dev-null Posted 2 hours ago Posted 2 hours ago (edited) Just a warning for everyone, the new kernel update (6.18.xx I think?) absolutely wrecks the system (atleast it does on Ubuntu Noble). It doesn't boot at all anymore I needed to recover an old kernel from an old backup I had and overwrite the current kernel from rescue mode/petitboot. Kernel 6.12.xx seems to work fine(ish) Just a heads up because I don't know enough to pinpoint the exact cause. p.s. for me the kernel means the files in /boot not sure if I used proper terminology Edited 2 hours ago by dev-null 0 Quote
dev-null Posted 1 hour ago Author Posted 1 hour ago (edited) @Werner Which logs would be usefull? I have a full image from the broken state. Kern.log is empty (0 bytes) syslog only has log from the last shutdown and ends there dmesg is from last startup before the system broke Edited 1 hour ago by dev-null 0 Quote
dev-null Posted 1 hour ago Author Posted 1 hour ago I don't have a device for that. Which one would you recommend getting? I might try it out later when I get time (not soon so if anyone else is able to post logs?) 0 Quote
