tpc010 11 Posted December 6, 2017 Share Posted December 6, 2017 (edited) UPDATE: Today I build it again and now it's working, I think someone has change something. Thank you :-) OLD: I created an new board, based on the lime-a33.conf with BOOTCONFIG="q8_a33_tablet_1024x600_defconfig" and build a Debian Stretch Image with mainline Kernel 4.13 / 4.14. The SD Card is booting with a nice screen output but only to Kernel Boot, then the screen freezes. The Serial connection is only in the SD Adapter and I cant use it if I'm booting from it, or is there a possibility ?? I was checking devuan.org and this Image is booting the Tablet, with Kernel 4.1x. So I want to debug the Armbian Kernel with serial output and I used fastboot for it, I'm booting into fastboot with "adb reboot bootloader" and then I'm sending the bootimage with fastboot ( first I created a image with mkimage with and without dtb file) fastboot -c "console=ttyS0,115200" boot uImage But I get this error from armbian Kernel Starting kernel ... Uncompressing Linux... done, booting the kernel. Error: unrecognized/unsupported machine ID (r1 = 0x00001029). Available machine support: ID (hex) NAME ffffffff Generic DT based system ffffffff Allwinner sun9i Family ffffffff Allwinner sun8i Family ffffffff Allwinner sun7i (A20) Family ffffffff Allwinner sun6i (A31) Family ffffffff Allwinner sun4i/sun5i Families Please check your kernel config and/or bootloader. Full Log is attached. I checked a lot of things, but I can't find a solution to solve this problem, the devuan.org Kernel is booting this way, until it can't find the SD Card. Thanks for your Help log1.txt Edited December 15, 2017 by tpc010 0 Quote Link to post Share on other sites
markbirss 6 Posted September 15, 2018 Share Posted September 15, 2018 @tpc010 What specific tablet you are using ? Are you able to boot a Armbian build image directly from sdcard now? 0 Quote Link to post Share on other sites
tpc010 11 Posted September 25, 2018 Author Share Posted September 25, 2018 On 9/15/2018 at 10:19 PM, markbirss said: @tpc010 What specific tablet you are using ? Are you able to boot a Armbian build image directly from sdcard now? Hi Markbirss, I checked it again with current build and it's working with module "g_serial" add to boards/lime-a33.conf config/boards/a33-q8-tablet2.conf # A33 quad core 1Gb SoC BOARD_NAME="q8 A33" BOARDFAMILY="sun8i" # depending of board and resolution use a defconfig file from sources/u-boot/v2018.05/configs BOOTCONFIG="q8_a33_tablet_1024x600_defconfig" #MODULES="hci_uart gpio_sunxi rfcomm hidp bonding spi_sun7i 8021q a20_tp" MODULES="hci_uart gpio_sunxi rfcomm hidp bonding spi_sun7i 8021q a20_tp g_serial gslx680 gc0312 gc2145 rtl8150" MODULES_NEXT="hci_uart gpio_sunxi rfcomm hidp bonding spi_sun7i 8021q a20_tp g_serial gslx680 gc0312 gc2145 rtl8150" OVERLAY_PREFIX="sun8i-a33" # KERNEL_TARGET="next" CLI_TARGET="stretch:next" DESKTOP_TARGET="" # RECOMMENDED="Debian_stretch_next:75" ~/armbian/cache/sources/u-boot/v2018.05/configs$ ls -1 *[Aa]33* A33-OLinuXino_defconfig q88_a33_tablet_1024x600_defconfig q8_a33_tablet_1024x600_defconfig q8_a33_tablet_800x480_defconfig Sinlinx_SinA33_defconfig I had to disable the pwm_bl module, otherwise the screen will go black while boot. echo blacklist pwm_bl>/etc/modprobe.d/pwm.conf I checked it with some Allwinner A33 Tablets from eBay or Amazon, the touch isn't working at the moment, but I hope I have time to check it in the future. 1 Quote Link to post Share on other sites
markbirss 6 Posted October 10, 2018 Share Posted October 10, 2018 @tpc010 unfortunately my A33 tablet, does not start at all from sdcard no matter what A33 image or u-boot i try. fel-storage does not work for me either, so im stuck NeonNiQ NQT-7W tablet from South Africa, running Android 5.1 7inch 1024x600, 512mb ram, 8Gb storage 0 Quote Link to post Share on other sites
