Google has found the following:
https://www.garron.me/en/linux/turn-off-stop-ubuntu-automatic-update.html
Using your favorite editor open the file /etc/apt/apt.conf.d/10periodic and change:
APT::Periodic::Update-Package-Lists "1";
To:
APT::Periodic::Update-Package-Lists "0";
That's it. Automatic update is now off.
or
https://askubuntu.com/questions/235278/how-can-i-stop-unattended-upgrades-from-rebooting-the-machine
sudo apt-get remove unattended-upgrades
Info:
https://wiki.debian.org/UnattendedUpgrades
https://linoxide.com/ubuntu-how-to/enable-disable-unattended-upgrades-ubuntu-16-04/
https://unix.stackexchange.com/questions/71746/can-i-disable-unattended-debian-package-updates
@guidol
Thanks for the links, already did that though and seen that there is a bit of difference in armbian, there are two files in armbian for periodic config (02periodic and 02-periodic)
and since I know that some services might need to always be present (for any reason) in armbian, so I asked the question.
The question is actually, can I totally remove the unnatended upgrades package in armbian? or what is the best method in armbian for unattended upgrades Not to run?
PS.
Using Xenial, legacy
@Igor
 @guidol
Ooops, in the latest 5.51 it looks we cannot remove only unattended-upgrades, if doing so we also lose the most useful armbian-config amongst others (armbian-config python3-software-properties software-properties-common)
So, we cannot remove only unattended-upgrades?
If so, if we set to "0" all options in 02-armbian-periodic, is it the same and no unattended upgrade will ever happen?
  ___                               ____  _   ____   ____
 / _ \ _ __ __ _ _ __   __ _  ___  |  _ \(_) |  _ \ / ___|
| | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | | |_) | |
| |_| | | | (_| | | | | (_| |  __/ |  __/| | |  __/| |___
 \___/|_|  \__,_|_| |_|\__, |\___| |_|   |_| |_|    \____|
                       |___/
Welcome to ARMBIAN 5.51 user-built Debian GNU/Linux 8 (jessie) 3.4.113-rt143-sun8i
System load:   0.67 0.18 0.06   Up time:       0 min
Memory usage:  6 % of 997MB     IP:            192.168.1.42
CPU temp:      52°C
Usage of /:    24% of 3.6G
Last login: Tue Jul  3 13:48:59 2018
root@pisdr:~# apt-get remove unattended-upgrades
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
  armbian-config python3-software-properties software-properties-common unattended-upgrades
0 upgraded, 0 newly installed, 4 to remove and 0 not upgraded.
After this operation, 721 kB disk space will be freed.
Do you want to continue? [Y/n]
Yes. I'll fix dependencies later on.
