One of my orange pi zeros eth seems to be only negotiationg down to 10Mb/s full duplex.  Not sure why.
Below are examples of a stock nightly build. it only happens on one of the pis.
[    4.177634] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    4.181353] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    4.348951] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    4.349026] dwmac-sun8i 1c30000.ethernet: No regulator found
[    4.349104] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[    4.349331] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000)
[    4.349495] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    4.349507] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    4.349519] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    4.349530] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    4.349542] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    4.349553] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[   11.502776] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[   11.502793] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[   19.849903] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[   21.930440] dwmac-sun8i 1c30000.ethernet eth0: Link is Down
[   22.970097] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 10Mbps/Full - flow control rx/tx
root@orangepizero:~# ethtool eth0
Settings for eth0:
        Supported ports: [ TP AUI BNC MII FIBRE ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
        Supported pause frame use: Symmetric Receive-only
        Supports auto-negotiation: Yes
        Advertised link modes:  10baseT/Half 10baseT/Full
        Advertised pause frame use: No
        Advertised auto-negotiation: Yes
        Link partner advertised link modes:  10baseT/Half 10baseT/Full
        Link partner advertised pause frame use: Symmetric Receive-only
        Link partner advertised auto-negotiation: Yes
        Speed: 10Mb/s
        Duplex: Full
        Port: MII
        PHYAD: 1
        Transceiver: internal
        Auto-negotiation: on
        Supports Wake-on: d
        Wake-on: d
        Current message level: 0x0000003f (63)
                               drv probe link timer ifdown ifup
        Link detected: yes
Manually
ethtool -s eth0 speed 100 duplex full sometimes work, other times the interface starts moving up and down continually
but even if it works its for a short period of time
especially if i put some load on it
[  290.489795] dwmac-sun8i 1c30000.ethernet eth0: Link is Down
[  291.529727] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[  313.369751] dwmac-sun8i 1c30000.ethernet eth0: Link is Down
[  314.409717] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[  318.569954] dwmac-sun8i 1c30000.ethernet eth0: Link is Down
[  320.649716] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[  322.729744] dwmac-sun8i 1c30000.ethernet eth0: Link is Down
[  323.769905] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[  327.929501] dwmac-sun8i 1c30000.ethernet eth0: Link is Down
[  328.969615] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[  343.529731] dwmac-sun8i 1c30000.ethernet eth0: Link is Down
[  344.569948] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[  352.889602] dwmac-sun8i 1c30000.ethernet eth0: Link is Down
[  353.929935] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[  358.090496] dwmac-sun8i 1c30000.ethernet eth0: Link is Down
[  360.169897] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[  363.289777] dwmac-sun8i 1c30000.ethernet eth0: Link is Down
[  364.330026] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
Any ideas?
Any ideas?
Does this Orange Pi Zero only get  10MBit where another Orange Pi Zero does get 100MBit - or do you use with this Zero another cable?
I have already tried different cables.  It did not seem to help any.
Also tried those cables on other pis/other devices and they all seem to work fine.
Did you try on the old kernel as well?
then I would suggest to use all components from a working Zero/one:
- Network-Cable
- uSD-Card with OS
and
- Power-Supply
on the false-working Zero/one - then you could also eliminate the problem with the kernel/OS which Igor mentioned :)
Also the false-working one should only have devices (like additional USB-devices) connected which had been used on the working one.
