DDR issues with 24GB board.
Go to solution Solved by meco,
Hi there.
I just got my hands on a brand new 5T with 24GB of RAM and installed Armbian 26.04 minimal on it (on an SD card - no eMMC on this board). I immediately put it to use running CI jobs, however started seeing segfaults and things almost straight away.
Current power source is the Radxa 60W power supply. Currently passively cooled (with the Radxa heat sink). Hasn't gone over 70º in the last 24 hours, even when maxxed out compiling rust packages.
Here's information about the board:
james@kassandra:~$ cat /proc/device-tree/model
Radxa ROCK 5Tjames@kassandra:~$
james@kassandra:~$ dpkg -l | grep '^ii  linux-'
ii  linux-base                                       4.15ubuntu5                                      all          Linux image base package
ii  linux-dtb-current-rockchip64                     26.2.5                                           arm64        Armbian Linux current DTBs in /boot/dtb-6.18.24-current-rockchip64
ii  linux-image-current-rockchip64                   26.2.5                                           arm64        Armbian Linux current kernel image 6.18.24-current-rockchip64
ii  linux-libc-dev:arm64                             7.0.0-15.15                                      arm64        Linux Kernel Headers for development
ii  linux-u-boot-rock-5t-current                     26.2.5                                           arm64        Das U-Boot for rock-5t
james@kassandra:~$ sudo dd if=/dev/mmcblk1 bs=512 count=8192 2> /dev/null | strings | grep '^DDR'
DDR 9fa84341ce typ 24/09/06-09:51:11,fwver: v1.18
I can reliably recreate the segfault by running `claude`:
Bun v1.3.14 (0a466a11) Linux arm64
Linux Kernel v6.18.24 | glibc v2.43
CPU: neon fp aes crc32 atomics
Args: "claude"
Features: Bun.stderr(2) Bun.stdin(2) Bun.stdout(2) abort_signal(5) fetch(35) jsc spawn(8) standalone_executable yaml_parse claude_code
Builtins: "bun:main" "node:assert" "node:async_hooks" "node:buffer" "node:child_process" "node:constants" "node:crypto" "node:dns" "node:events" "node:fs" "node:fs/promises" "node:http" "node:https" "node:module" "node:net" "node:os" "node:path" "node:path/posix" "node:path/win32" "node:perf_hooks" "node:process" "node:readline" "node:stream" "node:stream/consumers" "node:string_decoder" "node:timers/promises" "node:tls" "node:tty" "node:url" "node:util" "node:vm" "node:zlib" "ws" "node:http2"
Elapsed: 9886ms | User: 3200ms | Sys: 775ms
RSS: 72.61MB | Peak: 0.32GB | Commit: 72.61MB | Faults: 993 | Machine: 24.72GB
panic(main thread): Segmentation fault at address 0x7300A749AD00
dmesg output:
[54442.949901] 2.1.128: claude: potentially unexpected fatal signal 5.
[54442.949933] CPU: 5 UID: 1000 PID: 540517 Comm: claude Not tainted 6.18.24-current-rockchip64 #2 PREEMPT
[54442.949952] Hardware name: Radxa ROCK 5T (DT)
[54442.949959] pstate: 00001000 (nzcv daif -PAN -UAO -TCO -DIT +SSBS BTYPE=--)
[54442.949973] pc : 00000000031cb264
[54442.949980] lr : 00000000031cb264
[54442.949986] sp : 0000ffffece87fd0
[54442.949992] x29: 0000ffffece88070 x28: 000000000059aabe x27: 0000ffffb267f740
[54442.950016] x26: 0000000000000004 x25: 0000ffffece884c8 x24: 0000ffffece887b8
[54442.950035] x23: 0000ffffece88850 x22: 000000000691c000 x21: 0000ffffece88540
[54442.950055] x20: 000000000691c000 x19: 0000ffffece886d0 x18: 0000000000000000
[54442.950073] x17: 0000ffffb28386a0 x16: 0000000006a12ff0 x15: 0000000000000034
[54442.950092] x14: 0000000000000032 x13: 0000000000000003 x12: aaaaaaaaaaaaaaaa
[54442.950111] x11: 0101010101010101 x10: 0000000000000000 x9 : 0000000000000000
[54442.950130] x8 : 0000000000000086 x7 : 0000000000000000 x6 : 0000000000000000
[54442.950148] x5 : 0000000000000000 x4 : 0000000000000000 x3 : 0000000000000000
[54442.950165] x2 : 0000000000000000 x1 : 0000ffffb2a3bc90 x0 : 0000000000000000
I tried running stress-ng and saw thousands of failures leading to a hard lockup:
stress-ng: info:  [542138] setting to a 10 mins run per stressor
stress-ng: info:  [542138] dispatching hogs: 8 vm
