Orange Pi Plus 2 WIFI connection failed...
jiapei100
Hi, all, sorry to bother you again.
I still cannot make wifi on my OPi Plus2 work. The following are the results of ifonfig and iwlist scan .
and my /etc/network/interfaces is as follows:
What's in file /etc/wpa_supplicant/wpa_supplicant.conf :
network={
        ssid="xxxxx"
        psk="yyyyy"
and I'm sure the SSID and password are correct.
I used to posted a mesage about WIRED connection, which is solved by setting hwaddress ether .
However, for wireless connection, can anybody give me hand please?
Thank you very much
Pei
Link to comment
Share on other sites
12 hours ago, jiapei100 said:
It seems WIFI connections are NOT listed. However, iwlist scan works now.... So weird...
Nothing is weird. If you have wlan used by ifup ( /etc/network/interfaces) than network manager can't use them and vice versa. Remove /etc/network/interfaces, reboot and nmtui-conenect will work.
Link to comment
Hi, Igor, I made some progress after removing /etc/network/interfaces, however, I still Could not activate connection: Activation failed
Link to comment
before reboot /etc/network/interfaces will be active.
Configure via nmtui and set it active at boot, then save and reboot  - this wil activate the connection
Link to comment
Hi, guidol:
Now, it's working...
I just leave ONLY 2 lines in /etc/network/interfaces as:
auto lo
iface lo inet loopback
and set nmtui ... Wifi is NOW working...
Still, I think it's more or less a bit unexplainable. I prefere modifying /etc/network/interfaces, but have NO idea how to figure that out.
Anyway, NOW, wifi is working !!!
Thanks
Pei
Link to comment
1 hour ago, jiapei100 said:
Hi, guidol:
auto lo
if you want to setup wlan0 from the /etc/network/interfaces, then you can delete the connection in nmtui and ADD something like the following line (with the IP-Numbers and data of your WiFi-Connection):
auto wlan0
iface wlan0 inet static
       address 192.168.8.16
       netmask 255.255.255.0
       gateway 192.168.8.1
       dns-nameservers 8.8.8.8 8.8.4.4
       wpa-ssid "your_wifi_ssid"
       wpa-psk "your_wifi_pre-shared-key"
you have to check if your wifi-device is named wlan0 or has a name which does include some part of your MAC-address
e.g. like wlx3f4e2a1b0d
Link to comment
