dwonga Posted June 3, 2018 Posted June 3, 2018 (edited) Hi everyone. I got a Orange Pi Prime (OPi Prime). It works ok with "official" debian and ubuntu images from Xulong (xulong web site). When I try to use Armbian 5.33 stable, I got some text into HDMI screen until the words "loading kernel", then nothing is shown on monitor; but through TTL port I can login as root. That behaviour is repeated wheter using Ubuntu (desktop or server), Debian (desktop or server). With Legacy kernel (3.x) the same card worked in the past, but the image is not available anymore. I'm attaching the output from TTL console: Spoiler CPU: Allwinner H5 (SUN50I) Model: OrangePi Prime DRAM: 2 GiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: vidconsole Err: vidconsole Net: No ethernet found. starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3100 bytes read in 208 ms (13.7 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 167 ms (0 Bytes/s) 30283 bytes read in 387 ms (76.2 KiB/s) 4179 bytes read in 438 ms (8.8 KiB/s) Applying kernel provided DT fixup script (sun50i-h5-fixup.scr) ## Executing script at 44000000 4914837 bytes read in 529 ms (8.9 MiB/s) 12943368 bytes read in 912 ms (13.5 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 4914773 Bytes = 4.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 49b50000, end 49fffe55 ... OK reserving fdt memory region: addr=4fa00000 size=6d000 Loading Device Tree to 0000000049ae0000, end 0000000049b4ffff ... OK Cannot setup simplefb: node not found Starting kernel ... Loading, please wait... starting version 232 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.29.2 [/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1 /dev/mmcblk0p1: recovering journal CPU: Allwinner H5 (SUN50I) Model: OrangePi Prime DRAM: 2 GiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: vidconsole Err: vidconsole Net: No ethernet found. starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3100 bytes read in 208 ms (13.7 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 167 ms (0 Bytes/s) 30283 bytes read in 387 ms (76.2 KiB/s) 4179 bytes read in 438 ms (8.8 KiB/s) Applying kernel provided DT fixup script (sun50i-h5-fixup.scr) ## Executing script at 44000000 4914837 bytes read in 529 ms (8.9 MiB/s) 12943368 bytes read in 912 ms (13.5 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 4914773 Bytes = 4.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 49b50000, end 49fffe55 ... OK reserving fdt memory region: addr=4fa00000 size=6d000 Loading Device Tree to 0000000049ae0000, end 0000000049b4ffff ... OK Cannot setup simplefb: node not found Starting kernel ... CPU: Allwinner H5 (SUN50I) Model: OrangePi Prime DRAM: 2 GiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: vidconsole Err: vidconsole Net: No ethernet found. starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3100 bytes read in 208 ms (13.7 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 167 ms (0 Bytes/s) 30283 bytes read in 387 ms (76.2 KiB/s) 4179 bytes read in 438 ms (8.8 KiB/s) Applying kernel provided DT fixup script (sun50i-h5-fixup.scr) ## Executing script at 44000000 4914837 bytes read in 529 ms (8.9 MiB/s) 12943368 bytes read in 912 ms (13.5 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 4914773 Bytes = 4.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 49b50000, end 49fffe55 ... OK reserving fdt memory region: addr=4fa00000 size=6d000 Loading Device Tree to 0000000049ae0000, end 0000000049b4ffff ... OK Cannot setup simplefb: node not found Starting kernel ... Loading, please wait... starting version 232 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.29.2 [/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1 /dev/mmcblk0p1: recovering journal CPU: Allwinner H5 (SUN50I) Model: OrangePi Prime DRAM: 2 GiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: vidconsole Err: vidconsole Net: No ethernet found. starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3100 bytes read in 208 ms (13.7 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 167 ms (0 Bytes/s) 30283 bytes read in 387 ms (76.2 KiB/s) 4179 bytes read in 438 ms (8.8 KiB/s) Applying kernel provided DT fixup script (sun50i-h5-fixup.scr) ## Executing script at 44000000 4914837 bytes read in 529 ms (8.9 MiB/s) 12943368 bytes read in 912 ms (13.5 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 4914773 Bytes = 4.