4 hours ago4 hr I have a Rock S0 that's running 24.11.2 Bookworm from the eMMC. It's using U-Boot 2022.04I have 26.11.3 Trixie on an µSD card, but the Rock won't boot from that, so I assume it needs the bootloader updated.Since it will only boot to bookworm, can I run armbian-install and update the bootloader on the eMMC, will it put the 2026.07 U-Boot onto the eMMC? Basically, I'm wondering where it would get that bootloader code if it's only running bookworm and it's the older armbian-install script?What's the proper procedure to update U-Boot on this device so I can boot into Trixie?
3 hours ago3 hr 57 minutes ago, Meestor_X said:What's the proper procedure to update U-Boot on this device so I can boot into Trixie?Boot the only working, update your packages, then its always like this:https://docs.armbian.com/getting-started/updating/#update-the-boot-loaderexcept some special cases. That is noted on their download pages.I think you can bypass emmc bootloader by holding one of the buttons on the board. After that you choose update bootloader on eMMC and you can run modern images.
