Hello everyone..  below is from a board with a bad flash, or download.
HELLO! BOOT0 is starting!
boot0 version : 4.0.0
rtc[1] value = 0x00010000
rtc[2] value = 0x00020000
rtc[3] value = 0x00030000
DRAM DRIVE INFO: V1.0
DRAM Type =3 (2DR2,3DR3,6:LPDDR2,7:LPDDR3)
DRAM normal_mode value: 00000001
DRAM CLK =720 MHZ
PMU: AXP81X
ddr voltage = 1500 mv
using ic H8
using axp AXP818
DRAM zq value: 00003bfb
dram size =2048
card boot number = 2
card no is 2
sdcard 2 line count 0
[mmc]: mmc driver ver 2014-8-11 15:06:39
[mmc]: ***Try SD card 2***
[mmc]: mmc 2 cmd 8 timeout, err 00000100
[mmc]: mmc 2 cmd 8 err 00000100
[mmc]: mmc 2 send if cond failed
[mmc]: mmc 2 cmd 55 timeout, err 00000100
[mmc]: mmc 2 cmd 55 err 00000100
[mmc]: mmc 2 send app cmd failed
[mmc]: ***Try MMC card 2***
[mmc]: MMC ver 5.0
[mmc]: SD/MMC Card: 4bit, capacity: 14910MB
[mmc]: vendor: Man 00150100 Snr 004df7f4
[mmc]: product: AWPD3
[mmc]: revision: 5.2
[mmc]: ***SD/MMC 2 init OK!!!***
sdcard 2 init ok
The size of uboot is 000d8000.
sum=afc82dcd
src_sum=afc82dcd
set_mmc_para,sdly 50M 0
set_mmc_para,sdly 25M 0
Succeed in loading uboot from sdmmc flash.
Ready to disable icache.
Jump to secend Boot.
[ 0.334]
U-Boot 2011.09-rc1-00001-gb8627fb-dirty (Sep 02 2016 - 09:17:56) Allwinner Technology
[ 0.344]version: 2.1.0
normal mode
[ 0.419]pmbus: normal or secure os
ready
[ 0.424]PMU: AXP81X
[ 0.426]PMU: AXP81X found
bat_vol=385, ratio=100
[ 0.431]PMU: dcdc2 900
[ 0.434]PMU: pll1 1008 Mhz
AXI0=336 Mhz,PLL_PERIPH =1200 Mhz AHB1=200 Mhz, APB1=100 Mhz
set power on vol to default
dcdc1_vol = 3000, onoff=1
dcdc2_vol = 900, onoff=1
dcdc3_vol = 900, onoff=1
dcdc4_vol = 900, onoff=1
dcdc6_vol = 900, onoff=1
aldo1_vol = 1800, onoff=1
aldo2_vol = 1800, onoff=1
aldo3_vol = 3000, onoff=1
fldo2_vol = 900, onoff=1
dldo1_vol = 3300, onoff=0
eldo2_vol = 1800, onoff=0
find power_sply to end
supply=dcdc1
axp=axp81x, supply=dcdc1, vol=3000
reg addr=0x1c20b04, value=0xa, pmu_vol=3000
supply=dcdc1
reg addr=0x1c20b08, value=0xa, pmu_vol=3000
supply=dldo4
axp=axp81x, supply=dldo4, vol=3000
reg addr=0x1c20b0c, value=0xa, pmu_vol=3000
supply=dcdc1
reg addr=0x1c20b10, value=0xa, pmu_vol=3000
supply=dcdc1
reg addr=0x1c20b14, value=0xa, pmu_vol=3000
supply=dcdc1
reg addr=0x1c20b18, value=0xa, pmu_vol=3000
supply=dcdc1
reg addr=0x1c20b1c, value=0xa, pmu_vol=3000
supply=aldo3
axp=axp81x, supply=aldo3, vol=3000
reg addr=0x1f02f00, value=0xa, pmu_vol=3000
config gpio bias voltage finish
vbus exist
no battery, limit to dc
ac100 reg 0x00 = 0x101
ac100 reg 0xd0 = 0x0
ac100 reg 0xd1 = 0x0
fel key old mode
run key detect
no key found
no key input
dram_para_set start
dram_para_set end
[ 1.149]DRAM: 2 GiB
relocation Offset is: 75af5000
gic: normal or no secure os mode
script config pll_de to 504 Mhz
script config pll_video1 to 297 Mhz
Not Found clk pll_video in script
DRV_DISP_Init end
[ 1.356]fetch script data boot_disp.output_disp fail
[ 1.361]boot_disp.output_type=1
[ 1.364]fetch script data boot_disp.output_mode fail
[ 1.369]boot_disp.auto_hpd=0
disp0 device type(1) enable
disp 0, clk: pll(560000000),clk(560000000),dclk(140000000) dsi_rate(140000000)
clk realll(558000000),clk(0),dclk(0) dsi_rate(139500000)
enable power axp81x_aldo1, ret=0
enable power axp81x_eldo2, ret=0
enable power axp81x_dc1sw, ret=0
workmode = 0
MMC: 2
[ 1.675][mmc]: mmc driver ver 2015-12-03 21:17:15
[ 1.680][mmc]: get sdc_phy_wipe fail.
