Banana Pi M2 Zero with fake/unofficial Armbian based image
New to this forum. Hope someone can please assist.
I recently purchased a tiny 5" display UMPC device.
See instagram/puterpi for photos. There's also YouTube video of it in action by maker too.
I installed Armbian image:
http://forum.banana-pi.org/t/bpi-m2-zero-new-image-2017-12-04-armbian-5-36-m2-zero-ubuntu-xenial-next-4-14-3-desktop-preview-buildbybpi/4325
Overall, works great. However, I periodically get the following error message at boot up in console and device will not boot up. Only fix I have now is to res-install image file.
 missing environment variable: boot file
Retrieving file: pxelinux.cfg/00000
Not ethernet found.
Not ethernet found.
Not ethernet found.
Not ethernet found.
Not ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
Not ethernet found.
Not ethernet found.
Not ethernet found.
Config file not found
starting USB...
No controllers found
No ethernet found.
No ethernet found.
The error message is obviously about ethernet coonection. I use a USB hub with ethernet port to get ethernet connection. It has worked OK.
Error has occurred only after some restarts. Have not figured why it occurs after some shutdowns and then restarts. But when it occurs, i have not been able to bypass error and continue to boot up.
Thank you for any advice.
Mark
This means boot process is somehow and sometimes broken due to wrong u-boot settings and/or hardware issue ... and fails to network boot and since there is no network drivers nor any configurations it ends like this. We don't support this board and this Armbian build is not ours
Thank you for your input, Igor.
Understand your points.
Was hoping this might be a simple fix that I might be able to do.
Not ethernet found.
Hi Mark,
the error-message will only tell you that the Banana Pi couldnt find your boot uSDCard and it do try to boot from Ethernet, but the BPi Zero hasnt a Ethernet Port.
So - how you also did find out - you have to reflash the card....
Now there are many options for this error... bad or old card or a bad power-supply or a power-outage while using the dveice -> bad filesystem = no boot
Info for PXE (Network) Boot: https://en.wikipedia.org/wiki/Preboot_Execution_Environment
You did not. BPi M2 Zero is not supported by Armbian (same with BPi M64).
Can a moderator please adjust the title of this thread: 'Problems with fake Armbian images' or something like that?
The error message is an u-boot message and u-boot has been read from SD card. So most probably it's SD card corruption. Armbian instructions are pretty clear how to deal with images and SD cards (CHECKING download integrity -- not possible with fake images -- and TESTING them in case errors occur): https://docs.armbian.com/User-Guide_Getting-Started/#how-to-check-download-authenticity
Thank you, Guidol and tkaiser, for your input. helpful and appreciated.
Understand your points and about this being 'fake Armbian' image.
in meantime, I re-flashed card and bought a AC adapter for my usb and ethernet hub. Hopefully, this will help avoid future issues like I had.
