31 minutes ago, cvaldess said:
Hi all,
looking for jessie img for Pine64so, found it for Pine64 but not for SOPINE
thanks
2
Then you need to build one: http://git.armbian.com
Look like armbian do their magic only for Pine64, there any problems with sopine boards??
buy a cluster board and some sopine for study and practice micro services, this cheap than pc for virtualize but without software I'm stuck....
2 hours ago, guidol said:
But I couldnt see jessie for the Pine64so at
That's only a target for our automated build system. Manually you can build whatever you want. Well, not whatever ... with the old 3.10.y legacy kernel you are limited to Jessie and Xenial while on a modern kernel (next 4.14.y or dev 4.17.y) you can build whatever you like. But for DEV I have no idea if it boots and what works.
You have (Stallmanized) Ubuntu build but if you prefer Jessie, you need to build on your own. That's all magic.
i'm not prefer jessie, only need running image for sopine board where can run latest versions of Docker & Kubernetes, do you know any?? also trying to build jessie for sopine image
Then download Ubuntu and burn. Docker is enabled on all our builds where the kernel is higher than 3.10.y.
Our SoPhine image should work the same as our Orange Win image for this guy:
But since kernel 3.10 is old you might run into problems ... try modern kernel, 4.14.y / 4.17.y, but those are not quite ready. Perhaps they work fine, perhaps not.
Igor,
thanks !! I'm have ready my build system and testing new kernels on my sopine board
also I'm have one orangepi winplus it run nice but for the cluster  pine are cheap & compact
I built a 18.04 for opiwin+ ... mostly works but for some reason wifi needs to be manually started
