If you want this "now",  you have to do the work https://docs.armbian.com/Process_Contribute ... We are too busy with other stuff and this has overall low priority.
Search for "xenial" in the lib/ would be a good start to understand how things are made together. Not that critical, but you need to do some coding and .. test the whole thing, solve troublesome dependencies ...
9 hours ago, m][sko said:
some problem with ubuntu glibc on ubuntu 17.10 and 18.04
Nevertheless, support preparation can still start. It is a great way to get familiar with the build engine. The first step would be to add:
[[ $EXPERT=yes ]] && options+=("bionic" "Ubuntu Bionic 18.04 LTS")
after this line and everything else. Then we just wait that deboostrap is fixed upstream or we use some dirty hack in between.
@m][sko or anybody. I am adding this board with economy worldwide shipping as an extra motivation for this task :)
It is not a huge task and we will assist in case of troubles.
Building has to be reasonably well tested to catch as many upstream (debootsrap) bugs as possible. It is valuable to transform unknown bugs to known one. When Bionic builds and boots with minor problems, the task is done and I send the board out.
One remark: Bionic has to be dealt with the same way we are dealing with Stretch: target kernel version must be 3.13 or higher, so no legacy builds for sunxi and some other platforms, otherwise we will drown in issues like "Service x failed to start" and "Service x doesn't work properly".
  • Igor pinned this topic
3 hours ago, monsieur said:
It works with the orange pi pc.
I assume via upgrade? Now via deboostrap method :)
It looks like they fixed the bug.
As I was able to build the image and all work fine
except It only work on ubuntu 18.04
so run NO_HOST_RELEASE_CHECK=yes ./compile.sh
It freeze on ubuntu 16.04 in regenerating man pages :(
I am looking that all work is done in development branch and I want to make pull request :)
some changes with ubuntu 18.04
ntpdate is not instaled by default and they changed ntp daemon so ntpdate return error :(
missing package rcconf  but armbian-conf depend on that
so temporary workaround just add
PACKAGE_LIST_ADDITIONAL="${PACKAGE_LIST_ADDITIONAL/armbian-firmware/}"
PACKAGE_LIST="${PACKAGE_LIST/rcconf/}"
1 hour ago, m][sko said:
what if we enable support for ubuntu 18.04 only on ubuntu 18.04 ?
It builds on Xenial. You only need to get latest debootstrap_1.0.95_all.deb
Not really :huh: arm o.k. / arm64 hangs, yes.
Setting up man-db (2.8.3-2) ...
Building database of manual pages ...
qemu: Unsupported syscall: 383
Setting up pinentry-curses (1.1.0-1) ...
I haven't boot the image yet.
@Igor
I am not sure if ubuntu plan to support 32bit version of ubuntu 18.04
My test case is to build Odroid C2 next with ubuntu 18.04 image
I did try to build it on 16.04
but it freeze when armbian what to update packages in image to latest version
qemu: Unsupported syscall: 277
man       87078  87074  0 00:57 pts/22   00:00:00 [mandb] <defunct>
all same with debootstrap_1.0.95 :(
I use windows as host with ubuntu 16.04 as guest
All works on ubuntu 18.04 as guest OS
Maybe all woks fine without virtualisation :)
Yes, it freezes and I hope this will be fixed upstream, like the previous issue with BASH. We don't plan to release Ubuntu Bionic (support) anytime soon so this remains a known issue with low priority.
A workaround is to kill the mandb process. Good enough for testing and development purposes.
@Igor
just workaround idea:
variable that will disable update packages stage
what about
missing package rcconf(in ubuntu 18.04)  as armbian-conf depend on that
now it end with armbian-conf install
I workaround that with removing armbian and rcconf from install package list
I added
to bionic switch as temporary solution
30 minutes ago, m][sko said:
what about
That is deprecated and it was removed from armbian-config ... currently present in a beta repository only. Also, armbian-firmware is present if you switch to the beta building BETA="yes".
@Igor
BETA="yes" EXPERT="yes" ./compile.sh
it looks like qemu from bionic solved the problem :)
I was able to build ubuntu 18.04 server/console image for Odroid C2  :beer:
I don't know where is problem but with network configuration
but my image don't start with working eth0 adapter
IPv6 works fine byt IPv4 don't
Do you have same problem with your image ?
echo "allow-hotplug eth0" >> /etc/network/interfaces
echo "iface eth0 inet dhcp" >> /etc/network/interfaces
fixed problem
looks like some problem with NetworkManager :(
Yes, the same. And only with ethernet. Wireless works but I have troubles with host preparation. On a clean host, deboostrap of any system fails completely:
I: Extracting libmount1...
I: Extracting libsmartcols1...
I: Extracting libuuid1...
I: Extracting mount...
I: Extracting util-linux...
I: Extracting liblzma5...
I: Extracting zlib1g...
[ error ] ERROR in function create_chroot [ chroot-buildpackages.sh:43 ]
[ error ] Create chroot first stage failed
[ o.k. ] Process terminated
That bothers me atm. Still investigating why is this happening. On my main build machine, it works.
So I can't reproduce your problem
That is good since I (hopefully) fixed the problem
Now, general userspace problems. We already spotted that network is not up, more packages might be missing, ...
1 hour ago, tkaiser said:
I would prefer to do it correctly: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=892768
Noted.
And IMO there's no need to hurry and I honestly do not understand the bunch of hacks recently added to get 18.04 built now...
True, there is no need to hurry but its more convenient to repair things on the way. As a side task. My intention was to bring it to the level, where one can build and test. We are there now. We can build, we have a network, a desktop is up, ... There are small known problems and probably many hidden. Some will be fixed upstream and some can be fixed by people interested to run Bionic ASAP. I will still fix things if I bump into them, but will not hunt them.
  • Igor unpinned this topic
