building a stable armbian image with a customized init script to pregenerate NextCloudPi images for this board, as I did with the Odroid HC1 Could someone kindly point me to the exact parameters / commit version so I can replicate one of the tested builds that boot and work? Many thanks!
Igor Posted April 11, 2018 Posted April 11, 2018 11 hours ago, MunkeyBalls said: and could use some help. Not possible. You are not listening and reading what is written. Everything you claim, it is not working, works. If you are a noob why are you installing a kernel that is not fully compatible? Where did we put such instructions? If you are using armbian, you should only use kernels we prepare ... of course you can use other (compatible) kernels, but in that case, you have to understand what you are doing. This forum is support for armbian builds, anything else is ignored. We don't support any 3rd party kernels since supporting own creations is already expensive enough. All this is written in the documentation, which is written with a reason that we don't waste time repeating things over and over again. Again. This is your first start: https://docs.armbian.com/
Igor Posted April 11, 2018 Posted April 11, 2018 28 minutes ago, nachoparker said: Could someone kindly point me to the exact parameters / commit version so I can replicate one of the tested builds that boot and work? https://www.armbian.com/rock64/ Both are tested.
nachoparker Posted April 11, 2018 Posted April 11, 2018 1 minute ago, Igor said: https://www.armbian.com/rock64/ Both are tested. Thanks for your answer. My intention is to build a custom version of those images. Those images are tested, so I know that they boot, now I would like to know how to build exactly that image so I can add my own userpatches/customize-image.sh as I have done in the past with the odroid HC1. I probably need the armbian repo commit that builds those images (I am interested in the Stretch one), and also the build parameters, for instance BOARD=rock64 BRANCH=default KERNEL_ONLY=no KERNEL_CONFIGURE=no RELEASE=stretch BUILD_DESKTOP=no I could not find this information, I apologize if I it's there somewhere and I haven't seen it. Thanks
Igor Posted April 11, 2018 Posted April 11, 2018 1 minute ago, nachoparker said: I could not find this information, I apologize if I it's there somewhere and I haven't seen it. This image is officially still WIP/testing phase. Add parameter EXPERT=yes
MunkeyBalls Posted April 11, 2018 Posted April 11, 2018 2 hours ago, Igor said: Not possible. You are not listening and reading what is written. Everything you claim, it is not working, works. If you are a noob why are you installing a kernel that is not fully compatible? Where did we put such instructions? If you are using armbian, you should only use kernels we prepare ... of course you can use other (compatible) kernels, but in that case, you have to understand what you are doing. This forum is support for armbian builds, anything else is ignored. We don't support any 3rd party kernels since supporting own creations is already expensive enough. All this is written in the documentation, which is written with a reason that we don't waste time repeating things over and over again. Again. This is your first start: https://docs.armbian.com/ I read the guide, didn't install any kernels only tried booting another image to try out and figure what was going wrong. The reason the image didn't boot was because I still had the emmc card in the Rock64 and somehow even though it boots the image from the SDCard it uses the kernel from the emmc. I'm sorry if this is common knowledge but I still can't find that anywhere in the docs, I thought it was possible to dual boot on the device.
Igor Posted April 11, 2018 Posted April 11, 2018 1 hour ago, MunkeyBalls said: The reason the image didn't boot was because I still had the emmc card in the Rock64 and somehow even though it boots the image from the SDCard it uses the kernel from the emmc. Aha. This is a problem of a system which is on eMMC. This device is not officially supported yet so you won't find a lot of specifics information yet. I tried eMMC install (with our general install tool called nand-sata-install or from armbian-config) and it is broken, but boot from SPI works ... There are rough edges and that's why we keep this image labeled WIP.
MunkeyBalls Posted April 11, 2018 Posted April 11, 2018 29 minutes ago, Igor said: Aha. This is a problem of a system which is on eMMC. This device is not officially supported yet so you won't find a lot of specifics information yet. I tried eMMC install (with our general install tool called nand-sata-install or from armbian-config) and it is broken, but boot from SPI works ... There are rough edges and that's why we keep this image labeled WIP. I know it's a WIP and it's ok to run into problems, but try and keep that in mind when people run into problems. You came off as a bit hostile while I'm only trying to see if someone with more experience had an idea what was going on. I appreciate the work you guys put into making this for the community for free, keep it the awesome work!
