@lex Posted June 17, 2018 Share Posted June 17, 2018 (edited) Today I had a chance to test OV5640 on mainline kernel 4.17.2 and see the status of OV5640 and CSI drivers, thanks to FE work and the author of the driver (help name here...). I tested on NanoPi K1 Plus (H5) to verify the images in very low light conditions, so don't expect good quality. I could take some images using fswebcam and you should expect basic v4l2 functionality already works if not all. I think motion (did not test / had time to test it) can work with current OV5640 on mainline kernel. Grabbing Image is very fast, currently, Image size I can get are 320x240 and 640x480 pixels, above this i get a dark image. I have not looked at the driver source code to see if it is implemented or not. Basically, you need to add the sun6i_csi and ov5640 drivers to the kernel and adjust DT to have the endpoint. FE has already done it and left H5 for homework, but is the same as H3. To check the functionality, install v4l2-utils and when the driver sun6i_cs loads, it creates the device node /dev/video0 and you can check that: sudo v4l2-ctl -d /dev/video0 -D Driver Info (not using libv4l2): Driver name : sun6i-video Card type : sun6i-csi Bus info : platform:camera Driver version: 4.17.2 Capabilities : 0x84200001 Video Capture Streaming Extended Pix Format Device Capabilities Device Caps : 0x04200001 Video Capture Streaming Extended Pix Format You should see the modules loaded like this: lsmod Module Size Used by sun6i_csi 24576 0 videobuf2_dma_contig 20480 1 sun6i_csi videobuf2_memops 16384 1 videobuf2_dma_contig ov5640 36864 1 videobuf2_v4l2 24576 1 sun6i_csi videobuf2_common 40960 2 videobuf2_v4l2,sun6i_csi v4l2_fwnode 20480 2 ov5640,sun6i_csi v4l2_common 16384 1 ov5640 videodev 196608 6 v4l2_fwnode,v4l2_common,ov5640,videobuf2_v4l2,sun6i_csi,videobuf2_common sunxi_cir 16384 0 media 36864 3 videodev,ov5640,sun6i_csi rc_core 40960 2 sunxi_cir sch_fq_codel 20480 6 8189es 1118208 0 So time to revisit the camera drivers on mainline. Here are some images (remember, low light condition!): *update: All possible window sizes are working for streaming! Edited June 18, 2018 by @lex Image resolutions 3 Link to comment Share on other sites More sharing options...
@lex Posted June 19, 2018 Author Share Posted June 19, 2018 If anyone is wondering how is the performance of the driver, just take a look: ---- cap parameters ----- width: 1920 height: 1080 v4l2 buffers: 4 exposure: -999 hflip: -1 vflip: -1 Mode: V4L2_MODE_VIDEO Driver: "sun6i-video" Card: "sun6i-csi" Bus: "platform:camera" Version: 1.0 Capabilities: 84200001 Input: 0 V4L2 pixel formats: 0: [0x59565955] 'UYVY' (UYVY 4:2:2) 1: [0x32314D48] 'HM12' (YUV 4:2:0 (16x16 Macroblocks)) 2: [0x3231564E] 'NV12' (Y/CbCr 4:2:0) 3: [0x3132564E] 'NV21' (Y/CrCb 4:2:0) 4: [0x32315559] 'YU12' (Planar YUV 4:2:0) 5: [0x32315659] 'YV12' (Planar YVU 4:2:0) 6: [0x3631564E] 'NV16' (Y/CbCr 4:2:2) 7: [0x3136564E] 'NV61' (Y/CrCb 4:2:2) 8: [0x50323234] '422P' (Planar YUV 4:2:2) 9: [0x56595559] 'YUYV' (YUYV 4:2:2) 10: [0x32314D48] 'HM12' (YUV 4:2:0 (16x16 Macroblocks)) 11: [0x3231564E] 'NV12' (Y/CbCr 4:2:0) 12: [0x3132564E] 'NV21' (Y/CrCb 4:2:0) 13: [0x32315559] 'YU12' (Planar YUV 4:2:0) 14: [0x32315659] 'YV12' (Planar YVU 4:2:0) 15: [0x3631564E] 'NV16' (Y/CbCr 4:2:2) 16: [0x3136564E] 'NV61' (Y/CrCb 4:2:2) 17: [0x50323234] '422P' (Planar YUV 4:2:2) V4L2 pixel sizes: Sensor size: 1920x1080 pixels Pixel Format: V4L2_PIX_FMT_YUV420 [0x32315559] Frame #10 will be saved! Length: 3110400 Bytesused: 3110400 Address: 0x55b01b9670 FPS[0]: 25.77 Length: 3110400 Bytesused: 3110400 Address: 0x55b01b9680 FPS[1]: 30.06 Length: 3110400 Bytesused: 3110400 Address: 0x55b01b9690 FPS[2]: 30.01 Length: 3110400 Bytesused: 3110400 Address: 0x55b01b96a0 FPS[3]: 29.79 Length: 3110400 Bytesused: 3110400 Address: 0x55b01b9670 FPS[4]: 30.32 Length: 3110400 Bytesused: 3110400 Address: 0x55b01b9680 FPS[5]: 30.04 Length: 3110400 Bytesused: 3110400 Address: 0x55b01b9690 FPS[6]: 29.95 Length: 3110400 Bytesused: 3110400 Address: 0x55b01b96a0 FPS[7]: 30.14 Length: 3110400 Bytesused: 3110400 Address: 0x55b01b9670 FPS[8]: 29.81 Length: 3110400 Bytesused: 3110400 Address: 0x55b01b9680 FPS[9]: 0.72 ------- Avg FPS: 30.02 -------- Link to comment Share on other sites More sharing options...