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 49b50000, end 49fffe55 ... OK reserving fdt memory region: addr=4fa00000 size=6d000 Loading Device Tree to 0000000049ae0000, end 0000000049b4ffff ... OK Cannot setup simplefb: node not found Starting kernel ... Here is when the HDMI Monitor (an LG 25UM58-P), starts to shown black screens, alternating with "out of range" messages. But in the console, I can see the kernel is loading fine: Spoiler Loading, please wait... starting version 232 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.29.2 [/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1 /dev/mmcblk0p1: recovering journal Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. Welcome to Debian GNU/Linux 9 (stretch)! [ OK ] Set up automount Arbitrary Executab��…rmats File System Automount Point. [ OK ] Created slice System Slice. [ OK ] Created slice User and Session Slice. [ OK ] Listening on /dev/initctl Compatibility Named Pipe. [ OK ] Created slice system-serial\x2dgetty.slice. [ OK ] Listening on udev Control Socket. [ OK ] Listening on Syslog Socket. [ OK ] Reached target Slices. [ OK ] Reached target Remote File Systems. [ OK ] Listening on Journal Socket. Starting Set the console keyboard layout... Starting Restore / save the current clock... Starting Create list of required st��…ce nodes for the current kernel... [ OK ] Listening on Journal Audit Socket. Mounting Huge Pages File System... Starting Nameserver information manager... Mounting POSIX Message Queue File System... [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ OK ] Listening on Journal Socket (/dev/log). Starting Load Kernel Modules... Mounting Debug File System... [ OK ] Created slice system-getty.slice. [ OK ] Listening on fsck to fsckd communication Socket. Starting Remount Root and Kernel File Systems... [ OK ] Started Forward Password Requests to Wall Directory Watch. [ OK ] Reached target Paths. [ OK ] Reached target Encrypted Volumes. [ OK ] Listening on udev Kernel Socket. [ OK ] Mounted Huge Pages File System. [ OK ] Mounted Debug File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Started Restore / save the current clock. [ OK ] Started Create list of required sta��…vice nodes for the current kernel. [ OK ] Started Load Kernel Modules. [ OK ] Started Remount Root and Kernel File Systems. [ OK ] Started Nameserver information manager. Activating swap /var/swap... Starting udev Coldplug all Devices... Starting Load/Save Random Seed... Starting Apply Kernel Variables... Mounting Configuration File System... Starting Create Static Device Nodes in /dev... [ OK ] Mounted Configuration File System. [ OK ] Activated swap /var/swap. [ OK ] Started Set the console keyboard layout. [ OK ] Started Load/Save Random Seed. [ OK ] Started Apply Kernel Variables. [ OK ] Reached target Swap. [ OK ] Started Create Static Device Nodes in /dev. [ OK ] Reached target Local File Systems (Pre). Mounting /tmp... Starting udev Kernel Device Manager... [ OK ] Mounted /tmp. [ OK ] Started udev Coldplug all Devices. [ OK ] Reached target Local File Systems. Starting Set console font and keymap... Starting Raise network interfaces... Starting Armbian enhanced Log2Ram... [ OK ] Started Set console font and keymap. [ OK ] Started udev Kernel Device Manager. [ OK ] Started Armbian enhanced Log2Ram. Starting Journal Service... [ OK ] Found device /dev/ttyS0. [ OK ] Reached target Sound Card. [ OK ] Started Journal Service. Starting Flush Journal to Persistent Storage... [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ OK ] Started Flush Journal to Persistent Storage. Starting Create Volatile Files and Directories... [ OK ] Started ifup for eth0. Starting Load/Save RF Kill Switch Status... [ OK ] Started Create Volatile Files and Directories. [ OK ] Started Load/Save RF Kill Switch Status. [ OK ] Started Entropy daemon using the HAVEGE algorithm. [ OK ] Reached target System Time Synchronized. Starting Update UTMP about System Boot/Shutdown... [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Started Raise network interfaces. [ OK ] Reached target System Initialization. [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Reached target Sockets. [ OK ] Reached target Basic System. [ OK ] Started D-Bus System Message Bus. Starting Network Manager... Starting LSB: Armbian gathering hardware information... [ OK ] Started Regular background program processing daemon. Starting System Logging Service... [ OK ] Started Daily Cleanup