Igor Posted April 11, 2018 Posted April 11, 2018 No problem, at least we find the source of troubles. My hostile reaction was due to the fact you were technically not running Armbian at all, claiming it doesn't run and asking for help even we actually dont provide any support for this kind of builds. Wrote on mobile
q-bert Posted April 12, 2018 Posted April 12, 2018 What are the CPU and RAM clock rates? Is AES / crypto enabled?
chwe Posted April 12, 2018 Posted April 12, 2018 4 minutes ago, q-bert said: Is AES / crypto enabled? btw. We have some special features on our site called: SEARCH an amazing tool to find informations about the things you search for...
q-bert Posted April 12, 2018 Posted April 12, 2018 18 minutes ago, chwe said: btw. We have some special features on our site called: SEARCH an amazing tool to find informations about the things you search for... 18 minutes ago, chwe said: btw. We have some special features on our site called: SEARCH an amazing tool to find informations about the things you search for... Quote
q-bert Posted April 12, 2018 Posted April 12, 2018 I should have been more specific: Is AES/Crypto enabled and what are the CPU and RAM clock rates using Armbian's latest nightly Rock images? I used the search functionality and read the quoted threads weeks ago. But I also tried several of Ayufan's and also Dietpi Rock64 images and with some AES/Crypto was disabled... I did not ask if this board supports it or not.
Igor Posted April 12, 2018 Posted April 12, 2018 18 minutes ago, q-bert said: I should have been more specific: Is AES/Crypto enabled and what are the CPU and RAM clock rates using Armbian's latest nightly Rock images? I would need to download and burn the image to be sure I am telling you correct info, but you can do that on your own as well. 18 minutes ago, q-bert said: But I also tried several of Ayufan's and also Dietpi Rock64 images and with some AES/Crypto was disabled Waste of time. Dietpi is a BASH creation on top of Ayufan image. Download Armbian and see what's in and what's missing. If something is missing and only need to be enabled ... no problem. Submit a patch (to this file) and the very next day this feature is enabled in a (beta/nightly) repository.
chwe Posted April 12, 2018 Posted April 12, 2018 As far as I see, AES should be enabled by default no matter which kernel you use (dev or default). https://github.com/armbian/build/blob/1034f68ff0f4e6f4c864f2f53958ca65aa6d693e/config/kernel/linux-rk3328-dev.config#L4778 https://github.com/armbian/build/blob/1034f68ff0f4e6f4c864f2f53958ca65aa6d693e/config/kernel/linux-rk3328-default.config#L5737 but as Igor suggested, testing might be much faster than waiting until someone has confirmed it. Especially when you have tested other images the efforts to test Armbians nightly is a minor effort..
q-bert Posted April 12, 2018 Posted April 12, 2018 9 minutes ago, Igor said: I would need to download and burn the image to be sure I am telling you correct info, but you can do that on your own as well. Waste of time. Dietpi is a BASH creation on top of Ayufan image. Download Armbian and see what's in and what's missing. If something is missing and only need to be enabled ... no problem. Submit a patch (to this file) and the very next day this feature is enabled in a (beta/nightly) repository. Thanks Igor. I was hoping someone already did that and would share his experience in this thread.
q-bert Posted April 12, 2018 Posted April 12, 2018 1 minute ago, chwe said: As far as I see, AES should be enabled by default no matter which kernel you use (dev or default). https://github.com/armbian/build/blob/1034f68ff0f4e6f4c864f2f53958ca65aa6d693e/config/kernel/linux-rk3328-dev.config#L4778 https://github.com/armbian/build/blob/1034f68ff0f4e6f4c864f2f53958ca65aa6d693e/config/kernel/linux-rk3328-default.config#L5737 but as Igor suggested, testing might be much faster than waiting until someone has confirmed it. Especially when you have tested other images the efforts to test Armbians nightly is a minor effort.. Thanks, that helps me a lot. Where do you set CPU and RAM clock speeds for you build process / images? Is that set in the bootloader / uboot?