Moklev Posted June 20, 2018 Share Posted June 20, 2018 On 6/17/2018 at 11:45 PM, @lex said: Today I had a chance to test OV5640 on mainline kernel 4.17.2 and see the status of OV5640 and CSI drivers, thanks to FE work and the author of the driver (help name here...). I tested on NanoPi K1 Plus (H5) to verify the images in very low light conditions, so don't expect good quality. [...] This sounds very interesting! But ... I can not find the interface driver (sun6i_csi). This is the Maxime Ripard's patch to mailine kernel or another one? For the testing: I've a Orange Pi PC2 H5 and a OV5647 NoIR CSI. Link to comment Share on other sites More sharing options...
@lex Posted June 20, 2018 Author Share Posted June 20, 2018 Here is a diff patch for mainline kernel. Apply from the kernel root tree. Enter menuconfig to Enable VIDEO / CSI , don't know about your camera. or how you wire it. patch -p0 -i sun6i_csi.dif.patch sun6i_csi.dif.patch.tar.gz Link to comment Share on other sites More sharing options...
Moklev Posted June 20, 2018 Share Posted June 20, 2018 It looks like Yong Deng's patch for V3s CSI. +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2011-2018 Magewell Electronics Co., Ltd. (Nanjing) + * All rights reserved. + * Author: Yong Deng <yong.deng@magewell.com> + */ Here: https://www.spinics.net/lists/linux-media/msg130006.html http://linux-sunxi.org/Linux_mainlining_effort Link to comment Share on other sites More sharing options...
Igor Posted June 22, 2018 Share Posted June 22, 2018 On 6/20/2018 at 4:12 PM, Moklev said: It looks like Yong Deng's patch for V3s CSI. https://github.com/armbian/build/commit/10e206519089b8ff81b0dd6a6f3caa6c1adba04d Added to DEV kernel, enabled on Air but haven't got time to test. Link to comment Share on other sites More sharing options...
xeniter Posted September 11, 2018 Share Posted September 11, 2018 where did you get the ov5640 driver? trying now to get ov5640 on a allwinner A33 running. my status till now: flashed new armbian stretch build on sdcard ( 4.14.69-sunxi) found out that sun6i_csi works only with v4l2 interface with kernel 4.15+ upgraded to 4.18.5 (linux-dtb-dev-sunxi_5.59.180904_armhf.deb, linux-headers-dev-sunxi_5.59.180904_armhf.deb, linux-image-dev-sunxi_5.59.180904_armhf.deb) from https://mirror.applebred.net/armbian-beta/pool/main/l/linux-4.18.5-sunxi/ was able to build sun6i_csi, however it looks like its already buildin, now stuck with loading / compiling the ov5640 driver to get a /dev/video device Anyone an idea where to get this driver? yours, Manuel Link to comment Share on other sites More sharing options...
petit_miner Posted November 11, 2018 Share Posted November 11, 2018 Hi, I'm struggling to get the driver working on my V3s. Could you please show me your devicetree files and which command you used to capture the images? I tried fswebcam, but I only get a greenish image however I can see the shapes of things. thanks Link to comment Share on other sites More sharing options...
@lex Posted November 11, 2018 Author Share Posted November 11, 2018 The device tree: https://github.com/armbian/build/commit/10e206519089b8ff81b0dd6a6f3caa6c1adba04d#diff-5ec21c7daf434027694931230901ca60R96 If I recall correctly the driver (specific to FE boards) delivers YUV so you need to instruct fswebcam and cap-v4l2 to receive V4L2_PIX_FMT_YUYV. You can try mjpg-streamer that does that by default. Try 640x480 window size first and then move to 720p or higher. I have noticed there is (or there was) a slightly new/modified driver on mainline kernel 4.19.0 but did not have time to check the changes. That mainline driver has been originally written to v3s, you may check linux-sunxi. I don't know v3s so can't help much. Link to comment Share on other sites More sharing options...
yogggoy Posted March 4, 2019 Share Posted March 4, 2019 @@lex, can you show the result (dt_full.dts) of the command: dtc -I fs -O dts -o dt_full.dts /sys/firmware/devicetree/base/ , please? I think this patch work only for nano_pi, and on my orangepi i have other DT description. (i am a newbie) Link to comment Share on other sites More sharing options...
petit_miner Posted March 5, 2019 Share Posted March 5, 2019 The patch only adds the c source code to the linux kernel. As I posted on your thread you need to rebuild the kernel and change the devicetree source files to support the CSI /DVP and the ADV7611. Link to comment Share on other sites More sharing options...