stress-ng: info:  [542139] vm: using 1.35GB per stressor instance (total 10.79GB of 13.48GB available memory)
stress-ng: fail:  [542153] checkerboard: detected 4 memory errors
stress-ng: fail:  [542149] galpat-one: detected 2437 memory errors
stress-ng: fail:  [542148] flip: detected 32 memory errors
stress-ng: fail:  [542147] flip: detected 96 memory errors
stress-ng: fail:  [542152] galpat-one: detected 5632 memory errors
stress-ng: fail:  [542148] galpat-one: detected 818 memory errors
stress-ng: fail:  [542147] fwdrev: detected 48 memory errors
stress-ng: fail:  [542149] gray code (flip): detected 96 memory errors
stress-ng: fail:  [542150] flip: detected 96 memory errors
stress-ng: fail:  [542147] galpat-one: detected 1980 memory errors
stress-ng: fail:  [542148] gray code: detected 160 memory errors
stress-ng: fail:  [542150] fwdrev: detected 112 memory errors
stress-ng: fail:  [542149] incdec code: detected 160 memory errors
stress-ng: fail:  [542150] galpat-one: detected 1740 memory errors
stress-ng: fail:  [542149] inc-nybble: detected 32 memory errors
stress-ng: fail:  [542148] incdec code: detected 16 memory errors
stress-ng: fail:  [542152] incdec code: detected 16 memory errors
stress-ng: fail:  [542151] flip: detected 288 memory errors
stress-ng: fail:  [542154] flip: detected 288 memory errors
stress-ng: fail:  [542153] flip: detected 144 memory errors
stress-ng: fail:  [542151] galpat-one: detected 256 memory errors
stress-ng: fail:  [542153] galpat-one: detected 871 memory errors
stress-ng: fail:  [542149] modulo X: detected 2 memory errors
stress-ng: fail:  [542149] info: 5 failures reached, aborting stress process
stress-ng: fail:  [542144] vm: detected 2727 bit errors while stressing memory
stress-ng: error: [542138] vm: [542144] terminated with an error, exit status=2 (stressor failed)
stress-ng: fail:  [542148] modulo X: detected 4 memory errors
stress-ng: fail:  [542148] info: 5 failures reached, aborting stress process
stress-ng: fail:  [542142] vm: detected 1030 bit errors while stressing memory
stress-ng: error: [542138] vm: [542142] terminated with an error, exit status=2 (stressor failed)
stress-ng: fail:  [542152] modulo X: detected 3 memory errors
stress-ng: fail:  [542150] modulo X: detected 8 memory errors
stress-ng: fail:  [542147] modulo X: detected 1 memory error
stress-ng: fail:  [542150] moving inversion: detected 12 memory errors
stress-ng: fail:  [542150] info: 5 failures reached, aborting stress process
stress-ng: fail:  [542139] vm: detected 1968 bit errors while stressing memory
stress-ng: error: [542138] vm: [542139] terminated with an error, exit status=2 (stressor failed)
stress-ng: fail:  [542151] modulo X: detected 5 memory errors
stress-ng: fail:  [542152] one-zero: detected 7881 memory errors
stress-ng: fail:  [542151] moving inversion: detected 168 memory errors
stress-ng: fail:  [542153] modulo X: detected 37 memory errors
stress-ng: fail:  [542146] vm: detected 13532 bit errors while stressing memory
stress-ng: error: [542138] vm: [542146] terminated with an error, exit status=2 (stressor failed)
stress-ng: fail:  [542147] mscan: detected 640 memory errors
stress-ng: fail:  [542147] info: 5 failures reached, aborting stress process
stress-ng: fail:  [542143] vm: detected 2765 bit errors while stressing memory
stress-ng: error: [542138] vm: [542143] terminated with an error, exit status=2 (stressor failed)
stress-ng: fail:  [542153] moving inversion: detected 32 memory errors
stress-ng: fail:  [542153] info: 5 failures reached, aborting stress process
stress-ng: fail:  [542141] vm: detected 1088 bit errors while stressing memory
stress-ng: error: [542138] vm: [542141] terminated with an error, exit status=2 (stressor failed)
Anyone have any advice on how to fix this? Is it faulty DDR or a firmware issue?
At Radxa's suggestion I grabbed their latest image `rock-5t_bookworm_kde_r5.output_512.img` which contains `DDR b8ce94f14b cym 25/09/26-15:48.05,fwver: v1.20` and `stress-ng` now passes without any errors.
