Missing functionfs modules in recent sunxi64 kernels
xpk
I've installed the latest available xenial image for orangepizeroplus2-h5 and also upgraded all the packages, so currently running on 4.14.14-sunxi64.
I can see the following parameters in the kernel config file:
CONFIG_USB_CDC_COMPOSITE=m
CONFIG_USB_FUNCTIONFS=m
But at the same time the actual modules are missing:
ls: cannot access '/lib/modules/4.14.14-sunxi64/kernel/drivers/usb/gadget/libcomposite.ko': No such file or directory
ls: cannot access '/lib/modules/4.14.14-sunxi64/kernel/drivers/usb/gadget/function/usb_f_fs.ko': No such file or directory
Does it look like some issue during the image build process (if so, do I need to open it in github?)
Also, how is it possible to build just the missing modules without rebuilding the whole kernel now?
Thanks
Link to comment
Share on other sites
CONFIG_USB_CDC_COMPOSITE makes the g_cdc.ko module
CONFIG_USB_FUNCTIONFS makes the g_ffs.ko module
libcomposite.ko is compiled by CONFIG_USB_LIBCOMPOSITE
usb_f_fs.ko is compiled by CONFIG_USB_F_FS
so please check kernel Kconfigs and Makefiles to map missing kernel modules to configuration options
It is possible only if modules are designed to be built out of tree and if all required functionality for these modules was compiled in the kernel.
Link to comment
