Hy
I tried to play around with the GPIOs and found some nice threads here however I don't get past the
modprobe gpio
command. I get this error
modprobe: FATAL: Module gpio not found in directory /lib/modules/4.14.29-sunxi64
Does my kernel build has no GPIO library inside?
Linux 4.14.29-sunxi64 #64 SMP Sat Mar 24 11:13:51 CET 2018 aarch64 GNU/Linux
Andy
thx hmm I installed it but I get:
Unrecognized board type, aborting...
AIOInit error
I tried to launch the ledtest.py script
When I look the board up in the /run/machine.id file its a "Nanopi Neo Plus 2" and this is not listed in the
armbianio.c file. So what can I do? (the real board is a "NanoPi Neo Core 2")
Andy
So can you implement thees pins (for the Neo Core2 and Neo Plus 2)?
I used the http://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO_Core2#Diagram.2C_Layout_and_Dimension link and tried to blink an LED:
I used the UART1_TX / GPIOG6 Pin. This is the Linux Pin 198. And it works!
# echo "198" >/sys/class/gpio/export
# echo "out" >/sys/class/gpio/gpio198/direction
# echo "1" > /sys/class/gpio/gpio198/value
Now it would be great if I could use this in a Python script
Andy
how about a system-call?
import os
os.system('echo "198" >/sys/class/gpio/export')
os.system('echo "out" >/sys/class/gpio/gpio198/direction')
os.system('echo "1" > /sys/class/gpio/gpio198/value')
yes I did already try this however without root permission it does not work.
I tired then to add this to the rule file
SUBSYSTEM=="gpio*", PROGRAM="/bin/sh -c 'chown -R root:gpio /sys/class/gpio && chmod -R 770 /sys/class/gpio; chown -R root:gpio /sys/devices/virtual/gpio && chmod -R 770 /sys/devices/virtual/gpio; chown -R root:gpio /sys/devices/platform/soc/*.gpio/gpio && chmod -R 770 /sys/devices/platform/soc/*.gpio/gpio'"
And add my user to the GPIO group created before but still I get Permission denied for the direction command...
How can I get permission to execute the Python file without being root -s?
Andy
Andy
In Python:
  o = open("/sys/class/gpio/export", "w"); o.write("198");  o.close()
  o = open("/sys/class/gpio/gpio198/direction", "w"); o.write("out"); o.close()
  o = open("/sys/class/gpio/gpio198/value", "w"); o.write("1"); o.close()
1 hour ago, richardk said:
In Python:
Thx richard but same problem. No permission for the command "/sys/class/gpio/gpio198/direction"
See post above...
Andy
See post above...
Andy
Oh - okay.
If Debian, then "sudo adduser debian gpio" will add "gpio" privileges to user "debian", then log out and back in so the change takes effect.
I have already done that but still no success....
Traceback (most recent call last):
  File "testGPIO.py", line 13, in <module>
    open('/sys/class/gpio/gpio198/direction', 'w').write('out')
IOError: [Errno 13] Permission denied: '/sys/class/gpio/gpio198/direction'
Andy
maybe python does not run as your user?
what is the output of
import os
os.system('id')
and then try to give gpio permission to this user?
this is the output:
uid=1000(deldro) gid=1000(deldro) groups=1000(deldro),20(dialout),27(sudo),29(audio),44(video),46(plugdev),101(systemd-journal),108(netdev),112(ssh),1001(gpio)
Andy
9 minutes ago, Andy said:
this is the output:
user deldro seems already to be in the group gpio:
uid=1000(deldro) gid=1000(deldro) groups= 1001(gpio)
So I got no other idea :(
the problem seems the permission command.
I used the
However after boot it does not set properly.
I put this command in the /etc/rc.local file is this the wrong place?
Andy
It must be placed before the last line showing "exit 0"
after booting it seems that the permissions are set correctly:
ls -l /sys/class/gpio/
total 0
--w--w---- 1 root gpio 4096 Mar 27 21:17 export
lrwxrwxrwx 1 root gpio    0 Mar 27 21:17 gpiochip0 -> ../../devices/platform/soc/1c20800.pinctrl/gpio/gpiochip0
lrwxrwxrwx 1 root gpio    0 Mar 27 21:17 gpiochip352 -> ../../devices/platform/soc/1f02c00.pinctrl/gpio/gpiochip352
--w------- 1 root gpio 4096 Mar 27 21:17 unexport
However when I run the Python code I get permission denied for the open('/sys/class/gpio/gpio198/direction', 'w').write('out') command.
When I now type again the same command as written in the /etc/rc.local (chown -R root:gpio /sys/class/gpio) in the terminal
and relaunch the python script it does work! (ls -l /sys/class/gpio/ shows the same result as right after the booting)
Why do I need to set the permission twice??
Andy
Doing "chown -R root:gpio /sys/class/gpio" is only changing this directory, not the pointed symlinks, so you probably need to do a "chown -R root:gpio /sys/devices/platform/soc/1c20800.pinctrl/gpio" also...
a next idea from tonight - as I did see the user deldro is also sudo-user, maybe the echo does work with sudo?
import os
os.system('sudo echo "198" >/sys/class/gpio/export')
os.system('sudo echo "out" >/sys/class/gpio/gpio198/direction')
os.system('sudo echo "1" > /sys/class/gpio/gpio198/value')
sorry guys still same error.
However when I run the script with sudo and enter the password then it works.
However I need to run this script as "normal" user (deldro) which is also a sudo-user.
I could add the python to visudo to not ask for a password when using "sudo python...) but
I think this is not the "right" solution...
Andy
This would be a function of sysfs.  You'lll note that you are able to write to /sys/class/gpio/export without error (after changing permissions).  This triggers the new creation of /sys/class/gpio/gpioXX using default sysfs permissions.  You would need to do the chmod after writing to the export, and not before (IE: during boot).
The gpio sysfs module would need to support configuration of ownerships and permissions for new creations to change this.
hmm and what about a python library like the one from bitbank2 (ArmbianIO).
Would this solve the problem?
Andy