of Temporary Directories. Starting LSB: Start/stop sysstat's sadc... [ OK ] Started Daily apt download activities. [ OK ] Started Daily apt upgrade and clean activities. [ OK ] Reached target Timers. Starting Login Service... Starting Save/Restore Sound Card State... Starting LSB: Load kernel modules needed to enable cpufreq scaling... [ OK ] Started Save/Restore Sound Card State. [ OK ] Started LSB: Start/stop sysstat's sadc. [ OK ] Started Login Service. [ OK ] Started LSB: Load kernel modules needed to enable cpufreq scaling. Starting LSB: set CPUFreq kernel parameters... [ OK ] Started System Logging Service. [ OK ] Started LSB: set CPUFreq kernel parameters. Starting LSB: Set sysfs variables from /etc/sysfs.conf... [ OK ] Started LSB: Set sysfs variables from /etc/sysfs.conf. [ OK ] Started Network Manager. [ OK ] Reached target Network. Starting OpenBSD Secure Shell server... Starting Permit User Sessions... [ OK ] Started Unattended Upgrades Shutdown. Starting Network Manager Wait Online... [ OK ] Started Permit User Sessions. Starting Network Manager Script Dispatcher Service... [ OK ] Started Network Manager Script Dispatcher Service. [ OK ] Started OpenBSD Secure Shell server. Starting Hostname Service... [ OK ] Started LSB: Armbian gathering hardware information. [ OK ] Started Hostname Service. Starting Authorization Manager... Starting WPA supplicant... [ OK ] Started Authorization Manager. [ OK ] Started WPA supplicant. [ OK ] Started Network Manager Wait Online. [ OK ] Reached target Network is Online. Starting LSB: disk temperature monitoring daemon... Starting /etc/rc.local Compatibility... Starting LSB: Start NTP daemon... Starting LSB: Advanced IEEE 802.11 management daemon... [ OK ] Started /etc/rc.local Compatibility. [ OK ] Started LSB: Advanced IEEE 802.11 management daemon. [ OK ] Started LSB: disk temperature monitoring daemon. [ OK ] Started Serial Getty on ttyS0. [ OK ] Started Getty on tty1. [ OK ] Reached target Login Prompts. [ OK ] Started LSB: Start NTP daemon. [ OK ] Reached target Multi-User System. [ OK ] Reached target Graphical Interface. Starting Update UTMP about System Runlevel Changes... [ OK ] Started Update UTMP about System Runlevel Changes. Debian GNU/Linux 9 orangepiprime ttyS0 orangepiprime login: Your suggestions would be trully aprreciated! David. Edited June 4, 2018 by Igor add spoiler
guidol Posted June 3, 2018 Posted June 3, 2018 what kind of Monitor do you use? which resolution is max. supported? Do you use a adapter to connect the monitor?
dwonga Posted June 3, 2018 Author Posted June 3, 2018 Hi guidol, I have an HDMI Monitor (an LG 25UM58-P), with no adapters. Thanks for any advise you can give.
Slackstick Posted June 3, 2018 Posted June 3, 2018 I also had issues with mainline kernel an Allwinner (H3 and _H5). If your monitor has more than one HDMI input, tray the other ones. It helped for me.
dwonga Posted June 3, 2018 Author Posted June 3, 2018 I've managed to use this card but with a TV, using HDMI, instead of this LG monitor. Maybe this problem is related with LG monitor is widescreen and LCD TV is not. Who knows? Anyone has been able to change the resolution to manual, overriding the resolution that HDMI requests? Thank you for any comment. D.
Igor Posted June 4, 2018 Posted June 4, 2018 7 hours ago, dwonga said: Anyone has been able to change the resolution to manual, overriding the resolution that HDMI requests? We are changing to a proper video driver in 4.17.y and this could already be improved. You can try it by changing to the beta repository and then switch to alternative DEV kernel (4.17.RC). Note that beta area can be completely broken and you won't be able to boot the board after that ... but it's worth trying out.
dwonga Posted June 5, 2018 Author Posted June 5, 2018 22 hours ago, Igor said: We are changing to a proper video driver in 4.17.y and this could already be improved. You can try it by changing to the beta repository and then switch to alternative DEV kernel (4.17.RC). Note that beta area can be completely broken and you won't be able to boot the board after that ... but it's worth trying out. Thank for your for suggestion, Igor. I will give it a try. Right now I am using the beta repository but not alternative DEV kernel. I will the information here if I am able to solve this issue. Moreover, thank you for that great job you do here, with armbian. It is trully appreciated. David.