[ 1.776][mmc]: get sdc0 sdc_erase fail.
[ 1.780][mmc]: get sdc_2xmode ok, val = 1
[ 1.784][mmc]: get sdc_ddrmode ok, val = 1
[ 1.788][mmc]: get sdc_f_max fail,use default 50000000Hz
[ 1.794][mmc]: get card_line ok, card_line = 8
[ 1.798][mmc]: get sdc_ex_dly_used fail,use default
[ 1.803][mmc]: SUNXI SD/MMC: 2
[ 1.808][mmc]: mmc_config_clock: clk 400000
[ 1.823][mmc]: *Try SD card 2*
[ 1.828][mmc]: mmc 2 cmd 8 err 100
[ 1.834][mmc]: mmc send if cond failed
[ 1.839][mmc]: mmc 2 cmd 55 err 100
[ 1.845][mmc]: send app cmd failed
[ 1.848][mmc]: *Try MMC card 2*
[ 1.899][mmc]: mmc_config_clock: clk 25000000
[ 1.913][mmc]: mmc re-update_phase
[ 1.920][mmc]: mmc re-update_phase
[ 1.927][mmc]: mmc re-update_phase
[ 1.932][mmc]: ddr8
[ 1.936][mmc]: mmc re-update_phase
[ 1.943][mmc]: mmc_config_clock: clk 25000000
[ 1.953][mmc]: mmc_config_clock: clk 50000000
[ 1.959][mmc]: CID 0x15010041 0x57504433 0x52004df7 0xf4848307
[ 1.964][mmc]: MMC ver 5.0
[ 1.967][mmc]: mmc clk 50000000
[ 1.970][mmc]: SD/MMC Card: 8bit, capacity: 14910MB
[ 1.976][mmc]: boot0 capacity: 4000KB,boot1 capacity: 4000KB
[ 1.981][mmc]: ***SD/MMC 2 init OK!!!***
[ 1.986][mmc]: erase_grp_size:0x400WrBlk * 0x200 = 0x80000 Byte
[ 1.992][mmc]: secure_feature 0x55
[ 1.995][mmc]: secure_removal_type 0x9
[ 1.999]sunxi flash init ok
read item0 copy0
Item0 (Map) magic is bad
the secure storage item0 copy0 is bad
read item0 copy1
the secure storage item0 copy0 == copy1, the data is good
the secure storage map is empty
no item name key_burned_flag in the map
sunxi secure storage has no flag
[ 2.029]usb burn from boot
delay time 0
[ 2.100]usb prepare ok
usb sof ok
[ 2.290]usb probe ok
[ 2.292]usb setup ok
set address 0x8
[ 5.294]timer occur
[ 5.329]do_burn_from_boot usb : have no handshake
In: serial
Out: serial
Err: serial
--------fastboot partitions--------
-total partitions:13-
-name- -start- -size-
bootloader : 1000000 1000000
env : 2000000 1000000
boot : 3000000 1000000
system : 4000000 30000000
misc : 34000000 1000000
recovery : 35000000 2000000
private : 37000000 1000000
Reserve0 : 38000000 1000000
Reserve1 : 39000000 2000000
Reserve2 : 3b000000 1000000
cache : 3c000000 28000000
media_data : 64000000 1000000
UDISK : 65000000 0
base bootcmd=run setargs_nand boot_normal
bootcmd set setargs_mmc
key 0
cant find rcvy value
cant find fstbt value
misc partition found
Recovery detected, will boot recovery
to be run cmd=run setargs_mmc boot_recovery
no item name mac in the map
sunxi storage read fail
check user data form private
the user data'magic is bad
** Unable to read "ULI/factory/snum.txt" from sunxi_flash 6:0 **
load file(ULI/factory/snum.txt) error
serial is: 200000f10200a7180b09
mount part name bootloader
cant open script.bin, maybe it is not exist