Homoran Posted April 14, 2018 Posted April 14, 2018 On 11.4.2018 at 3:37 PM, Igor said: This device is not officially supported yet so you won't find a lot of specifics information yet. I tried eMMC install (with our general install tool called nand-sata-install or from armbian-config) and it is broken, but boot from SPI works ... Hi Igor, I can confirm this issue. last week I had to reinstall armbian and it won't start. After installing to eMMC from an SD card via armbian-config, removing the card and rebooting - there was apparently nothing. A ping to the Rock64 was possible, but nothing else. I tried a lot, even some more images I had downloaded earlier. The first one (out of my downloads) that worked was Armbian_5.32.170919_Rock64_Ubuntu_xenial_default_4.4.77.img armbian-config wasn't supplied, but was automatically installed when calling the command sudo armbian-config After moving to eMMC and removing the SD-Card all worked well, even all updates and upgrades. Hope this may help a little on searching (and finding) the reason for it. EDIT: I was told that installing the image directly to the eMMC using an USB-to-eMMC Adapter will produce a bootable Armbian Greets Rainer
Igor Posted April 14, 2018 Posted April 14, 2018 4 hours ago, Homoran said: I tried a lot, even some more images I had downloaded earlier. Rainer, thank you. Fixed:https://github.com/armbian/build/commit/28feb0269a8f084e23f0760ab5a19ab6b12b174f Will show up in next nightly update.
Homoran Posted April 17, 2018 Posted April 17, 2018 Hi Igor, On 14.4.2018 at 7:58 PM, Igor said: Will show up in next nightly update. Thank you, in Armbian_5.43.180415_Rock64_Debian_stretch_dev_4.16.0-rc6.img it works again! Greetz Rainer
matteobp Posted April 18, 2018 Author Posted April 18, 2018 Yesterday I downloaded the latest "Debian desktop" image (it should be 5.42) linked herehttps://www.armbian.com/rock64/ but I'm still having the error reported below. I have never been able to run a version of Armbian on my Rock 64 (1GB version) . I'm currently using Armbian (Debian) on an Orange Pi+ without any problem. What's the problem? Can someone help me please? Welcome to minicom 2.7.1 OPTIONS: I18n Compiled on Aug 13 2017, 15:25:34. Port /dev/ttyUSB0, 20:57:55 Press CTRL-A Z for help on special keys DDR version 1.06 20170424 In LPDDR3 786MHz Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=32 Size=1024MB ddrconfig:1 OUT U-Boot SPL 2017.09-g5a90a9a (Jan 12 2018 - 11:06:01) setup_ddr_param 1 booted from SPI flash Trying to boot from SPI NOTICE: BL31: v1.3(release):f947c7e NOTICE: BL31: Built : 11:06:00, Jan 12 2018 NOTICE: BL31:Rockchip release version: v1.3 U-Boot 2017.09-g5a90a9a (Jan 12 2018 - 11:06:15 +0000), Build: jenkins-linux-build-rock-64-177 Model: Pine64 Rock64 DRAM: 1022 MiB MMC: rksdmmc@ff520000: 0, rksdmmc@ff500000: 1 *** Warning - bad CRC, using default environment In: serial@ff130000 Out: serial@ff130000 Err: serial@ff130000 Model: Pine64 Rock64 misc_init_r cpuid=55524b503039303038000000000d2b11 serial=ea6ec868699cad5 Net: eth0: ethernet@ff540000 Hit any key to stop autoboot: 0 Card did not respond to voltage select! mmc_init: -95, time 9 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 2960 bytes read in 27 ms (106.4 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 112 bytes read in 21 ms (4.9 KiB/s) "Synchronous Abort" handler, esr 0x96000210 ELR: 3ff77944 LR: 3ff75eb0 x0 : 000000003df2e9b0 x1 : 0000000044000000 x2 : 0000000000000070 x3 : 0000000000000000 x4 : 0000000000000070 x5 : 000000000000000e x6 : 0000000000000000 x7 : 0000000000000000 x8 : 0000000000000000 x9 : 0000000000000008 x10: 000000003df2e9c0 x11: 000000003df13b70 x12: 0000000000000000 x13: 0000000000000200 x14: 000000003df04bfc x15: 00000000ffffffff x16: 0000000060df18a6 x17: 0000000070a12210 x18: 000000003df0ce08 x19: 0000000000000000 x20: 0000000000000070 x21: 0000000044000000 x22: 000000003df2e9b0 x23: 000000003ffa0118 