Hy
I'm currently running the latest experimental image on my NanoPi Neo Core 2.  Works great haven't had any problems with it.
Now my question when does the "experimental image" state change to a "stable build"? What are the criteria?
Andy
It's somewhat common decision by the developers. When:
- known critical problems are solved
- less critical are at least acknowledged and marked at the board download page
- not very much reported troubles on the forum
- if/when we can afford to provide end-user support. This part is getting more and more problematic due to large board count.
Even labeled experimental, they are usually in a (much) better shape than factory/stock ones. They just don't label it.
which image did you use? On my NanoPi Neo Core 2 I do run the image for the NanoPi Neo Plus 2?
Is there a "real" Core 2 image?
Its running fine? I didnt try the eMMC option.
Iam using:
ARMBIAN 5.42.180323 nightly Debian GNU/Linux 9 (stretch) 4.14.29-sunxi64
Linux nanopi-core2 4.14.29-sunxi64 #57 SMP Fri Mar 23 12:09:14 CET 2018 aarch64 GNU/Linux
thx for the info.
no of course its the NanoPi Neo Plus 2 image.
I use the eMMC option and it boots fine and is stable. Currently running this build as a companion pc for a drone.
Andy
Today I did install from MicroSD to eMMC (ext4 format selected) - did work fine on my NanoPi Neo Core2 (with the NanoPi Neo Plus 2 Image).
The only thing was a dissorted question (warning?) at the beginning at the start of the installation....
The 1.4GB of the installation did take around 20 minutes.
After the copy routine I did remove the card and could boot my installation from eMMC - its fast and Iam happy :)
