Rea Posted February 4, 2018 Posted February 4, 2018 Hi.Can you help me fix this problem.Can't use usbwifi wl167g(need like reciever). Network-manager show(wifi enable) but firmware missing. Tried to install RT73_linux_STA_DRV1.0.3.6, have error, when step make, rtmp_main.c error "-march=i686". In new version desktop ubuntu wifi working, but shows slow video(I guess many improvements "use" a lot of resources).
guidol Posted February 5, 2018 Posted February 5, 2018 10 hours ago, Rea said: Hi.Can you help me fix this problem.Can't use usbwifi wl167g(need like reciever). Network-manager show(wifi enable) but firmware missing. Tried to install RT73_linux_STA_DRV1.0.3.6, have error, when step make, rtmp_main.c error "-march=i686". In new version desktop ubuntu wifi working, but shows slow video(I guess many improvements "use" a lot of resources). are you sure you have a wl167g v2 with RT73 Chipset? https://wikidevi.com/wiki/ASUS_WL-167g_v2 = rt73usb because there is also a v1 - https://wikidevi.com/wiki/ASUS_WL-167g_v1 = rt2500usb and v3 - https://wikidevi.com/wiki/ASUS_WL-167g_v3 = RTL8188SU which version of armbian do you use? legacy or mainline kernel? I dont know if it helps, but normally installed is the package "armbian-firmware" There seem to be a "bigger" package called "armbian-firmware-full" and a special package for realtek called "firmware-realtek" armbian-firmware - Linux firmware armbian-firmware-full - Linux firmware-full firmware-realtek - Binary firmware for Realtek wired/wifi/BT adapters You could try to install firmware-realtek or armbian-firmware-full for getting the firmware of your rt73
Igor Posted February 5, 2018 Posted February 5, 2018 armbianmonitor -u for a start would really help in this case. USB ID will tell what driver to use.
Rea Posted February 5, 2018 Author Posted February 5, 2018 are you sure you have a wl167g v2 with RT73 Chipset? https://wikidevi.com/wiki/ASUS_WL-167g_v2 = rt73usb because there is also a v1 - https://wikidevi.com/wiki/ASUS_WL-167g_v1 = rt2500usb and v3 - https://wikidevi.com/wiki/ASUS_WL-167g_v3 = RTL8188SU which version of armbian do you use? legacy or mainline kernel? I dont know if it helps, but normally installed is the package "armbian-firmware" There seem to be a "bigger" package called "armbian-firmware-full" and a special package for realtek called "firmware-realtek" armbian-firmware - Linux firmware armbian-firmware-full - Linux firmware-full firmware-realtek - Binary firmware for Realtek wired/wifi/BT adapters You could try to install firmware-realtek or armbian-firmware-full for getting the firmware of your rt73 Yes, it is ASUS WL-167g v2, ID 0b05:1723 (Now i see, driver Ralink RT2571W) Armbian version 5.38 stable. (ubuntu desktop 16.04 kernel 3.4.113-sun7i)
guidol Posted February 5, 2018 Posted February 5, 2018 4 minutes ago, Rea said: Yes, it is ASUS WL-167g v2, ID 0b05:1723 (Now i see, driver Ralink RT2571W) Armbian version 5.38 stable. (ubuntu desktop 16.04 kernel 3.4.113-sun7i) what did you change to get the driver?
Rea Posted February 5, 2018 Author Posted February 5, 2018 14 minutes ago, guidol said: ambianmonitor -u http://ix.io/Fjj
Igor Posted February 5, 2018 Posted February 5, 2018 Login as root and run: apt install armbian-firmware-full or manually it that won't work - check this: http://mitchtech.net/realtek-wireless-dongle-rt3070-on-the-raspberry-pi/ Remember to reboot or reload the module. 1
Rea Posted February 6, 2018 Author Posted February 6, 2018 On 05.02.2018 at 10:05 PM, guidol said: what did you change to get the driver? Just install firmware. Nothing else. I guess i need firmware rt73.bin. And i have it. but doesn't work. I tried manually add module: modprobe rt73usb, then rtx00usb, rtx00lib and was loaded without errors. I download rt73 and tried install it, before, tried install linux-firmware all-043.deb, firmware-ralink all.deb. I think problem with modul rt2x00. Dmesg show : rt2x00lib_request_firmware: Error - failed to request Firmware. full usb 2-1.4: Product: 802.11 bg WLAN usb 2-1.4: Manufacturer: Ralink usb 2-1.4: reset high-speed USB device number 8 using sw-ehci ieee80211 phy2: Selected rate control algorithm 'minstrel_ht' Registered led device: rt73usb-phy2::radio Registered led device: rt73usb-phy2::assoc Registered led device: rt73usb-phy2::quality phy2 -> rt2x00lib_request_firmware: Error - Failed to request Firmware
Rea Posted February 11, 2018 Author Posted February 11, 2018 On 05.02.2018 at 10:53 PM, Igor said: Login as root and run: apt install armbian-firmware-full or manually it that won't work - check this: http://mitchtech.net/realtek-wireless-dongle-rt3070-on-the-raspberry-pi/ Remember to reboot or reload the module. I tried install armbian-firmware-full. Nothing happens, wifiusb firmware missing. But i can see firmware rt73.bin in /lib/firmware/
guidol Posted February 11, 2018 Posted February 11, 2018 25 minutes ago, Rea said: I tried install armbian-firmware-full. Nothing happens, wifiusb firmware missing. But i can see firmware rt73.bin in /lib/firmware/ I think the rt73.bin isnt the right firmware.... it seems that you need the rt2870.bin The user @HarfTarf did found the solution for the "problem" here:
Rea Posted February 18, 2018 Author Posted February 18, 2018 On 2/11/2018 at 1:42 PM, guidol said: I think the rt73.bin isnt the right firmware.... it seems that you need the rt2870.bin The user @HarfTarf did found the solution for the "problem" here: deb@bananapi:~$ lsusb Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 005: ID 1a2c:0021 China Resource Semico Co., Ltd Keyboard Bus 004 Device 004: ID 0b05:1723 ASUSTek Computer, Inc. WL-167G v2 802.11g Adapter [Ralink RT2571W] Bus 004 Device 003: ID 192f:0916 Avago Technologies, Pte. Bus 004 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