x24: 0000000000000000 x25: 0000000000000000 x26: 000000000000000a x27: 0000000000000001 x28: 0000000000000000 x29: 000000003df02b10 Resetting CPU ... DDR version 1.06 20170424 In SRX LPDDR3 786MHz Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=32 Size=1024MB ddrconfig:1 OUT U-Boot SPL 2017.09-g5a90a9a (Jan 12 2018 - 11:06:01) setup_ddr_param 1 booted from SPI flash Trying to boot from SPI NOTICE: BL31: v1.3(release):f947c7e NOTICE: BL31: Built : 11:06:00, Jan 12 2018 NOTICE: BL31:Rockchip release version: v1.3 U-Boot 2017.09-g5a90a9a (Jan 12 2018 - 11:06:15 +0000), Build: jenkins-linux-build-rock-64-177 Model: Pine64 Rock64 DRAM: 1022 MiB MMC: rksdmmc@ff520000: 0, rksdmmc@ff500000: 1 *** Warning - bad CRC, using default environment In: serial@ff130000 Out: serial@ff130000 Err: serial@ff130000 Model: Pine64 Rock64 misc_init_r cpuid=55524b503039303038000000000d2b11 serial=ea6ec868699cad5 normal boot Net: eth0: ethernet@ff540000 Hit any key to stop autoboot: 0 Card did not respond to voltage select! mmc_init: -95, time 9 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 2960 bytes read in 28 ms (102.5 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 112 bytes read in 22 ms (4.9 KiB/s) "Synchronous Abort" handler, esr 0x96000210 ELR: 3ff77944 LR: 3ff75eb0 x0 : 000000003df2e9d0 x1 : 0000000044000000 x2 : 0000000000000070 x3 : 0000000000000000 x4 : 0000000000000070 x5 : 000000000000000e x6 : 0000000000000000 x7 : 0000000000000000 x8 : 0000000000000000 x9 : 0000000000000008 x10: 000000003df2e9e0 x11: 000000003df13b70 x12: 0000000000000000 x13: 0000000000000200 x14: 000000003df04bfc x15: 00000000ffffffff x16: 0000000060df18a6 x17: 0000000070a12210 x18: 000000003df0ce08 x19: 0000000000000000 x20: 0000000000000070 x21: 0000000044000000 x22: 000000003df2e9d0 x23: 000000003ffa0118 x24: 0000000000000000 x25: 0000000000000000 x26: 000000000000000a x27: 0000000000000001 x28: 0000000000000000 x29: 000000003df02b10 Resetting CPU ...
q-bert Posted April 24, 2018 Posted April 24, 2018 finally had some time to flash Armbian_5.43.180423_Rock64_Debian_stretch_dev_4.16.0-rc6: root@rock64:/share# openssl speed -elapsed -evp aes-256-cbc type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes 16384 bytes aes-256-cbc 82888.98k 235948.63k 427434.41k 550766.25k 600880.47k 604788.05k
Set3 Posted June 5, 2018 Posted June 5, 2018 Hi guys, same problem here as matteobp 2 messages up, Rock64 1GB in boot loop ( same output found on UART ) I tried 2 1GB Rock64 devices, both same problem. Believe me, I know how to install Armbian on Banana/Orange pi and loving it :-). using etcher etc. I have over 20+ running using Docker, TvHeadEnd, SATIP, NodeRed MySQL servers, etc etc. The Pine bionic-minimal-rock64-0.6.44-239-armhf.img works The Pine OMV from works ( nice and fast file transfer, 80MBps, and with usb 3.0 hub, got my 4 HDD NAS working.) But I want Armbian naturally on all Pis ( OK not Raspberry, I understand and agree ) I tried 8 Armbian images so far, but all failed. Coming days I can try more if not all ;-( to see if one does work ) I see above, that Igor says, the standard images work for him, but perhaps he is not using the 1GB Rock64 ? Could that be the problem ? I had 2 times, that minicom stopped after "DRAM" and no size, but stopped. Is there newer / older hardware ? My board says : Rock64 V2.0 2017-0713 no eMMC fitted, no jumper ( tried with, no success either) I tried the current images (https://www.armbian.com/rock64/) and Armbian_5.46.180602_Rock64_Debian_stretch_dev_4.17.0-rc6.img and a few others No succes. Please dont get me using Rock64 without Armbian ;-)
Igor Posted June 5, 2018 Posted June 5, 2018 3 hours ago, Set3 said: I see above, that Igor says, the standard images work for him, but perhaps he is not using the 1GB Rock64 ? Mine has 4GB. If I understand correctly, there is a problem already before u-boot? But Xenial image with kernel 4.4.y works?