guidol 271 Posted October 11, 2018 Share Posted October 11, 2018 On 9/25/2018 at 6:12 PM, tpc010 said: I checked it with some Allwinner A33 Tablets from eBay or Amazon, the touch isn't working at the moment, but I hope I have time to check it in the future. which one from ebay would work (without touch)? 0 Quote Link to post Share on other sites
tpc010 11 Posted October 11, 2018 Author Share Posted October 11, 2018 10 hours ago, guidol said: which one from ebay would work (without touch)? Tablets like this, I bought it at ebay with broken Touch for testing, also a broken 10,1" Tablet, this was also working for testing, and an A88S from alldaymall. Wifi is also working, but this can change from tablet to tablet. Yuntab Q88H - 7 Zoll Tablet PC,Android 4.4, Quad Core, HD 1024x600, Dual-Kamera, Bluetooth, Wi-Fi, 8GB https://www.amazon.de/dp/B01IJRDGGK 2 Quote Link to post Share on other sites
markbirss 6 Posted December 5, 2018 Share Posted December 5, 2018 @tpc010 is it possible for you to share your last known working image ? I found a YunTab 7, but my build stuck at starting kernel.... 0 Quote Link to post Share on other sites
tpc010 11 Posted December 10, 2018 Author Share Posted December 10, 2018 On 12/5/2018 at 7:40 PM, markbirss said: @tpc010 is it possible for you to share your last known working image ? I found a YunTab 7, but my build stuck at starting kernel.... Hi, sorry for the late response, do you blacklisted the pwm module? Otherwise the screen will go black. "echo blacklist pwm_bl>/etc/modprobe.d/pwm.conf" Do you have some last messages before the kernel stuck? At the moment I have no time to build a clean Image, sorry. I hope next week. br 0 Quote Link to post Share on other sites
markbirss 6 Posted December 10, 2018 Share Posted December 10, 2018 I did blacklist the pwm_bl on the card, but it just stuck at Starting Kernel... Did you need to set via u-boot console the disp parameter at all? it seems my bootup want to change video mode ? 0 Quote Link to post Share on other sites
tpc010 11 Posted December 10, 2018 Author Share Posted December 10, 2018 Important is the correct defconfig for the tablet, you have to test some of them. The only thing I changed was the BOOTCONFIG line and add the g_serial to the modules for OTG USB (and wifi modules) check if there is a newer or different version in u-boot armbian/cache/sources/u-boot/v2018.XX/configs$ ls -1 *[Aa]33* A33-OLinuXino_defconfig q88_a33_tablet_1024x600_defconfig q8_a33_tablet_1024x600_defconfig q8_a33_tablet_800x480_defconfig Sinlinx_SinA33_defconfig 0 Quote Link to post Share on other sites
markbirss 6 Posted December 19, 2018 Share Posted December 19, 2018 I don't have other u-boot configs to try and the previous version do the same 0 Quote Link to post Share on other sites
tpc010 11 Posted December 19, 2018 Author Share Posted December 19, 2018 Hi, I build a new Image, q88_a33_tablet_1024x600_defconfig is not booting but q8_a33_tablet_1024x600_defconfig is working on my YUNTAB. The compressed Image is around 250MB, without Desktop. Do you have a storage where I can put the image file? You only have to add the file pwm.conf to /etc/modprobe.d/ br pwm.conf 0 Quote Link to post Share on other sites
markbirss 6 Posted December 21, 2018 Share Posted December 21, 2018 @tpc010 oh thank you! for building, i will send link to where to store image (personal message) 0 Quote Link to post Share on other sites
Danilo Almeida 0 Posted August 21, 2019 Share Posted August 21, 2019 Hello, could you upload the image you developed? otherwise have any tutorial to build and exchange script.bin in the project? thank you very much 0 Quote Link to post Share on other sites