Andrey93 Posted April 12, 2019 Share Posted April 12, 2019 Hello. Can you give an common advise. In order to use ov5640 you add the sun6i_csi and ov5640 drivers and adjust DT to have the endpoint. Did you take the ov5640 driver from mainline kernel. Right? So, main task is to use ov2710. The sun6i_csi driver I can load with modprobe (the mainline kernel has it). But where can i find the ov2710 driver. I found 2 drivers for ov2710. The first is from linux-3.4-sunxi and it has vfe functions. It turns out, that I have to rewrite that driver (remove vfe) in order to compile it. Do I get it right? The second driver is from tegra. That ov2710 driver does not contain vfe. But I don't know if that driver suit for me. What do you think about it? Thanks. Link to comment Share on other sites More sharing options...
xenpac Posted August 21, 2019 Share Posted August 21, 2019 so the csi camera is now working in mainline kernel? woow The device tree stuff is implemented,csi, i2c and clock are supported? as to this vfe_v4l2 driver, this confuses me too, i think it originates from qualcomm. (video front end), rather complicated. mainline uses the videobuf2 interface, so drivers need to be modified, i guess. Link to comment Share on other sites More sharing options...
@lex Posted August 21, 2019 Author Share Posted August 21, 2019 i have had success with OV5640 on FE HW (H3,H5,A64, possibly H2+) You should check camera schematic of your board if it matches the same way FE handle the camera. I think I2C must be tied to CSI or you cannot communicate with the sensor. vfe_v4l2 driver seems to be from Android and has additional Image Processing in it. (ISP) (Kernel 3.x and 4.4.y, perhaps 4.9.y). I think there is still no support for OPIs, BPIs and some others for the mainline OV5640 / OV5647 and you have to use the Android kernel way or until someone writes the code. Link to comment Share on other sites More sharing options...
darkstealthx Posted September 15, 2019 Share Posted September 15, 2019 Hai @lex In my orange pi pc2, i'm load sun6i_csi and ov5640 module on boot. Now to connect ov5640, need adjust DT Script. Can i see DT Script for ov5640 ? I already tried to adjust DT but on dmesg, i see error : ov5640_read_reg: error: reg=300a. how to fix this ? Link to comment Share on other sites More sharing options...
@lex Posted September 15, 2019 Author Share Posted September 15, 2019 You can refer to this patch: https://lkml.org/lkml/2018/11/27/1041 https://patchwork.kernel.org/patch/10783429/ If this works for banana pi it will work for orange pi. DO NOT MERGE is there for a reason. ov5640_read_reg: error: reg=300a. It usually means it cannot communicate with the sensor. Use this: PE12/CSI_SCK/TWI2_SCK ==> CSI-SCK PE13/CSI_SDA/TWI2_SDA ==> CSI-SDA PE14 ==> CSI-RESET# PE15 ==> CSI-STBY-EN Link to comment Share on other sites More sharing options...
thanh_tan Posted February 19, 2020 Share Posted February 19, 2020 On 6/18/2018 at 4:45 AM, @lex said: Today I had a chance to test OV5640 on mainline kernel 4.17.2 and see the status of OV5640 and CSI drivers, thanks to FE work and the author of the driver (help name here...). I tested on NanoPi K1 Plus (H5) to verify the images in very low light conditions, so don't expect good quality. I could take some images using fswebcam and you should expect basic v4l2 functionality already works if not all. I think motion (did not test / had time to test it) can work with current OV5640 on mainline kernel. Grabbing Image is very fast, currently, Image size I can get are 320x240 and 640x480 pixels, above this i get a dark image. I have not looked at the driver source code to see if it is implemented or not. Basically, you need to add the sun6i_csi and ov5640 drivers to the kernel and adjust DT to have the endpoint. FE has already done it and left H5 for homework, but is the same as H3. To check the functionality, install v4l2-utils and when the driver sun6i_cs loads, it creates the device node /dev/video0 and you can check that: Hi, How to find the Armbian version with mainline kernel 4.17.2? Now the kernel goes to high, but cannot find any kernel have OV5640 driver Link to comment Share on other sites More sharing options...