Set3 Posted June 5, 2018 Posted June 5, 2018 Hi Igor, It was late yesterday, so just to be sure I was not dreaming, I did a restart : I use Rock64 to replace Orange Pi 2E Plus as headless server with Docker as a platform for multiple applications, and looking at memory usage before, I saw no need for more than 1GB to be honest. I use 5V2A and 5V3A supply, a few Samsung 16GB Evo+, etcher, that work fine with OrangePi I have 2 Rock64 1GB, and used the current images from https://www.armbian.com/rock64/ None of these 3 work on either of the 2 sbc-s : 1. Armbian_5.42_Rock64_Debian_stretch_default_4.4.124_desktop 2. Armbian_5.42_Rock64_Ubuntu_xenial_default_4.4.124.img 3. Armbian_5.44.180515_Rock64_Ubuntu_bionic_dev_4.17.0-rc3.img After testing with Armbian, I used the Pine64 bionic-minimal-rock64-0.6.44-239-armhf.img on the same SD card, sbc, supply, and that boots and seems to work fine on HDMI and ssh. Let me know if you need more info / testing. Results : So I see "Found U-Boot script /boot/boot.scr" but before that there are also errors/warnings, but I am not sure if that is supposed to be like that. I think the output is the same, but for completeness : 1. Spoiler DDR version 1.06 20170424 In SRX LPDDR3 786MHz Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=32 Size=1024MB ddrconfig:1 OUT Boot1 Release Time: 2017-05-18, version: 2.43 ChipType = 0x11, 189 emmc reinit emmc reinit SdmmcInit=2 20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=15304MB FwPartOffset=2000 , 0 StorageInit ok = 49256 Raw SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit ret = 0, SecureMode = 0 LoadTrustBL No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xa4cf8 RunBL31 0x10000 NOTICE: BL31: v1.3(debug):f947c7e NOTICE: BL31: Built : 18:38:03, Mar 12 2018 NOTICE: BL31:Rockchip release version: v1.3 INFO: ARM GICv2 driver initialized INFO: Using rkfiq sec cpu_context! INFO: boot cpu mask: 1 INFO: plat_rockchip_pmu_init: pd status 0xe INFO: BL31: Initializing runtime services INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09-armbian (Mar 28 2018 - 17:14:43 +0200) Model: Pine64 Rock64 DRAM: 1022 MiB MMC: rksdmmc@ff520000: 0, rksdmmc@ff500000: 1 *** Warning - bad CRC, using default environment In: serial@ff130000 Out: serial@ff130000 Err: serial@ff130000 Model: Pine64 Rock64 misc_init_r cpuid=xxx serial=xxx normal boot Net: eth0: ethernet@ff540000 Hit any key to stop autoboot: 0 Card did not respond to voltage select! mmc_init: -95, time 9 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 2960 bytes read in 27 ms (106.4 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 112 bytes read in 21 ms (4.9 KiB/s) "Synchronous Abort" handler, esr 0x96000210 ELR: 3ff77168 LR: 3ff75700 x0 : 000000003df2d9d0 x1 : 0000000044000000 x2 : 0000000000000070 x3 : 0000000000000000 x4 : 000000000000000e x5 : 0000000000000070 x6 : 0000000000000000 x7 : 0000000000000000 x8 : 0000000000000044 x9 : 0000000000000008 x10: 000000003df2d9e0 x11: 000000003df12b70 x12: 0000000000000000 x13: 0000000000000200 x14: 000000003df03bfc x15: 00000000ffffffff x16: 000000008d1bcd85 x17: 00000000605202c9 x18: 000000003df0be08 x19: 0000000000000000 x20: 0000000044000000 x21: 000000003df2d9d0 x22: 000000003ff9f7b0 x23: 0000000000000000 x24: 0000000000000000 x25: 000000000000000a x26: 0000000000000001 x27: 0000000000000070 x28: 0000000000000000 x29: 000000003df01b10 Resetting CPU ... and repeats 2. Spoiler DDR version 1.06 20170424 In SRX LPDDR3 786MHz Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=32 Size=1024MB ddrconfig:1 OUT Boot1 Release Time: 2017-05-18, version: 2.43 ChipType = 0x11, 188 emmc reinit emmc reinit SdmmcInit=2 20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=15279MB FwPartOffset=2000 , 0 StorageInit ok = 49099 Raw SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit ret = 0, SecureMode = 0 LoadTrustBL No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xa4cf8 