Hello!
I wanted to install the Armbian 26.2.1 Minimal / IOT  to an Ordoid HC2 (using the XU4 distro).
Download ok - sha hash is ok - balena etcher ok - startup - ok.
Problem: When I log in the first time with "root", the "1234" as first password is not accepted.
Also, PUTTY warns that ths ssh of the armbian uses only "Diffie-hellmann-group1-sha1" which (for PUTTY) is a bit unsecure.
Any idea about the password issue?
Posted (edited)
that is why i am confused,
I used the one image from here (armbian.com) https://www.armbian.com/odroid-xu4/
edit: what happens if the SBC starts the first time and you cut the power before hooking up with ssh - does it fall back to other credentials?
P.P.S: did a new install and 1234 just got me a "access denied" on the first attempt directly after boot
Edited by Sebas07
Trouble with SSH client or failed SD card could explain this. We didn't change anything in this regard. SSH settings are Debian / Ubuntu defaults. We are not altering this.
I tested latest image on XU4 and - it worked.
If I understand you correctly: root via ssh is not allowed by default
I usually setup (new) SBC's in a different way, but last time testing 2 of my boards with 26.2 minimal/IoT fresh image was via serial console, have not used ssh and certainly not putty.
If no (serial) console, you might also have sme networking firewall issues somewhere in Windows or so, although would be vary rare.
Have you setup a normal user first via (serial) console first?