WORK_MODE_BOOT
board_status_probe
[ 5.455]power trigger
bat_exist=0
[ 5.458]no battery exist
sunxi_bmp_logo_display
[ 5.568]fetch script data boot_disp.output_disp fail
[ 5.573]screen_id =0, screen_width =1080, screen_height =1920
[ 5.579]frame buffer address 46400036
[ 5.583]gd->fb_base address 46400000
[ 5.587]Hit any key to stop autoboot: 0
read boot or recovery all
[ 5.661]sunxi flash read :offset 35000000, 5848786 bytes OK
[ 5.672]ready to boot
[ 5.675][mmc]: mmc exit start
[ 5.679][mmc]: mmc_config_clock: clk 50000000
[ 5.683][mmc]: mmc_config_clock: clk 400000
[ 5.699][mmc]: mmc 2 cmd 8 err 100
[ 5.705][mmc]: mmc send if cond failed
[ 5.710][mmc]: mmc 2 cmd 55 err 100
[ 5.716][mmc]: send app cmd failed
[ 5.733][mmc]: get sdc_phy_wipe fail.
[ 5.737][mmc]: get sdc0 sdc_erase fail.
[ 5.741][mmc]: get sdc_2xmode ok, val = 1
[ 5.745][mmc]: get sdc_ddrmode ok, val = 1
[ 5.749][mmc]: get sdc_f_max fail,use default 50000000Hz
[ 5.755][mmc]: get card_line ok, card_line = 8
[ 5.759][mmc]: get sdc_ex_dly_used fail,use default
[ 5.764][mmc]: mmc 2 exit ok
[ 5.767]
Starting kernel ...
undefined instruction
pc : [<80008004>] lr : [<bfafa3b4>]
sp : b29fd390 ip : 00000007 fp : b3a1b0d0
r10: 00000000 r9 : b3a1a2c0 r8 : b29fff14
r7 : b3a1a3e8 r6 : 40007840 r5 : b29fffe4 r4 : 00000000
r3 : 80008000 r2 : 40000100 r1 : 00001029 r0 : 00000000
Flags: nZCv IRQs off FIQs off Mode SVC_32
Holding for test mode
Edited by Tido
added spoiler + code box
it a Allwinner H8 octa core, V6-H8-V1.0   2016-09-02   ARM CORTEX A17
The firmware is ( homlet4.4.2-h8-v1.0 )   (kernal 3.4.39 )   OS Nibiru 2.00.000    verVR0069/20161009122814
gpu SGX544MP1
On the board there a sticker here is what I got
V6-V1.0  16G/2G  NB900
101-0V6FF00ECA2A
SP1610006  102
It a VR all in one, a Vr headset, that has a built in lcd.. so no need for smartphone..
Thanks for the reply, if there any info you need please just ask.. I have the full specs of the device also.
1 hour ago, Tido said:
this is a valid question.
How would u help if u read your post?
I wouldn't have an answer, I don't know what I looking at, that is why im here. I hopeing someone can look at this and see where something went wrong, the device keeps stalling on boot image.
But I see what your saying though..
Probably the only way to bring it back to life is to reflash it with a stock Phoenix tools/firmware.
A80 is not very well supported so there aren't any alternatives ... some very basic mainline support exists, but that's all.
Thanks Iqor,
Yes going to have to reflash, the only problem is, the pc only detects the device when it fully boots up into the OS. I can get in download mode, and I did get the info above by UART,  but adb, and Phoenix tools, don't detect the device..
Thank you.. very much..