RunBL31 0x10000 NOTICE: BL31: v1.3(debug):f947c7e NOTICE: BL31: Built : 18:38:03, Mar 12 2018 NOTICE: BL31:Rockchip release version: v1.3 INFO: ARM GICv2 driver initialized INFO: Using rkfiq sec cpu_context! INFO: boot cpu mask: 1 INFO: plat_rockchip_pmu_init: pd status 0xe INFO: BL31: Initializing runtime services INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09-armbian (Mar 28 2018 - 17:14:43 +0200) Model: Pine64 Rock64 DRAM: 1022 MiB MMC: rksdmmc@ff520000: 0, rksdmmc@ff500000: 1 *** Warning - bad CRC, using default environment In: serial@ff130000 Out: serial@ff130000 Err: serial@ff130000 Model: Pine64 Rock64 misc_init_r cpuid=xxx serial=xxx normal boot Net: eth0: ethernet@ff540000 Hit any key to stop autoboot: 0 Card did not respond to voltage select! mmc_init: -95, time 10 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 2960 bytes read in 34 ms (85 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 112 bytes read in 28 ms (3.9 KiB/s) "Synchronous Abort" handler, esr 0x96000210 ELR: 3ff77168 LR: 3ff75700 x0 : 000000003df2d9d0 x1 : 0000000044000000 x2 : 0000000000000070 x3 : 0000000000000000 x4 : 000000000000000e x5 : 0000000000000070 x6 : 0000000000000000 x7 : 0000000000000000 x8 : 0000000000000044 x9 : 0000000000000008 x10: 000000003df2d9e0 x11: 000000003df12b70 x12: 0000000000000000 x13: 0000000000000200 x14: 000000003df03bfc x15: 00000000ffffffff x16: 000000008d1bcd85 x17: 00000000605202c9 x18: 000000003df0be08 x19: 0000000000000000 x20: 0000000044000000 x21: 000000003df2d9d0 x22: 000000003ff9f7b0 x23: 0000000000000000 x24: 0000000000000000 x25: 000000000000000a x26: 0000000000000001 x27: 0000000000000070 x28: 0000000000000000 x29: 000000003df01b10 Resetting CPU ... and repeats 3. Spoiler DDR version 1.06 20170424 In SRX LPDDR3 786MHz Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=32 Size=1024MB ddrconfig:1 OUT Boot1 Release Time: 2017-05-18, version: 2.43 ChipType = 0x11, 189 emmc reinit emmc reinit SdmmcInit=2 20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=15279MB FwPartOffset=2000 , 0 StorageInit ok = 49100 Raw SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit ret = 0, SecureMode = 0 LoadTrustBL No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0x97af0 RunBL31 0x10000 NOTICE: BL31: v1.3(debug):f947c7e NOTICE: BL31: Built : 18:38:03, Mar 12 2018 NOTICE: BL31:Rockchip release version: v1.3 INFO: ARM GICv2 driver initialized INFO: Using rkfiq sec cpu_context! INFO: boot cpu mask: 1 INFO: plat_rockchip_pmu_init: pd status 0xe INFO: BL31: Initializing runtime services INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2018.01-rc2-armbian (May 14 2018 - 20:13:51 +0200) Model: Pine64 Rock64 DRAM: 1022 MiB MMC: rksdmmc@ff520000: 0, rksdmmc@ff500000: 1 *** Warning - bad CRC, using default environment In: serial@ff130000 Out: serial@ff130000 Err: serial@ff130000 Model: Pine64 Rock64 Net: eth0: ethernet@ff540000 Hit any key to stop autoboot: 0 Card did not respond to voltage select! mmc_init: -95, time 10 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 2958 bytes read in 34 ms (85 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 113 bytes read in 28 ms (3.9 KiB/s) "Synchronous Abort" handler, esr 0x96000210 ELR: 25e348 LR: 25c994 x0 : 000000003df3bc80 x1 : 0000000044000000 x2 : 0000000000000071 x3 : 0000000000000000 x4 : 000000000000000e x5 : 0000000000000070 x6 : 0000000000000048 x7 : 000000003ffa2560 x8 : 0000000000000044 x9 : 0000000000000008 x10: 000000003df3bc80 x11: 000000003df20d70 x12: 0000000000000000 x13: 0000000000000200 x14: 000000003df130bc x15: 00000000ffffffff x16: 000000008d1bcd85 x17: 00000000605202c9 x18: 000000003df1ae10 x19: 0000000000000000 x20: 0000000044000000 x21: 000000003df3bc80 x22: 000000003ffa43f8 x23: 0000000000000000 x24: 0000000000000000 x25: 000000000000000a x26: 0000000000000001 x27: 0000000000000071 x28: 0000000000000000 x29: 000000003df10fd0 Resetting CPU ... and repeats
